TA的每日心情 | 开心 2024-11-20 21:23 |
签到天数: 597 天 连续签到: 1 天 [LV.9]以坛为家II
米尔 MYS-Y6ULL-IOT NFS 启动
米尔 MYS-Y6ULL-IOT NFS 启动:
boot.scr 文件内容更换成这样,打包替换原 boot.scr 文件:
- setenv ipaddr 192.168.8.202
- setenv ethaddr [mac]
- setenv serverip 192.168.8.200
- setenv bootargs console=${console},${baudrate} root=/dev/nfs rw nfsroot=192.168.8.200:[path]nfs ip=192.168.8.202:192.168.8.200:192.168.8.1:255.255.255.0::eth0:off
- nfs 0x83000000 192.168.8.200:[path]nfs/boot/zImage
- nfs 0x84000000 192.168.8.200:[path]nfs/boot/dts/mys-imx6ull-14x14-evk-emmc.dtb
- bootz 0x83000000 - 0x84000000
复制代码 启动信息:
- U-Boot 2016.03-g4ade113-dirty (Aug 16 2018 - 12:16:37 +0800) - build by Robe!
- CPU: Freescale i.MX6ULL rev1.0 528 MHz (running at 396 MHz)
- CPU: Commercial temperature grade (0C to 95C) at 51C
- Reset cause: POR
- Board: MYS-MX6ULL 14x14
- I2C: ready
- DRAM: 256 MiB
- MMC: FSL_SDHC: 0, FSL_SDHC: 1
- Display: LCD050_800x480_Robe (800x480)
- Video: 800x480x24
- In: serial
- Out: serial
- Err: serial
- switch to partitions #0, OK
- mmc0 is current device
- Net: FEC0
- Error: FEC0 address not set.
- Normal Boot
- Hit any key to stop autoboot: 0
- reading boot.scr
- 552 bytes read in 13 ms (41 KiB/s)
- Running bootscript from mmc ...
- ## Executing script at 80800000
- Using FEC0 device
- File transfer via NFS from server 192.168.8.200; our IP address is 192.168.8.202
- Filename '[path]nfs/boot/zImage'.
- Load address: 0x83000000
- Loading: #################################################################
- done
- Bytes transferred = 6771120 (6751b0 hex)
- Using FEC0 device
- Filename '[path]nfs/boot/dts/mys-imx6ull-14x14-evk-emmc.dtb'.
- Load address: 0x84000000
- Loading: #######
- done
- Bytes transferred = 34860 (882c hex)
- Kernel image @ 0x83000000 [ 0x000000 - 0x6751b0 ]
- ## Flattened Device Tree blob at 84000000
- Booting using the fdt blob at 0x84000000
- Using Device Tree in place at 84000000, end 8400b82b
- Starting kernel ...
- Booting Linux on physical CPU 0x0
- Linux version 4.1.15+ (robe@robe-desktop) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05) ) #6 SMP PREEMPT Thu Aug 23 09:25:07 CST 2018
- CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c53c7d
- CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
- Machine model: Freescale i.MX6 ULL 14x14 EVK Board
- Reserved memory: failed to allocate memory for node 'linux,cma'
- Memory policy: Data cache writealloc
- PERCPU: Embedded 12 pages/cpu @8fdd4000 s16908 r8192 d24052 u49152
- Built 1 zonelists in Zone order, mobility grouping on. Total pages: 65024
- Kernel command line: console=ttymxc0,115200 root=/dev/nfs rw nfsroot=192.168.8.200:[path]nfs ip=192.168.8.202:192.168.8.200:192.168.8.1:255.255.255.0::eth0:off
- PID hash table entries: 1024 (order: 0, 4096 bytes)
- Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
- Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
- Memory: 246904K/262144K available (8500K kernel code, 438K rwdata, 2936K rodata, 432K init, 450K bss, 15240K reserved, 0K cma-reserved, 0K highmem)
- Virtual kernel memory layout:
- vector : 0xffff0000 - 0xffff1000 ( 4 kB)
- fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
- vmalloc : 0x90800000 - 0xff000000 (1768 MB)
- lowmem : 0x80000000 - 0x90000000 ( 256 MB)
- pkmap : 0x7fe00000 - 0x80000000 ( 2 MB)
- modules : 0x7f000000 - 0x7fe00000 ( 14 MB)
- .text : 0x80008000 - 0x80b33284 (11437 kB)
- .init : 0x80b34000 - 0x80ba0000 ( 432 kB)
- .data : 0x80ba0000 - 0x80c0d920 ( 439 kB)
- .bss : 0x80c10000 - 0x80c809c0 ( 451 kB)
- SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
- Preemptible hierarchical RCU implementation.
