TA的每日心情 | 开心 前天 22:46 |
签到天数: 596 天 连续签到: 3 天 [LV.9]以坛为家II
17. Lmbench测试结果
[BeagleBone Black] 连载目录
Lmbench测试结果:- [lmbench3.0 results for Linux beaglebone 4.4.91-ti-r133 #1 SMP Tue Oct 10 05:18:08 UTC 2017 armv7l GNU/Linux]
- [LMBENCH_VER: 3.0-a9]
- [BENCHMARK_HARDWARE: YES]
- [BENCHMARK_OS: YES]
- [ALL: 512 1k 2k 4k 8k 16k 32k 64k 128k 256k 512k 1m 2m 4m 8m 16m 32m 64m 128m 256m]
- [DISKS: ]
- [DISK_DESC: ]
- [ENOUGH: 5000]
- [FAST: ]
- [FASTMEM: NO]
- [FILE: /samba/XXX]
- [FSDIR: /samba]
- [HALF: 512 1k 2k 4k 8k 16k 32k 64k 128k 256k 512k 1m 2m 4m 8m 16m 32m 64m 128m]
- [INFO: INFO.beaglebone]
- [LINE_SIZE: 64]
- [LOOP_O: 0.00000109]
- [MB: 340]
- [MHZ: 997 MHz, 1.0030 nanosec clock]
- [MOTHERBOARD: ]
- [NETWORKS: ]
- [PROCESSORS: 1]
- [REMOTE: ]
- [SLOWFS: NO]
- [OS: armv7l-linux-gnu]
- [SYNC_MAX: 1]
- [LMBENCH_SCHED: DEFAULT]
- [TIMING_O: 1]
- [LMBENCH VERSION: 3.0-20171231]
- [USER: root]
- [HOSTNAME: beaglebone]
- [NODENAME: beaglebone]
- [SYSNAME: Linux]
- [PROCESSOR: unknown]
- [MACHINE: armv7l]
- [RELEASE: 4.4.91-ti-r133]
- [VERSION: #1 SMP Tue Oct 10 05:18:08 UTC 2017]
- [Sun Dec 31 18:50:25 UTC 2017]
- [ 18:50:25 up 3 min, 1 user, load average: 0.41, 0.78, 0.39]
- [net: Kernel Interface table]
- [net: Iface MTU RX-OK RX-ERR RX-DRP RX-OVR TX-OK TX-ERR TX-DRP TX-OVR Flg]
- [net: eth0 1500 336 0 0 0 161 0 0 0 BMdRU]
- [if: eth0: flags=-28605<UP,BROADCAST,RUNNING,MULTICAST,DYNAMIC> mtu 1500]
- [if: inet 192.168.8.22 netmask 255.255.255.0 broadcast 192.168.8.255]
- [if: inet6 fe80::caa0:30ff:feaa:4533 prefixlen 64 scopeid 0x20<link>]
- [if: ether c8:a0:30:aa:45:33 txqueuelen 1000 (Ethernet)]
- [if: RX packets 336 bytes 28898 (28.2 KiB)]
- [if: RX errors 0 dropped 0 overruns 0 frame 0]
- [if: TX packets 161 bytes 25286 (24.6 KiB)]
- [if: TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0]
- [if: device interrupt 181 ]
- [if: ]
- [net: lo 65536 164 0 0 0 164 0 0 0 LRU]
- [if: lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536]
- [if: inet 127.0.0.1 netmask 255.0.0.0]
- [if: inet6 ::1 prefixlen 128 scopeid 0x10<host>]
- [if: loop txqueuelen 1 (Local Loopback)]
- [if: RX packets 164 bytes 13200 (12.8 KiB)]
- [if: TX packets 164 bytes 13200 (12.8 KiB)]
- [if: ]
- [net: usb0 1500 1301 0 4 0 1859 0 0 0 BMRU]
- [if: usb0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500]
- [if: inet 192.168.7.2 netmask 255.255.255.252 broadcast 192.168.7.3]
- [if: inet6 fe80::caa0:30ff:feaa:4535 prefixlen 64 scopeid 0x20<link>]
- [if: ether c8:a0:30:aa:45:35 txqueuelen 1000 (Ethernet)]
- [if: RX packets 1301 bytes 71962 (70.2 KiB)]
- [if: RX errors 0 dropped 4 overruns 0 frame 0]
- [if: TX packets 1859 bytes 373526 (364.7 KiB)]
