查看: 782|回复: 0
[BCM943364WCD1]试玩TCP Server
  • 签到天数: 2 天
    发表于 2016-12-14 13:11:27 | 显示全部楼层 |阅读模式
    一、目标
          TCP Server程序跑通,监听端口8888
           收到客户端的信息,再原文转发给客户端。
    二、 大概流程
          上一篇经验已经完成了获取IP的功能。接下来的流程:
           1、创建TCP SOCKET
           2、注册回掉函数:连接、收到数据、断开三个事件的回掉
           3、监听端口8888
           4、连接的回掉函数打印出客户端的IP
           5、收到数据后转发给客户端
           6、断开后重新监听8888
    三、 堆代码
        1-》3步代码:
      /* Create a TCP server socket */                                            if ( wiced_tcp_create_socket( &tcp_server_socket, WICED_STA_INTERFACE ) != WICED_SUCCESS )                                            {                                                WPRINT_APP_INFO( ("TCP socket creation failed\r\n") );                                            }                                            /* Register callbacks to handle various TCP events */                                            ret = wiced_tcp_register_callbacks( &tcp_server_socket, client_connected_callback, received_data_callback, client_disconnected_callback, NULL );                                            if ( ret != WICED_SUCCESS )                                            {                                                WPRINT_APP_INFO( ("TCP server socket initialization failed\r\n") );                                            }                                            /* Start TCP server to listen for connections */                                            if ( wiced_tcp_listen( &tcp_server_socket, TCP_SERVER_LISTEN_PORT ) != WICED_SUCCESS )                                            {                                                WPRINT_APP_INFO( ("TCP server socket initialization failed\r\n") );                                                wiced_tcp_delete_socket( &tcp_server_socket );                                                continue;                                            }                                                WPRINT_APP_INFO( ("TCP server socket initialization success\r\n") );    4-》6步代码:
    static wiced_result_t client_connected_callback( wiced_tcp_socket_t* socket, void* arg ){    wiced_result_t      result;    wiced_ip_address_t  ipaddr;    uint16_t            port;    UNUSED_PARAMETER( arg );    /* Accept connection request */    result = wiced_tcp_accept( &tcp_server_socket );    if( result == WICED_SUCCESS )    {        /* Extract IP address and the Port of the connected client */        wiced_tcp_server_peer( socket, &ipaddr, &port );        WPRINT_APP_INFO(("Accepted connection from :: "));        WPRINT_APP_INFO ( ("IP %u.%u.%u.%u : %d\r\n", (unsigned char) ( ( GET_IPV4_ADDRESS(ipaddr) >> 24 ) & 0xff ),                                                      (unsigned char) ( ( GET_IPV4_ADDRESS(ipaddr) >> 16 ) & 0xff ),                                                      (unsigned char) ( ( GET_IPV4_ADDRESS(ipaddr) >>  8 ) & 0xff ),                                                      (unsigned char) ( ( GET_IPV4_ADDRESS(ipaddr) >>  0 ) & 0xff ),                                                      port ) );        return WICED_SUCCESS;    }    return WICED_ERROR;}static wiced_result_t client_disconnected_callback( wiced_tcp_socket_t* socket, void* arg ){    UNUSED_PARAMETER( arg );    WPRINT_APP_INFO(("Client disconnected\r\n\r\n"));    /* Start listening on the socket again */    if ( wiced_tcp_listen( socket, TCP_SERVER_LISTEN_PORT ) != WICED_SUCCESS )    {        WPRINT_APP_INFO( ("TCP server socket re-initialization failed\r\n") );        wiced_tcp_delete_socket( socket );        return WICED_ERROR;    }    return WICED_SUCCESS;}static wiced_result_t received_data_callback( wiced_tcp_socket_t* socket, void* arg ){    wiced_result_t      result;    wiced_packet_t*     tx_packet;    char*               tx_data;    wiced_packet_t*     rx_packet = NULL;    char*               request;    uint16_t            request_length;    uint16_t            available_data_length;    result = wiced_tcp_receive( socket, &rx_packet, WICED_WAIT_FOREVER );    if ( result != WICED_SUCCESS )    {        return result;    }    wiced_packet_get_data( rx_packet, 0, (uint8_t**) &request, &request_length, &available_data_length );    /* Null terminate the received string */    request[request_length] = '\x0';    WPRINT_APP_INFO(("Received data: %s \r\n", request));    /* Send echo back */    if ( wiced_packet_create_tcp( socket, TCP_PACKET_MAX_DATA_LENGTH, &tx_packet, (uint8_t**)&tx_data, &available_data_length ) != WICED_SUCCESS )    {        WPRINT_APP_INFO(("TCP packet creation failed\r\n"));        return WICED_ERROR;    }    /* Write the message into tx_data"  */    tx_data[request_length] = '\x0';    memcpy( tx_data, request, request_length );    /* Set the end of the data portion */    wiced_packet_set_data_end( tx_packet, (uint8_t*)tx_data + request_length );    /* Send the TCP packet */    if ( wiced_tcp_send_packet( socket, tx_packet ) != WICED_SUCCESS )    {        WPRINT_APP_INFO( ("TCP packet send failed\r\n") );        /* Delete packet, since the send failed */        wiced_packet_delete( tx_packet );    }    WPRINT_APP_INFO(("Echo data: %s\r\n", tx_data));    /* Release a packet */    wiced_packet_delete( rx_packet );    return WICED_SUCCESS;}四、 测试结果
          本机IP:
    测试结果:
    GMT+8, 2024-11-19 14:52 , Processed in 0.131234 second(s), 21 queries , MemCache On.
