查看: 2298|回复: 0
[评测分享] 【树莓派5 测评】 + 03.CPU、DDR与蓝牙测试(zmj)
    慵懒
    2025-1-12 17:53
  • 签到天数: 259 天
    发表于 2024-3-27 11:25:57 | 显示全部楼层 |阅读模式
    1.        CPU性能测试    .
    1.1        查看CPU信息
    树莓派5采用了四核 2.4 GHz Cortex-A76 Arm CPU,支持32-bit/64-bit两种模式指令集。运行时CPU的低功耗模式CPU工作频率1.5GHz,高性能模式CPU工作频率2.4GHz。
    通过查看CPU信息的反馈结果可以确认上述信息。
    1. //------查看CPU信息:lscpu
    2. //---指令
    3. lscpu
    4. cat /proc/cpuinfo
    5. //---结果
    6. 指令集: Cortex-A76 Arm
    7. 4核CPU:编号0~3
    8. //------查看CPU频率:
    9. //---指令
    10. cat /sys/bus/cpu/devices/cpu0/cpufreq/cpuinfo_cur_freq
    11. cat /sys/bus/cpu/devices/cpu0/cpufreq/cpuinfo_max_freq
    12. cat /sys/bus/cpu/devices/cpu0/cpufreq/cpuinfo_min_freq
    13. //---结果
    14. 工作频率:1.5GHz~2.4GHz
    15. 当前频率:1.5GHz
    16. //---借助vcgencmd查看CPU频率
    17. vcgencmd measure_clock arm
    18. //------示例Log信息
    19. zhaomeijing@raspberrypi5:~$ lscpu
    20. Architecture:            aarch64
    21.   CPU op-mode(s):        32-bit, 64-bit
    22.   Byte Order:            Little Endian
    23. CPU(s):                  4
    24.   On-line CPU(s) list:   0-3
    25. Vendor ID:               ARM
    26.   Model name:            Cortex-A76
    27.     Model:               1
    28.     Thread(s) per core:  1
    29.     Core(s) per cluster: 4
    30.     Socket(s):           -
    31.     Cluster(s):          1
    32.     Stepping:            r4p1
    33.     CPU(s) scaling MHz:  62%
    34.     CPU max MHz:         2400.0000
    35.     CPU min MHz:         1500.0000
    36.     BogoMIPS:            108.00
    37.     Flags:               fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp
    38. Vulnerabilities:
    39.   Gather data sampling:  Not affected
    40.   Itlb multihit:         Not affected
    41.   L1tf:                  Not affected
    42.   Mds:                   Not affected
    43.   Meltdown:              Not affected
    44.   Mmio stale data:       Not affected
    45.   Retbleed:              Not affected
    46.   Spec rstack overflow:  Not affected
    47.   Spec store bypass:     Mitigation; Speculative Store Bypass disabled via prctl
    48.   Spectre v1:            Mitigation; __user pointer sanitization
    49.   Spectre v2:            Mitigation; CSV2, BHB
    50.   Srbds:                 Not affected
    51.   Tsx async abort:       Not affected
    52. zhaomeijing@raspberrypi5:~$ cat /proc/cpuinfo
    53. processor       : 0
    54. BogoMIPS        : 108.00
    55. Features        : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp
    56. CPU implementer : 0x41
    57. CPU architecture: 8
    58. CPU variant     : 0x4
    59. CPU part        : 0xd0b
    60. CPU revision    : 1
    61. processor       : 1
    62. BogoMIPS        : 108.00
