查看: 4937|回复: 1
[经验] fireduino和arduino Due
  • 签到天数: 827 天
    发表于 2017-5-16 20:45:01 | 显示全部楼层 |阅读模式
    接上一篇帖子
    四周年庆-【赚周年币】fireduino-基于labview的双机通信-系统调试-爱板网论坛 - 电子工程师学习交流园地 https://www.cirmall.com/bbs/thread-59347-1-1.html
    准备做一个如下功能的东西
    要求:温度传感器检测到某一温度警戒值,触发单片机控制摄像头开始拍摄视频15s,然后存储至存储设备(SD卡或U盘),然后通过蓝牙将视频传输至手机。可以不涉及视频压缩技术。
    为什么不直接把视频考到手机呢?因为我想发朋友圈,比如说当我朋友圈看到soso同学更新状态时,我也更新,发一条状态,紧随其后,表示和她的形影不离。
    目前摄像使用OV7670,一直想试用arduino due,但是未能如愿,这个板子一直没到手。于是想到了之前的fireduino,两个32位的MCU PK下,
    due使用ATSAM3X8EA,参数如下
    封装 / 箱体:LQFP-144
    核心:
    ARM Cortex M3
    数据总线宽度:
    32 bit
    最大时钟频率:
    84 MHz
    程序存储器大小:
    512 kB
    数据 RAM 大小:
    64 kB
    工作电源电压:
    1.8 V
    最大工作温度:
    + 85 C
    处理器系列:
    SAM3X
    I/O 电压:3.3 V
    最小工作温度:- 40 C
    电源电压-最大:1.95 V
    电源电压-最小:1.62 V
    单位重量:1.290 g
    官网介绍
    Features
    Core
    • ARM® Cortex®-M3 revision 2.0 running at up to 84MHz
    Memories
    • 16kb ROM with embedded bootloader routines (UART, USB) and IAP routines
    • Static Memory Controller (SMC): SRAM, NOR, NAND support. NAND Flash controller with 4kb RAM buffer and ECC
    • SDRAM Controller
    System
    • Embedded voltage regulator for single supply operation
    • POR, BOD, and Watchdog for safe reset
    • Quartz or ceramic resonator oscillators: 3 to 20MHz main and optional low power 32.768kHz for RTC or device clock
    • High precision 8/12MHz factory trimmed internal RC oscillator with 4MHz Default Frequency for fast device startup
    • Slow Clock Internal RC oscillator as permanent clock for device clock in low power mode
    • One PLL for device clock and one dedicated PLL for USB 2.0 High Speed Mini Host/Device
    • Temperature sensor
    • Up to 17 peripheral DMA (PDC) channels and 6-channel central DMA plus dedicated DMA for High-Speed USB Mini Host/Device and Ethernet MAC
    Low Power Modes
    • Sleep and Backup modes, down to 2.5μA in Backup mode
    • Backup domain: VDDBU pin, RTC, eight 32-bit backup registers
    • Ultra Low-power RTC
    Peripherals
    • USB 2.0 Device/Mini Host: 480Mbps, 4kb FIFO, up to 10 bidirectional Endpoints, dedicated DMA
    • Up to 8-channel 16-bit PWM (PWMC) with Complementary Output, Fault Input, 12-bit Dead Time Generator Counter for Motor Control
    • One Ethernet MAC 10/100 (EMAC) with dedicated DMA
    • Two CAN Controller with eight Mailboxes
    • One True Random Number Generator (TRNG)
    同系列比较
    fireduino使用Rockchip NanoD处理器,关于它的介绍详见下面帖子,都是M3内核
    四周年庆-【赚周年币】fireduino-介绍Rockchip NanoD-爱板网论坛 - 电子工程师学习交流园地 https://www.cirmall.com/bbs/thread-59208-1-1.html
    虽然fireduino是双核,但是fireduino引出的引脚着实不多,总有一种感觉:Rockchip NanoD似乎没有SAM3X强
    这个项目能做多少做多少,加油
    发表于 2017-5-17 09:51:30 | 显示全部楼层
    这个项目能做多少做多少,加油
    GMT+8, 2025-1-28 00:54 , Processed in 0.128943 second(s), 20 queries , MemCache On.
