楼主: 乖乖妮
9月8日下午14:30-16:00线上技术支持讨论专用贴(直接回复)
发表于 2016-9-8 15:46:04 | 显示全部楼层
那些埋头写程序的岁月 发表于 2016-9-8 14:38
程序里只需要加陀螺仪和加速计水平校准和调PID就能正常飞行?
yes, the programm needs the gyroscope and accelerometer for the filter algorithm to work properly
发表于 2016-9-8 15:47:04 | 显示全部楼层
金宝宝 发表于 2016-9-8 14:58
对于一些人来说,比如我,RN42的蓝牙默认名称为RN42,并不是XMC-Bluetooth,所以,APP无法直接连接。 ...
Please take a look at Answer to Question #20
发表于 2016-9-8 15:47:39 | 显示全部楼层
FantasyJXF 发表于 2016-9-8 15:02
请问使用商品电调需要进行哪些设置
I'm not sure what you mean, please try to describe the problem further and more detailed.
发表于 2016-9-8 15:48:10 | 显示全部楼层
about the blue-tooth .we had add two resistor to the right place according to the forum answer.
发表于 2016-9-8 15:51:09 | 显示全部楼层
不用XMC_FLASH,用编译环境烧程序会有这个问题
发表于 2016-9-8 15:51:24 | 显示全部楼层
他的意思是,假如我们使用已经完善的,在市面上销售的电调去替换,该如何与主控板连接与适配。
发表于 2016-9-8 15:51:53 | 显示全部楼层
魏某某 发表于 2016-9-8 15:03
Sometimes,My drone's motor was stucked on the start stage,which results motor to be so hot.
Is there ...
Always try to gently apply throttle until the Motors spin in the correct direction, then apply more throttle. If any Motor spins in the wrong direction at startup, immediately cut throttle and try again. sometimes the Motors can get hot when trying the startup too often, if so - let them cool down and try again.
with the newest ESC Motorcontroller Firmware the problem is better. the motors do not get that hot anymore.
  • 签到天数: 2 天
    发表于 2016-9-8 15:52:51 | 显示全部楼层
    Oh,one more .
    About the USB VCOM Drivers.
    with DAVE3 on WIN10,It will be installed automatically
    However,some friends who use WIN7,can not fine the driver,files or installing pack,after google.
    So, is there any drivers from Infineon ?
  • 签到天数: 6 天
    发表于 2016-9-8 15:54:10 | 显示全部楼层
    Can you give me a group of right PID parameter?
    发表于 2016-9-8 15:54:43 | 显示全部楼层
    junjimya 发表于 2016-9-8 15:03
    最近看到大家说可以换商业电调,目前我们组的飞行没问题,正在增加功能,不知道能支持挂过重的东西。我们目 ...
    The LARIX Drone is not meant to carry a heavy load. For demonstration purposes you can carry like styrofoam or something lightweight with this drone and it's current setup. For heavier loads you need to use commercial ESCs and bigger Motors. What also will require a new flightframe and modifications on the PCB for PWM output. If you want to do so, let me know and i will guide you on how to do this
    GMT+8, 2024-12-24 21:22 , Processed in 0.213656 second(s), 34 queries , MemCache On.
