查看: 2185|回复: 0
香蕉派BPI-M1+ Lubuntu系统安装,启动成功
  • 签到天数: 981 天
    发表于 2015-7-23 13:07:26 | 显示全部楼层 |阅读模式
    官网下载镜像
    https://www.bananapi.com/index.php/download?layout=edit&id=29
    百度云:https://pan.baidu.com/s/1qW9ESFy
    压缩包解压后得到镜像:Lubuntu_For_BPI_V3.1.img
    安装SD卡格式化工具SDFormatterv4,打开SDFormatterv4
    最后点击格式化,等待完成。
    用Win32 Diskimager 制作启动卡,打开 Win32 Diskimager ,在Image file中打开镜像,在device选中SD卡,最后点击write
    将制作好的SD卡插入BPI-M1+卡槽,准备上电启动。
    通过banana pi的UART口来查看启动信息。
    U-Boot SPL 2014.04-10691-g493a12c (Jul 02 2014 - 15:02:40)
    Board: Bananapi
    DRAM: 1024 MiB
    CPU: 960000000Hz, AXI/AHB/APB: 3/2/2
    spl: not an uImage at 1600
    U-Boot 2014.04-10691-g493a12c (Jul 02 2014 - 15:02:40) Allwinner Technology
    CPU:   Allwinner A20 (SUN7I)
    Board: Bananapi
    I2C:   ready
    DRAM:  1 GiB
    MMC:   SUNXI SD/MMC: 0
    *** Warning - bad CRC, using default environment
    In:    serial
    Out:   serial
    Err:   serial
    Net:
    dwmac.1c50000
    Hit any key to stop autoboot:  2
    1
    reading uEnv.txt
    332 bytes read in 16 ms (19.5 KiB/s)
    Loaded environment from uEnv.txt
    Running uenvcmd ...
    reading script.bin
    50980 bytes read in 29 ms (1.7 MiB/s)
    reading uImage
    4801640 bytes read in 244 ms (18.8 MiB/s)
    ## Booting kernel from Legacy Image at 48000000 ...
       Image Name:   Linux-3.4.90
       Image Type:   ARM Linux Kernel Image (uncompressed)
       Data Size:    4801576 Bytes = 4.6 MiB
       Load Address: 40008000
       Entry Point:  40008000
       Verifying Checksum ... OK
       Loading Kernel Image ... OK
    Starting kernel ...
    <6>Booting Linux on physical CPU 0
    <6>Initializing cgroup subsys cpuset
    <5>Linux version 3.4.90 (bananapi@lemaker) (gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) ) #3 SMP PREEMPT Tue Jul 29 16:16:05 CST 2014
    CPU: ARMv7 Processor [410fc074] revision 4 (ARMv7), cr=10c5387d
    CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
    Machine: sun7i
    <6>Memory Reserved:
    <6>        SYS  : 0x43000000 - 0x4300ffff  (  64 kB)
    <6>        VE   : 0x44000000 - 0x48ffffff  (  80 MB)
    <6>        G2D  : 0x49000000 - 0x49ffffff  (  16 MB)
    <6>        LCD  : 0x4a000000 - 0x4bffffff  (  32 MB)
    Memory policy: ECC disabled, Data cache writealloc
    <6>sunxi: Allwinner A20 (AW1651/sun7i) detected.
    <7>On node 0 totalpages: 262144
    <7>free_area_init_node: node 0, pgdat c08ff780, node_mem_map d0000000
    <7>  DMA zone: 512 pages used for memmap
    <7>  DMA zone: 0 pages reserved
    <7>  DMA zone: 65024 pages, LIFO batch:15
    <7>  Normal zone: 1008 pages used for memmap
    <7>  Normal zone: 128016 pages, LIFO batch:31
    <7>  HighMem zone: 528 pages used for memmap
    <7>  HighMem zone: 67056 pages, LIFO batch:15
    <6&gtERCPU: Embedded 7 pages/cpu @d0808000 s7616 r8192 d12864 u32768
    <7>pcpu-alloc: s7616 r8192 d12864 u32768 alloc=8*4096<c>
    <7>pcpu-alloc: <c>[0] <c>0 <c>[0] <c>1 <c>
    Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 260096
    <5>Kernel command line: console=ttyS0,115200 console=tty0 disp.screen0_output_mode=EDID:1280x720p50 hdmi.audio=EDID:0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait
    <6&gtID hash table entries: 4096 (order: 2, 16384 bytes)
    <6>Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
    <6>Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
    <6>allocated 2097152 bytes of page_cgroup
    <6>please try 'cgroup_disable=memory' option if you don't want memory cgroups
    <6>Memory: 1024MB = 1024MB total
    <5>Memory: 895208k/895208k available, 153368k reserved, 270336K highmem
    <5>Virtual kernel memory layout:
        vector  : 0xffff0000 - 0xffff1000   (   4 kB)
        fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
        vmalloc : 0xf0000000 - 0xff000000   ( 240 MB)
        lowmem  : 0xc0000000 - 0xef800000   ( 760 MB)
        pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
        modules : 0xbf000000 - 0xbfe00000   (  14 MB)
          .text : 0xc0008000 - 0xc085c2c0   (8529 kB)
          .init : 0xc085d000 - 0xc0895dc0   ( 228 kB)
          .data : 0xc0896000 - 0xc0906de8   ( 452 kB)
           .bss : 0xc0906e0c - 0xc0ad6718   (1855 kB)
    <6>SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
    <6&gtreemptible hierarchical RCU implementation.
    <6>        RCU dyntick-idle grace-period acceleration is enabled.
    <6>        Additional per-CPU info printed with stalls.
    <6>NR_IRQS:192
    <6>Architected local timer running at 24.00MHz.
    <6>sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
    <2>start_kernel(): bug: interrupts were enabled early
    <6>Console: colour dummy device 80x30
    <6>console [tty0] enabled
    <6>Calibrating delay loop... <c>1915.28 BogoMIPS (lpj=9576448)
    <6>pid_max: default: 32768 minimum: 301
    <6>Mount-cache hash table entries: 512
    <6>Initializing cgroup subsys cpuacct
    <6>Initializing cgroup subsys memory
    <6>Initializing cgroup subsys devices
    <6>Initializing cgroup subsys freezer
    <6>Initializing cgroup subsys blkio
    <6>Initializing cgroup subsys perf_event
    <6>CPU: Testing write buffer coherency: ok
    <6>CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    <6>hw perfevents: enabled with ARMv7 Cortex-A7 PMU driver, 5 counters available
    <6>Setting up static identity map for 0x405c3458 - 0x405c34b0
    CPU1: Booted secondary processor
    <6>CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
    <6>Brought up 2 CPUs
    <6>SMP: Total of 2 processors activated (3830.57 BogoMIPS).