- [if: ]
- [net: usb1 1500 0 0 0 0 0 0 0 0 BMU]
- [if: usb1: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500]
- [if: inet 192.168.6.2 netmask 255.255.255.252 broadcast 192.168.6.3]
- [if: ether c8:a0:30:aa:45:38 txqueuelen 1000 (Ethernet)]
- [if: RX packets 0 bytes 0 (0.0 B)]
- [if: TX packets 0 bytes 0 (0.0 B)]
- [if: ]
- [mount: sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)]
- [mount: proc on /proc type proc (rw,nosuid,nodev,noexec,relatime)]
- [mount: udev on /dev type devtmpfs (rw,nosuid,relatime,size=221764k,nr_inodes=55441,mode=755)]
- [mount: devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)]
- [mount: tmpfs on /run type tmpfs (rw,nosuid,noexec,relatime,size=49876k,mode=755)]
- [mount: /dev/mmcblk0p1 on / type ext4 (rw,noatime,errors=remount-ro,data=ordered)]
- [mount: securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)]
- [mount: tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)]
- [mount: tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)]
- [mount: tmpfs on /sys/fs/cgroup type tmpfs (rw,mode=755)]
- [mount: cgroup on /sys/fs/cgroup/systemd type cgroup (rw,nosuid,nodev,noexec,relatime,xattr,release_agent=/lib/systemd/systemd-cgroups-agent,name=systemd)]
- [mount: cgroup on /sys/fs/cgroup/net_cls,net_prio type cgroup (rw,nosuid,nodev,noexec,relatime,net_cls,net_prio)]
- [mount: cgroup on /sys/fs/cgroup/devices type cgroup (rw,nosuid,nodev,noexec,relatime,devices)]
- [mount: cgroup on /sys/fs/cgroup/memory type cgroup (rw,nosuid,nodev,noexec,relatime,memory)]
- [mount: cgroup on /sys/fs/cgroup/pids type cgroup (rw,nosuid,nodev,noexec,relatime,pids,release_agent=/run/cgmanager/agents/cgm-release-agent.pids)]
- [mount: cgroup on /sys/fs/cgroup/blkio type cgroup (rw,nosuid,nodev,noexec,relatime,blkio)]
- [mount: cgroup on /sys/fs/cgroup/cpu,cpuacct type cgroup (rw,nosuid,nodev,noexec,relatime,cpu,cpuacct)]
- [mount: cgroup on /sys/fs/cgroup/freezer type cgroup (rw,nosuid,nodev,noexec,relatime,freezer)]
- [mount: cgroup on /sys/fs/cgroup/cpuset type cgroup (rw,nosuid,nodev,noexec,relatime,cpuset,clone_children)]
- [mount: cgroup on /sys/fs/cgroup/perf_event type cgroup (rw,nosuid,nodev,noexec,relatime,perf_event,release_agent=/run/cgmanager/agents/cgm-release-agent.perf_event)]
- [mount: systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=28,pgrp=1,timeout=0,minproto=5,maxproto=5,direct)]
- [mount: mqueue on /dev/mqueue type mqueue (rw,relatime)]
- [mount: debugfs on /sys/kernel/debug type debugfs (rw,relatime)]
- [mount: configfs on /sys/kernel/config type configfs (rw,relatime)]
- [mount: fusectl on /sys/fs/fuse/connections type fusectl (rw,relatime)]