    63. Features        : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp
    64. CPU implementer : 0x41
    65. CPU architecture: 8
    66. CPU variant     : 0x4
    67. CPU part        : 0xd0b
    68. CPU revision    : 1
    69. processor       : 2
    70. BogoMIPS        : 108.00
    71. Features        : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp
    72. CPU implementer : 0x41
    73. CPU architecture: 8
    74. CPU variant     : 0x4
    75. CPU part        : 0xd0b
    76. CPU revision    : 1
    77. processor       : 3
    78. BogoMIPS        : 108.00
    79. Features        : fp asimd evtstrm aes pmull sha1 sha2 crc32 atomics fphp asimdhp cpuid asimdrdm lrcpc dcpop asimddp
    80. CPU implementer : 0x41
    81. CPU architecture: 8
    82. CPU variant     : 0x4
    83. CPU part        : 0xd0b
    84. CPU revision    : 1
    85. Revision        : c04170
    86. Serial          : c4197593e8cb6150
    87. Model           : Raspberry Pi 5 Model B Rev 1.0
    88. zhaomeijing@raspberrypi5:~$ sudo cat /sys/bus/cpu/devices/cpu0/cpufreq/cpuinfo_cur_freq
    89. 1500000
    90. zhaomeijing@raspberrypi5:~$ cat /sys/bus/cpu/devices/cpu0/cpufreq/cpuinfo_max_freq
    91. 2400000
    92. zhaomeijing@raspberrypi5:~$ cat /sys/bus/cpu/devices/cpu0/cpufreq/cpuinfo_min_freq
    93. 1500000
    94. zhaomeijing@raspberrypi5:~$ vcgencmd measure_clock arm
    95. frequency(0)=1500016128
    96. zhaomeijing@raspberrypi5:~$
    1.2        CoreMark性能测试
    1.2.1        CoreMark简介
    //------CoreMark简介
    CoreMark是用来衡量嵌入式系统中心处理单元(CPU,或叫做微控制器MCU)性能的标准。
    该标准于2009年由EEMBC组织的Shay Gla-On提出,并且试图将其发展成为工业标准,从而代替陈旧的Dhrystone标准。代码使用C语言写成,包含如下的运算法则:列举(寻找并排序),数学矩阵操作(普通矩阵运算)和状态机(用来确定输入流中是否包含有效数字),最后还包括CRC(循环冗余校验)。
    CoreMark是由EEMBC(Embedded Microprocessor Benchmark Consortium)的Shay Gla-On于2009年提出的一项基准测试程序,CoreMark的主要目标是简化操作,并提供一套测试单核处理器核心的方法。测试标准是在配置参数的组合下单位时间内运行的CoreMark程序次数(单位:CoreMark/MHz),该数字值越大则说明测试的性能越好。
    目前在嵌入式CPU行业中普遍公认的性能测试指标的标准主要使用以下三种,MIPS、Dhrystone、Coremark,而CoreMark与Dhrystone一样,拥有体积小、方便移植、易于理解、免费并且显示单个数字基准分数。与Dhrystone不同的是,Dhrystone的主要部分实际上暴露了编译器优化工作负载的能力,而不是实际MCU或CPU的能力,的性能,而CoreMark具有特定的运行和报告规则,从而可以避免由于所使用的编译库不同而导致的测试结果难以比较。
    1.2.2        CoreMark源码获取与编译
    //------CoreMark源码获取
    EEMBC 在将 CoreMark 源码托管在 GitHub 上可以访**ithub.com/eembc/coremark直接点击下载获得源码;也可以通过 git 命令下载到本地。
    1. //------CoreMark源码获取
    2. //---CoreMark说明
    3. https://www.eembc.org/coremark/
    4. //---直接下载(CoreMark开源代码仓)
    5. https://github.com/eembc/coremark
    6. //---Git下载
    7. git clone https://github.com/eembc/coremark.git
    8. //---编译(生成可执行程序coremark.exe)
    9. make run
    10. 或者
    11. make
    CoreMark 项目的详细介绍,可以查阅当前目录下 “coremark/docs/html/index.html” 。以下是当前目录的每个文件介绍:
    1. #在tree命令的输出中,作了部分删除(不影响分析整个CoreMark工程)
    2. imaginemiracle@:coremark$ tree
    3. .