- Additional per-CPU info printed with stalls.
- RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=1.
- RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
- NR_IRQS:16 nr_irqs:16 16
- mxc_clocksource_init 24000000
- Switching to timer-based delay loop, resolution 41ns
- sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
- clocksource mxc_timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
- Console: colour dummy device 80x30
- Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
- pid_max: default: 32768 minimum: 301
- Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
- Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
- CPU: Testing write buffer coherency: ok
- /cpus/cpu@0 missing clock-frequency property
- CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
- Setting up static identity map for 0x80008280 - 0x800082d8
- Brought up 1 CPUs
- SMP: Total of 1 processors activated (48.00 BogoMIPS).
- CPU: All CPU(s) started in SVC mode.
- devtmpfs: initialized
- device-tree: Duplicate name in lcdif@021c8000, renamed to "display#1"
- VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
- clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
- pinctrl core: initialized pinctrl subsystem
- NET: Registered protocol family 16
- DMA: preallocated 256 KiB pool for atomic coherent allocations
- cpuidle: using governor ladder
- cpuidle: using governor menu
- hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
- hw-breakpoint: maximum watchpoint size is 8 bytes.
- imx6ul-pinctrl 20e0000.iomuxc: initialized IMX pinctrl driver
- imx6ul-pinctrl 2290000.iomuxc-snvs: initialized IMX pinctrl driver
- mxs-dma 1804000.dma-apbh: initialized
- SCSI subsystem initialized
- usbcore: registered new interface driver usbfs
- usbcore: registered new interface driver hub
- usbcore: registered new device driver usb
- i2c i2c-1: IMX I2C adapter registered
- i2c i2c-1: can't use DMA
- media: Linux media interface: v0.10
- Linux video capture interface: v2.00
- pps_core: LinuxPPS API ver. 1 registered
- pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
- PTP clock support registered
- MIPI CSI2 driver module loaded
- Advanced Linux Sound Architecture Driver Initialized.
- Bluetooth: Core ver 2.20
- NET: Registered protocol family 31
- Bluetooth: HCI device and connection manager initialized
- Bluetooth: HCI socket layer initialized
- Bluetooth: L2CAP socket layer initialized
- Bluetooth: SCO socket layer initialized
- Switched to clocksource mxc_timer1
- NET: Registered protocol family 2
- TCP established hash table entries: 2048 (order: 1, 8192 bytes)
- TCP bind hash table entries: 2048 (order: 2, 16384 bytes)
- TCP: Hash tables configured (established 2048 bind 2048)
- UDP hash table entries: 256 (order: 1, 8192 bytes)
- UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
- RPC: Registered named UNIX socket transport module.
- RPC: Registered udp transport module.
- RPC: Registered tcp transport module.
- RPC: Registered tcp NFSv4.1 backchannel transport module.
- imx rpmsg driver is registered.
- Bus freq driver module loaded
- futex hash table entries: 256 (order: 2, 16384 bytes)
- VFS: Disk quotas dquot_6.6.0
- VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
- NFS: Registering the id_resolver key type
- Key type id_resolver registered
- Key type id_legacy registered
- jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
- fuse init (API version 7.23)
- io scheduler noop registered
- io scheduler deadline registered
- io scheduler cfq registered (default)
- imx-weim 21b8000.weim: Driver registered.
