查看: 3804|回复: 0
香蕉派BPI-M1+ Android 4.4 (Beta 1)系统安装
  • 签到天数: 981 天
    发表于 2015-7-14 08:25:10 | 显示全部楼层 |阅读模式
    BPI-M1+ Android 4.4 (Beta 1)镜像下载:
    https://www.bananapi.com/index.php/download?layout=edit&id=29
    解压android_for_bananapi_4.4_beta1.img.7z后得到android_for_bananapi_4.4_beta1.img
    使用工具PhoenixCard,制作安卓系统启动卡。工具PhoenixCard到下面连接下载
    https://www.eeboard.com/bbs/forum.php?mod=viewthread&tid=42655&page=1#pid339247
    将TF卡插入读卡器中,读卡器插入电脑USB口
    打开PhoenixCard
    盘符选择TF卡对应的盘符,镜像文件选择android_for_bananapi_4.4_beta1.img,烧写模式选择“卡启动”,然后点击“烧录”,开始烧写。等待及分钟后,烧写完成。
    拔掉读卡器,然后再插到电脑USB口,发现TF卡由原来的14.6G可用,变成12.2G可用
    将TF卡插入banana pi BPI M1+卡槽中,由于显示器没有HDMI接口,暂且通过banana pi的UART口来查看启动信息。
    注意:将电源适配器插入banana pi的供电miniUSB,banana pi的OTG USB插入电脑USB口,否则banana pi不启动。
    启动时串口打印信息如下:
    HELLO! BOOT0 is starting!
    boot0 version : 3.0.0
    dram size =1024
    card boot number = 0
    card no is 0
    sdcard 0 line count 0
    [mmc]: SD/MMC Card: 4bit, capacity: 14992MB
    [mmc]: vendor: Man 0x00413432 Snr 0x37ccec14
    [mmc]: product: SD16G
    [mmc]: revision: 3.0
    sdcard 0 init ok
    The size of uboot is 0x000a8000.
    sum=0xe7d369eb
    src_sum=0xe7d369eb
    Succeed in loading uboot from sdmmc flash.
    Ready to disable icache.
    Jump to secend Boot.
    [     0.171]
    U-Boot 2011.09-rc1 (Jul 08 2014 - 07:29:52) Allwinner Technology
    [     0.179]version: 1.1.0
    [     0.182]pmbus:   ready
    [     0.287]PMU: AXP209
    [     0.289]PMU: AXP20x found
    [     0.292]PMU: bat ratio = 100
    [     0.299]PMU: dcdc2 1400
    [     0.309]PMU: pll1 912 Mhz
    boot_clock = 912
    dcdc2_vol = 1400
    dcdc3_vol = 1250
    ldo2_vol = 3000
    ldo3_vol = 2800
    ldo4_vol = 2800
    power_start = 0
    storage_type = -1
    usb_recovery = 1
    find power_sply to end
    battery: reg value=10
    no battery, limit to dc
    fel key old mode
    run key detect
    no key found
    no key input
    dram_para_set start
    dram_para_set end
    [     0.354]DRAM: 1 GiB
    relocation Offset is: 35b23000
    DRV_DISP_Init: opened
    [     0.562]fetch script data boot_disp.output_type fail
    [     0.567]fetch script data boot_disp.output_mode fail
    [     0.572]fetch script data boot_disp.auto_hpd fail
    [     0.577]lcd0_para.lcd_used=1
    workmode = 0
    MMC:       0
    SUNXI SD/MMC: 0
    Man 413432 Snr 37ccec14
    SD16G
    3.0
    ---------------MMC version 4.0---------------
    ---------------mmc->clock 50000000-----------
    ---------------mmc->bus_width 4--------------
    boot0 capacity: 0KB,boot1 capacity: 0KB
    [     0.618]sunxi flash init ok
    In:    serial
    Out:   serial
    Err:   serial
    --------fastboot partitions--------
    -total partitions:11-
    -name-     -start-      -size-
    bootloader : 1000000      1000000
    env       : 2000000      1000000
    boot     : 3000000      1000000
    system     : 4000000      2e000000
    data     : 32000000     28000000
    misc     : 5a000000     1000000
    recovery    : 5b000000     2000000
    cache      : 5d000000     28000000
    databk     : 85000000     10000000
    private   : 95000000     1000000
    UDISK      : 96000000     0
    base bootcmd=run setargs_mmc boot_normal
    bootcmd set setargs_mmc
    key 0
    recovery key high 6, low 4
    cant find fstbt value
    to be run cmd=run setargs_mmc boot_normal
    WORK_MODE_BOOT
    board_status_probe
    [     0.704]power trigger
    bat_exist=0
    [     0.710]no battery exist
    sunxi_bmp_display
    [     0.726]Hit any key to stop autoboot: 3
    2
    1
    read boot or recovery all
    [     4.446]sunxi flash read ffset 3000000, 11043034 bytes OK
    no signature
    [     4.455]ready to boot
    [     4.457]
    Starting kernel ...
    [    0.000000] Booting Linux on physical CPU 0
    [    0.000000] Initializing cgroup subsys cpu
    [    0.000000] Linux version 3.4.39 (bpi@bananapi-desktop) (gcc version 4.6.3 20120201 (prerelease) (crosstool-NG linaro-1.13.1-2012.02-20120222 - Linaro GCC 2012.02) ) #17 SMP PREEMPT Wed Aug 6 15:41:47 PDT 2014
    [    0.000000] CPU: ARMv7 Processor [410fc074] revision 4 (ARMv7), cr=10c5387d
    [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
    [    0.000000] Machine: sun7i
    [    0.000000] [sun7i_fixup]: From boot, get meminfo:
    [    0.000000]       Start:     0x40000000
    [    0.000000]       Size:     1024MB
    [    0.000000] memory reserved(in bytes):
    [    0.000000]       : 0x43000000, 0x00010000
    [    0.000000]       : 0x52000000, 0x00020000
    [    0.000000]       : 0x44000000, 0x0c000000
    [    0.000000] Memory policy: ECC disabled, Data cache writealloc
    [    0.000000] On node 0 totalpages: 262144
    [    0.000000] free_area_init_node: node 0, pgdat c0818100, node_mem_map d0000000
    [    0.000000]   DMA zone: 576 pages used for memmap
    [    0.000000]   DMA zone: 0 pages reserved
    [    0.000000]   DMA zone: 64960 pages, LIFO batch:15
    [    0.000000]   Normal zone: 1134 pages used for memmap
    [    0.000000]   Normal zone: 127890 pages, LIFO batch:31
    [    0.000000]   HighMem zone: 594 pages used for memmap
    [    0.000000]   HighMem zone: 66990 pages, LIFO batch:15
    [    0.000000] [scu_get_core_count] cores=1800001
    [    0.000000] sun7i_init_early: enter
    [    0.000000] PERCPU: Embedded 7 pages/cpu @d0908000 s6208 r8192 d14272 u32768
    [    0.000000] pcpu-alloc: s6208 r8192 d14272 u32768 alloc=8*4096
    [    0.000000] pcpu-alloc: [0] 0 [0] 1
    [    0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 259840
    [    0.000000] Kernel command line: console=ttyS0,115200 root=/dev/mmcblk0p7 init=/init loglevel=8 partitions=bootloader@mmcblk0p2:env@mmcblk0p5:boot@mmcblk0p6:system@mmcblk0p7:data@mmcblk0p8:misc@mmcblk0p9:recovery@mmcblk0p10:cache@mmcblk0p11:databk@mmcblk0p12:private@mmcblk0p13:UDISK@mmcblk0p
    1 boot_type=1 partitions=bootloader@mmcblk0p2:env@mmcblk0p5:boot@mmcblk0p6:system@mmcblk0p7:data@mmcblk0p8:misc@mmcblk0p9:recovery@mmcblk0p10:cache@mmcblk0p11:databk@mmcblk0p12:private@mmcblk0p13:UDISK@mmcblk0p1
    [    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
    [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
    [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
    [    0.000000] allocated 2097152 bytes of page_cgroup
    [    0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
    [    0.000000] Memory: 1024MB = 1024MB total
    [    0.000000] Memory: 828480k/828480k available, 220096k reserved, 270336K highmem
    [    0.000000] Virtual kernel memory layout:
    [    0.000000]   vector : 0xffff0000 - 0xffff1000   (   4 kB)
    [    0.000000]   fixmap : 0xfff00000 - 0xfffe0000   ( 896 kB)
    [    0.000000]   vmalloc : 0xf0000000 - 0xff000000   ( 240 MB)
    [    0.000000]   lowmem : 0xc0000000 - 0xef800000   ( 760 MB)
    [    0.000000]   pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
    [    0.000000]   modules : 0xbf000000 - 0xbfe00000   ( 14 MB)
    [    0.000000]      .text : 0xc0008000 - 0xc0788d70   (7684 kB)
    [    0.000000]      .init : 0xc0789000 - 0xc07bc840   ( 207 kB)
    [    0.000000]      .data : 0xc07be000 - 0xc0819220   ( 365 kB)
    [    0.000000]     .bss : 0xc0819244 - 0xc0969080   (1344 kB)
    [    0.000000] Preemptible hierarchical RCU implementation.
    [    0.000000] NR_IRQS:160
    [    0.000000] aw_clkevt_init: timer base 0xf000cc00
    [    0.000000] [aw_delay]: It is use use_time_delay function!
    [    0.000000] aw_clksrc_init(96)
    [    0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
    [    0.000000] aw_clksrc_init(120)
    [    0.000000] Architected local timer running at 24.00MHz.
    [    0.000000] Console: colour dummy device 80x30
    [    0.000437] Calibrating delay loop... 1810.43 BogoMIPS (lpj=9052160)
    [    0.059985] pid_max: default: 32768 minimum: 301
    [    0.060262] Security Framework initialized
    [    0.060286] SELinux: Initializing.
    [    0.060352] SELinux: Starting in permissive mode
    [    0.060364] AppArmor: AppArmor disabled by boot time parameter
    [    0.060483] Mount-cache hash table entries: 512
    [    0.061464] Initializing cgroup subsys debug
    [    0.061482] Initializing cgroup subsys cpuacct
    [    0.061492] Initializing cgroup subsys memory
    [    0.061525] Initializing cgroup subsys freezer
    [    0.061593] CPU: Testing write buffer coherency: ok
    [    0.061924] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    [    0.062180] Setting up static identity map for 0x40562930 - 0x40562988
    [    0.174790] CPU1: Booted secondary processor
    [    0.232247] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
    [    0.232341] Brought up 2 CPUs
    [    0.232357] SMP: Total of 2 processors activated (3633.97 BogoMIPS).
    [    0.233272] devtmpfs: initialized
    [    0.238136] script_init enter!
    [    0.239150] script_init exit!
    [    0.239838] kworker/u:0 used greatest stack depth: 6560 bytes left
    [    0.241058] dummy:
    [    0.241619] NET: Registered protocol family 16
    [    0.242260] sunxi_dump_init success
    [    0.242319] kworker/u:0 used greatest stack depth: 6384 bytes left
    [    0.242636] bandwidth_sysfs_init success
    [    0.244983] sun7i_init: enter
    [    0.245595] [ccu-inf] aw clock manager init
    [    0.245608] [ccu-inf] aw_ccu_init
    [    0.245830] [ccu-inf] script config pll3 to 297MHz
    [    0.245846] [ccu-inf] script config pll4 to 300MHz
    [    0.245860] [ccu-inf] script config pll6 to 600MHz
    [    0.245873] [ccu-inf] script config pll7 to 297MHz
    [    0.245886] [ccu-inf] script config pll8 to 336MHz
    [    0.246472] axp config [pmu_para] [pmu_used] : 1
    [    0.246488] axp config [pmu_para] [pmu_twi_id] : 0
    [    0.246499] axp config [pmu_para] [pmu_irq_id] : 32
    [    0.246510] axp config [pmu_para] [pmu_twi_addr] : 52
    [    0.246522] axp config [pmu_para] [pmu_battery_rdc] : 100
    [    0.246534] axp config [pmu_para] [pmu_battery_cap] : 3200
    [    0.246546] axp config [pmu_para] [pmu_init_chgcur] : 300
    [    0.246558] axp config [pmu_para] [pmu_suspend_chgcur] : 1000
    [    0.246570] axp config [pmu_para] [pmu_resume_chgcur] : 300
    [    0.246582] axp config [pmu_para] [pmu_shutdown_chgcur] : 1000
    [    0.246594] axp config [pmu_para] [pmu_init_chgvol] : 4200
    [    0.246606] axp config [pmu_para] [pmu_init_chgend_rate] : 15
    [    0.246618] axp config [pmu_para] [pmu_init_chg_enabled] : 1
    [    0.246630] axp config [pmu_para] [pmu_init_adc_freq] : 100
    [    0.246642] axp config [pmu_para] [pmu_init_adc_freqc] : 100
    [    0.246654] axp config [pmu_para] [pmu_init_chg_pretime] : 50
    [    0.246667] axp config [pmu_para] [pmu_init_chg_csttime] : 720
    [    0.246679] axp config [pmu_para] [pmu_bat_para1] : 0
    [    0.246691] axp config [pmu_para] [pmu_bat_para2] : 0
    [    0.246702] axp config [pmu_para] [pmu_bat_para3] : 0
    [    0.246714] axp config [pmu_para] [pmu_bat_para4] : 0
    [    0.246725] axp config [pmu_para] [pmu_bat_para5] : 5
    [    0.246737] axp config [pmu_para] [pmu_bat_para6] : 8
    [    0.246748] axp config [pmu_para] [pmu_bat_para7] : 11
    [    0.246760] axp config [pmu_para] [pmu_bat_para8] : 22
    [    0.246772] axp config [pmu_para] [pmu_bat_para9] : 33
    [    0.246783] axp config [pmu_para] [pmu_bat_para10] : 43
    [    0.246795] axp config [pmu_para] [pmu_bat_para11] : 50
    [    0.246807] axp config [pmu_para] [pmu_bat_para12] : 59
    [    0.246818] axp config [pmu_para] [pmu_bat_para13] : 71
    [    0.246830] axp config [pmu_para] [pmu_bat_para14] : 83
    [    0.246842] axp config [pmu_para] [
    pmu_bat_para15] : 92
    [    0.246853] axp config [pmu_para] [pmu_bat_para16] : 100
    [    0.246865] axp config [pmu_para] [pmu_usbvol_limit] : 1
    [    0.246877] axp config [pmu_para] [pmu_usbvol] : 4000
    [    0.246889] axp config [pmu_para] [pmu_usbcur_limit] : 0
    [    0.246900] axp config [pmu_para] [pmu_usbcur] : 0
    [    0.246912] axp config [pmu_para] [pmu_pwroff_vol] : 3300
    [    0.246924] axp config [pmu_para] [pmu_pwron_vol] : 2900
    [    0.246935] axp config [target] [dcdc2_vol] : 1400
    [    0.246946] axp config [target] [dcdc3_vol] : 1250
    [    0.246957] axp config [target] [ldo2_vol] : 3000
    [    0.246967] axp config [target] [ldo3_vol] : 2800
    [    0.246978] axp config [target] [ldo4_vol] : 2800
    [    0.246990] axp config [pmu_para] [pmu_pekoff_time] : 6000
    [    0.247001] axp config [pmu_para] [pmu_pekoff_en] : 1
    [    0.247015] axp config [pmu_para] [pmu_peklong_time] : 1500
    [    0.247027] axp config [pmu_para] [pmu_pwrok_time] : 64
    [    0.247039] axp config [pmu_para] [pmu_pwrnoe_time] : 2000
    [    0.247051] axp config [pmu_para] [pmu_intotp_en] : 1
    [    0.247062] axp config [pmu_para] [pmu_pekon_time] : 1000
    [    0.247761] [gpio-inf] aw gpio init start
    [    0.247792] [gpio-inf] gpio_clk_init: apb pio clk enable success
    [    0.248046] gpiochip_add: registered GPIOs 0 to 17 on device: GPA
    [    0.248266] gpiochip_add: registered GPIOs 24 to 47 on device: GPB
    [    0.248493] gpiochip_add: registered GPIOs 54 to 78 on device: GPC
    [    0.248684] gpiochip_add: registered GPIOs 85 to 112 on device: GPD
    [    0.248868] gpiochip_add: registered GPIOs 119 to 130 on device: GPE
    [    0.249111] gpiochip_add: registered GPIOs 137 to 142 on device: GPF
    [    0.249337] gpiochip_add: registered GPIOs 149 to 160 on device: GPG
    [    0.249554] gpiochip_add: registered GPIOs 167 to 194 on device: GPH
    [    0.249763] gpiochip_add: registered GPIOs 201 to 222 on device: GPI
    [    0.250159] [gpio-inf] aw gpio init done
    [    0.301379] bio: create slab <bio-0> at 0
    [    0.306318] SCSI subsystem initialized
    [    0.306927] libata version 3.00 loaded.
    [    0.307884] usbcore: registered new interface driver usbfs
    [    0.308264] usbcore: registered new interface driver hub
    [    0.308554] usbcore: registered new device driver usb
    [    0.310912] -------------------------------------------
    [    0.310930] axp_mfd_probe:axp20_mfd pmu probed !
    [    0.310938] -------------------------------------------
    [    0.313302] axp_mfd 0-0034: AXP (CHIP ID: 0x41) detected
    [    0.313993] -------------------------------------------
    [    0.314005] axp_mfd_probe:axp20_mfd pmu request_irq ok !
    [    0.314013] -------------------------------------------
    [    0.315961] I2C: i2c-0: sun7i I2C adapter
    [    0.315975] **********start************
    [    0.315984] 0x40
    [    0.315990] 0xf8
    [    0.315997] 0x58
    [    0.316004] 0x0
    [    0.316011] 0x0
    [    0.316017] **********end************
    [    0.316401] I2C: i2c-1: sun7i I2C adapter
    [    0.316412] **********start************
    [    0.316421] 0x40
    [    0.316428] 0xf8
    [    0.316435] 0x58
    [    0.316441] 0x0
    [    0.316448] 0x0
    [    0.316454] **********end************
    [    0.316768] I2C: i2c-2: sun7i I2C adapter
    [    0.316780] **********start************
    [    0.316789] 0x40
    [    0.316796] 0xf8
    [    0.316803] 0x28
    [    0.316810] 0x0
    [    0.316816] 0x0
    [    0.316823] **********end************
    [    0.317138] I2C: i2c-3: sun7i I2C adapter
    [    0.317149] **********start************
    [    0.317157] 0x40
    [    0.317164] 0xf8
    [    0.317171] 0x58
    [    0.317178] 0x0
    [    0.317185] 0x0
    [    0.317191] **********end************
    [    0.317499] I2C: i2c-4: sun7i I2C adapter
    [    0.317509] **********start************
    [    0.317518] 0x40
    [    0.317525] 0xf8
    [    0.317532] 0x58
    [    0.317539] 0x0
    [    0.317546] 0x0
    [    0.317552] **********end************
    [    0.317748] Linux video capture interface: v2.00
    [    0.318369] axp20_ldo1: 1300 mV
    [    0.320088] axp20_ldo2: 1800 <--> 3300 mV at 3000 mV
    [    0.321756] axp20_ldo3: 700 <--> 3500 mV at 2800 mV
    [    0.323522] axp20_ldo4: 1250 <--> 3300 mV at 2800 mV
    [    0.325218] axp20_buck2: 700 <--> 2275 mV at 1400 mV
    [    0.326926] axp20_buck3: 700 <--> 3500 mV at 1250 mV
    [    0.327921] axp20_ldoio0: 1800 <--> 3300 mV at 2800 mV
    [    0.328789] gpiochip_add: registered GPIOs 229 to 233 on device: axp_pin
    [    0.330099] Advanced Linux Sound Architecture Driver Version 1.0.25.
    [    0.331337] Bluetooth: Core ver 2.16
    [    0.331556] NET: Registered protocol family 31
    [    0.331568] Bluetooth: HCI device and connection manager initialized
    [    0.331582] Bluetooth: HCI socket layer initialized
    [    0.331593] Bluetooth: L2CAP socket layer initialized
    [    0.331628] Bluetooth: SCO socket layer initialized
    [    0.332305] cfg80211: Calling CRDA to update world regulatory domain
    [    0.335355] Switching to clocksource arch_sys_counter
    [    0.335804] FS-Cache: Loaded
    [    0.336305] CacheFiles: Loaded
    [    0.358578] line = 507,usb_manager_init
    [    0.358592] [usb_manager]: CONFIG_USB_SW_SUN7I_USB0_OTG
    [    0.358624] WRN220(drivers/usb/sun7i_usb/manager/usb_manager.c):ERR: get usbc(0) det_vbus gpio failed
    [    0.358646] WRN252(drivers/usb/sun7i_usb/manager/usb_manager.c):ERR: get usbc(0) ac_enable failed
    [    0.359201] [sw_hcd0]: usb host driver initialize........
    [    0.359311] [sw_hcd0]: open_usb_clock
    [    0.379216] [sw_hcd0]: host_init_state = 0
    [    0.379233] [sw_hcd0]: platform is usb host
    [    0.379325] [sw_hcd0]: sw_hcd_init_controller: sw_hcd_host0: USB Host mode controller at f1c13000 using PIO, IRQ 70
    [    0.379354] sw_hcd_host0 sw_hcd_host0: sw_hcd host driver
    [    0.379374] sw_hcd_host0 sw_hcd_host0: new USB bus registered, assigned bus number 1
    [    0.380587] hub 1-0:1.0: USB hub found
    [    0.380622] hub 1-0:1.0: 1 port detected
    [    0.380653] wrn: hcd is not enable, need not start hcd
    [    0.381135] [sw_hcd0]: sw_usb_host0_disable start
    [    0.381149] -------sw_hcd0_soft_disconnect---------
    [    0.381163] [sw_hcd_host0]: Set USB Power OFF
    [    0.381178] wrn: hcd is not enable, need not stop hcd
    [    0.381209] [sw_hcd0]: close_usb_clock
    [    0.381227] [sw_hcd0]: sw_usb_host0_disable end
    [    0.381440] [sw_udc]: udc_init: version 20080411
    [    0.382277] NET: Registered protocol family 2
    [    0.382822] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
    [    0.385326] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
    [    0.389503] TCP bind hash table entries: 65536 (order: 7, 786432 bytes)
    [    0.390549] TCP: Hash tables configured (established 131072 bind 65536)
    [    0.390563] TCP: reno registered
    [    0.390620] UDP hash table entries: 512 (order: 2, 16384 bytes)
    [    0.390689] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
    [    0.391203] NET: Registered protocol family 1
    [    0.391819] RPC: Registered named UNIX socket transport module.
    [    0.391833] RPC: Registered udp transport module.
    [    0.391843] RPC: Registered tcp transport module.
    [    0.391852] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.392172] Unpacking initramfs...
    [    0.532046] Freeing initrd memory: 1496K
    [    0.532349] sunxi_reg_init enter
    [    0.533668] [pm]aw_pm_init!
    [    0.533688] dram config [dram_para] [dram_baseaddr] : 0x40000000
    [    0.533699] dram config [dram_para] [dram_clk] : 0x1e0
    [    0.533710] dram config [dram_para] [dram_type] : 0x3
    [    0.533721] dram config [dram_para] [dram_rank_num] : 0x1
    [    0.533732] dram config [dram_para] [dram_chip_density] : 0x1000
    [    0.533744] dram config [dram_para] [dram_io_width] : 0x10
    [    0.533756] dram config [dram_para] [dram_bus_width] : 0x20
    [    0.533767] dram config [dram_para] [dram_cas] : 0x9
    [    0.533778] dram config [dram_para] [dram_zq] : 0x7f
    [    0.533788] dram config [dram_para] [dram_odt_en] : 0x0
    [    0.533799] dram config [dram_para] [dram_size] : 0x400
    [    0.533810] dram config [dram_para] [dram_tpr0] : 0x42d899b7
    [    0.533822] dram config [dram_para] [dram_tpr1] : 0xa090
    [    0.533833] dram config [dram_para] [dram_tpr2] : 0x22a00
    [    0.533844] dram config [dram_para] [dram_tpr3] : 0x0
    [    0.533854] dram config [dram_para] [dram_tpr4] : 0x1
    [    0.533865] dram config [dram_para] [dram_tpr5] : 0x0
    [    0.533875] dram config [dram_para] [dram_emr1] : 0x4
    [    0.533886] dram config [dram_para] [dram_emr2] : 0x10
    [    0.533897] dram config [dram_para] [dram_emr3] : 0x0
    [    0.533908] standby_mode = 0.
    [    0.533917] aw_pm_init: not support super standby.
    [    0.533927] cpu0_en = 0.
    [    0.533936] dram_selfresh_en = 1.
    [    0.533946] wakeup src cnt is : 0.
    [    0.534033] DRAM_STANDBY_PGD_ADDR:d201c000
    [    0.534058] [wifi]: select wifi: rtl8192cu !!
    [    0.534429] [rtl8192cu]: exec rtl8192cu_wifi_gpio_init
    [    0.534447] [rtl8192cu]: rtl8192cu module power set by axp.
    [    0.534462] [rtl8192cu]: get power regulator failed.
    [    0.534491] [wifi_pm]: wifi gpio init is OK !!
    [    0.534709] [powernow inf] module init
    [    0.534915] [powernow inf] create class sw_powernow done
    [    0.535863] audit: initializing netlink socket (disabled)
    [    0.535936] type=2000 audit(0.530:1): initialized
    [    0.537041] highmem bounce pool size: 64 pages
    [    0.540165] NTFS driver 2.1.30 [Flags: R/W].
    [    0.540451] fuse init (API version 7.18)
    [    0.541665] msgmni has been set to 1093
    [    0.541722] SELinux: Registering netfilter hooks
    [    0.544318] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
    [    0.544340] io scheduler noop registered
    [    0.544351] io scheduler deadline registered (default)
    [    0.544505] io scheduler cfq registered
    [    0.553662] [uart]: driver initializied
    [    0.555153] sw_serial.0: ttyS0 at MMIO 0x1c28000 (irq = 33) is a SW
    [    0.555181] [uart]: console setup baud 115200 parity n bits 8, flow n
    [    0.555209] [uart]: uart0 LCR & BAUD changed, reset controller...
    [    2.263089] console [ttyS0] enabled
    [    2.267640] sw_serial.2: ttyS2 at MMIO 0x1c28800 (irq = 35) is a SW
    [    2.275103] sw_serial.3: ttyS3 at MMIO 0x1c28c00 (irq = 36) is a SW
    [    2.282959] sw_serial.5: ttyS5 at MMIO 0x1c29400 (irq = 50) is a SW
    [    2.290479] sw_serial.6: ttyS6 at MMIO 0x1c29800 (irq = 51) is a SW
    [    2.298257] sw_serial.7: ttyS7 at MMIO 0x1c29c00 (irq = 52) is a SW
    [    2.306905] G2D: drv_g2d_init
    [    2.310405] G2D: Module initialized.major:251
    [    2.322129] loop: module loaded
    [    2.328206] sw_ahci sw_ahci.0: SATA power enable do not exist!!