    <6>devtmpfs: initialized
    <6>dummy:
    <6>NET: Registered protocol family 16
    <6>DMA: preallocated 256 KiB pool for atomic coherent allocations
    <6>hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
    <6>hw-breakpoint: maximum watchpoint size is 8 bytes.
    <6>[ccu-inf] aw clock manager init
    <6>[ccu-inf] aw_ccu_init
    <6>[ccu-inf] script config pll3 to 297MHz
    <6>[ccu-inf] script config pll4 to 300MHz
    <6>[ccu-inf] script config pll6 to 600MHz
    <6>[ccu-inf] script config pll7 to 297MHz
    <6>[ccu-inf] script config pll8 to 336MHz
    <6>Init eGon pin module V2.0
    <6>bio: create slab <bio-0> at 0
    <6>sunxi_gpio driver init ver 1.3
    <6>gpiochip_add: registered GPIOs 1 to 88 on device: A1X_GPIO
    <5>SCSI subsystem initialized
    <7>libata version 3.00 loaded.
    <6>usbcore: registered new interface driver usbfs
    <6>usbcore: registered new interface driver hub
    <6>usbcore: registered new device driver usb
    <6>Linux media interface: v0.10
    <6>Linux video capture interface: v2.00
    <6>Advanced Linux Sound Architecture Driver Version 1.0.25.
    <6>Switching to clocksource arch_sys_counter
    <5>FS-Cache: Loaded
    <6>CacheFiles: Loaded
    <6>cfg80211: Calling CRDA to update world regulatory domain
    WRN287(/home/bananapi/bananapi/bananapi-bsp/linux-bananapi/drivers/usb/sunxi_usb/manager/usb_manager.c):ERR: det_vbus pin is invaild
    WRN426(/home/bananapi/bananapi/bananapi-bsp/linux-bananapi/drivers/usb/sunxi_usb/manager/usb_manager.c):ERR: check_usb_board_info failed
    WRN480(/home/bananapi/bananapi/bananapi-bsp/linux-bananapi/drivers/usb/sunxi_usb/manager/usb_manager.c):ERR: get_usb_cfg failed
    <6>NET: Registered protocol family 2
    <6>IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
    <6>TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
    <6>TCP bind hash table entries: 65536 (order: 7, 786432 bytes)
    <6>TCP: Hash tables configured (established 131072 bind 65536)
    <6>TCP: reno registered
    <6>UDP hash table entries: 512 (order: 2, 16384 bytes)
    <6>UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
    <6>RPC: Registered named UNIX socket transport module.
    <6>RPC: Registered udp transport module.
    <6>RPC: Registered tcp transport module.
    <6>RPC: Registered tcp NFSv4.1 backchannel transport module.
    <6>audit: initializing netlink socket (disabled)
    <5>type=2000 audit(0.530:1): initialized
    highmem bounce pool size: 64 pages
    <5>VFS: Disk quotas dquot_6.5.2
    Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
    <6>squashfs: version 4.0 (2009/01/31) Phillip Lougher
    <5>NFS: Registering the id_resolver key type
    <6>NTFS driver 2.1.30 [Flags: R/W].
    <6>fuse init (API version 7.18)
    <6>msgmni has been set to 1220
    <3>alg: comp: Compression test 1 failed for lzo-generic: output len = 57
    <6>alg: No test for stdrng (krng)
    <6>Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
    <6>io scheduler noop registered
    <6>io scheduler deadline registered (default)
    <6>io scheduler cfq registered
    <6>sunxi disp driver loaded (/dev/disp api 1.0)
    <6>Serial: 8250/16550 driver, 32 ports, IRQ sharing disabled
    <6>[uart]: used uart info.: 0x8d
    <6>[uart]: serial probe 0 irq 33 mapbase 0x01c28000
    <6>sunxi-uart.0: ttyS0 at MMIO 0x1c28000 (irq = 33) is a U6_16550A
    [    0.000000] Booting Linux on physical CPU 0
    [    0.000000] Initializing cgroup subsys cpuset
    [    0.000000] Linux version 3.4.90 (bananapi@lemaker) (gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) ) #3 SMP PREEMPT Tue Jul 29 16:16:05 CST 2014
    [    0.000000] Memory Reserved:
    [    0.000000]         SYS  : 0x43000000 - 0x4300ffff  (  64 kB)
    [    0.000000]         VE   : 0x44000000 - 0x48ffffff  (  80 MB)
    [    0.000000]         G2D  : 0x49000000 - 0x49ffffff  (  16 MB)
    [    0.000000]         LCD  : 0x4a000000 - 0x4bffffff  (  32 MB)
    [    0.000000] sunxi: Allwinner A20 (AW1651/sun7i) detected.
    [    0.000000] PERCPU: Embedded 7 pages/cpu @d0808000 s7616 r8192 d12864 u32768
    [    0.000000] Kernel command line: console=ttyS0,115200 console=tty0 disp.screen0_output_mode=EDID:1280x720p50 hdmi.audio=EDID:0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait
    [    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
    [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
    [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
    [    0.000000] allocated 2097152 bytes of page_cgroup
    [    0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
    [    0.000000] Memory: 1024MB = 1024MB total
    [    0.000000] Memory: 895208k/895208k available, 153368k reserved, 270336K highmem
    [    0.000000] Virtual kernel memory layout:
    [    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    [    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    [    0.000000]     vmalloc : 0xf0000000 - 0xff000000   ( 240 MB)
    [    0.000000]     lowmem  : 0xc0000000 - 0xef800000   ( 760 MB)
    [    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
    [    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
    [    0.000000]       .text : 0xc0008000 - 0xc085c2c0   (8529 kB)
    [    0.000000]       .init : 0xc085d000 - 0xc0895dc0   ( 228 kB)
    [    0.000000]       .data : 0xc0896000 - 0xc0906de8   ( 452 kB)
    [    0.000000]        .bss : 0xc0906e0c - 0xc0ad6718   (1855 kB)
    [    0.000000] SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
    [    0.000000] Preemptible hierarchical RCU implementation.
