查看: 2313|回复: 0
[评测分享] 【树莓派5 测评】 + 12.UVC扩展功能测试(zmj)
    慵懒
    2025-1-12 17:53
  • 签到天数: 259 天
    发表于 2024-4-30 16:38:45 | 显示全部楼层 |阅读模式
    UVC的有很多好玩的地方,继续推一篇关于UVC的功能测试。
    1.        借助lsusb检测UVC更多信息
    以前没有着重留意“lsusb”的扩展功能,这次发现它的功能十分强大。
    1. //------指令lsusb
    2. //---基础功能:lsusb
    3. Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
    4. Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
    5. Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
    6. Bus 001 Device 004: ID 1b3f:2008 Generalplus Technology Inc. Usb Audio Device
    7. Bus 001 Device 003: ID 0c45:6362 Microdia USB 2.0 Camera
    8. Bus 001 Device 002: ID 1a40:0801 Terminus Technology Inc. USB 2.0 Hub
    9. Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
    10. //---检查接口设备速率:lsusb -t
    11. /:  Bus 04.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 5000M
    12. /:  Bus 03.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/2p, 480M
    13. /:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 5000M
    14. /:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/2p, 480M
    15.     |__ Port 2: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
    16.         |__ Port 1: Dev 3, If 0, Class=Video, Driver=uvcvideo, 480M
    17.         |__ Port 1: Dev 3, If 1, Class=Video, Driver=uvcvideo, 480M
    18.         |__ Port 3: Dev 4, If 2, Class=Audio, Driver=snd-usb-audio, 12M
    19.         |__ Port 3: Dev 4, If 0, Class=Audio, Driver=snd-usb-audio, 12M
    20.         |__ Port 3: Dev 4, If 3, Class=Human Interface Device, Driver=usbhid, 12M
    21. //---查看更详细信息:lsusb -v -s 001:003
    22. Bus 001 Device 003: ID 0c45:6362 Microdia USB 2.0 Camera
    23. Couldn't open device, some information will be missing
    24. Device Descriptor:
    25.   bLength                18
    26.   bDescriptorType         1
    27.   bcdUSB               2.00
    28.   bDeviceClass          239 Miscellaneous Device
    29.   bDeviceSubClass         2
    30.   bDeviceProtocol         1 Interface Association
    31.   bMaxPacketSize0        64
    32.   idVendor           0x0c45 Microdia
    33.   idProduct          0x6362
    34.   bcdDevice            0.00
    35.   iManufacturer           2 Sonix Technology Co., Ltd.
    36.   iProduct                1 USB 2.0 Camera
    37.   iSerial                 0
    38.   bNumConfigurations      1
    39.   ...
