查看: 9043|回复: 20
Qorvo 在线设计小工具
    郁闷
    2013-9-12 12:12
    发表于 2016-6-8 09:06:10 | 显示全部楼层 |阅读模式
    Bandpass Filter Response Calculator
    View and analyze Butterworth and Chebyshev filter performance using frequency inputs.
    Cascade Calculator
    Analyze system performance including small-signal gain, noise figure and one-dB compression point.
    dBm-Volts-Watts Conversion
    See the relationship between power in dBm, Watts and RMS Voltage. This is relevant for many power applications.
    Noise Figure & Noise Temperature Calculator
    Calculate the noise figure and noise temperature of an RF system.
    Pad Attenuator (Pi & Tee) Calculator
    Obtain the resistor values of a Pi and Tee attenuator based on impedance and attenuation inputs.
    RF Impedance Matching Calculator
    Calculate capacitance and inductance of an L-Match network by entering the R load and inputs as well as the center frequency range. This type of calculator is useful in matching one amplifier output to the input of a following stage.
    Trace Width Calculator
    Calculate trace width values based using the IPC-2221 charts by providing inputs such as current thickness and temperature values.
    VSWR / Return Loss Conversion
    See the relationship between VSWR and return loss. The VSWR value range from 1.01:1 to 3.5:1.
    更多关于Qorvo 在线小工具,请进入Qorvo 查看:http://www.qorvo.com/design-tools
  • 签到天数: 1251 天
    发表于 2016-7-26 16:22:02 | 显示全部楼层
    过来灌灌水哈
    发表于 2016-8-10 14:19:36 | 显示全部楼层
    看看看在吗
    发表于 2016-8-13 15:32:15 | 显示全部楼层
    这是手机上用的吗?有没有PC版的
    发表于 2016-10-18 10:57:46 | 显示全部楼层
    收下,作参考
    发表于 2016-11-8 22:24:44 | 显示全部楼层
    看到这种小东西就想都下载了用用
    发表于 2016-11-11 10:05:33 | 显示全部楼层
    小工具很好用
    GMT+8, 2024-12-28 18:02 , Processed in 0.222116 second(s), 37 queries , MemCache On.