    [    0.000000]         RCU dyntick-idle grace-period acceleration is enabled.
    [    0.000000]         Additional per-CPU info printed with stalls.
    [    0.000000] NR_IRQS:192
    [    0.000000] Architected local timer running at 24.00MHz.
    [    0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
    [    0.000000] start_kernel(): bug: interrupts were enabled early
    [    0.000000] Console: colour dummy device 80x30
    [    0.000000] console [tty0] enabled
    [    0.013703] Calibrating delay loop... 1915.28 BogoMIPS (lpj=9576448)
    [    0.076029] pid_max: default: 32768 minimum: 301
    [    0.079699] Mount-cache hash table entries: 512
    [    0.083907] Initializing cgroup subsys cpuacct
    [    0.087241] Initializing cgrou
    p subsys memory
    [    0.090674] Initializing cgroup subsys devices
    [    0.094118] Initializing cgroup subsys freezer
    [    0.097352] Initializing cgroup subsys blkio
    [    0.101034] Initializing cgroup subsys perf_event
    [    0.104618] CPU: Testing write buffer coherency: ok
    [    0.109796] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    [    0.116902] hw perfevents: enabled with ARMv7 Cortex-A7 PMU driver, 5 counters available
    [    0.122462] Setting up static identity map for 0x405c3458 - 0x405c34b0
    [    0.297346] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
    [    0.299340] Brought up 2 CPUs
    [    0.304679] SMP: Total of 2 processors activated (3830.57 BogoMIPS).
    [    0.307893] devtmpfs: initialized
    [    0.313210] dummy:
    [    0.316893] NET: Registered protocol family 16
    [    0.323122] DMA: preallocated 256 KiB pool for atomic coherent allocations
    [    0.330771] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
    [    0.335652] hw-breakpoint: maximum watchpoint size is 8 bytes.
    [    0.338817] [ccu-inf] aw clock manager init
    [    0.341096] [ccu-inf] aw_ccu_init
    [    0.345057] [ccu-inf] script config pll3 to 297MHz
    [    0.348820] [ccu-inf] script config pll4 to 300MHz
    [    0.352578] [ccu-inf] script config pll6 to 600MHz
    [    0.356351] [ccu-inf] script config pll7 to 297MHz
    [    0.360109] [ccu-inf] script config pll8 to 336MHz
    [    0.362869] Init eGon pin module V2.0
    [    0.371966] bio: create slab <bio-0> at 0
    [    0.375420] sunxi_gpio driver init ver 1.3
    [    0.381739] gpiochip_add: registered GPIOs 1 to 88 on device: A1X_GPIO
    [    0.384844] SCSI subsystem initialized
    [    0.392369] usbcore: registered new interface driver usbfs
    [    0.396716] usbcore: registered new interface driver hub
    [    0.400886] usbcore: registered new device driver usb
    [    0.404057] Linux media interface: v0.10
    [    0.407682] Linux video capture interface: v2.00
    [    0.413440] Advanced Linux Sound Architecture Driver Version 1.0.25.
    [    0.418692] Switching to clocksource arch_sys_counter
    [    0.420822] FS-Cache: Loaded
    [    0.422997] CacheFiles: Loaded
    [    0.432887] cfg80211: Calling CRDA to update world regulatory domain
    [    0.472368] NET: Registered protocol family 2
    [    0.478711] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
    [    0.485619] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
    [    0.493034] TCP bind hash table entries: 65536 (order: 7, 786432 bytes)
    [    0.499612] TCP: Hash tables configured (established 131072 bind 65536)
    [    0.501831] TCP: reno registered
    [    0.506716] UDP hash table entries: 512 (order: 2, 16384 bytes)
    [    0.512060] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
    [    0.515701] NET: Registered protocol family 1
    [    0.520997] RPC: Registered named UNIX socket transport module.
    [    0.524719] RPC: Registered udp transport module.
    [    0.528387] RPC: Registered tcp transport module.
    [    0.533787] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.539254] audit: initializing netlink socket (disabled)
    [    0.543018] type=2000 audit(0.530:1): initialized
    [    0.558432] VFS: Disk quotas dquot_6.5.2
    [    0.570937] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.575609] NFS: Registering the id_resolver key type
    [    0.580145] NTFS driver 2.1.30 [Flags: R/W].
    [    0.583638] fuse init (API version 7.18)
    [    0.587074] msgmni has been set to 1220
    [    0.597464] alg: comp: Compression test 1 failed for lzo-generic: output len = 57
    [    0.600666] alg: No test for stdrng (krng)
    [    0.607366] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
    [    0.610274] io scheduler noop registered
    [    0.614456] io scheduler deadline registered (default)
    [    0.617294] io scheduler cfq registered
    [    0.622049] sunxi disp driver loaded (/dev/disp api 1.0)
    [    0.627700] Serial: 8250/16550 driver, 32 ports, IRQ sharing disabled
    [    0.635694] [uart]: used uart info.: 0x8d
    [    0.640402] [uart]: serial probe 0 irq 33 mapbase 0x01c28000
    [    0.666657] sunxi-uart.0: ttyS0 at MMIO 0x1c28000 (irq = 33) is a U6_16550A
    <6>console [ttyS0] enabled
    [    1.291582] console [ttyS0] enabled
    <6>[uart]: serial probe 2 irq 35 mapbase 0x01c28800
    [    1.299958] [uart]: serial probe 2 irq 35 mapbase 0x01c28800
    <6>sunxi-uart.2: ttyS1 at MMIO 0x1c28800 (irq = 35) is a U6_16550A
    [    1.331806] sunxi-uart.2: ttyS1 at MMIO 0x1c28800 (irq = 35) is a U6_16550A
    <6>[uart]: serial probe 3 irq 36 mapbase 0x01c28c00
    [    1.343630] [uart]: serial probe 3 irq 36 mapbase 0x01c28c00
    <6>sunxi-uart.3: ttyS2 at MMIO 0x1c28c00 (irq = 36) is a U6_16550A
    [    1.375454] sunxi-uart.3: ttyS2 at MMIO 0x1c28c00 (irq = 36) is a U6_16550A
    <6>[uart]: serial probe 7 irq 52 mapbase 0x01c29c00
    [    1.387257] [uart]: serial probe 7 irq 52 mapbase 0x01c29c00