    40. //------Log信息
    41. zhaomeijing@raspberrypi5:~/workspace/09_uvc$ lsusb
    42. Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
    43. Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
    44. Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
    45. Bus 001 Device 004: ID 1b3f:2008 Generalplus Technology Inc. Usb Audio Device
    46. Bus 001 Device 003: ID 0c45:6362 Microdia USB 2.0 Camera
    47. Bus 001 Device 002: ID 1a40:0801 Terminus Technology Inc. USB 2.0 Hub
    48. Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
    49. zhaomeijing@raspberrypi5:~/workspace/09_uvc$ lsusb -h
    50. Usage: lsusb [options]...
    51. List USB devices
    52.   -v, --verbose
    53.       Increase verbosity (show descriptors)
    54.   -s [[bus]:][devnum]
    55.       Show only devices with specified device and/or
    56.       bus numbers (in decimal)
    57.   -d vendor:[product]
    58.       Show only devices with the specified vendor and
    59.       product ID numbers (in hexadecimal)
    60.   -D device
    61.       Selects which device lsusb will examine
    62.   -t, --tree
    63.       Dump the physical USB device hierarchy as a tree
    64.   -V, --version
    65.       Show version of program
    66.   -h, --help
    67.       Show usage and help
    68. zhaomeijing@raspberrypi5:~/workspace/09_uvc$ lsusb -t
    69. /:  Bus 04.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 5000M
    70. /:  Bus 03.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/2p, 480M
    71. /:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 5000M
    72. /:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/2p, 480M
    73.     |__ Port 2: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
    74.         |__ Port 1: Dev 3, If 0, Class=Video, Driver=uvcvideo, 480M
    75.         |__ Port 1: Dev 3, If 1, Class=Video, Driver=uvcvideo, 480M
    76.         |__ Port 3: Dev 4, If 2, Class=Audio, Driver=snd-usb-audio, 12M
    77.         |__ Port 3: Dev 4, If 0, Class=Audio, Driver=snd-usb-audio, 12M
    78.         |__ Port 3: Dev 4, If 3, Class=Human Interface Device, Driver=usbhid, 12M
    79. zhaomeijing@raspberrypi5:~/workspace/09_uvc$ lsusb -v -s 001:003
    80. Bus 001 Device 003: ID 0c45:6362 Microdia USB 2.0 Camera
    81. Couldn't open device, some information will be missing
    82. Device Descriptor:
    83.   bLength                18
    84.   bDescriptorType         1
    85.   bcdUSB               2.00
    86.   bDeviceClass          239 Miscellaneous Device
    87.   bDeviceSubClass         2
    88.   bDeviceProtocol         1 Interface Association
    89.   bMaxPacketSize0        64
    90.   idVendor           0x0c45 Microdia
    91.   idProduct          0x6362
    92.   bcdDevice            0.00
    93.   iManufacturer           2 Sonix Technology Co., Ltd.
    94.   iProduct                1 USB 2.0 Camera
    95.   iSerial                 0
    96.   bNumConfigurations      1
    97.     Interface Descriptor:
    98.       bLength                 9
    99.       bDescriptorType         4
    100.       bInterfaceNumber        1
    101.       bAlternateSetting       6
    102.       bNumEndpoints           1
    103.       bInterfaceClass        14 Video
    104.       bInterfaceSubClass      2 Video Streaming
    105.       bInterfaceProtocol      0
    106.       iInterface              0
    107.       Endpoint Descriptor:
    108.         bLength                 7
    109.         bDescriptorType         5
    110.         bEndpointAddress     0x81  EP 1 IN
    111.         bmAttributes            5
    112.           Transfer Type            Isochronous
    113.           Synch Type               Asynchronous
    114.           Usage Type               Data
    115.         wMaxPacketSize     0x1400  3x 1024 bytes
    116.         bInterval               1
    117. zhaomeijing@raspberrypi5:~/workspace/09_uvc$
    2.        借助OpenCV实现便捷的RGB与灰度转换
    下面的代码可捕捉UVC生成的视频流,用BGR颜色和灰色模式展示。
    1. //------测试指令
    2. python3 ./uvc_gray.py
    3. 注:测试界面按“Q”退出,或者指令界面“Ctrl + C”退出。
    4. //------Log信息
    5. zhaomeijing@raspberrypi5:~/workspace/09_uvc$ python3 ./uvc_gray.py
    6. [ WARN:0@1.217] global ./modules/videoio/src/cap_gstreamer.cpp (1405) open OpenCV | GStreamer warning: Cannot query video position: status=0, value=-1, duration=-1
    8. //------源码:OpenCV实现UVC灰度转换
    9. import numpy as np
    10. import cv2
    11. cap = cv2.VideoCapture(0)
    12. cap.set(3,640) # set Width
    13. cap.set(4,480) # set Height
    14.
    15. while(True):
    16.     ret, frame = cap.read()
    17.     frame = cv2.flip(frame, -1) # Flip camera vertically
    18.     gray = cv2.cvtColor(frame, cv2.COLOR_BGR2GRAY)
    19.
    20.     cv2.imshow('frame', frame)
    21.     cv2.imshow('gray', gray)
    22.
    23.     k = cv2.waitKey(30) & 0xff
    24.     if k == 27: # press 'ESC' to quit
    25.         break
    26. cap.release()
    27. cv2.destroyAllWindows()
    //------测试结果:
    3.        人脸检测
    人脸检测有多种方式实现,此处通过python实现。
    1. //------测试指令
    2. python3 ./face_detect.py
    4. //------源码
    5. import cv2
    6. # 导入人脸级联分类器,'.xml'文件里包含训练出来的人脸特征
    7. #face_engine = cv2.CascadeClassifier('haarcascade_frontalface_alt.xml')
    8. face_engine = cv2.CascadeClassifier('/usr/share/opencv4/haarcascades/haarcascade_frontalface_alt.xml')
    9. #/usr/share/opencv4/haarcascades/haarcascade_frontalface_alt.xml
    10. # 导入人眼级联分类器,'.xml'文件里包含训练出来的人眼特征
    11. eye_cascade = cv2.CascadeClassifier('/usr/share/opencv4/haarcascades/haarcascade_eye.xml')
    12. #/usr/share/opencv4/haarcascades/haarcascade_eye.xml
    13. # 调用摄像头(读取/ect中的驱动);这里索引是0的原因是添加过驱动了;
    14. cap = cv2.VideoCapture(0)
    15. while (True):
    16.     # 获取摄像头拍摄到的画面
    17.     # 会得到两个参数,一个是否捕捉到图像(True/False),另一个为存放每帧的图像
    18.     ret, frame = cap.read()  # 读取一帧图像
    19.     # 每帧图像放大1.1倍,重复检测10次
    20.     faces = face_engine.detectMultiScale(frame, 1.1, 10)  # 得到人脸,可能不止一个
    21.     img = frame  # 复制
    22.     print(img)
    23.     for (x, y, w, h) in faces:
    24.         # 画出人脸框,蓝色,画笔宽度为2
    25.         img = cv2.rectangle(img, (x, y), (x + w, y + h), (255, 0, 0), 2)
    26.         # 框选出人脸区域,在人脸区域而不是全图中进行人眼检测,节省计算资源
    27.         face_area = img[y:y + h, x:x + w]  # 人脸区域
    28.         eyes = eye_cascade.detectMultiScale(face_area, 1.1, 5)
    29.         # 用人眼级联分类器在人脸区域进行人眼识别,返回的eyes为眼睛坐标列表
    30.         for (ex, ey, ew, eh) in eyes:
    31.             # 画出人眼框,绿色,画笔宽度为1
    32.             cv2.rectangle(face_area, (ex, ey), (ex + ew, ey + eh), (0, 255, 0), 1)
    33.     # 实时展示效果画面
    34.     #cv2.imshow(''frame'', img)
    35.     cv2.imshow('frame', img)
    36.     # 每5毫秒监听一次键盘动作
    37.     if cv2.waitKey(5) & 0xFF == ord('q'):  # 当按下“q”键时退出人脸检测
    38.         break
    39. # 最后,关闭所有窗口
    40. cap.release()
    41. cv2.destroyAllWindows()  # 释放资源
    42. //------Log信息
    43. zhaomeijing@raspberrypi5:~/workspace/09_uvc$ python3 ./face_detect.py
    44. Xlib:  extension "DRI2" missing on display "localhost:11.0".
    45. Xlib:  extension "DRI2" missing on display "localhost:11.0".
    46. [ WARN:0@3.464] global ./modules/videoio/src/cap_gstreamer.cpp (1405) open OpenCV | GStreamer warning: Cannot query video position: status=0, value=-1, duration=-1
    47. [[[253 253 252]
    48.   [253 253 252]
    49.   [253 253 252]
    50.   ...
    51.   [253 253 252]
    52.   [253 253 252]
    53.   [253 253 252]]
    54.   ...
    55. [[[253 253 252]
    56.   [253 253 252]
    57.   [253 253 252]
    58.   ...
    59.   [249 255 231]
    60.   [248 255 220]
    61.   [205 225 174]]
    62.
    63. [[ 76  90  70]
    64.   [ 80  90  73]
    65.   [ 86  93  80]
    66.   ...
    67.   [ 46  50  45]
    68.   [ 46  48  43]
    69.   [ 44  46  41]]
    70. [[ 80  93  75]
    71.   [ 78  90  75]
    72.   [ 83  92  79]
    73.   ...
    74.   [ 46  50  45]
    75.   [ 44  49  47]
    76.   [ 42  47  46]]
    77. [[ 82  92  75]
    78.   [ 82  91  77]
    79.   [ 78  88  80]
    80.   ...
    81.   [ 44  51  44]
    82.   [ 42  47  45]
    83.   [ 42  47  46]]]
    84.
    85. zhaomeijing@raspberrypi5:~/workspace/09_uvc$
    //------测试结果:
    //------end
    GMT+8, 2025-1-29 06:07 , Processed in 0.110386 second(s), 16 queries , MemCache On.