- backlight supply power not found, using dummy regulator
- MIPI DSI driver module loaded
- 21c8000.lcdif supply lcd not found, using dummy regulator
- mxsfb 21c8000.lcdif: failed to find mxc display driver
- Console: switching to colour frame buffer device 100x30
- mxsfb 21c8000.lcdif: initialized
- imx-sdma 20ec000.sdma: no event needs to be remapped
- imx-sdma 20ec000.sdma: loaded firmware 3.3
- imx-sdma 20ec000.sdma: initialized
- 2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 18, base_baud = 5000000) is a IMX
- console [ttymxc0] enabled
- imx-rng 2284000.rngb: iMX RNG Registered.
- imx sema4 driver is registered.
- [drm] Initialized drm 1.1.0 20060810
- [drm] Initialized vivante 1.0.0 20120216 on minor 0
- brd: module loaded
- loop: module loaded
- CAN device driver interface
- 2188000.ethernet supply phy not found, using dummy regulator
- pps pps0: new PPS source ptp0
- libphy: fec_enet_mii_bus: probed
- fec 2188000.ethernet eth0: registered PHC device 0
- PPP generic driver version 2.4.2
- PPP BSD Compression module registered
- PPP Deflate Compression module registered
- PPP MPPE Compression module registered
- NET: Registered protocol family 24
- SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
- CSLIP: code copyright 1989 Regents of the University of California.
- SLIP linefill/keepalive option.
- ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
- ehci-mxc: Freescale On-Chip EHCI Host driver
- usbcore: registered new interface driver usb-storage
- usbcore: registered new interface driver usb_ehset_test
- 2184800.usbmisc supply vbus-wakeup not found, using dummy regulator
- 2184200.usb supply vbus not found, using dummy regulator
- ci_hdrc ci_hdrc.1: EHCI Host Controller
- ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 1
- ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
- hub 1-0:1.0: USB hub found
- hub 1-0:1.0: 1 port detected
- mousedev: PS/2 mouse device common for all mice
- input: 20cc000.snvs:snvs-powerkey as /devices/platform/soc/2000000.aips-bus/20cc000.snvs/20cc000.snvs:snvs-powerkey/input/input0
- Goodix-TS 1-005d: IC VERSION: 39 31 31 00 60 10
- ts->int_trigger_type = 1 .debug-robe
- ts->max_touch_num = 10 .debug-robe
- ts->abs_x_max = 1024 .debug-robe
- ts->abs_y_max = 600 .debug-robe
- input: Goodix Capacitive TouchScreen as /devices/platform/soc/2100000.aips-bus/21a4000.i2c/i2c-1/1-005d/input/input1
- snvs_rtc 20cc000.snvs:snvs-rtc-lp: rtc core: registered 20cc000.snvs:snvs-r as rtc0
- i2c /dev entries driver
- IR NEC protocol handler initialized
- IR RC5(x/sz) protocol handler initialized
- IR RC6 protocol handler initialized
- IR JVC protocol handler initialized
- IR Sony protocol handler initialized
- IR SANYO protocol handler initialized
- IR Sharp protocol handler initialized
- IR MCE Keyboard/mouse protocol handler initialized
- IR XMP protocol handler initialized
- pxp-v4l2 pxp_v4l2: initialized
- usbcore: registered new interface driver uvcvideo
- USB Video Class driver (1.1.1)
- imx2-wdt 20bc000.wdog: use WDOG_B to reboot.