    <6>sunxi-uart.7: ttyS3 at MMIO 0x1c29c00 (irq = 52) is a U6_16550A
    [    1.419067] sunxi-uart.7: ttyS3 at MMIO 0x1c29c00 (irq = 52) is a U6_16550A
    <7>G2D: drv_g2d_init
    <6>G2D: g2dmem: g2d_start=49000000, g2d_size=1000000
    [    1.433258] G2D: g2dmem: g2d_start=49000000, g2d_size=1000000
    <6>G2D: head:c9000000,tail:ca000000
    [    1.442259] G2D: head:c9000000,tail:ca000000
    <6>G2D: Module initialized.major:250
    [    1.449866] G2D: Module initialized.major:250
    <6>brd: module loaded
    [    1.462846] brd: module loaded
    <6>loop: module loaded
    [    1.471502] loop: module loaded
    <3>gpio count < =0 ,gpio_count is: 0
    [    1.478461] gpio count < =0 ,gpio_count is: 0
    <6>sw_ahci sw_ahci.0: controller can't do PMP, turning off CAP_PMP
    [    1.488780] sw_ahci sw_ahci.0: controller can't do PMP, turning off CAP_PMP
    <4>sw_ahci sw_ahci.0: forcing PORTS_IMPL to 0x1
    [    1.500035] sw_ahci sw_ahci.0: forcing PORTS_IMPL to 0x1
    <6>sw_ahci sw_ahci.0: AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl platform mode
    [    1.512795] sw_ahci sw_ahci.0: AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl platform mode
    <6>sw_ahci sw_ahci.0: flags: ncq sntf pm led clo only pio slum part ccc
    [    1.527690] sw_ahci sw_ahci.0: flags: ncq sntf pm led clo only pio slum part ccc
    <6>scsi0 : sw_ahci_platform
    [    1.538423] scsi0 : sw_ahci_platform
    <6>ata1: SATA max UDMA/133 mmio [mem 0x01c18000-0x01c18fff] port 0x100 irq 88
    [    1.549225] ata1: SATA max UDMA/133 mmio [mem 0x01c18000-0x01c18fff] port 0x100 irq 88
    <6>Fixed MDIO Bus: probed
    [    1.561007] Fixed MDIO Bus: probed
    <4>eth%d: device MAC address 02:d8:01:c2:51:03
    [    1.569125] eth%d: device MAC address 02:d8:01:c2:51:03
    gmac_para gpio count is 18
    [gmac]: sun6i_gmac platform driver registration completed
    <6&gtPP generic driver version 2.4.2
    [    1.585843] PPP generic driver version 2.4.2
    <6&gtPP BSD Compression module registered
    [    1.594041] PPP BSD Compression module registered
    <6&gtPP Deflate Compression module registered
    [    1.602753] PPP Deflate Compression module registered
    <6>NET: Registered protocol family 24
    [    1.611229] NET: Registered protocol family 24
    <6>ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
    [    1.621442] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
    <6>ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
    [    1.633190] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
    [sw-ehci1]: open clock
    [sw-ehci1]: Set USB Power ON
    <6>sw-ehci sw-ehci.1: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
    [    1.670840] sw-ehci sw-ehci.1: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
    <6>sw-ehci sw-ehci.1: new USB bus registered, assigned bus number 1
    [    1.684579] sw-ehci sw-ehci.1: new USB bus registered, assigned bus number 1
    <6>sw-ehci sw-ehci.1: irq 71, io mem 0x01c14000
    [    1.696025] sw-ehci sw-ehci.1: irq 71, io mem 0x01c14000
    <6>sw-ehci sw-ehci.1: USB 2.0 started, EHCI 1.00
    [    1.723157] sw-ehci sw-ehci.1: USB 2.0 started, EHCI 1.00
    <6>usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
    [    1.734386] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
    <6>usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    1.747371] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    <6>usb usb1: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
    [    1.761040] usb usb1: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
    <6>usb usb1: Manufacturer: Linux 3.4.90 ehci_hcd
    [    1.772887] usb usb1: Manufacturer: Linux 3.4.90 ehci_hcd
    <6>usb usb1: SerialNumber: sw-ehci
    [    1.781434] usb usb1: SerialNumber: sw-ehci
    <6>hub 1-0:1.0: USB hub found
    [    1.788838] hub 1-0:1.0: USB hub found
    <6>hub 1-0:1.0: 1 port detected
    [    1.795522] hub 1-0:1.0: 1 port detected
    [sw-ohci1]: open clock
    <6>sw-ohci sw-ohci.1: SW USB2.0 'Open' Host Controller (OHCI) Driver
    [    1.828099] sw-ohci sw-ohci.1: SW USB2.0 'Open' Host Controller (OHCI) Driver
    <6>sw-ohci sw-ohci.1: new USB bus registered, assigned bus number 2
    [    1.841464] sw-ohci sw-ohci.1: new USB bus registered, assigned bus number 2
    <6>sw-ohci sw-ohci.1: irq 96, io mem 0x01c14400
    [    1.852827] sw-ohci sw-ohci.1: irq 96, io mem 0x01c14400
    <6>ata1: SATA link down (SStatus 0 SControl 300)
    [    1.903164] ata1: SATA link down (SStatus 0 SControl 300)
    <6>usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
    [    1.918609] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
    <6>usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    1.931598] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    <6>usb usb2: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
    [    1.944922] usb usb2: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
    <6>usb usb2: Manufacturer: Linux 3.4.90 ohci_hcd
    [    1.956420] usb usb2: Manufacturer: Linux 3.4.90 ohci_hcd
    <6>usb usb2: SerialNumber: sw-ohci
    [    1.964966] usb usb2: SerialNumber: sw-ohci
    <6>hub 2-0:1.0: USB hub found
    [    1.972357] hub 2-0:1.0: USB hub found
    <6>hub 2-0:1.0: 1 port detected
    [    1.979002] hub 2-0:1.0: 1 port detected
    [sw-ehci2]: open clock
    [sw-ehci2]: Set USB Power ON
    <6>sw-ehci sw-ehci.2: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
    [    2.014550] sw-ehci sw-ehci.2: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
    <6>sw-ehci sw-ehci.2: new USB bus registered, assigned bus number 3
    [    2.028304] sw-ehci sw-ehci.2: new USB bus registered, assigned bus number 3
    <6>sw-ehci sw-ehci.2: irq 72, io mem 0x01c1c000
    [    2.039744] sw-ehci sw-ehci.2: irq 72, io mem 0x01c1c000
