楼主: sky-Hawk where
[项目] STM32 系列 刀刀 迷你四轴 有兴趣可以一起来玩 楼主考完了
    擦汗
    2020-3-19 13:22
  • 签到天数: 805 天
    发表于 2013-4-28 22:55:07 | 显示全部楼层
    强烈关注
    发表于 2013-5-2 23:53:49 | 显示全部楼层
    软件部分建议参考
    http://code.google.com/p/afrodevices/
    AfroFlight32
    STM32F103-based simple multirotor flight controlle
    Introduction
    Simple, small, fun flight controller. Several available firmware choices:
    MultiWii-dev port to STM32 ("baseflight" in SVN)
    Written from scratch "correct" firmware using various attitude estimators, Kalman filtering, etc ("baseflightplus" in SVN)
    Chinese 'FreeFlight' firmware. Autolevel/gyro, limited functionality. Supported on rev0 to rev3 hardware. Not supported on rev4 hardware.
    Hardware
    36x36mm 2 layer pcb, 30.5mm mounting pattern
    STM32F103CxT6 CPU (32bit ARM Cortex M3, 72MHz, 64K/128K flash. Pin compatible with upcoming STM32F3 Cortex M4)
    Invensense MPU3050 3-axis gyro (rev0 to rev3)
    Invensense MPU6050 3-axis gyro (rev4)
    Analog ADXL345 digital accelerometer (rev0 to rev3, removed in rev4)
    FreeScale MMA8452Q digital accelerometer (rev3 to rev4)
    Honeywell HMC5883L digital compass
    Bosch-Sensortec BMP085 pressure sensor (rev0 to rev3, removed in rev4)
    MEAS-SPEC MS5611-01BA03 pressure sensor (rev4)
    6 + 8 PWM I/O can remap as input or output for RC/CPPM/Motors/Servos
    second UART accessible for Spektrum Satellite RX or GPS
    CPPM (up to 12 channels) RC input
    8 channel standard PWM RC input
    PWM (50..1kHz) motor output for up to 6 motors, can be remapped with other pins for 8 motors + camera stabilization
    Onboard USB connector for telemetry and firmware update
    Battery voltage monitoring and low-voltage alarm
    Buzzer for alarm/user notification
    Status LEDs
    发表于 2013-5-3 23:07:46 | 显示全部楼层
    我兄弟一直念叨这个东西啊。。。
  • 签到天数: 12 天
    发表于 2013-5-11 10:59:15 | 显示全部楼层
    楼主啥专业的啊
  • 签到天数: 2 天
    发表于 2013-6-5 17:18:15 | 显示全部楼层
    楼主,对四轴我也非常感兴趣,问一下啊, 你的马达和风扇用什么?
  • 签到天数: 724 天
    发表于 2013-6-23 21:21:05 | 显示全部楼层
    不错,赞一个!
  • 签到天数: 42 天
    [LV.5]常住居民I
    发表于 2013-7-2 12:59:01 | 显示全部楼层
    谢谢楼主,学习了
  • 签到天数: 980 天
    发表于 2013-7-8 11:13:15 | 显示全部楼层
    楼主威武  跟进楼主  欢迎大家一起研究学习
    擦汗
    2016-7-28 09:42
  • 签到天数: 292 天
    发表于 2013-7-8 23:40:59 | 显示全部楼层
    顶了 哈哈  很厉害的样子
  • 签到天数: 9 天
    发表于 2013-7-17 20:03:25 | 显示全部楼层
    mark,,,,楼主,好样的,顶起········
    GMT+8, 2025-1-11 19:43 , Processed in 0.209202 second(s), 33 queries , MemCache On.