    4. ├── barebones --移植到裸机环境下需要修改的目录
    5. │   ├── core_portme.c --移植的目标平台配置信息
    6. │   ├── core_portme.h --计时以及板级初始化实现
    7. │   ├── core_portme.mak --该子目录的makefile
    8. │   ├── cvt.c
    9. │   └── ee_printf.c --打印函数串口发送实现
    10. ├── core_list_join.c --列表操作程序
    11. ├── core_main.c --主程序
    12. ├── coremark.h --项目配置与数据结构的定义头文件
    13. ├── coremark.md5
    14. ├── core_matrix.c --矩阵运算程序
    15. ├── core_state.c --状态机控制程序
    16. ├── core_util.c --CRC计算程序
    17. ├── cygwin --x86 cygwin和gcc 3.4(四核,双核和单核系统)的测试代码
    18. │   ├── core_portme.c
    19. │   ├── core_portme.h
    20. │   └── core_portme.mak
    21. ├── freebsd --以下同理,是在不同操作系统下的测试代码
    22. │   ├── ...
    23. ├── LICENSE.md
    24. ├── linux
    25. │   ├── ...
    26. ├── linux64
    27. │   ├── ...
    28. ├── macos
    29. │   ├── ...
    30. ├── Makefile
    31. ├── README.md --自述文件,CoreMark项目的基本介绍
    32. ├── rtems
    33. │   ├── ...
    34. └──simple
    35.    ├── ...
    36.    └── core_portme.mak
    1.2.3        运行coremark.exe测试性能
    运行coremark.exe测试性能,测试得分18078.823671。
    1. zhaomeijing@raspberrypi5:~/workspace/01_cpu_ddr $ git clone https://github.com/eembc/coremark.git
    2. Cloning into 'coremark'...
    3. remote: Enumerating objects: 379, done.
    4. remote: Counting objects: 100% (163/163), done.
    5. remote: Compressing objects: 100% (61/61), done.
    6. remote: Total 379 (delta 121), reused 115 (delta 97), pack-reused 216
    7. Receiving objects: 100% (379/379), 517.77 KiB | 1.06 MiB/s, done.
    8. Resolving deltas: 100% (217/217), done.
    9. zhaomeijing@raspberrypi5:~/workspace/01_cpu_ddr $ ll
    10. total 12
    11. drwxr-xr-x  3 zhaomeijing zhaomeijing 4096 Mar 24 19:49 ./
    12. drwxr-xr-x  3 zhaomeijing zhaomeijing 4096 Mar 24 19:49 ../
    13. drwxr-xr-x 14 zhaomeijing zhaomeijing 4096 Mar 24 19:49 coremark/
    14. zhaomeijing@raspberrypi5:~/workspace/01_cpu_ddr $ cd coremark/
    15. zhaomeijing@raspberrypi5:~/workspace/01_cpu_ddr/coremark $ make
    16. (省略编译过程,详细可以参考README.md)
    17. zhaomeijing@raspberrypi5:~/workspace/01_cpu_ddr/coremark $ ./coremark.exe
    18. 2K performance run parameters for coremark.
    19. CoreMark Size    : 666
    20. Total ticks      : 16594
    21. Total time (secs): 16.594000
    22. Iterations/Sec   : 18078.823671
    23. Iterations       : 300000
    24. Compiler version : GCC12.2.0
    25. Compiler flags   : -O2 -DPERFORMANCE_RUN=1  -lrt
    26. Memory location  : Please put data memory location here
    27.                         (e.g. code in flash, data on heap etc)
    28. seedcrc          : 0xe9f5
    29. [0]crclist       : 0xe714
    30. [0]crcmatrix     : 0x1fd7
    31. [0]crcstate      : 0x8e3a
    32. [0]crcfinal      : 0xcc42
    33. Correct operation validated. See README.md for run and reporting rules.
    34. CoreMark 1.0 : 18078.823671 / GCC12.2.0 -O2 -DPERFORMANCE_RUN=1  -lrt / Heap
    35. zhaomeijing@raspberrypi5:~/workspace/01_cpu_ddr/coremark $
    1.3        CPU温度检测
    此处示例两种获取CPU温度的方式:lm-sensors和lm-sensors是一款linux的硬件监控的软件,可以帮助我们来监控主板,CPU的工作电压,风扇转速、温度等数据。当然,树莓派5还可以通过vcgencmd指令查看温度等信息。
    1. //------sensors
    2. //---sensors安装
    3. sudo apt install lm-sensors
    4. //---snesors使用
    5. sensors
    6. //------vcgencmd
    7. //---vcgencmd指令
    8. vcgencmd commands
    9. //---vcgencmd获取温度
    10. vcgencmd measure_temp
    11. //------示例Log信息
    12. zhaomeijing@raspberrypi5:~$ sudo apt install lm-sensors
    13. zhaomeijing@raspberrypi5:~$ sensors
    14. rpi_volt-isa-0000
    15. Adapter: ISA adapter
    16. in0:              N/A
    17. cpu_thermal-virtual-0
    18. Adapter: Virtual device
    19. temp1:        +37.5°C
    20. rp1_adc-isa-0000
    21. Adapter: ISA adapter
    22. in1:         955.00 mV
    23. in2:           2.52 V
    24. in3:           1.40 V
    25. in4:           1.42 V
    26. temp1:        +42.1°C
    27. zhaomeijing@raspberrypi5:~$ vcgencmd commands
    28. commands="commands, set_logging, bootloader_config, bootloader_version, cache_flush, codec_enable pmicrd, pmicwr, read_ring_osc, version, readmr, otp_dump, pmic_read_adc, power_monitor"
    29. zhaomeijing@raspberrypi5:~$ vcgencmd measure_temp
    30. temp=37.8'C
    31. zhaomeijing@raspberrypi5:~$
    2.        DDR内存性能测试
    树莓派5开发板采用4GB LPDDR4-SDRAM。
    2.1        DDR内存基本信息
    通过“free -h”指令读取内存DDR的使用情况;通过/proc/meminfo 文件读取系统中的内存的参数信息。
    1. //------测试工具
    2. free
    3. //---测试指令
    4. free -h
    5. 或者
    6. free -m
    7. //---参数解析
    8. -h 参数代表单位为 GByte
    9. -m 参数代表单位为 MByte
    10. total :内存总量
    11. used :被使用的内存量
    12. free :可使用的内存量
    13. //------查看系统内存信息文件
    14. cat /proc/meminfo
    15. //------
    16. zhaomeijing@raspberrypi5:~/workspace/01_cpu_ddr$ free -h
    17.                total        used        free      shared  buff/cache   available
    18. Mem:           4.0Gi       874Mi       477Mi        82Mi       2.8Gi       3.1Gi
    19. Swap:           99Mi          0B        99Mi
    20. zhaomeijing@raspberrypi5:~/workspace/01_cpu_ddr$ free -m
    21.                total        used        free      shared  buff/cache   available
    22. Mem:            4045         874         477          82        2840        3170
    23. Swap:             99           0          99
    24. zhaomeijing@raspberrypi5:~/workspace/01_cpu_ddr$ cat /proc/meminfo
    25. MemTotal:        4142304 kB
    26. MemFree:          488816 kB
    27. MemAvailable:    3246416 kB
    28. Buffers:          293648 kB
    29. Cached:          2447392 kB
    30. SwapCached:            0 kB
    31. Active:          1915696 kB
    32. Inactive:        1390080 kB
    33. Active(anon):     649056 kB
    34. Inactive(anon):        0 kB
    35. Active(file):    1266640 kB
    36. Inactive(file):  1390080 kB
