查看: 2473|回复: 0
PCB设计中专业英译术语之形状与尺寸
  • 签到天数: 18 天
    [LV.4]偶尔看看III
    发表于 2018-5-10 14:45:45 | 显示全部楼层 |阅读模式
      1. 导线(信道):conduction (track)
      2. 导线(体)宽度:conductor width
      3. 导线距离:conductor spacing
      4. 导线层:conductor layer
      5. 导线宽度/间距:conductor line/space
      6. 第一导线层:conductor layer No.1
      7. 圆形盘:round pad
      8. 方形盘:square pad
      9. 菱形盘:diamond pad
      10. 长方形焊盘:oblong pad
      11. 子弹形盘:bullet pad
      12. 泪滴盘:teardrop pad
      13. 雪人盘:snowman pad
      14. V形盘:V-shaped pad
      15. 环形盘:annular pad
      16. 非圆形盘:non-circular pad
      17. 隔离盘:isolation pad
      18. 非功能连接盘:monfunctional pad
      19. 偏置连接盘:offset land
      20. 腹(背)裸盘:back-bard land
      21. 盘址:anchoring spaur
      22. 连接盘图形:land pattern
      23. 连接盘网格阵列:land grid array
      24. 孔环:annular ring
      25. 组件孔:component hole
      26. 安装孔:mounting hole
      27. 支撑孔:supported hole
      28. 非支撑孔:unsupported hole
      29. 导通孔:via
      30. 镀通孔:plated through hole (PTH)
      31. 余隙孔:access hole
      32. 盲孔:blind via (hole)
      33. 埋孔:buried via hole
      34. /盲孔:buried /blind via
      35. 任意层内部导通孔:any layer inner via hole (ALIVH)
      36. 全部钻孔:all drilled hole
      37. 定位孔:toaling hole
      38. 无连接盘孔:landless hole
      39. 中间孔:interstitial hole
      40. 无连接盘导通孔:landless via hole
      41. 引导孔:pilot hole
      42. 端接全隙孔:terminal clearomee hole
      43. 准表面间镀覆孔:quasi-interfacing plated-through hole
      44. 准尺寸孔:dimensioned hole
      45. 在连接盘中导通孔:via-in-pad
      46. 孔位:hole location
      47. 孔密度:hole density
      48. 孔图:hole pattern
      49. 钻孔图:drill drawing
      50. 装配图:assembly drawing
      51. 印制板组装图:printed board assembly drawing
    52. 参考基准:datum referan
    以上即是PCB设计中专业英译术语之形状与尺寸
    GMT+8, 2024-11-27 04:31 , Processed in 0.126676 second(s), 18 queries , MemCache On.