    [    2.334797] sw_ahci sw_ahci.0: controller can't do PMP, turning off CAP_PMP
    [    2.342602] sw_ahci sw_ahci.0: forcing PORTS_IMPL to 0x1
    [    2.348983] sw_ahci sw_ahci.0: AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl platform mode
    [    2.358504] sw_ahci sw_ahci.0: flags: ncq sntf pm led clo only pio slum part ccc
    [    2.367198] dma_alloc_coherent mem = 0xffde0000, size = 0x16500, mem_dma=0x43c00000
    [    2.376941] scsi0 : sw_ahci_platform
    [    2.381719] ata1: SATA max UDMA/133 mmio [mem 0x01c18000-0x01c18fff] port 0x100 irq 88
    [    2.392798] [spi-inf] sun7i spi init
    [    2.396819] [spi-inf] spi_sun7i_init: spi_used: 0x1
    [    2.402241] [spi-err] sun7i_spi_register_spidev: get spi devices number failed
    [    2.410310] [spi-err] spi_sun7i_init: register spi devices board info failed
    [    2.418258] [spi-inf] sun7i_spi_norflash: Register norflash:at25df641 information OK
    [    2.427275] [spi-inf] sun7i_spi_probe: spi0 dma type: normal
    [    2.433573] [spi-inf] sun7i_spi_probe: spi0 cs bitmap: 0x1
    [    2.439954] [spi-inf] sun7i_spi_set_mclk: spi0 source = sata_pll, src_clk = 600000000, mclk 100000000
    [    2.450272] [spi-inf] sun7i_spi_request_gpio: maybe error, request gpio 211 failed
    [    2.458699] [spi-inf] sun7i_spi_request_gpio: maybe error, request gpio 212 failed
    [    2.467146] [spi-inf] sun7i_spi_request_gpio: maybe error, request gpio 213 failed
    [    2.475573] [spi-inf] sun7i_spi_request_gpio: maybe error, request gpio 214 failed
    [    2.484305] sun7i-spi sun7i-spi.0: master is unqueued, this is deprecated
    [    2.492147] [spi-inf] sun7i_spi_probe: reuuimlla's SoC SPI Driver loaded for Bus SPI0 with 2 Slaves at most
    [    2.503031] [spi-inf] sun7i_spi_probe: spi0 driver probe succeed, base f0054000, irq 42, dma_id_rx 24, dma_id_tx 24
    [    2.514954] [nor-msg] id = c05bdc00
    [    2.518868] [nor-msg] spi->dev.platform_data = c07eda80
    [    2.524674] [nor-msg] data->type = at25df641
    [    2.529435] [nor-msg] data->name = at45db041d
    [    2.534273] [nor-msg] data->nr_parts = 0
    [    2.538661] [nor-msg] data->parts =   (null)
    [    2.543406] [nor-msg] info = c07ee1c0
    [    2.547488] [nor-msg] info->jedec_id = 001f4800
    [    2.552520] [nor-msg] info->flags = 1
    [    2.556600] [nor-msg] info->addr_width = 0
    [    2.561245] [nor-err] unrecognized JEDEC id ffffff
    [    2.566837] tun: Universal TUN/TAP device driver, 1.6
    [    2.572450] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
    [    2.581238] [gmac]: sun6i_gmac platform driver registration completed
    [    2.588483] PPP generic driver version 2.4.2
    [    2.593952] PPP BSD Compression module registered
    [    2.599225] PPP Deflate Compression module registered
    [    2.605664] PPP MPPE Compression module registered
    [    2.610995] NET: Registered protocol family 24
    [    2.616116] PPTP driver version 0.8.5
    [    2.621807] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
    [    2.629410] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
    [    2.636584] [sw_hci_sun4i_init 1254]
    [    2.640572] WRN163(drivers/usb/host/sw_hci_sun7i.c):ERR: sw-ehci1(restrict_gpio) is invalid
    [    2.650171] WRN163(drivers/usb/host/sw_hci_sun7i.c):ERR: sw-ohci1(restrict_gpio) is invalid
    [    2.659735] WRN163(drivers/usb/host/sw_hci_sun7i.c):ERR: sw-ehci2(restrict_gpio) is invalid
    [    2.669262] WRN163(drivers/usb/host/sw_hci_sun7i.c):ERR: sw-ohci2(restrict_gpio) is invalid
    [    2.679139] [sw-ehci1]: probe, pdev->name: sw-ehci, pdev->id: 1, sw_ehci: 0xc085dbcc
    [    2.687786] [sw-ehci1]: open clock
    [    2.711428] [sw-ehci1]: open clock, 0x60(0x210c162), 0xcc(0x102)
    [    2.718125] [sw-ehci1]: Set USB Power ON
    [    2.722481] __set_vbus
    [    2.725101] sw-ehci sw-ehci.1: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
    [    2.733457] sw-ehci sw-ehci.1: new USB bus registered, assigned bus number 2
    [    2.741441] sw-ehci sw-ehci.1: irq 71, io mem 0xf1c14000
    [    2.745452] ata1: SATA link down (SStatus 0 SControl 300)
    [    2.765453] sw-ehci sw-ehci.1: USB 0.0 started, EHCI 1.00
    [    2.772471] hub 2-0:1.0: USB hub found
    [    2.776683] hub 2-0:1.0: 1 port detected
    [    2.781815] [sw-ohci1]: probe, pdev->name: sw-ohci, pdev->id: 1, sw_ohci: 0xc085dce0
    [    2.790484] [sw-ohci1]: open clock
    [    2.814125] [sw-ohci1]: open clock, 0x60(0x210c166), 0xcc(0x162)
    [    2.820816] [sw_ohci_hcd_probe 360]:reg(0xf1c20060) = 210c166
    [    2.827220] sw-ohci sw-ohci.1: SW USB2.0 'Open' Host Controller (OHCI) Driver
    [    2.835172] sw-ohci sw-ohci.1: new USB bus registered, assigned bus number 3
    [    2.843070] sw-ohci sw-ohci.1: irq 96, io mem 0xf1c14400
    [    2.910389] hub 3-0:1.0: USB hub found
    [    2.914573] hub 3-0:1.0: 1 port detected
    [    2.919742] [sw-ehci2]: probe, pdev->name: sw-ehci, pdev->id: 2, sw_ehci: 0xc085ddf4
    [    2.928400] [sw-ehci2]: open clock
    [    2.952038] [sw-ehci2]: open clock, 0x60(0x210c16e), 0xcc(0x166)
    [    2.958752] [sw-ehci2]: Set USB Power ON
    [    2.963110] __set_vbus
    [    2.965757] sw-ehci sw-ehci.2: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
    [    2.974097] sw-ehci sw-ehci.2: new USB bus registered, assigned bus number 4
    [    2.982077] sw-ehci sw-ehci.2: irq 72, io mem 0xf1c1c000
    [    3.005439] sw-ehci sw-ehci.2: USB 0.0 started, EHCI 1.00
    [    3.012434] hub 4-0:1.0: USB hub found
    [    3.016700] hub 4-0:1.0: 1 port detected
    [    3.021800] [sw-ohci2]: probe, pdev->name: sw-ohci, pdev->id: 2, sw_ohci: 0xc085df08
    [    3.030455] [sw-ohci2]: open clock
    [    3.054093] [sw-ohci2]: open clock, 0x60(0x210c17e), 0xcc(0x1e6)
    [    3.060825] [sw_ohci_hcd_probe 360]:reg(0xf1c20060) = 210c17e
    [    3.067230] sw-ohci sw-ohci.2: SW USB2.0 'Open' Host Controller (OHCI) Driver
    [    3.075184] sw-ohci sw-ohci.2: new USB bus registered, assigned bus number 5
    [    3.083087] sw-ohci sw-ohci.2: irq 97, io mem 0xf1c1c400
    [    3.150409] hub 5-0:1.0: USB hub found
    [    3.154614] hub 5-0:1.0: 1 port detected
    [    3.159848] usbcore: registered new interface driver cdc_acm
    [    3.166206] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
    [    3.175101] Initializing USB Mass Storage driver...
    [    3.180889] usbcore: registered new interface driver usb-storage
    [    3.187617] USB Mass Storage support registered.
    [    3.193224] usbcore: registered new interface driver usbserial
    [    3.199758] usbserial: USB Serial Driver core
    [    3.204819] usbcore: registered new interface driver option
    [    3.211249] USB Serial support registered for GSM modem (1-port)
    [    3.218688] [sw_udc]: [sw_usb_udc]: binding gadget driver 'android_usb'
    [    3.226104] [sw_udc]: alloc request: ep(0xc07f4780, ep0, 64), req(0xef36fc40)
    [    3.234050] WRN2736(drivers/usb/sun7i_usb/udc/sw_udc.c):ERR: usb device is not active
    [    3.242972] [sw_udc]: sw_udc_pullup, is_on = 0
    [    3.248000] WRN2771(drivers/usb/sun7i_usb/udc/sw_udc.c):ERR: usb device is not active
    [    3.257249] file system registered
    [    3.264267] android_usb gadget: Mass Storage Function, version: 2009/09/11
    [    3.271963] android_usb gadget: Number of LUNs=2
    [    3.277123] lun0: LUN: removable file: (no medium)
    [    3.282543] lun1: LUN: removable file: (no medium)
    [    3.288829] WRN2736(drivers/usb/sun7i_usb/udc/sw_udc.c):ERR: usb device is not active
    [    3.297913] android_usb gadget: android_usb ready
    [    3.304030] mousedev: PS/2 mouse device common for all mice
    [    3.310921] input: sw-keyboard as /devices/virtual/input/input0
    [    3.318507] get_device_para_value:get subname:stk831x error! val.val:0
    [    3.325997] get_detect_list: script_get_item err.support_number = 4.
    [    3.333337] sw_get_write_info:read erro or read null !
    [    3.339224] get write info erro!
    [    3.342975] sunxi_rtc_init: enter
    [    3.346706] [i2c1] incomplete xfer (status: 0x20, dev addr: 0x18)
    [    3.353761] rtc_hw_init(400): start
    [    3.357766] rtc_hw_init(432): end
    [    3.361526] sunxi_rtc_gettime, line 39
    [    3.365719] sunxi_rtc_gettime(59): rtc_tm->tm_year:0
    [    3.371256] sunxi_rtc_gettime(61): year < 70, so add 100, to check
    [    3.371268] [i2c1] incomplete xfer (status: 0x20, dev addr: 0x18)
    [    3.384915] sunxi_rtc_gettime(67): read time 2000-1-1 0:1:4
    [    3.391125] sunxi_rtc_getalarm(269): year < 70, so add 100, to check
    [    3.398218] sunxi_rtc_getalarm(281): get alarm time 2000-1-1 0:0:0
    [    3.398229] [i2c1] incomplete xfer (status: 0x20, dev addr: 0x18)
    [    3.411871] sunxi_rtc_gettime, line 39
    [    3.416053] sunxi_rtc_gettime(59): rtc_tm->tm_year:0
    [    3.421585] sunxi_rtc_gettime(61): year < 70, so add 100, to check
    [    3.421596] [i2c1] incomplete xfer (status: 0x20, dev addr: 0x18)
    [    3.435236] sunxi_rtc_gettime(67): read time 2000-1-1 0:1:4
    [    3.441511] [i2c1] incomplete xfer (status: 0x20, dev addr: 0x18)
    [    3.442194] using rtc device, rtc, for alarms
    [    3.442244] sunxi-rtc sunxi-rtc: rtc core: registered rtc as rtc0
    [    3.442541] i2c /dev entries driver
    [    3.445022] lirc_dev: IR Remote Control driver registered, major 248
    [    3.445033] IR NEC protocol handler initialized
    [    3.445041] IR RC5(x) protocol handler initialized
    [    3.445049] IR RC6 protocol handler initialized
    [    3.445056] IR JVC protocol handler initialized
    [    3.445063] IR Sony protocol handler initialized
    [    3.445070] IR RC5 (streamzap) protocol handler initialized
    [    3.445078] IR SANYO protocol handler initialized
    [    3.445086] IR MCE Keyboard/mouse protocol handler initialized
    [    3.445093] IR LIRC bridge handler initialized
    [    3.445343] [hx-cedar dev]: install start!!!
    [    3.446828] [cedar dev]: install end!!!
    [    3.446839] Driver for 1-wire Dallas network protocol.
    [    3.447855] usbcore: registered new interface driver DS9490R
    [    3.448102] DS1WM w1 busmaster driver - (c) 2004 Szabolcs Gyurko
    [    3.449328] input: axp20-supplyer as /devices/platform/sun7i-i2c.0/i2c-0/0-0034/axp20-supplyer.28/input/input1
    [    3.562888] pmu_pekoff_time = 6000
    [    3.566853] pmu_pekoff_en = 1
    [    3.570149] pmu_peklong_time = 1500
    [    3.574021] pmu_pekon_time = 1000
    [    3.577940] pmu_pwrok_time = 64
    [    3.581433] pmu_pwrnoe_time = 2000
    [    3.585210] pmu_intotp_en = 1
    [    3.588613] [i2c1] incomplete xfer (status: 0x20, dev addr: 0x19)
    [    3.589156] [AXP]POWER20_OFF_CTL:2077-->0x42
    [    3.589766] POWER20_PEK_SET:2094-->0x9d
    [    3.590376] POWER20_PEK_SET:2105-->0x9d
    [    3.590986] POWER20_PEK_SET:2114-->0x9d
    [    3.591595] POWER20_PEK_SET:2125-->0x9d
    [    3.592205] POWER20_PEK_SET:2137-->0x9d
    [    3.592816] POWER20_HOTOVER_CTL:2146-->0x25
    [    3.597961] [AXP]last_rest_vol = 0, now_rest_vol     = 100
    [    3.599008] [AXP]charger->rest_vol = 100
    [    3.636357] ==============backup=============
    [    3.643502] axp20_ldo2: Failed to create debugfs directory
    [    3.649747] regulator_virtual_consumer_probe:get regulator:axp20_analog/fm ok
    [    3.658072] regulator_virtual_consumer_probe:get regulator:axp20_pll ok
    [    3.665643] [i2c1] incomplete xfer (status: 0x20, dev addr: 0x19)
    [    3.672683] regulator_virtual_consumer_probe:get regulator:axp20_hdmi ok
    [    3.680498] axp20_buck2: Failed to create debugfs directory
    [    3.686863] regulator_virtual_consumer_probe:get regulator:axp20_core ok
    [    3.694687] regulator_virtual_consumer_probe:get regulator:axp20_ddr ok
    [    3.702146] [i2c1] incomplete xfer (status: 0x20, dev addr: 0x19)
    [    3.702462] regulator_virtual_consumer_probe:get regulator:axp20_mic ok
    [    3.717081] device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat.com
    [    3.726948] device-mapper: multipath: version 1.3.0 loaded
    [    3.733050] device-mapper: multipath round-robin: version 1.0.0 loaded
    [    3.740356] device-mapper: multipath queue-length: version 0.1.0 loaded
    [    3.740523] [i2c1] incomplete xfer (status: 0x20, dev addr: 0x19)
    [    3.754491] device-mapper: multipath service-time: version 0.2.0 loaded
    [    3.755640] [i2c1] incomplete xfer (status: 0x20, dev addr: 0x19)
    [    3.769589] [mmc-msg] sw_mci_init
    [    3.773321] [mmc-msg] MMC host used card: 0x9, boot card: 0x0, io_card 8
    [    3.775648] [i2c1] incomplete xfer (status: 0x20, dev addr: 0x8)
    [    3.788801] [mmc-msg] sdc0 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
    [    3.795653] [i2c1] incomplete xfer (status: 0x20, dev addr: 0x8)
    [    3.806655] [mmc-msg] sdc0 Probe: base:0xf00b4000 irq:64 sg_cpu:ffdf7000(43c1f000) ret 0.
    [    3.815629] [i2c1] incomplete xfer (status: 0x20, dev addr: 0x8)
    [    3.823113] [mmc-msg] sdc3 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
    [    3.834307] [mmc-msg] sdc3 Probe: base:0xf00b6000 irq:67 sg_cpu:ffddf000(43c1e000) ret 0.
    [    3.843635] [i2c1] incomplete xfer (status: 0x20, dev addr: 0x8)
    [    3.863214] usbcore: registered new interface driver usbhid
    [    3.869519] usbhid: USB HID core driver
    [    3.869696] [i2c1] incomplete xfer (status: 0x20, dev addr: 0x8)
    [    3.880486] zram: num_devices not specified. Using default: 1
    [    3.886891] zram: Creating 1 devices ...
    [    3.893351] ashmem: initialized
    [    3.897084] [i2c1] incomplete xfer (status: 0x20, dev addr: 0x38)
    [    3.904076] logger: created 256K log 'log_main'
    [    3.909637] logger: created 256K log 'log_events'
    [    3.915192] logger: created 256K log 'log_radio'
    [    3.920552] [i2c1] incomplete xfer (status: 0x20, dev addr: 0x38)
    [    3.927512] logger: created 256K log 'log_system'
    [    3.934566] value is 1
    [    3.937603] enter sun7i Audio codec!!!
    [    3.943202] sun7i audio support initialized
    [    3.947963] [i2c1] incomplete xfer (status: 0x20, dev addr: 0x38)
    [    3.948088] type err!
    [    3.948096] value is 0
    [    3.975633] [i2c1] incomplete xfer (status: 0x20, dev addr: 0x38)
    [    3.995606] [i2c1] incomplete xfer (status: 0x20, dev addr: 0x38)
    [    4.015643] [i2c1] incomplete xfer (status: 0x20, dev addr: 0x1c)
    [    4.035607] [i2c1] incomplete xfer (status: 0x20, dev addr: 0x1c)
    [    4.055645] [i2c1] incomplete xfer (status: 0x20, dev addr: 0x1c)
    [    4.075606] [i2c1] incomplete xfer (status: 0x20, dev addr: 0x1c)
    [    4.095616] [i2c1] incomplete xfer (status: 0x20, dev addr: 0x1c)
    [    4.115619] [i2c1] incomplete xfer (status: 0x20, dev addr: 0x1d)
    [    4.135615] [i2c1] incomplete xfer (status: 0x20, dev addr: 0x1d)
    [    4.155618] [i2c1] incomplete xfer (status: 0x20, dev addr: 0x1d)
    [    4.175614] [i2c1] incomplete xfer (status: 0x20, dev addr: 0x1d)
    [    4.195613] [i2c1] incomplete xfer (status: 0x20, dev addr: 0x1d)
    [    4.215617] [i2c1] incomplete xfer (status: 0x20, dev addr: 0x4c)
    [    4.235614] [i2c1] incomplete xfer (status: 0x20, dev addr: 0x4c)
    [    4.255615] [i2c1] incomplete xfer (status: 0x20, dev addr: 0x4c)
    [    4.275614] [i2c1] incomplete xfer (status: 0x20, dev addr: 0x4c)
    [    4.295614] [i2c1] incomplete xfer (status: 0x20, dev addr: 0x4c)
    [    4.315616] [i2c1] incomplete xfer (status: 0x20, dev addr: 0x3d)
    [    4.335614] [i2c1] incomplete xfer (status: 0x20, dev addr: 0x3d)
    [    4.355614] [i2c1] incomplete xfer (status: 0x20, dev addr: 0x3d)
    [    4.375617] [i2c1] incomplete xfer (status: 0x20, dev addr: 0x3d)
    [    4.395624] [i2c1] incomplete xfer (status: 0x20, dev addr: 0x3d)
    [    4.415617] [i2c1] incomplete xfer (status: 0x20, dev addr: 0x22)
    [    4.435615] [i2c1] incomplete xfer (status: 0x20, dev addr: 0x22)
    [    4.455615] [i2c1] incomplete xfer (status: 0x20, dev addr: 0x22)
    [    4.475615] [i2c1] incomplete xfer (status: 0x20, dev addr: 0x22)
    [    4.495614] [i2c1] incomplete xfer (status: 0x20, dev addr: 0x22)
    [    4.515617] [i2c1] incomplete xfer (status: 0x20, dev addr: 0x28)
    [    4.535614] [i2c1] incomplete xfer (status: 0x20, dev addr: 0x28)
    [    4.555623] [i2c1] incomplete xfer (status: 0x20, dev addr: 0x28)
    [    4.555632] sun7i Audio codec successfully loaded..
    [    4.558029] soc-audio soc-audio.0: ASoC machine sndhdmi should use snd_soc_register_card()
    [    4.558813] asoc: sndhdmi <-> sun7i-hdmiaudio.0 mapping ok
    [    4.560142] [I2S]sun7i-i2s cannot find any using configuration for controllers, return directly!
    [    4.560777] [hdcp]sndhdcp cannot find any using configuration for controllers, return directly!
    [    4.560794] [I2S]sun7i_sndi2s cannot find any using configuration for controllers, return directly!
    [    4.563050] soc-audio soc-audio.1: ASoC machine sndspdif should use snd_soc_register_card()
    [    4.563831] asoc: sndspdif <-> sun7i-spdif.0 mapping ok
    [    4.565166] [I2S]sun7i-i2s cannot find any using configuration for controllers, return directly!
    [    4.565919] [I2S]sndi2s cannot find any using configuration for controllers, return directly!
    [    4.565937] [I2S]sun7i_sndi2s cannot find any using configuration for controllers, return directly!
    [    4.565950] func:sun7i_pcm_init(line:953)sun7i-pcm.c
    [    4.565963] func:sun7i_pcm_init(line:964)sun7i-pcm.c,pcm_used:0
    [    4.565972] [PCM]sun7i-i2s cannot find any using configuration for controllers, return directly!
    [    4.565983] func:sun7i_soc_platform_i2s_init(line:803)sun7i-pcmdma.c
    [    4.566630] func:sndpcm_codec_init(line:181)sndpcm.c
    [    4.566647] func:sndpcm_codec_init(line:187)sndpcm.c,pcm_used:0
    [    4.566656] [PCM]sndi2s cannot find any using configuration for controllers, return directly!
    [    4.566673] func:sun7i_sndpcm_init(line:209)sun7i-sndpcm.c,pcm_used:0
    [    4.566682] [I2S]sun7i_sndi2s cannot find any using configuration for controllers, return directly!
    [    4.724621] u32 classifier
    [    4.728001]   Actions configured
    [    4.731791] Netfilter messages via NETLINK v0.30.
    [    4.737122] [i2c1] incomplete xfer (status: 0x20, dev addr: 0x28)
    [    4.737213] nf_conntrack version 0.5.0 (12968 buckets, 51872 max)
    [    4.751255] ctnetlink v0.93: registering with nfnetlink.
    [    4.757652] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
    [    4.765394] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
    [    4.771987] [i2c1] incomplete xfer (status: 0x20, dev addr: 0x28)
    [    4.779281] xt_time: kernel timezone is -0000
    [    4.784330] IPv4 over IPv4 tunneling driver
    [    4.790087] gre: GRE over IPv4 demultiplexor driver
    [    4.795546] ip_gre: GRE over IPv4 tunneling driver
    [    4.800404] [mmc-msg] mmc 0 detect change, present 1
    [    4.806505] [i2c1] incomplete xfer (status: 0x20, dev addr: 0x29)
    [    4.808079] ip_tables: (C) 2000-2006 Netfilter Core Team
    [    4.808294] arp_tables: (C) 2002 David S. Miller
    [    4.808354] TCP: cubic registered
    [    4.808362] Initializing XFRM netlink socket
    [    4.833151] NET: Registered protocol family 10
    [    4.839790] Mobile IPv6
    [    4.842551] ip6_tables: (C) 2000-2006 Netfilter Core Team
    [    4.848663] [i2c1] incomplete xfer (status: 0x20, dev addr: 0x29)
    [    4.848840] IPv6 over IPv4 tunneling driver
    [    4.851707] NET: Registered protocol family 17
    [    4.851764] NET: Registered protocol family 15
    [    4.852001] Bluetooth: RFCOMM TTY layer initialized
    [    4.852024] Bluetooth: RFCOMM socket layer initialized
    [    4.852035] Bluetooth: RFCOMM ver 1.11
    [    4.852044] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
    [    4.852052] Bluetooth: BNEP filters: protocol multicast
    [    4.852063] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
    [    4.852522] L2TP core driver, V2.0
    [    4.852556] PPPoL2TP kernel driver, V2.0
    [    4.852565] L2TP IP encapsulation support (L2TPv3)
    [    4.916973] L2TP netlink interface
    [    4.920790] L2TP ethernet pseudowire support (L2TPv3)
    [    4.926765] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 4
    [    4.935291] ThumbEE CPU extension supported.
    [    4.940089] Registering SWP/SWPB emulation handler
    [    4.945462] [i2c1] incomplete xfer (status: 0x20, dev addr: 0x29)
    [    4.945472] [rfkill]: init no bt used in configuration
    [    4.947758] axp20_buck3: incomplete constraints, leaving on
    [    4.948103] axp20_buck2: incomplete constraints, leaving on
    [    4.948444] axp20_ldo4: incomplete constraints, leaving on
    [    4.948785] axp20_ldo3: incomplete constraints, leaving on
    [    4.949126] axp20_ldo2: incomplete constraints, leaving on
    [    4.949467] axp20_ldo1: incomplete constraints, leaving on
    [    4.949687] sunxi_rtc_gettime, line 39
    [    4.949696] sunxi_rtc_gettime(59): rtc_tm->tm_year:0
    [    4.949707] sunxi_rtc_gettime(61): year < 70, so add 100, to check
    [    4.949719] sunxi_rtc_gettime(67): read time 2000-1-1 0:1:5
    [    5.017393] sunxi-rtc sunxi-rtc: setting system clock to 2000-01-01 00:01:05 UTC (946684865)
    [    5.026981] ALSA device list:
    [    5.030279]   #0: sun7i-CODEC Audio Codec
    [    5.034827]   #1: sndhdmi
    [    5.037772]   #2: sndspdif
    [    5.040809] [i2c1] incomplete xfer (status: 0x20, dev addr: 0x29)
    [    5.048224] Freeing init memory: 204K
    [    5.062107] SELinux: 512 avtab hash slots, 1353 rules.
    [    5.068106] [i2c1] incomplete xfer (status: 0x20, dev addr: 0x29)
    [    5.068801] SELinux: 512 avtab hash slots, 1353 rules.
    [    5.068841] SELinux: 1 users, 2 roles, 291 types, 1 bools, 1 sens, 1024 cats
    [    5.068854] SELinux: 84 classes, 1353 rules
    [    5.070834] SELinux: Completing initialization.
    [    5.070845] SELinux: Setting up existing superblocks.
    [    5.070885] SELinux: initialized (dev sysfs, type sysfs), uses genfs_contexts
    [    5.070916] SELinux: initialized (dev rootfs, type rootfs), uses genfs_contexts
    [    5.070985] SELinux: initialized (dev bdev, type bdev), not configured for labeling
    [    5.071005] SELinux: initialized (dev proc, type proc), uses genfs_contexts
    [    5.071052] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
    [    5.071090] SELinux: initialized (dev devtmpfs, type devtmpfs), uses transition SIDs
    [    5.071857] SELinux: initialized (dev debugfs, type debugfs), uses genfs_contexts
    [    5.072097] SELinux: initialized (dev sockfs, type sockfs), uses task SIDs
    [    5.072120] SELinux: initialized (dev pipefs, type pipefs), uses task SIDs
    [    5.072138] SELinux: initialized (dev anon_inodefs, type anon_inodefs), not configured for labeling
    [    5.072161] SELinux: initialized (dev devpts, type devpts), uses transition SIDs
    [    5.072191] SELinux: initialized (dev selinuxfs, type selinuxfs), uses genfs_contexts
    [    5.072289] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
    [    5.072336] SELinux: initialized (dev sysfs, type sysfs), uses genfs_contexts
    [    5.235652] [i2c1] incomplete xfer (status: 0x20, dev addr: 0xf)
    [    5.255636] [i2c1] incomplete xfer (status: 0x20, dev addr: 0xf)
    [    5.275622] [i2c1] incomplete xfer (status: 0x20, dev addr: 0xf)
    [    5.295461] [mmc-msg] sdc0 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
    [    5.305439] [mmc-msg] sdc0 power on
    [    5.309337] [i2c1] incomplete xfer (status: 0x20, dev addr: 0xf)
    [    5.325089] type=1403 audit(946684865.860:2): policy loaded auid=4294967295 ses=4294967295
    [    5.334419] [mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
    [    5.334727] SELinux: Loaded policy from /sepolicy
    [    5.338854] type=1404 audit(946684865.880:3): enforcing=1 old_enforcing=0 auid=4294967295 ses=4294967295
    [    5.360856] [i2c1] incomplete xfer (status: 0x20, dev addr: 0xf)
    [    5.385618] [i2c1] incomplete xfer (status: 0x20, dev addr: 0x15)
    [    5.405603] [i2c1] incomplete xfer (status: 0x20, dev addr: 0x15)
    [    5.425609] [i2c1] incomplete xfer (status: 0x20, dev addr: 0x15)
    [    5.437774] [mmc-err] smc 0 err, cmd 52, RTO
    [    5.443437] [mmc-err] smc 0 err, cmd 52, RTO
    [    5.448329] [mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
    [    5.458870] [i2c1] incomplete xfer (status: 0x20, dev addr: 0x15)
    [    5.461202] [mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
    [    5.463362] [mmc-err] smc 0 err, cmd 5, RTO
    [    5.464189] [mmc-err] smc 0 err, cmd 5, RTO
    [    5.465014] [mmc-err] smc 0 err, cmd 5, RTO
    [    5.465840] [mmc-err] smc 0 err, cmd 5, RTO
    [    5.466492] [mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
    [    5.466538] [mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
    [    5.468943] [mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
    [    5.498077] [mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing SD-HS(SDR25) dt B
    [    5.498123] [mmc-msg] sdc0 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 1 timing SD-HS(SDR25) dt B
    [    5.553250] [mmc-msg] sdc0 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 4 timing SD-HS(SDR25) dt B
    [    5.564013] mmc0: new high speed SDHC card at address 0001
    [    5.571032] mmcblk0: mmc0:0001 SD16G 14.6 GiB
    [    5.576135] [i2c1] incomplete xfer (status: 0x20, dev addr: 0x15)
    [    5.578628] mmcblk0: p1 p2 p3 < p5 p6 p7 p8 p9 p10 p11 p12 p13 >
    [    5.615902] [i2c1] incomplete xfer (status: 0x20, dev addr: 0x1e)
    [    5.635655] [i2c1] incomplete xfer (status: 0x20, dev addr: 0x1e)
    [    5.655653] [i2c1] incomplete xfer (status: 0x20, dev addr: 0x1e)
    [    5.675664] [i2c1] incomplete xfer (status: 0x20, dev addr: 0x1e)
    [    5.695680] [i2c1] incomplete xfer (status: 0x20, dev addr: 0x1e)
    [    5.715674] [i2c1] incomplete xfer (status: 0x20, dev addr: 0x1f)
    [    5.735670] [i2c1] incomplete xfer (status: 0x20, dev addr: 0x1f)
    [    5.755672] [i2c1] incomplete xfer (status: 0x20, dev addr: 0x1f)
    [    5.775666] [i2c1] incomplete xfer (status: 0x20, dev addr: 0x1f)
    [    5.795663] [i2c1] incomplete xfer (status: 0x20, dev addr: 0x1f)
    [    5.925501] get_device_para_value:get subname:ilitek_ts error! val.val:0
    [    5.933088] get_detect_list: script_get_item err.support_number = 7.
    [    5.940310] get_device_para_value:get subname:aw5306_ts error! val.val:0
    [    5.947906] get_detect_list: script_get_item err.support_number = 6.
    [    5.955637] [i2c2] incomplete xfer (status: 0x20, dev addr: 0x38)
    [    5.975612] [i2c2] incomplete xfer (status: 0x20, dev addr: 0x38)
    [    5.995648] [i2c2] incomplete xfer (status: 0x20, dev addr: 0x38)
    [    6.015641] [i2c2] incomplete xfer (status: 0x20, dev addr: 0x38)
    [    6.035628] [i2c2] incomplete xfer (status: 0x20, dev addr: 0x38)
    [    6.055878] [i2c2] incomplete xfer (status: 0x20, dev addr: 0x5d)
    [    6.075644] [i2c2] incomplete xfer (status: 0x20, dev addr: 0x5d)
    [    6.095644] [i2c2] incomplete xfer (status: 0x20, dev addr: 0x5d)
    [    6.115646] [i2c2] incomplete xfer (status: 0x20, dev addr: 0x5d)
    [    6.135641] [i2c2] incomplete xfer (status: 0x20, dev addr: 0x5d)
    [    6.155893] [i2c2] incomplete xfer (status: 0x20, dev addr: 0x40)
    [    6.173666] CPU1: shutdown
    [    6.178709] [i2c2] incomplete xfer (status: 0x20, dev addr: 0x40)
    [    6.215702] [i2c2] incomplete xfer (status: 0x20, dev addr: 0x40)
    [    6.235660] [i2c2] incomplete xfer (status: 0x20, dev addr: 0x40)
    [    6.255636] [i2c2] incomplete xfer (status: 0x20, dev addr: 0x40)
    [    6.275696] [i2c2] incomplete xfer (status: 0x20, dev addr: 0x14)
    [    6.295647] [i2c2] incomplete xfer (status: 0x20, dev addr: 0x14)
    [    6.315677] [i2c2] incomplete xfer (status: 0x20, dev addr: 0x14)
    [    6.335648] [i2c2] incomplete xfer (status: 0x20, dev addr: 0x14)
    [    6.355652] [i2c2] incomplete xfer (status: 0x20, dev addr: 0x14)
    [    6.375652] [i2c2] incomplete xfer (status: 0x20, dev addr: 0x76)
    [    6.395650] [i2c2] incomplete xfer (status: 0x20, dev addr: 0x76)
    [    6.415652] [i2c2] incomplete xfer (status: 0x20, dev addr: 0x76)
    [    6.435649] [i2c2] incomplete xfer (status: 0x20, dev addr: 0x76)
    [    6.455670] [i2c2] incomplete xfer (status: 0x20, dev addr: 0x76)
    [    6.475648] [i2c2] incomplete xfer (status: 0x20, dev addr: 0x39)
    [    6.495634] [i2c2] incomplete xfer (status: 0x20, dev addr: 0x39)
    [    6.515628] [i2c2] incomplete xfer (status: 0x20, dev addr: 0x39)
    [    6.535666] [i2c2] incomplete xfer (status: 0x20, dev addr: 0x39)
    [    6.555637] [i2c2] incomplete xfer (status: 0x20, dev addr: 0x39)
    [    6.575652] [i2c2] incomplete xfer (status: 0x20, dev addr: 0x41)
    [    6.585480]
    [    6.585485]
    [    6.585489] insmod_device_driver
    [    6.585493]
    [    6.594008] [sw_udc]: [i2c2] incomplete xfer (status: 0x20, dev addr: 0x41)
    [    6.610822] sw_usb_device_enable start
    [    6.614984] [sw_udc]: usb_vbase = 0xf1c13000
    [    6.628074] [i2c2] incomplete xfer (status: 0x20, dev addr: 0x41)
    [    6.634849] [sw_udc]: sram_vbase = 0xf1c00000
    [    6.639748] [sw_udc]: open_usb_clock
    [    6.655476] [i2c2] incomplete xfer (status: 0x20, dev addr: 0x41)
    [    6.675613] [i2c2] incomplete xfer (status: 0x20, dev addr: 0x41)
    [    6.699489] [sw_udc]: usbd_stop_work
    [    6.703504] [sw_udc]: sw_usb_device_enable end
    [    7.017288] init (1): /proc/1/oom_adj is deprecated, please use /proc/1/oom_score_adj instead.
    [    7.321680] init: /dev/hw_random not found
    [    7.344490] [NAND][NAND]nand init start, nand_used_flag is 1
    [    7.356020] [NAND]nand_cache_level err! 0[NAND]nand init start
    [    7.362624] [NAND] nand clk request start
    [    7.367139] [NAND] nand clk request ok!
    [    7.371422] [NAND DMA] request dma success
    [    7.375988] [NAND DMA] set fulldone_cb success
    [    7.388163] busybox used greatest stack depth: 6192 bytes left
    [    7.485646] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
    [    7.494477] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
    [    7.515695] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
    [    7.526669] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
    [    7.535575] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
    [    7.543968] SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
    [    7.565608] SELinux: initialized (dev cgroup, type cgroup), uses genfs_contexts
    [    7.591755] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: (null)
    [    7.600915] SELinux: initialized (dev mmcblk0p7, type ext4), uses xattr
    [    7.609868] EXT4-fs (mmcblk0p11): VFS: Can't find ext4 filesystem
    [    7.645592] fs_mgr: begin to format ext4 buffer : /dev/block/mmcblk0p11
    [    9.496741] make_ext4fs used greatest stack depth: 5608 bytes left
    [    9.503995] fs_mgr: finish format to ext4 :/dev/block/mmcblk0p11
    [    9.510590] fs_mgr: Running /system/bin/e2fsck on /dev/block/by-name/cache
    [    9.576310] e2fsck: e2fsck 1.41.14 (22-Dec-2010)
    [    9.581535] e2fsck: /dev/block/by-name/cache: clean, 11/40960 files, 5256/163840 blocks
    [    9.607628] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,barrier=1
    [    9.618743] SELinux: initialized (dev mmcblk0p11, type ext4), uses xattr
    [    9.627690] EXT4-fs (mmcblk0p8): VFS: Can't find ext4 filesystem
    [    9.655591] fs_mgr: begin to format ext4 buffer : /dev/block/mmcblk0p8
    [   11.094320] fs_mgr: finish format to ext4 :/dev/block/mmcblk0p8
    [   11.101049] fs_mgr: Running /system/bin/e2fsck on /dev/block/by-name/data
    [   11.294351] CPU1: Booted secondary processor
    [   11.310619] e2fsck: e2fsck 1.41.14 (22-Dec-2010)
    [   11.315836] e2fsck: /dev/block/by-name/data: clean, 11/40960 files, 5256/163840 blocks
    [   11.345160] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: nomblk_io_submit,barrier=1,noauto_da_alloc
    [   11.357699] SELinux: initialized (dev mmcblk0p8, type ext4), uses xattr
    [   11.572297] [DISP]capture_module_init
    [   11.577662] [DISP]capture_probe
    [   11.581447] [DISP]==capture finish==
    [   11.607827] [LCD] lcd_module_init
    [   12.024918] hdcp: Unknown symbol __stack_chk_guard (err 0)
    [   12.031221] hdcp: Unknown symbol __stack_chk_fail (err 0)
    [   12.207165] mali_platform_init(182): get ahb_mali handle success!
    [   12.213953] mali_platform_init(190): get mali handle success!
    [   12.220392] mali_platform_init(197): get ve_pll handle success!
    [   12.227006] mali_platform_init(204): set mali clock source success!
    [   12.233970] mali_platform_init(208): get ve pll rate 336000000!
    [   12.240572] mali_platform_init(211): get mali_para->mali_used success! mali_use 1
    [   12.248906] mali_platform_init(215): get mali_para->mali_clkdiv success! clk_drv 1
    [   12.257335] mali_platform_init(224): mali_clk_div 1
    [   12.262757] mali_platform_init(230): set mali clock rate success!
    [   12.269544] mali_platform_init(236): reset release success!
    [   12.275745] Mali: enable mali clock
    [   12.279625] Mali: sun7i_mali_platform_device_register() sucess!!
    [   12.286424] axp20_buck3: Failed to create debugfs directory
    [   12.293004] mali_freq_init(693): get mali_para->mali_used success! mali_use 1
    [   12.301113] Mali: Mali 222 JetCui
    [   12.307123] Mali: Mali device driver loaded
    [   12.316653] [uart]: uart0 LCR & BAUD changed, reset controller...
    [   12.324038] init: width = 1024
    [   12.327530] init: height = 600
    [   12.330932] init: s.st_size = 2457600
    [   12.371677] init: dont need format /dev/block/by-name/UDISK
    [   12.409656] init: /dev/hw_random not found
    [   12.428376] healthd: wakealarm_init: timerfd_create failed
    [   12.450779] binder: 1360:1360 transaction failed 29189, size 0-0
    [   12.453828] init: cannot find '/system/etc/install-recovery.sh', disabling 'flash_recovery'
    [   12.487534] sw_device: module is already loaded
    [   12.732074] [i2c1] incomplete xfer (status: 0x20, dev addr: 0x21)
    [   12.824822] [i2c1] incomplete xfer (status: 0x20, dev addr: 0x3c)
    [   12.836691] iptables used greatest stack depth: 5568 bytes left
    [   12.936012] [CSI]Welcome to CSI driver
    [   12.940237] [CSI]csi_init
    [   12.995191] i2c i2c-1: Invalid 7-bit I2C address 0x00
    [   13.001028] [CSI_ERR]Error registering v4l2 subdevice,input_num = 0
    [   13.009165] [CSI_ERR]failed to install
    [   13.119969] usbcore: registered new interface driver asix
    [   13.158986] usbcore: registered new interface driver qf9700
    [   13.187809] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
    [   13.248225] usbcore: registered new interface driver rtl8150
    [   13.302754] usbcore: registered new interface driver cdc_ether
    [   13.317332] init: property 'sys.powerctl' doesn't exist while expanding '${sys.powerctl}'
    [   13.354483] init: powerctl: cannot expand '${sys.powerctl}'
    [   13.377526] init: property 'sys.sysctl.extra_free_kbytes' doesn't exist while expanding '${sys.sysctl.extra_free_kbytes}'
    [   13.408259] ###########close all layers 0, hdl 103
    [   13.414998] init: cannot expand '${sys.sysctl.extra_free_kbytes}' while writing to '/proc/sys/vm/extra_free_kbytes'
    [   13.431339] android_usb: already disabled
    [   13.437688] init: using deprecated syntax for specifying property 'sys.usb.config', use ${name} instead
    [   13.455547] [DISP WRN] file:drivers/video/sun7i/disp/dev_fb.c,line:1266:    =======GGG=====timeout
    [   13.468785] [uart]: uart0 LCR & BAUD changed, reset controller...
    [   13.501166] ep_matches, wrn: endpoint already claimed, ep(0xc07f47cc, 0xef292cc0, ep1in-bulk)
    [   13.537014] [sw_udc]: sw_udc_pullup, is_on = 1
    [   13.566226] [sw_udc]: CONFIG_USB_GADGET_DUALSPEED
    [   13.571465] [sw_udc]: usbd_start_work
    [   13.606157] init: using deprecated syntax for specifying property 'sys.usb.config', use ${name} instead
    [   13.620922] [AXP]init charger->rest_vol = 100
    [   13.630989] [sw_udc]: IRQ: suspend
    [   13.634783] [sw_udc]: ERR: usb speed is unkown
    [   13.640649] ****************Set_Rset_Cap=100***********
    shell@wing-k70:/ $ [   13.737692] [sw_udc]: IRQ: reset
    [   13.741320] [sw_udc]: irq: reset happen, throw away all urb
    [   13.756994] ###########close all layers 0, hdl 103
    [   13.893755] [sw_udc]:
    [   13.896203] +++++++++++++++++++++++++++++++++++++
    [   13.901627] [sw_udc]: usb enter high speed.
    [   13.906386] [sw_udc]:
    [   13.908829] +++++++++++++++++++++++++++++++++++++
    [   13.917269] android_work: sent uevent USB_STATE=CONNECTED
    [   13.923302] [sw_udc]: IRQ: reset
    [   13.926909] [sw_udc]: irq: reset happen, throw away all urb
    [   14.071786] [sw_udc]: Set address 1
    [   14.123213] android_usb gadget: high-speed config #1: android
    [   14.129661] [sw_udc]: ep enable: ep1(0xc07f47cc, ep1in-bulk, 128, 512), fifo(512, 1024, 0)
    [   14.138864] [sw_udc]: ep enable: ep1(0xc07f47cc, ep1in-bulk, 128, 512)
    [   14.146162] [sw_udc]: ep enable: ep1(0xc07f4818, ep1out-bulk, 0, 512), fifo(1536, 1024, 0)
    [   14.149148] android_work: sent uevent USB_STATE=CONFIGURED
    [   14.161538] [sw_udc]: ep enable: ep1(0xc07f4818, ep1out-bulk, 0, 512)
    [   14.170387] [sw_udc]: alloc request: ep(0xc07f47cc, ep1in-bulk, 512), req(0xecd7f640)
    [   14.179220] [sw_udc]: alloc request: ep(0xc07f4818, ep1out-bulk, 512), req(0xecd7ff40)
    [   14.188321] [sw_udc]: alloc request: ep(0xc07f47cc, ep1in-bulk, 512), req(0xecd7fc40)
    [   14.197993] [sw_udc]: alloc request: ep(0xc07f4818, ep1out-bulk, 512), req(0xed53a8c0)
    [   17.353005] dexopt used greatest stack depth: 5408 bytes left
    [   19.199273] WRN1240(drivers/usb/sun7i_usb/udc/sw_udc.c):handle_ep0: ep0 setup end
    [   19.207840] nuke: ep num is 0
    [   20.322795] dexopt used greatest stack depth: 5384 bytes left
    [   36.560391] Thread-6 used greatest stack depth: 5328 bytes left
    [   38.817887] warning: `zygote' uses 32-bit capabilities (legacy support in
    GMT+8, 2024-12-19 10:49 , Processed in 0.136304 second(s), 18 queries , MemCache On.