    37. Unevictable:       41568 kB
    38. Mlocked:              32 kB
    39. SwapTotal:        102384 kB
    40. SwapFree:         102384 kB
    41. Zswap:                 0 kB
    42. Zswapped:              0 kB
    43. Dirty:                 0 kB
    44. Writeback:             0 kB
    45. AnonPages:        606528 kB
    46. Mapped:           259216 kB
    47. Shmem:             84320 kB
    48. KReclaimable:     167568 kB
    49. Slab:             213360 kB
    50. SReclaimable:     167568 kB
    51. SUnreclaim:        45792 kB
    52. KernelStack:        6672 kB
    53. PageTables:        18288 kB
    54. SecPageTables:         0 kB
    55. NFS_Unstable:          0 kB
    56. Bounce:                0 kB
    57. WritebackTmp:          0 kB
    58. CommitLimit:     2173536 kB
    59. Committed_AS:    3168656 kB
    60. VmallocTotal:   68180246528 kB
    61. VmallocUsed:       22672 kB
    62. VmallocChunk:          0 kB
    63. Percpu:             1280 kB
    64. CmaTotal:         327680 kB
    65. CmaFree:          195872 kB
    66. zhaomeijing@raspberrypi5:~/workspace/01_cpu_ddr$
    2.2        内存功能压力测试-memtester
    内存功能压力测试-memtester需要安装:
    1. //------安装内存功能压力测试工具memtester
    2. sudo apt install memtester -y
    3. 或者
    4. sudo apt-get install memtester -y
    memtester通过给定测试内存的大小和次数, 可以对系统现有的内存进行压力上的测试。例如指定内存大小 512MB,测试次数为 10,则测试命令为“memtester 512M 10"。
    下列以使用 512MB 内存空间,单次测试为例:
    1. //------测试工具(MYD-YG2LX系统已带)
    2. memtester
    3. //------测试指令
    4. memtester 512M 1
    5. //---指令说明
    6. 指定内存大小 512MB,测试次数为 1
    7. //---示例
    8. zhaomeijing@raspberrypi5:~/workspace/01_cpu_ddr$ memtester 512M 1
    9. memtester version 4.6.0 (64-bit)
    10. Copyright (C) 2001-2020 Charles Cazabon.
    11. Licensed under the GNU General Public License version 2 (only).
    12. pagesize is 16384
    13. pagesizemask is 0xffffffffffffc000
    14. want 512MB (536870912 bytes)
    15. got  512MB (536870912 bytes), trying mlock ...locked.
    16. Loop 1/1:
    17.   Stuck Address       : ok
    18.   Random Value        : ok
    19.   Compare XOR         : ok
    20.   Compare SUB         : ok
    21.   Compare MUL         : ok
    22.   Compare DIV         : ok
    23.   Compare OR          : ok
    24.   Compare AND         : ok
    25.   Sequential Increment: ok
    26.   Solid Bits          : ok
    27.   Block Sequential    : ok
    28.   Checkerboard        : ok
    29.   Bit Spread          : ok
    30.   Bit Flip            : ok
    31.   Walking Ones        : ok
    32.   Walking Zeroes      : ok
    33.   8-bit Writes        : ok
    34.   16-bit Writes       : ok
    35. Done.
    36. zhaomeijing@raspberrypi5:~/workspace/01_cpu_ddr$
    3.        蓝牙功能测试(蓝牙键盘)
    树莓派5自带蓝牙5.0 /低功耗蓝牙(BLE),手上有一块蓝牙键盘正好用来测试(Device 15:03:02:62:10:C4 BT 5.1 keyboard-1503)。
    测试流程和详细日志参考下方:
    1. //------蓝牙软件安装(准备工作,官方系统该镜像已经安装,此处仅作安装说明)
    2. a.先升级软件安装包:
    3. sudo apt-get update
    4. b.下载蓝牙管理工具:
    5. sudo apt-get install bluetooth bluez blueman
    6. //------蓝牙连接使用(测试蓝牙键盘连接)
    7. a.首先使待链接树莓派的蓝牙键盘处于被发现状态;
    8. b.然后扫描蓝牙设备,记录设备蓝牙地址
    9. sudo bluetoothctl scan on
    10. 借助grep指令查找具体某个设备
    11. sudo bluetoothctl scan on | grep "1503"
    12. c.蓝牙配对设备(需要使用设备地址)
    13. sudo bluetoothctl pair Device-Address
    14. sudo bluetoothctl pair 15:03:02:62:10:C4
    15. d.查看蓝牙
    16. bluetoothctl
    17. //------示例Log日志
    18. zhaomeijing@raspberrypi5:~/workspace $ sudo bluetoothctl scan on
    19. zhaomeijing@raspberrypi5:~/workspace $ sudo bluetoothctl list
    20. Controller D8:3A:DD:BF:C2:C7 raspberrypi5 [default]
    21. zhaomeijing@raspberrypi5:~/workspace $ sudo bluetoothctl scan on | grep "1503"
    22. [NEW] Device 15:03:02:62:10:C4 BT 5.1 keyboard-1503
    23. zhaomeijing@raspberrypi5:~/workspace $ sudo bluetoothctl pair 15:03:02:62:10:C4
    24. Attempting to pair with 15:03:02:62:10:C4
    25. [CHG] Device 15:03:02:62:10:C4 Connected: yes
    26. [CHG] Device 15:03:02:62:10:C4 Bonded: yes
    27. [CHG] Device 15:03:02:62:10:C4 Modalias: usb:v0A5Cp8503d011B
    28. [CHG] Device 15:03:02:62:10:C4 UUIDs: 00001000-0000-1000-8000-00805f9b34fb
    29. [CHG] Device 15:03:02:62:10:C4 UUIDs: 00001124-0000-1000-8000-00805f9b34fb
    30. [CHG] Device 15:03:02:62:10:C4 UUIDs: 00001200-0000-1000-8000-00805f9b34fb
    31. [CHG] Device 15:03:02:62:10:C4 ServicesResolved: yes
    32. [CHG] Device 15:03:02:62:10:C4 Paired: yes
    33. Pairing successful
    34. zhaomeijing@raspberrypi5:~/workspace $ bluetoothctl
    35. Agent registered
    36. [bluetooth]#  show
    37. Controller D8:3A:DD:BF:C2:C7 (public)
    38.         Name: raspberrypi5
    39.         Alias: raspberrypi5
    40.         Class: 0x006c0000
    41.         Powered: yes
    42.         Discoverable: no
    43.         DiscoverableTimeout: 0x000000b4
    44.         Pairable: yes
    45.         UUID: A/V Remote Control        (0000110e-0000-1000-8000-00805f9b34fb)
    46.         UUID: Handsfree Audio Gateway   (0000111f-0000-1000-8000-00805f9b34fb)
    47.         UUID: PnP Information           (00001200-0000-1000-8000-00805f9b34fb)
    48.         UUID: Audio Sink                (0000110b-0000-1000-8000-00805f9b34fb)
    49.         UUID: Audio Source              (0000110a-0000-1000-8000-00805f9b34fb)
    50.         UUID: A/V Remote Control Target (0000110c-0000-1000-8000-00805f9b34fb)
    51.         UUID: Generic Access Profile    (00001800-0000-1000-8000-00805f9b34fb)
    52.         UUID: Generic Attribute Profile (00001801-0000-1000-8000-00805f9b34fb)
    53.         UUID: Device Information        (0000180a-0000-1000-8000-00805f9b34fb)
    54.         UUID: Handsfree                 (0000111e-0000-1000-8000-00805f9b34fb)
    55.         Modalias: usb:v1D6Bp0246d0542
    56.         Discovering: no
    57.         Roles: central
    58.         Roles: peripheral
    59. Advertising Features:
    60.         ActiveInstances: 0x00 (0)
    61.         SupportedInstances: 0x05 (5)
    62.         SupportedIncludes: tx-power
    63.         SupportedIncludes: appearance
    64.         SupportedIncludes: local-name
    65. [bluetooth]# devices
    66. Device 15:03:02:62:10:C4 BT 5.1 keyboard-1503
    67. [bluetooth]# exit
    68. zhaomeijing@raspberrypi5:~/workspace $
    //------end
    GMT+8, 2025-1-30 12:57 , Processed in 0.127723 second(s), 19 queries , MemCache On.
