查看: 1376|回复: 0
pcDuino 上运行motor shield
    发表于 2013-6-24 19:09:57 | 显示全部楼层 |阅读模式
    motor shield 是Arduino控制器兼容的电机驱动扩展板,让motor shield 成为pcDuino的电机扩展板,在pcDuino开发应用平台上快速上手,操作步骤如下:
    一、在protol Shield上的线路连接
    二、线路连接好之后,打开LXTerminal,进入目录
    三、输入命令,打开代码
    四、代码打开成功之后,输入make进行编译,出现可执行文件
    五、运行代码,成功之后电机转动
    代码:
    #include <core.h>
    #define pinI1 8 //define IN1 interface
    #define pinI2 11 //define IN2 interface
    #define speedpinA 3 //enable motor A
    #define pinI3 12 //define IN3 interface
    #define pinI4 13 //define IN4 interface
    #define speedpinB 4 //enable motor B
    #define spead 200 //define the spead of motor
    void forward()
    analogWrite(speedpinA,spead);//input a simulation value to set the speed
    analogWrite(speedpinB,spead);
    digitalWrite(pinI4,HIGH);//turn DC Motor B move clockwise
    digitalWrite(pinI3,LOW);
    digitalWrite(pinI2,LOW);//turn DC Motor A move anticlockwise
    digitalWrite(pinI1,HIGH);
    void backward()
    digitalWrite(pinI4,LOW);//turn DC Motor B move anticlockwise
    digitalWrite(pinI3,HIGH);
    digitalWrite(pinI2,HIGH);//turn DC Motor A move clockwise
    digitalWrite(pinI1,LOW);
    void left()
    void right()
    digitalWrite(pinI2,LOW);//turn DC Motor A move clockwise
    void stop()
    digitalWrite(speedpinA,LOW);// Unenble the pin, to stop the motor. this should be done to avid damaging the motor.
    digitalWrite(speedpinB,LOW);
    delay(2000);
    void setup()
    pinMode(pinI1,OUTPUT);
    pinMode(pinI2,OUTPUT);
    pinMode(speedpinA,OUTPUT);
    pinMode(pinI3,OUTPUT);
    pinMode(pinI4,OUTPUT);
    pinMode(speedpinB,OUTPUT);
    void loop()
    left();
    delay(2000);
    stop();
    right();
    delay(2000);
    stop();
    forward();
    delay(2000);
    stop();
    backward();
    delay(2000);
    stop();
    GMT+8, 2025-2-28 09:59 , Processed in 0.107256 second(s), 18 queries , MemCache On.