- [mount: tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=49872k,mode=700,uid=1000,gid=1000)]
- Simple syscall: 0.4510 microseconds
- Simple read: 1.3660 microseconds
- Simple write: 0.7794 microseconds
- Simple stat: 4.5899 microseconds
- Simple fstat: 1.4257 microseconds
- Simple open/close: 9.8458 microseconds
- Select on 10 fd's: 1.9916 microseconds
- Select on 100 fd's: 10.0945 microseconds
- Select on 250 fd's: 23.3154 microseconds
- Select on 500 fd's: 45.6864 microseconds
- Select on 10 tcp fd's: 2.4756 microseconds
- Select on 100 tcp fd's: 30.8361 microseconds
- Select on 250 tcp fd's: 76.7945 microseconds
- Select on 500 tcp fd's: 153.8889 microseconds
- Signal handler installation: 1.4601 microseconds
- Signal handler overhead: 14.0975 microseconds
- Protection fault: 1.0410 microseconds
- Pipe latency: 45.2808 microseconds
- AF_UNIX sock stream latency: 57.0309 microseconds
- Process fork+exit: 1429.7500 microseconds
- Process fork+execve: 1655.2500 microseconds
- sh: 1: /var/tmp/lmbench/hello: not found
- Process fork+/bin/sh -c: 7274.0000 microseconds
- integer bit: 1.01 nanoseconds
- integer add: 1.01 nanoseconds
- integer mul: 0.05 nanoseconds
- integer div: 73.18 nanoseconds
- integer mod: 23.18 nanoseconds
- int64 bit: 1.02 nanoseconds
- uint64 add: 1.21 nanoseconds
- int64 mul: 0.05 nanoseconds
- int64 div: 189.35 nanoseconds
- int64 mod: 51.35 nanoseconds
- float add: 8.96 nanoseconds
- float mul: 10.05 nanoseconds
- float div: 33.17 nanoseconds
- double add: 8.96 nanoseconds
- double mul: 11.06 nanoseconds
- double div: 57.27 nanoseconds
- float bogomflops: 97.65 nanoseconds
- double bogomflops: 120.30 nanoseconds
- integer bit parallelism: 1.79
- integer add parallelism: 1.60
- integer mul parallelism: 24.00
- integer div parallelism: 1.21
- integer mod parallelism: 1.09
- int64 bit parallelism: 1.00
- int64 add parallelism: 1.20
- int64 mul parallelism: 19.50
- int64 div parallelism: 1.00
- int64 mod parallelism: 1.24
- float add parallelism: 1.00
- float mul parallelism: 1.00
- float div parallelism: 1.00
- double add parallelism: 1.00
- double mul parallelism: 1.00
- double div parallelism: 1.00
- File /samba/XXX write bandwidth: 5025 KB/sec
- Pagefaults on /samba/XXX: 2.5300 microseconds
- "mappings
- 0.524288 43
- 1.048576 72
- 2.097152 112
- 4.194304 205
- 8.388608 372
- 16.777216 726
- 33.554432 1504
- 67.108864 3098
- 134.217728 6525
- 268.435456 13768
- "File system latency
- 0k 76 10284 20295
- 1k 45 5560 14578
- 4k 46 8232 14382
- 10k 32 5456 11552
- Cannot register service: RPC: Unable to receive; errno = Success
- unable to register (XACT_PROG, XACT_VERS, udp).
- UDP latency using localhost: 105.5105 microseconds
- TCP latency using localhost: 145.7459 microseconds
- localhost: RPC: Port mapper failure - RPC: Unable to receive
- localhost: RPC: Remote system error - Connection refused
- (null): RPC: Port mapper failure - RPC: Unable to receive
- TCP/IP connection cost to localhost: 986.6667 microseconds
- Socket bandwidth using localhost
- 0.000001 0.16 MB/sec
- 0.000064 8.94 MB/sec
- 0.000128 15.63 MB/sec
- 0.000256 28.55 MB/sec
- 0.000512 51.83 MB/sec
- 0.001024 68.91 MB/sec
- 0.001437 78.43 MB/sec
- 10.000000 98.59 MB/sec
- Avg xfer: 3.2KB, 41.8KB in 21.9560 millisecs, 1.90 MB/sec
- AF_UNIX sock stream bandwidth: 207.62 MB/sec
- Pipe bandwidth: 314.40 MB/sec
- "read bandwidth
- 0.000512 121.39
- 0.001024 212.21
- 0.002048 334.74
- 0.004096 485.33
- 0.008192 568.22
- 0.016384 581.59
- 0.032768 508.86
- 0.065536 535.24
- 0.131072 489.60
- 0.262144 264.30
- 0.524288 216.74
- 1.05 212.74
- 2.10 211.49
- 4.19 213.52
- 8.39 204.25
- 16.78 208.88
- 33.55 212.14
- 67.11 211.34
- 134.22 213.35
- 268.44 208.98
- "read open2close bandwidth
- 0.000512 30.75
- 0.001024 60.27
- 0.002048 111.65
- 0.004096 193.74
- 0.008192 293.86
- 0.016384 378.79
- 0.032768 407.55
- 0.065536 425.99
- 0.131072 322.41
- 0.262144 217.62
- 0.524288 198.52
- 1.05 197.25
- 2.10 193.75
- 4.19 203.91
- 8.39 203.90
- 16.78 209.68
- 33.55 211.37
- 67.11 210.31
- 134.22 205.46
- 268.44 213.37
- "Mmap read bandwidth
- 0.000512 1813.50
- 0.001024 1888.97
- 0.002048 1930.29
- 0.004096 1951.71
- 0.008192 1956.06
- 0.016384 1955.28
- 0.032768 1948.16
- 0.065536 1654.06
- 0.131072 1497.11
- 0.262144 667.82
- 0.524288 337.49
- 1.05 289.86
- 2.10 277.00
- 4.19 277.68
- 8.39 276.49
- 16.78 276.58
- 33.55 276.09
- 67.11 276.82
- 134.22 276.71
- 268.44 276.76
- "Mmap read open2close bandwidth
- 0.000512 14.81
- 0.001024 28.95
- 0.002048 57.08
- 0.004096 111.03
- 0.008192 199.33
- 0.016384 333.58
- 0.032768 469.51
- 0.065536 587.56
- 0.131072 530.27
- 0.262144 292.08
- 0.524288 218.61
- 1.05 208.46
- 2.10 213.67
- 4.19 223.70
- 8.39 230.37
- 16.78 233.23
- 33.55 235.40
- 67.11 235.97
- 134.22 236.80
- 268.44 235.79
- "libc bcopy unaligned
- 0.000512 996.11
- 0.001024 930.43
- 0.002048 941.73
- 0.004096 941.88
- 0.008192 920.02
- 0.016384 931.17
- 0.032768 929.29
- 0.065536 920.71
- 0.131072 909.03
- 0.262144 508.03
- 0.524288 270.25
- 1.05 236.27
- 2.10 234.42
- 4.19 229.70
- 8.39 234.13
- 16.78 244.62
- 33.55 247.64
- 67.11 250.47
- 134.22 251.68
- "libc bcopy aligned
- 0.000512 993.59
- 0.001024 946.85
- 0.002048 939.88
- 0.004096 941.84
- 0.008192 937.83
- 0.016384 935.55
- 0.032768 928.46
- 0.065536 921.38
- 0.131072 890.50
- 0.262144 625.07
- 0.524288 280.82
- 1.05 250.20
- 2.10 246.84
- 4.19 247.10
- 8.39 247.35
- 16.78 249.09
- 33.55 251.87
- 67.11 252.17
- 134.22 251.99
- Memory bzero bandwidth
- 0.000512 1536.74
- 0.001024 1537.95
- 0.002048 1528.11
- 0.004096 1560.28
- 0.008192 1536.37
- 0.016384 1515.61
- 0.032768 1508.27
- 0.065536 1509.17
- 0.131072 1508.02
- 0.262144 1505.49
- 0.524288 1505.76
- 1.05 1509.01
- 2.10 1504.95
- 4.19 1504.95
- 8.39 1506.57
- 16.78 1505.22
- 33.55 1499.77
- 67.11 1501.52
- 134.22 1499.92
- 268.44 1497.45
- "unrolled bcopy unaligned
- 0.000512 1536.09
- 0.001024 1535.45
- 0.002048 1538.13
- 0.004096 1535.63
- 0.008192 1540.78
- 0.016384 1534.25
- 0.032768 1492.38
- 0.065536 1494.98
- 0.131072 1475.53
- 0.262144 688.69
- 0.524288 126.98
- 1.05 215.22
- 2.10 211.11
- 4.19 209.40
- 8.39 211.32
- 16.78 216.29
- 33.55 217.47
- 67.11 127.31
- 134.22 216.88
- "unrolled partial bcopy unaligned
- 0.000512 1536.37
- 0.001024 1536.56
- 0.002048 1528.17
- 0.004096 1535.91
- 0.008192 1514.35
- 0.016384 1540.07
- 0.032768 1505.12
- 0.065536 1495.66
- 0.131072 1482.82
- 0.262144 632.11
- 0.524288 221.06
- 1.05 227.21
- 2.10 223.22
- 4.19 221.16
- 8.39 224.59
- 16.78 230.28
- 33.55 232.39
- 67.11 199.47
- 134.22 235.44
- Memory read bandwidth
- 0.000512 1937.76
- 0.001024 1955.01
- 0.002048 1964.15
- 0.004096 1972.64
- 0.008192 1964.54
- 0.016384 1968.45
- 0.032768 1963.83
- 0.065536 1654.45
- 0.131072 1515.43
- 0.262144 804.12
- 0.524288 339.56
- 1.05 288.59
- 2.10 276.45
- 4.19 277.90
- 8.39 278.34
- 16.78 276.05
- 33.55 277.22
- 67.11 276.77
- 134.22 277.05
- 268.44 277.09
- Memory partial read bandwidth
- 0.000512 7184.61
- 0.001024 7410.37
- 0.002048 7583.28
- 0.004096 7642.31
- 0.008192 7315.61
- 0.016384 7492.86
- 0.032768 7501.33
- 0.065536 4241.85
- 0.131072 3597.56
- 0.262144 1045.02
- 0.524288 357.14
- 1.05 288.51
- 2.10 279.51
- 4.19 279.64
- 8.39 280.45
- 16.78 277.65
- 33.55 276.68
- 67.11 278.90
- 134.22 278.96
- 268.44 279.28
- Memory write bandwidth
- 0.000512 1536.64
- 0.001024 1532.39
- 0.002048 1536.46
- 0.004096 1538.34
- 0.008192 1536.37
- 0.016384 1504.34
- 0.032768 1509.09
- 0.065536 1507.93
- 0.131072 1507.39
- 0.262144 1508.47
- 0.524288 1504.41
- 1.05 1508.74
- 2.10 1507.12
- 4.19 1507.66
- 8.39 1507.39
- 16.78 1505.90
- 33.55 1506.91
- 67.11 1502.63
- 134.22 1500.38
- 268.44 1497.07
- Memory partial write bandwidth
- 0.000512 1536.64
- 0.001024 1537.01
- 0.002048 1534.52
- 0.004096 1532.87
- 0.008192 1538.02
- 0.016384 1516.76
- 0.032768 1503.97
- 0.065536 1513.10
- 0.131072 1508.25
- 0.262144 1506.30
- 0.524288 1504.95
- 1.05 1507.39
- 2.10 1508.74
- 4.19 1508.74
- 8.39 1508.20
- 16.78 1506.98
- 33.55 1505.02
- 67.11 1502.53
- 134.22 1500.43
- 268.44 1500.11
- Memory partial read/write bandwidth
- 0.000512 4936.45
- 0.001024 5067.55
- 0.002048 5130.78
- 0.004096 5170.37
- 0.008192 5132.90
- 0.016384 5170.13
- 0.032768 5101.85
- 0.065536 3424.68
- 0.131072 3098.92
- 0.262144 956.90
- 0.524288 292.90
- 1.05 249.22
- 2.10 245.97
- 4.19 241.77
- 8.39 243.51
- 16.78 244.46
- 33.55 244.77
- 67.11 244.68
- 134.22 244.92
- 268.44 244.90
- "size=0k ovr=5.82
- 2 17.17
- 4 17.85
- 8 19.27
- 16 21.18
- 24 22.69
- 32 26.85
- 64 33.48
- 96 36.59
- "size=4k ovr=8.28
- 2 17.65
- 4 18.57
- 8 19.71
- 16 27.95
- 24 35.23
- 32 41.26
- 64 53.65
- 96 56.60
- "size=8k ovr=10.46
- 2 17.87
- 4 20.45
- 8 22.18
- 16 38.19
- 24 53.13
- 32 61.48
- 64 70.54
- 96 71.89
- "size=16k ovr=15.81
- 2 18.28
- 4 21.37
- 8 31.00
- 16 72.13
- 24 93.50
- 32 97.11
- 64 101.50
- 96 100.79
- "size=32k ovr=26.72
- 2 20.19
- 4 29.87
- 8 94.07
- 16 147.59
- 24 155.38
- 32 159.16
- 64 157.61
- 96 157.92
- "size=64k ovr=54.95
- 2 38.12
- 4 154.55
- 8 235.18
- 16 258.43
- 24 260.47
- 32 257.93
- 64 260.07
- 96 259.98
- tlb: 30 pages
- Memory load parallelism
- 0.001024 3.00
- 0.002048 3.00
- 0.004096 3.00
- 0.008192 3.00
- 0.016384 3.00
- 0.032768 3.18
- 0.065536 1.02
- 0.131072 1.03
- 0.262144 1.00
- 0.524288 1.00
- 1.048576 1.00
- 2.097152 1.00
- 4.194304 1.00
- 8.388608 1.00
- 16.777216 1.00
- 33.554432 1.00
- 67.108864 1.00
- 134.217728 1.00
- 268.435456 1.00
- STREAM copy latency: 36.37 nanoseconds
- STREAM copy bandwidth: 439.93 MB/sec
- STREAM scale latency: 33.72 nanoseconds
- STREAM scale bandwidth: 474.44 MB/sec
- STREAM add latency: 42.08 nanoseconds
- STREAM add bandwidth: 570.34 MB/sec
- STREAM triad latency: 44.47 nanoseconds
- STREAM triad bandwidth: 539.70 MB/sec
- STREAM2 fill latency: 5.33 nanoseconds
- STREAM2 fill bandwidth: 1501.54 MB/sec
- STREAM2 copy latency: 36.24 nanoseconds
- STREAM2 copy bandwidth: 441.55 MB/sec
- STREAM2 daxpy latency: 71.41 nanoseconds
- STREAM2 daxpy bandwidth: 336.08 MB/sec
- STREAM2 sum latency: 19.99 nanoseconds
- STREAM2 sum bandwidth: 400.22 MB/sec
- Memory load latency
- "stride=16
- 0.00049 3.033
- 0.00098 3.033
- 0.00195 3.025
- 0.00293 3.024
- 0.00391 3.019
- 0.00586 3.018
- 0.00781 3.017
- 0.01172 3.016
- 0.01562 3.027
- 0.02344 3.025
- 0.03125 3.026
- 0.04688 4.214
- 0.06250 4.485
- 0.09375 4.859
- 0.12500 5.124
- 0.18750 6.649
- 0.25000 14.496
- 0.37500 34.970
- 0.50000 43.819
- 0.75000 51.039
- 1.00000 53.501
- 1.50000 56.536
- 2.00000 56.758
- 3.00000 57.104
- 4.00000 57.167
- 6.00000 57.243
- 8.00000 57.136
- 12.00000 57.168
- 16.00000 57.188
- 24.00000 57.196
- 32.00000 57.097
- 48.00000 57.169
- 64.00000 57.140
- 96.00000 57.156
- 128.00000 57.145
- 192.00000 57.200
- 256.00000 57.223
- "stride=32
- 0.00049 3.035
- 0.00098 3.033
- 0.00195 3.033
- 0.00293 3.033
- 0.00391 3.023
- 0.00586 3.023
- 0.00781 3.020
- 0.01172 3.019
- 0.01562 3.019
- 0.02344 3.153
- 0.03125 3.036
- 0.04688 7.761
- 0.06250 8.799
- 0.09375 9.887
- 0.12500 10.771
- 0.18750 13.501
- 0.25000 30.126
- 0.37500 67.889
- 0.50000 86.176
- 0.75000 100.071
- 1.00000 104.635
- 1.50000 110.106
- 2.00000 111.110
- 3.00000 111.382
- 4.00000 111.614
- 6.00000 111.496
- 8.00000 111.618
- 12.00000 111.665
- 16.00000 111.471
- 24.00000 111.380
- 32.00000 111.496
- 48.00000 111.361
- 64.00000 111.590
- 96.00000 111.532
- 128.00000 111.624
- 192.00000 111.672
- 256.00000 111.692
- "stride=64
- 0.00049 3.034
- 0.00098 3.033
- 0.00195 3.033
- 0.00293 3.033
- 0.00391 3.035
- 0.00586 3.036
- 0.00781 3.023
- 0.01172 3.024
- 0.01562 3.023
- 0.02344 3.020
- 0.03125 3.030
- 0.04688 7.724
- 0.06250 8.940
- 0.09375 9.936
- 0.12500 11.078
- 0.18750 28.379
- 0.25000 45.664
- 0.37500 137.372
- 0.50000 169.491
- 0.75000 200.197
- 1.00000 210.126
- 1.50000 213.720
- 2.00000 213.620
- 3.00000 213.912
- 4.00000 213.969
- 6.00000 213.970
- 8.00000 214.153
- 12.00000 213.954
- 16.00000 214.542
- 24.00000 214.236
- 32.00000 214.108
- 48.00000 214.093
- 64.00000 214.372
- 96.00000 214.086
- 128.00000 214.518
- 192.00000 214.017
- 256.00000 214.548
- "stride=128
- 0.00049 3.034
- 0.00098 3.033
- 0.00195 3.033
- 0.00293 3.035
- 0.00391 3.033
- 0.00586 3.033
- 0.00781 3.034
- 0.01172 3.034
- 0.01562 3.023
- 0.02344 3.027
- 0.03125 3.038
- 0.04688 7.709
- 0.06250 8.887
- 0.09375 9.899
- 0.12500 11.706
- 0.18750 12.481
- 0.25000 33.801
- 0.37500 130.261
- 0.50000 172.094
- 0.75000 198.967
- 1.00000 207.957
- 1.50000 212.964
- 2.00000 213.517
- 3.00000 213.608
- 4.00000 213.639
- 6.00000 213.664
- 8.00000 213.700
- 12.00000 213.638
- 16.00000 213.829
- 24.00000 213.601
- 32.00000 213.951
- 48.00000 213.463
- 64.00000 213.620
- 96.00000 213.602
- 128.00000 214.030
- 192.00000 214.111
- 256.00000 214.143
- "stride=256
- 0.00049 3.033
- 0.00098 3.033
- 0.00195 3.033
- 0.00293 3.033
- 0.00391 3.033
- 0.00586 3.033
- 0.00781 3.033
- 0.01172 3.033
- 0.01562 3.033
- 0.02344 3.034
- 0.03125 3.027
- 0.04688 7.717
- 0.06250 8.882
- 0.09375 9.943
- 0.12500 12.868
- 0.18750 14.725
- 0.25000 79.161
- 0.37500 132.806
- 0.50000 172.180
- 0.75000 201.576
- 1.00000 210.498
- 1.50000 214.411
- 2.00000 214.746
- 3.00000 214.766
- 4.00000 214.779
- 6.00000 214.698
- 8.00000 214.794
- 12.00000 214.749
- 16.00000 214.712
- 24.00000 214.543
- 32.00000 214.590
- 48.00000 214.592
- 64.00000 214.849
- 96.00000 214.654
- 128.00000 214.917
- 192.00000 215.085
- 256.00000 215.184
- "stride=512
- 0.00049 3.033
- 0.00098 3.033
- 0.00195 3.033
- 0.00293 3.033
- 0.00391 3.033
- 0.00586 3.033
- 0.00781 3.034
- 0.01172 3.033
- 0.01562 3.034
- 0.02344 3.034
- 0.03125 3.034
- 0.04688 7.688
- 0.06250 9.045
- 0.09375 9.892
- 0.12500 15.257
- 0.18750 15.972
- 0.25000 24.344
- 0.37500 137.675
- 0.50000 176.518
- 0.75000 204.266
- 1.00000 214.237
- 1.50000 218.620
- 2.00000 219.106
- 3.00000 219.258
- 4.00000 219.144
- 6.00000 219.213
- 8.00000 219.361
- 12.00000 219.361
- 16.00000 219.367
- 24.00000 219.165
- 32.00000 219.360
- 48.00000 219.287
- 64.00000 219.647
- 96.00000 219.773
- 128.00000 220.200
- 192.00000 220.871
- 256.00000 220.729
- "stride=1024
- 0.00098 3.034
- 0.00195 3.033
- 0.00293 3.034
- 0.00391 3.033
- 0.00586 3.033
- 0.00781 3.034
- 0.01172 3.033
- 0.01562 3.034
- 0.02344 3.033
- 0.03125 3.114
- 0.04688 7.670
- 0.06250 9.066
- 0.09375 9.928
- 0.12500 20.138
- 0.18750 20.743
- 0.25000 52.301
- 0.37500 142.844
- 0.50000 185.518
- 0.75000 215.615
- 1.00000 225.309
- 1.50000 230.244
- 2.00000 231.045
- 3.00000 231.028
- 4.00000 230.901
- 6.00000 230.937
- 8.00000 231.006
- 12.00000 230.911
- 16.00000 230.942
- 24.00000 230.876
- 32.00000 230.939
- 48.00000 230.974
- 64.00000 231.027
- 96.00000 231.709
- 128.00000 232.561
- 192.00000 233.410
- 256.00000 233.804
- Random load latency
- "stride=16
- 0.00049 3.034
- 0.00098 3.033
- 0.00195 3.025
- 0.00293 3.023
- 0.00391 3.020
- 0.00586 3.019
- 0.00781 3.019
- 0.01172 3.017
- 0.01562 3.028
- 0.02344 3.024
- 0.03125 5.286
- 0.04688 8.444
- 0.06250 11.132
- 0.09375 11.704
- 0.12500 52.163
- 0.18750 88.586
- 0.25000 115.699
- 0.37500 192.816
- 0.50000 238.319
- 0.75000 272.611
- 1.00000 283.910
- 1.50000 297.132
- 2.00000 304.877
- 3.00000 326.558
- 4.00000 344.586
- 6.00000 376.001
- 8.00000 397.797
- 12.00000 420.563
- 16.00000 428.081
- 24.00000 432.616
- 32.00000 430.614
- 48.00000 427.171
- 64.00000 425.405
- 96.00000 422.331
- 128.00000 420.500
- 192.00000 419.546
- 256.00000 418.472
- [Sun Dec 31 19:26:11 UTC 2017]
复制代码 附件和上面贴的一摸一样:
beaglebone.txt
(19.53 KB, 下载次数: 1)