- imx2-wdt 20bc000.wdog: timeout 60 sec (nowayout=0)
- Bluetooth: HCI UART driver ver 2.3
- Bluetooth: HCI UART protocol H4 registered
- Bluetooth: HCI UART protocol BCSP registered
- Bluetooth: HCI UART protocol ATH3K registered
- usbcore: registered new interface driver btusb
- usbcore: registered new interface driver ath3k
- sdhci: Secure Digital Host Controller Interface driver
- sdhci: Copyright(c) Pierre Ossman
- sdhci-pltfm: SDHCI platform and OF driver helper
- /soc/aips-bus@02100000/usdhc@02190000: voltage-ranges unspecified
- sdhci-esdhc-imx 2190000.usdhc: could not get ultra high speed state, work on normal mode
- sdhci-esdhc-imx 2190000.usdhc: Got CD GPIO
- sdhci-esdhc-imx 2190000.usdhc: No vmmc regulator found
- sdhci-esdhc-imx 2190000.usdhc: No vqmmc regulator found
- mmc0: SDHCI controller on 2190000.usdhc [2190000.usdhc] using ADMA
- /soc/aips-bus@02100000/usdhc@02194000: voltage-ranges unspecified
- sdhci-esdhc-imx 2194000.usdhc: No vmmc regulator found
- sdhci-esdhc-imx 2194000.usdhc: No vqmmc regulator found
- usb 1-1: new high-speed USB device number 2 using ci_hdrc
- mmc0: host does not support reading read-only switch, assuming write-enable
- mmc1: SDHCI controller on 2194000.usdhc [2194000.usdhc] using ADMA
- mmc0: new high speed SDHC card at address aaaa
- mmcblk0: mmc0:aaaa SS16G 14.8 GiB
- usbcore: registered new interface driver usbhid
- mmcblk0: p1 p2
- usbhid: USB HID core driver
- usbcore: registered new interface driver snd-usb-audio
- fsl-asrc 2034000.asrc: driver registered
- hub 1-1:1.0: USB hub found
- NET: Registered protocol family 26
- hub 1-1:1.0: 2 ports detected
- NET: Registered protocol family 10
- sit: IPv6 over IPv4 tunneling driver
- NET: Registered protocol family 17
- can: controller area network core (rev 20120528 abi 9)
- NET: Registered protocol family 29
- can: raw protocol (rev 20120528)
- can: broadcast manager protocol (rev 20120528 t)
- can: netlink gateway (rev 20130117) max_hops=1
- Bluetooth: RFCOMM TTY layer initialized
- Bluetooth: RFCOMM socket layer initialized
- Bluetooth: RFCOMM ver 1.11
- Bluetooth: BNEP (Ethernet Emulation) ver 1.3
- Bluetooth: BNEP filters: protocol multicast
- Bluetooth: BNEP socket layer initialized
- Bluetooth: HIDP (Human Interface Emulation) ver 1.2
- Bluetooth: HIDP socket layer initialized
- 8021q: 802.1Q VLAN Support v1.8
- Key type dns_resolver registered
- cpu cpu0: dev_pm_opp_get_opp_count: device OPP not found (-19)
- dhd_module_init in
- input: gpio-keys as /devices/platform/gpio-keys/input/input2
- snvs_rtc 20cc000.snvs:snvs-rtc-lp: setting system clock to 2018-08-24 09:02:44 UTC (1535101364)
- usb 1-1.1: new high-speed USB device number 3 using ci_hdrc
- fec 2188000.ethernet eth0: Freescale FEC PHY driver [Generic PHY] (mii_bus:phy_addr=2188000.ethernet:00, irq=-1)
- IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
- usb 1-1.2: new full-speed USB device number 4 using ci_hdrc
- input: Logitech USB Receiver as /devices/platform/soc/2100000.aips-bus/2184200.usb/ci_hdrc.1/usb1/1-1/1-1.2/1-1.2:1.0/0003:046D:C534.0001/input/input3
- hid-generic 0003:046D:C534.0001: input: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-ci_hdrc.1-1.2/input0
- input: Logitech USB Receiver as /devices/platform/soc/2100000.aips-bus/2184200.usb/ci_hdrc.1/usb1/1-1/1-1.2/1-1.2:1.1/0003:046D:C534.0002/input/input4
- hid-generic 0003:046D:C534.0002: input: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-ci_hdrc.1-1.2/input1
- fec 2188000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
- IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
- IP-Config: Complete:
- device=eth0, hwaddr=de:ab:73:53:74:ea, ipaddr=192.168.8.202, mask=255.255.255.0, gw=192.168.8.1
- host=192.168.8.202, domain=, nis-domain=(none)
- bootserver=192.168.8.200, rootserver=192.168.8.200, rootpath=
- gpio_dvfs: disabling
- VSD_3V3: disabling
- can-3v3: disabling
- ALSA device list:
- No soundcards found.