    <6>sw-ehci sw-ehci.2: USB 2.0 started, EHCI 1.00
    [    2.063153] sw-ehci sw-ehci.2: USB 2.0 started, EHCI 1.00
    <6>usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
    [    2.074365] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
    <6>usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    2.087390] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    <6>usb usb3: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
    [    2.101064] usb usb3: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
    <6>usb usb3: Manufacturer: Linux 3.4.90 ehci_hcd
    [    2.112911] usb usb3: Manufacturer: Linux 3.4.90 ehci_hcd
    <6>usb usb3: SerialNumber: sw-ehci
    [    2.121463] usb usb3: SerialNumber: sw-ehci
    <6>hub 3-0:1.0: USB hub found
    [    2.128820] hub 3-0:1.0: USB hub found
    <6>hub 3-0:1.0: 1 port detected
    [    2.135492] hub 3-0:1.0: 1 port detected
    [sw-ohci2]: open clock
    <6>sw-ohci sw-ohci.2: SW USB2.0 'Open' Host Controller (OHCI) Driver
    [    2.168060] sw-ohci sw-ohci.2: SW USB2.0 'Open' Host Controller (OHCI) Driver
    <6>sw-ohci sw-ohci.2: new USB bus registered, assigned bus number 4
    [    2.181408] sw-ohci sw-ohci.2: new USB bus registered, assigned bus number 4
    <6>sw-ohci sw-ohci.2: irq 97, io mem 0x01c1c400
    [    2.192777] sw-ohci sw-ohci.2: irq 97, io mem 0x01c1c400
    <6>usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
    [    2.258602] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
    <6>usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    2.271588] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    <6>usb usb4: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
    [    2.284911] usb usb4: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
    <6>usb usb4: Manufacturer: Linux 3.4.90 ohci_hcd
    [    2.296408] usb usb4: Manufacturer: Linux 3.4.90 ohci_hcd
    <6>usb usb4: SerialNumber: sw-ohci
    [    2.304954] usb usb4: SerialNumber: sw-ohci
    <6>hub 4-0:1.0: USB hub found
    [    2.312320] hub 4-0:1.0: USB hub found
    <6>hub 4-0:1.0: 1 port detected
    [    2.318964] hub 4-0:1.0: 1 port detected
    <6>mousedev: PS/2 mouse device common for all mice
    [    2.328032] mousedev: PS/2 mouse device common for all mice
    try to request ir_para gpio failed
    <6>input: sunxi-ir as /devices/virtual/input/input0
    [    2.341798] input: sunxi-ir as /devices/virtual/input/input0
    IR Initial OK
    <3>sunxi-rtc sunxi-rtc: Warning: RTC time is wrong!
    [    2.353961] sunxi-rtc sunxi-rtc: Warning: RTC time is wrong!
    <6>sunxi-rtc sunxi-rtc: rtc core: registered rtc as rtc0
    [    2.364903] sunxi-rtc sunxi-rtc: rtc core: registered rtc as rtc0
    <6>i2c /dev entries driver
    [    2.373517] i2c /dev entries driver
    config i2c gpio with gpio_config api
    <6>axp_mfd 0-0034: AXP (CHIP ID: 0x41) detected
    [    2.386391] axp_mfd 0-0034: AXP (CHIP ID: 0x41) detected
    <6>axp_mfd 0-0034: AXP internal temperature monitoring enabled
    [    2.397543] axp_mfd 0-0034: AXP internal temperature monitoring enabled
    <6>I2C: i2c-0: AW16XX I2C adapter
    [    2.408105] I2C: i2c-0: AW16XX I2C adapter
    <6>I2C: i2c-1: AW16XX I2C adapter
    [    2.418984] I2C: i2c-1: AW16XX I2C adapter
    <6>I2C: i2c-2: AW16XX I2C adapter
    [    2.429826] I2C: i2c-2: AW16XX I2C adapter
    <6>I2C: i2c-3: AW16XX I2C adapter
    [    2.440632] I2C: i2c-3: AW16XX I2C adapter
    [ace_drv] start!!!
    [ace_drv] init end!!!
    [pa_drv] start!!!
    [pa_drv] init end!!!
    <6>Driver for 1-wire Dallas network protocol.
    [    2.456901] Driver for 1-wire Dallas network protocol.
    <3>invalid gpio pin in fex configuration : -1
    [    2.466263] invalid gpio pin in fex configuration : -1
    <6>axp20_ldo1: 1300 mV
    [    2.473801] axp20_ldo1: 1300 mV
    <6>axp20_ldo2: 1800 <--> 3300 mV at 3000 mV
    [    2.482193] axp20_ldo2: 1800 <--> 3300 mV at 3000 mV
    <6>axp20_ldo3: 700 <--> 3500 mV at 2800 mV
    [    2.492531] axp20_ldo3: 700 <--> 3500 mV at 2800 mV
    <6>axp20_ldo4: 1250 <--> 3300 mV at 2800 mV
    [    2.502669] axp20_ldo4: 1250 <--> 3300 mV at 2800 mV
    <6>axp20_buck2: 700 <--> 2275 mV at 1400 mV
    [    2.512883] axp20_buck2: 700 <--> 2275 mV at 1400 mV
    <6>axp20_buck3: 700 <--> 3500 mV at 1250 mV
    [    2.523271] axp20_buck3: 700 <--> 3500 mV at 1250 mV
    <6>axp20_ldoio0: 1800 <--> 3300 mV at 2800 mV
    [    2.533170] axp20_ldoio0: 1800 <--> 3300 mV at 2800 mV
    <6>input: axp20-supplyer as /devices/platform/sunxi-i2c.0/i2c-0/0-0034/axp20-supplyer.28/input/input1
    [    2.547920] input: axp20-supplyer as /devices/platform/sunxi-i2c.0/i2c-0/0-0034/axp20-supplyer.28/input/input1
    <4>axp20_ldo2: Failed to create debugfs directory
    [    2.576641] axp20_ldo2: Failed to create debugfs directory
    <6>device-mapper: uevent: version 1.0.3
    [    2.587010] device-mapper: uevent: version 1.0.3
    <6>device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat.com
    [    2.599454] device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat.com
    <6>cpuidle: using governor ladder
    [    2.611160] cpuidle: using governor ladder
    <6>cpuidle: using governor menu
    [    2.618173] cpuidle: using governor menu
    <6>[mmc-msg] sw_mci_init
    [    2.624429] [mmc-msg] sw_mci_init
    <6>[mmc-msg] MMC host used card: 0x1, boot card: 0x0, io_card 0
    [    2.633460] [mmc-msg] MMC host used card: 0x1, boot card: 0x0, io_card 0
    <6>[mmc-msg] sdc0 set round clock 400000, src 24000000
    [    2.645352] [mmc-msg] sdc0 set round clock 400000, src 24000000
    <6>[mmc-msg] sdc0 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
    [    2.659549] [mmc-msg] sdc0 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
    <6>[mmc-msg] sdc0 Probe: base:0xf0154000 irq:64 sg_cpu:f0156000(4fc00000) ret 0.
    [    2.676809] [mmc-msg] sdc0 Probe: base:0xf0154000 irq:64 sg_cpu:f0156000(4fc00000) ret 0.
    [mmc_pm]: failed to fetch sdio card configuration!
    <6>sunxi_leds driver init
    [    2.692019] sunxi_leds driver init
    <7>Registered led device: green:ph24:led1
    <6>ledtrig-cpu: registered to indicate activity on CPUs
    [    2.704493] ledtrig-cpu: registered to indicate activity on CPUs
    <6>usbcore: registered new interface driver usbhid
    [    2.717091] usbcore: registered new interface driver usbhid
    <6>usbhid: USB HID core driver
    [    2.725500] usbhid: USB HID core driver
    <6>ashmem: initialized
    [    2.732015] ashmem: initialized
    <6>logger: created 256K log 'log_main'
    [    2.738762] logger: created 256K log 'log_main'
    <6>logger: created 256K log 'log_events'
    [    2.747107] logger: created 256K log 'log_events'
    <6>logger: created 256K log 'log_radio'
    [    2.755509] logger: created 256K log 'log_radio'
    <6>logger: created 256K log 'log_system'
    [    2.763928] logger: created 256K log 'log_system'
    <6>IPv4 over IPv4 tunneling driver
    [    2.774301] IPv4 over IPv4 tunneling driver
    <6>TCP: bic registered
    [    2.781272] TCP: bic registered
    <6>TCP: cubic registered
    [    2.786692] TCP: cubic registered
    <6>TCP: westwood registered
    [    2.792568] TCP: westwood registered
    <6>TCP: highspeed registered
    [    2.798758] TCP: highspeed registered
    <6>TCP: hybla registered
    [    2.804703] TCP: hybla registered
    <6>TCP: htcp registered
    [    2.810199] TCP: htcp registered
    <6>TCP: vegas registered
    [    2.815731] TCP: vegas registered
    <6>TCP: veno registered
    [    2.821242] TCP: veno registered
    <6>TCP: scalable registered
    [    2.826996] TCP: scalable registered
    <6>TCP: lp registered
    [    2.832590] TCP: lp registered
    <6>TCP: yeah registered
    [    2.837825] TCP: yeah registered
    <6>TCP: illinois registered
    [    2.843591] TCP: illinois registered
    <6>Initializing XFRM netlink socket
    [    2.850386] Initializing XFRM netlink socket
    <6>NET: Registered protocol family 10
    [    2.858672] NET: Registered protocol family 10
    <6>NET: Registered protocol family 17
    [    2.867546] NET: Registered protocol family 17
    <6>NET: Registered protocol family 15
    [    2.875471] NET: Registered protocol family 15
    [mmc_pm]: No sdio card, please check your config !!
    <5>Registering the dns_resolver key type
    [    2.888257] Registering the dns_resolver key type
    <6>VFP support v0.3: [    2.895018] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 4
    <5>Registering SWP/SWPB emulation handler
    [    2.911254] Registering SWP/SWPB emulation handler
    <4>axp20_buck2: Failed to create debugfs directory
    [    2.920660] axp20_buck2: Failed to create debugfs directory
    <6>[cpu_freq] INF:-------------------V-F Table-------------------
    [    2.932402] [cpu_freq] INF:-------------------V-F Table-------------------
    <6>[cpu_freq] INF:        voltage = 1450mv         frequency = 1008MHz
    [    2.944355] [cpu_freq] INF:        voltage = 1450mv         frequency = 1008MHz
    <6>[cpu_freq] INF:        voltage = 1400mv         frequency =  912MHz
    [    2.955504] [cpu_freq] INF:        voltage = 1400mv         frequency =  912MHz
    <6>[cpu_freq] INF:        voltage = 1300mv         frequency =  864MHz
    [    2.966650] [cpu_freq] INF:        voltage = 1300mv         frequency =  864MHz
    <6>[cpu_freq] INF:        voltage = 1200mv         frequency =  720MHz
    [    2.977795] [cpu_freq] INF:        voltage = 1200mv         frequency =  720MHz
    <6>[cpu_freq] INF:        voltage = 1100mv         frequency =  528MHz
    [    2.988940] [cpu_freq] INF:        voltage = 1100mv         frequency =  528MHz
    <6>[cpu_freq] INF:        voltage = 1050mv         frequency =  312MHz
    [    3.000085] [cpu_freq] INF:        voltage = 1050mv         frequency =  312MHz
    <6>[cpu_freq] INF:        voltage = 1050mv         frequency =  144MHz
    [    3.011230] [cpu_freq] INF:        voltage = 1050mv         frequency =  144MHz
    <6>[cpu_freq] INF:        voltage = 1000mv         frequency =    0MHz
    [    3.022372] [cpu_freq] INF:        voltage = 1000mv         frequency =    0MHz
    <6>[cpu_freq] INF:-----------------------------------------------
    [    3.034295] [cpu_freq] INF:-----------------------------------------------
    <6>[cpu_freq] INF:sunxi_cpufreq_initcall, get cpu frequency from sysconfig, max freq: 912MHz, min freq: 60MHz
    [    3.050826] [cpu_freq] INF:sunxi_cpufreq_initcall, get cpu frequency from sysconfig, max freq: 912MHz, min freq: 60MHz
    <6>registered taskstats version 1
    [    3.065273] registered taskstats version 1
    <6>I2C: i2c-4: HDMI I2C adapter
    [    3.073879] I2C: i2c-4: HDMI I2C adapter
    <6>[mmc-msg] mmc 0 detect change, present 1
