查看: 2297|回复: 0
PCB设计中专业英译术语之基材
  • 签到天数: 18 天
    [LV.4]偶尔看看III
    发表于 2018-4-28 11:19:02 | 显示全部楼层 |阅读模式
      PCB设计中专业英译术语之基材:
      1. 基材:base material
      2. 层压板:laminate
      3. 覆金属箔基材:metal-clad bade material
      4. 覆铜箔层压板:copper-clad laminate (CCL)
      5. 单面覆铜箔层压板:single-sided copper-clad laminate
      6. 双面覆铜箔层压板:double-sided copper-clad laminate
      7. 复合层压板:composite laminate
      8. 薄层压板:thin laminate
      9. 金属芯覆铜箔层压板:metal core copper-clad laminate
      10. 金属基覆铜层压板:metal base copper-clad laminate
      11. 挠性覆铜箔绝缘薄膜:flexible copper-clad dielectric film
      12. 基体材料:basis material
      13. 预浸材料:prepreg
      14. 粘结片:bonding sheet
      15. 预浸粘结片:preimpregnated bonding sheer
      16. 环氧玻璃基板:epoxy glass substrate
      17. 加成法用层压板:laminate for additive process
      18. 预制内层覆箔板:mass lamination panel
      19. 内层芯板:core material
      20. 催化板材:catalyzed board ,coated catalyzed laminate
      21. 涂胶催化层压板:adhesive-coated catalyzed laminate
      22. 涂胶无催层压板:adhesive-coated uncatalyzed laminate
      23. 粘结层:bonding layer
      24. 粘结膜:film adhesive
      25. 涂胶粘剂绝缘薄膜:adhesive coated dielectric film
      26. 无支撑胶粘剂膜:unsupported adhesive film
      27. 覆盖层:cover layer (cover lay)
      28. 增强板材:stiffener material
      29. 铜箔面:copper-clad surface
      30. 去铜箔面:foil removal surface
      31. 层压板面:unclad laminate surface
      32. 基膜面:base film surface
      33. 胶粘剂面:adhesive faec
      34. 原始光洁面:plate finish
      35. 粗面:matt finish
      36. 纵向:length wise direction
      37. 模向:cross wise direction
      38. 剪切板:cut to size panel
      39. 酚醛纸质覆铜箔板:phenolic cellulose paper copper-clad laminates(phenolic/paper CCL)
      40. 环氧纸质覆铜箔板:epoxide cellulose paper copper-clad laminates (epoxy/paper CCL)
      41. 环氧玻璃布基覆铜箔板:epoxide woven glass fabric copper-clad laminates
      42. 环氧玻璃布纸复合覆铜箔板:epoxide cellulose paper core, glass cloth surfaces copper-clad laminates
      43. 环氧玻璃布玻璃纤维复合覆铜箔板:epoxide non woven/woven glass reinforced copper-clad laminates
      44. 聚酯玻璃布覆铜箔板:ployester woven glass fabric copper-clad laminates
      45. 聚酰亚胺玻璃布覆铜箔板:polyimide woven glass fabric copper-clad laminates
      46. 双马来酰亚胺三嗪环氧玻璃布覆铜箔板:bismaleimide/triazine/epoxide woven glass fabric copper-clad lamimates
      47. 环氧合成纤维布覆铜箔板:epoxide synthetic fiber fabric copper-clad laminates
      48. 聚四乙烯玻璃纤维覆铜箔板:teflon/fiber glass copper-clad laminates
      49. 超薄型层压板:ultra thin laminate
      50. 陶瓷基覆铜箔板:ceramics base copper-clad laminates
      51. 紫外线阻挡型覆铜箔板:UV blocking copper-clad laminates
      以上即是PCB设计中专业英译术语之基材
    GMT+8, 2024-11-27 05:38 , Processed in 0.134537 second(s), 18 queries , MemCache On.
