查看: 864|回复: 0
[BCM943364WCD1]开启UDP发送与接收
  • 签到天数: 2 天
    发表于 2016-12-21 13:13:28 | 显示全部楼层 |阅读模式
    一、目标
    在之前两篇经验中完成了TCP的客户端和服务端测试。有了TCP自然来玩玩UDP咯
    接下来完成UDP的发送以及接受。
    二、 流程
    UDP的整个流程相对于TCP要简单的多,流程这里也少了好几步:
    1、创建UDP SOCKET
    2、等待接收UDP
    3、建立PACKET
    4、发送PACKET
    三、 具体代码
    获取IP啥的就先不贴了,要看的可以看之前的几篇经验。
    #ifdef _UDP_TEST                                                ret = wiced_udp_create_socket(&udp_socket, UDP_PORT, WICED_STA_INTERFACE);                                                if(WICED_SUCCESS == ret)                                                {                                                        WPRINT_APP_INFO(("create udp socket success!\n"));                                                        stNetworkInfo.stTcpStatus = 2;                                                }#endif#ifdef _UDP_TEST                                                ret = wiced_udp_receive(&udp_socket, &rec_pack, 5000);                        if(ret == WICED_ERROR || ret == WICED_TIMEOUT)                        {                                ;                        }                        else                        {                                wiced_udp_packet_get_info(rec_pack, &rec_ip, &rec_port);                                WPRINT_APP_INFO(("REC->%d.%d.%d.%d:%d\n",        (rec_ip.ip.v4 & 0xff000000) >> 24,        (rec_ip.ip.v4 & 0x00ff0000) >> 16,        (rec_ip.ip.v4 & 0x0000ff00) >> 8,        (rec_ip.ip.v4 & 0x000000ff),        rec_port));                        }                        WPRINT_APP_INFO(("UDP->EEBOARD.ICYLINKER\n"));                        wiced_packet_create_udp(&udp_socket, UDP_MAX_LEN, &udp_packet, &udp_data, &udp_available_space);                        wiced_packet_set_data_end(udp_packet, (uint8_t *)udp_data + strlen(UDP_STRING));                        sprintf(udp_data, "%s", UDP_STRING);                        if(wiced_udp_send(&udp_socket, &udp_ip, UDP_PORT, udp_packet) != WICED_SUCCESS)                        {                                WPRINT_APP_INFO(("udp packet send failed\n"));                        /* Delete packet, since the send failed */                        stNetworkInfo.stTcpStatus = 3;                        }                        wiced_packet_delete(udp_packet);#endif四、测试结果
    GMT+8, 2024-11-19 14:37 , Processed in 0.111836 second(s), 17 queries , MemCache On.