- VFS: Mounted root (nfs filesystem) on device 0:14.
- devtmpfs: mounted
- Freeing unused kernel memory: 432K (80b34000 - 80ba0000)
- random: systemd urandom read with 89 bits of entropy available
- systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
- systemd[1]: Detected architecture arm.
- Welcome to Debian GNU/Linux 9 (stretch)!
- systemd[1]: Set hostname to <debian>.
- systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
- [ OK ] Set up automount Arbitrary Executab…rmats File System Automount Point.
- systemd[1]: Listening on Journal Socket.
- [ OK ] Listening on Journal Socket.
- systemd[1]: Reached target Swap.
- [ OK ] Reached target Swap.
- systemd[1]: Reached target Remote File Systems.
- [ OK ] Reached target Remote File Systems.
- systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
- [ OK ] Started Dispatch Password Requests to Console Directory Watch.
- systemd[1]: Listening on Syslog Socket.
- [ OK ] Listening on Syslog Socket.
- systemd[1]: Created slice System Slice.
- [ OK ] Created slice System Slice.
- systemd[1]: Mounting Debug File System...
- Mounting Debug File System...
- systemd[1]: dev-hugepages.mount: Couldn't determine result for ConditionVirtualization=!private-users, assuming failed: No such file or directory
- systemd[1]: Created slice system-getty.slice.
- [ OK ] Created slice system-getty.slice.
- systemd[1]: Starting Remount Root and Kernel File Systems...
- Starting Remount Root and Kernel File Systems...
- systemd[1]: Started Forward Password Requests to Wall Directory Watch.
- [ OK ] Started Forward Password Requests to Wall Directory Watch.
- systemd[1]: Reached target Paths.
- [ OK ] Reached target Paths.
- systemd[1]: Starting Load Kernel Modules...
- Starting Load Kernel Modules...
- systemd[1]: Listening on udev Control Socket.
- [ OK ] Listening on udev Control Socket.
- systemd[1]: Reached target Encrypted Volumes.
- [ OK ] Reached target Encrypted Volumes.
- systemd[1]: Created slice User and Session Slice.
- [ OK ] Created slice User and Session Slice.
- systemd[1]: Reached target Slices.
- [ OK ] Reached target Slices.
- systemd[1]: Created slice system-serial\x2dgetty.slice.
- [ OK ] Created slice system-serial\x2dgetty.slice.
- systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
- [ OK ] Listening on /dev/initctl Compatibility Named Pipe.
- systemd[1]: Listening on udev Kernel Socket.
- [ OK ] Listening on udev Kernel Socket.
- systemd[1]: Starting Create list of required static device nodes for the current kernel...
- Starting Create list of required st…ce nodes for the current kernel...
- systemd[1]: Listening on Journal Socket (/dev/log).
- [ OK ] Listening on Journal Socket (/dev/log).
- systemd[1]: Starting Journal Service...
- Starting Journal Service...
- systemd[1]: Mounted Debug File System.
- [ OK ] Mounted Debug File System.
- random: nonblocking pool is initialized
- systemd[1]: Started Remount Root and Kernel File Systems.