    [    3.657693] [mmc-msg] mmc 0 detect change, present 1
    <6>[mmc-msg] sdc0 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
    [    4.166711] [mmc-msg] sdc0 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
    <6>[mmc-msg] sdc0 power on
    [    4.178140] [mmc-msg] sdc0 power on
    <6>[mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
    [    4.207133] [mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
    [    4.221443] [mmc-msg] sdc0 set round clock 400000, src 24000000
    <3>[mmc-err] smc 0 err, cmd 52,  RTO
    [    4.304430] [mmc-err] smc 0 err, cmd 52,  RTO
    [    4.312923] [mmc-err] smc 0 err, cmd 52,  RTO
    [    4.325635] [mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
    [    4.345756] [mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
    <3>[mmc-err] smc 0 err, cmd 5,  RTO
    [    4.360519] [mmc-err] smc 0 err, cmd 5,  RTO
    [    4.368841] [mmc-err] smc 0 err, cmd 5,  RTO
    [    4.377166] [mmc-err] smc 0 err, cmd 5,  RTO
    [    4.385502] [mmc-err] smc 0 err, cmd 5,  RTO
    [    4.398760] [mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
    [    4.416518] [mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
    [    4.436640] [mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
    <6>[mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing SD-HS(SDR25) dt B
    [    4.479706] [mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing SD-HS(SDR25) dt B
    <6>[mmc-msg] sdc0 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 1 timing SD-HS(SDR25) dt B
    [    4.497456] [mmc-msg] sdc0 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 1 timing SD-HS(SDR25) dt B
    <6>[mmc-msg] sdc0 set round clock 42857143, src 600000000
    [    4.512096] [mmc-msg] sdc0 set round clock 42857143, src 600000000
    <6>[mmc-msg] sdc0 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 4 timing SD-HS(SDR25) dt B
    [    4.577267] [mmc-msg] sdc0 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 4 timing SD-HS(SDR25) dt B
    <6>mmc0: new high speed SDHC card at address 0001
    [    4.591209] mmc0: new high speed SDHC card at address 0001
    <6>mmcblk0: mmc0:0001 SD16G 14.6 GiB
    [    4.600532] mmcblk0: mmc0:0001 SD16G 14.6 GiB
    <6> mmcblk0: p1 p2
    [    4.608308]  mmcblk0: p1 p2
    <4>Timeout waiting for EDID info
    [   13.101798] Timeout waiting for EDID info
    <6>disp clks: lcd 74250000 pre_scale 1 hdmi 74250000 pll 297000000 2x 0
    [   13.112220] disp clks: lcd 74250000 pre_scale 1 hdmi 74250000 pll 297000000 2x 0
    <6>Console: switching to colour frame buffer device 160x45
    [   13.816118] Console: switching to colour frame buffer device 160x45
    <4>axp20_buck3: incomplete constraints, leaving on
    [   13.864710] axp20_buck3: incomplete constraints, leaving on
    <4>axp20_buck2: incomplete constraints, leaving on
    [   13.875657] axp20_buck2: incomplete constraints, leaving on
    <4>axp20_ldo4: incomplete constraints, leaving on
    [   13.886496] axp20_ldo4: incomplete constraints, leaving on
    <4>axp20_ldo3: incomplete constraints, leaving on
    [   13.897233] axp20_ldo3: incomplete constraints, leaving on
    <4>axp20_ldo2: incomplete constraints, leaving on
    [   13.907986] axp20_ldo2: incomplete constraints, leaving on
    <4>axp20_ldo1: incomplete constraints, leaving on
    [   13.918738] axp20_ldo1: incomplete constraints, leaving on
    <6>console [netcon0] enabled
    [   13.927792] console [netcon0] enabled
    <6>netconsole: network logging started
    [   13.935248] netconsole: network logging started
    <3>otg_wakelock_init: No USB transceiver found
    [   13.956784] otg_wakelock_init: No USB transceiver found
    <6>sunxi-rtc sunxi-rtc: setting system clock to 2010-01-01 00:00:00 UTC (1262304000)
    <6>ALSA device list:
    <6>  #0: sunxi-CODEC  Audio Codec
    [   13.969901] sunxi-rtc sunxi-rtc: setting system clock to 2010-01-01 00:00:00 UTC (1262304000)
    [   13.972046] ALSA device list:
    [   13.975106]   #0: sunxi-CODEC  Audio Codec
    <6>md: Waiting for all devices to be available before autodetect
    [   14.024205] md: Waiting for all devices to be available before autodetect
    <6>md: If you don't use raid, use raid=noautodetect
    [   14.046707] md: If you don't use raid, use raid=noautodetect
    <6>md: Autodetecting RAID arrays.
    [   14.067699] md: Autodetecting RAID arrays.
    <6>md: Scanned 0 and added 0 devices.
    [   14.085880] md: Scanned 0 and added 0 devices.
    <6>md: autorun ...
    [   14.102697] md: autorun ...
    <6>md: ... autorun DONE.
    [   14.118421] md: ... autorun DONE.
    <6>EXT4-fs (mmcblk0p2): recovery complete
    [   14.423711] EXT4-fs (mmcblk0p2): recovery complete
    <6>EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [   14.452721] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    <6>VFS: Mounted root (ext4 filesystem) on device 179:2.
    [   14.477107] VFS: Mounted root (ext4 filesystem) on device 179:2.
    <6>devtmpfs: mounted
    [   14.497739] devtmpfs: mounted
    <6>Freeing init memory: 224K
    [   14.514842] Freeing init memory: 224K
    <4>init: plymouth-upstart-bridge main process (58) terminated with status 1
    [   15.239039] init: plymouth-upstart-bridge main process (58) terminated with status 1
    <4>init: plymouth-upstart-bridge main process ended, respawning
    [   15.264228] init: plymouth-upstart-bridge main process ended, respawning
    <4>init: plymouth-upstart-bridge main process (68) terminated with status 1
    [   15.373053] init: plymouth-upstart-bridge main process (68) terminated with status 1
    [   15.379037] init: plymouth-upstart-bridge main process ended, respawning
    <4>init: plymouth-upstart-bridge main process (71) terminated with status 1
    [   15.481175] init: plymouth-upstart-bridge main process (71) terminated with status 1
    [   15.517491] init: plymouth-upstart-bridge main process ended, respawning
    <4>init: ureadahead main process (61) terminated with status 5
    [   15.542526] init: ureadahead main process (61) terminated with status 5
    <30>systemd-udevd[213]: starting version 204
    UMP<2>: Inserting UMP device driver. Compiled: Jul 22 2014, time: 13:55:55
    UMP<2>: Using OS memory backend, allocation limit: 134217728
    UMP: UMP device driver  loaded
    Mali: permit MALI_IOC_MEM_MAP_EXT ioctl for framebuffer (paddr=0x4A000000, size=33554432)
    <6>mali: use config clk_div 1
    <6>mali: clk_div 1
    Mali: mali clock set completed, clock is  312000000 Hz
    <6>mali: clk_div 1
    Mali: Mali device driver loaded
    <6>[drm] Initialized drm 1.1.0 20060810
    <6>Mali DRM initialize, driver name: mali_drm, version 2.1
    <6>[drm] Initialized mali_drm 2.1.1 20101111 on minor 0
    <6>[drm] Initialized mali_drm 2.1.1 20101111 on minor 1
    <6>usbcore: registered new interface driver rtl8192cu
    <6>Bluetooth: Core ver 2.16
    <6>NET: Registered protocol family 31
    <6>Bluetooth: HCI device and connection manager initialized
    <6>Bluetooth: HCI socket layer initialized
    <6>Bluetooth: L2CAP socket layer initialized
    <6>Bluetooth: SCO socket layer initialized
    <6>Bluetooth: BNEP (Ethernet Emulation) ver 1.3
    <6>Bluetooth: BNEP filters: protocol multicast
    <6>Bluetooth: RFCOMM TTY layer initialized
    <6>Bluetooth: RFCOMM socket layer initialized
    <6>Bluetooth: RFCOMM ver 1.11
    * Starting Mount filesystems on boot[154G[ OK ]
    * Starting Signal sysvinit that the rootfs is mounted[154G[ OK ]
    * Starting Clean /tmp directory[154G[ OK ]
    * Starting Populate and link to /run filesystem[154G[ OK ]
    * Stopping Populate and link to /run filesystem[154G[ OK ]
    * Stopping Clean /tmp directory[154G[ OK ]
    * Stopping Track if upstart is running in a container[154G[ OK ]
    * Starting Initialize or finalize resolvconf[154G[ OK ]
    * Starting Signal sysvinit that virtual filesystems are mounted[154G[ OK ]
    * Starting Bridge udev events into upstart[154G[ OK ]
    * Starting Signal sysvinit that local filesystems are mounted[154G[ OK ]
    * Starting Signal sysvinit that remote filesystems are mounted[154G[ OK ]
    * Starting device node and kernel event manager[154G[ OK ]
    * Starting flush early job output to logs[154G[ OK ]
    * Stopping Mount filesystems on boot[154G[ OK ]
    * Stopping flush early job output to logs[154G[ OK ]
    * Starting load modules from /etc/modules[154G[ OK ]
    * Starting cold plug devices[154G[ OK ]
    * Starting log initial device creation[154G[ OK ]
    * Starting D-Bus system message bus[154G[ OK ]
    * Starting SystemD login management service[154G[ OK ]
    * Stopping load modules from /etc/modules[154G[ OK ]
    * Starting set console font[154G[ OK ]
    * Stopping cold plug devices[154G[ OK ]
    * Stopping set console font[154G[ OK ]
    * Starting userspace bootsplash[154G[ OK ]
    * Stopping log initial device creation[154G[ OK ]
    * Starting bluetooth daemon[154G[ OK ]
    * Starting system logging daemon[154G[ OK ]
    * Stopping userspace bootsplash[154G[ OK ]
    * Starting Uncomplicated firewall[154G[ OK ]
    * Starting configure network device security[154G[ OK ]
    * Starting Send an event to indicate plymouth is up[154G[ OK ]
    * Starting enable remaining boot-time encrypted block devices[154G[ OK ]
    * Stopping Send an event to indicate plymouth is up[154G[ OK ]
    * Starting mDNS/DNS-SD daemon[154G[ OK ]
    * Starting Reload cups, upon starting avahi-daemon to make sure remote queues are populated[154G[ OK ]
    * Starting CUPS printing spooler/server[154G[ OK ]
    * Starting early crypto disks...       [160G
    * Starting System V initialisation compatibility[154G[ OK ]
    * Starting modem connection manager[154G[ OK ]
    [154G[ OK ]
    * Setting up X socket directories...
    [160G
    [154G[ OK ]
    * Stopping Reload cups, upon starting avahi-daemon to make sure remote queues are populated[154G[ OK ]
    * Starting configure virtual network devices[154G[ OK ]
    * Starting configure network device[154G[ OK ]
    * Stopping System V initialisation compatibility[154G[ OK ]
    * Starting network connection manager[154G[ OK ]
    * Starting System V runlevel compatibility[154G[ OK ]
    * Starting save kernel messages[154G[ OK ]
    * Starting OpenSSH server[154G[ OK ]
    * Starting anac(h)ronistic cron[154G[ OK ]
    * Starting regular background program processing daemon[154G[ OK ]
    * Stopping save kernel messages[154G[ OK ]
    GMAC gpio_power_hd:gpio_direction_output
    <4>eth0: device MAC address 02:d8:01:c2:51:03
    <6>sunxi_gmac: probed
    <6>eth0: PHY ID 001cc915 at 0 IRQ 0 (sunxi_gmac-0:00) active
    <6>eth0: PHY ID 001cc915 at 1 IRQ 0 (sunxi_gmac-0:01)
    <4>init: plymouth-stop pre-start process (863) terminated with status 1
    Ubuntu 14.04 LTS bananapi ttyS0
    bananapi login:
    <7>eth0: no IPv6 routers present
    <3>INFO: rcu_preempt detected stalls on CPUs/tasks:[  115.492318] INFO: rcu_preempt detected stalls on CPUs/tasks:<c>
    <3>        Tasks blocked on level-0 rcu_node (CPUs 0-1):[  115.502696]         Tasks blocked on level-0 rcu_node (CPUs 0-1):<c>
    <3>        Tasks blocked on level-0 rcu_node (CPUs 0-1):[  115.512888]         Tasks blocked on level-0 rcu_node (CPUs 0-1):<c>
    <3>        [  115.519177]         <c>(detected by 0, t=6005 jiffies)
    <3>INFO: Stall ended before state dump start
    [  115.530578] INFO: Stall ended before state dump start
    GMT+8, 2024-12-19 11:10 , Processed in 0.128722 second(s), 19 queries , MemCache On.