- [ OK ] Started Remount Root and Kernel File Systems.
- systemd[1]: Started Load Kernel Modules.
- [ OK ] Started Load Kernel Modules.
- systemd[1]: Started Create list of required static device nodes for the current kernel.
- [ OK ] Started Create list of required sta…vice nodes for the current kernel.
- systemd[1]: Starting Create Static Device Nodes in /dev...
- Starting Create Static Device Nodes in /dev...
- systemd[1]: Starting Apply Kernel Variables...
- Starting Apply Kernel Variables...
- systemd[1]: Mounting FUSE Control File System...
- Mounting FUSE Control File System...
- systemd[1]: Starting udev Coldplug all Devices...
- Starting udev Coldplug all Devices...
- systemd[1]: Starting Load/Save Random Seed...
- Starting Load/Save Random Seed...
- systemd[1]: Mounted FUSE Control File System.
- [ OK ] Mounted FUSE Control File System.
- systemd[1]: Started Journal Service.
- [ OK ] Started Journal Service.
- [ OK ] Started Apply Kernel Variables.
- [ OK ] Started Create Static Device Nodes in /dev.
- [ OK ] Reached target Local File Systems (Pre).
- [ OK ] Reached target Local File Systems.
- Starting udev Kernel Device Manager...
- Starting Raise network interfaces...
- Starting Flush Journal to Persistent Storage...
- [ OK ] Started Load/Save Random Seed.
- systemd-journald[105]: Received request to flush runtime journal from PID 1
- [ OK ] Started Flush Journal to Persistent Storage.
- Starting Create Volatile Files and Directories...
- [ OK ] Started udev Kernel Device Manager.
- [ OK ] Started Create Volatile Files and Directories.
- Starting Network Time Synchronization...
- Starting Update UTMP about System Boot/Shutdown...
- [ OK ] Started Update UTMP about System Boot/Shutdown.
- [ OK ] Started Raise network interfaces.
- [ OK ] Reached target Network.
- [ OK ] Created slice system-systemd\x2dbacklight.slice.
- Starting Load/Save Screen Backlight…ightness of backlight:backlight...
- [ OK ] Started Network Time Synchronization.
- [ OK ] Started udev Coldplug all Devices.
- [ OK ] Reached target System Time Synchronized.
- [ OK ] Found device /dev/ttymxc0.
- [ OK ] Started Load/Save Screen Backlight Brightness of backlight:backlight.
- [ OK ] Reached target System Initialization.
- [ OK ] Started Daily apt download activities.
- [ OK ] Listening on D-Bus System Message Bus Socket.
- [ OK ] Reached target Sockets.
- [ OK ] Started Daily apt upgrade and clean activities.
- [ OK ] Started Daily Cleanup of Temporary Directories.
- [ OK ] Reached target Timers.
- [ OK ] Reached target Basic System.
- Starting RealtimeKit Scheduling Policy Service...
- [ OK ] Started Regular background program processing daemon.
- Starting Login Service...
- Starting System Logging Service...
- [ OK ] Started D-Bus System Message Bus.
- Starting Permit User Sessions...
- [ OK ] Started System Logging Service.
- [FAILED] Failed to start RealtimeKit Scheduling Policy Service.
- See 'systemctl status rtkit-daemon.service' for details.
- [ OK ] Started Permit User Sessions.
- [ OK ] Started Login Service.
- [ OK ] Started Getty on tty1.
- Starting Light Display Manager...
- [ OK ] Started Serial Getty on ttymxc0.
- [ OK ] Reached target Login Prompts.
- [ OK ] Reached target Multi-User System.
- [ OK ] Started Light Display Manager.
- [ OK ] Reached target Graphical Interface.
- Starting Update UTMP about System Runlevel Changes...
- [ OK ] Started Update UTMP about System Runlevel Changes.
- Debian GNU/Linux 9 debian ttymxc0
- debian login:
