查看: 3718|回复: 4
How to compile Arduino style sample code?
    郁闷
    2013-6-3 09:22
  • 签到天数: 29 天
    [LV.4]偶尔看看III
    发表于 2013-3-22 10:50:51 | 显示全部楼层 |阅读模式
    We are developing Arduino style sample code for Ubuntu, and host the sample code in progress at gitub.
    Firstly, we need to install git on pcDuino by the doing the following:
    1. $ sudo apt-get install git
    Next we will fork the repo:
    1. ubuntu@ubuntu:~$ pwd
    2. /home/ubuntu
    3. ubuntu@ubuntu:~$ mkdir myworkdirectory
    4. ubuntu@ubuntu:~$ cd myworkdirectory/
    5. ubuntu@ubuntu:~/myworkdirectory$ git clone https://github.com/pcduino/arduino
    6. Cloning into 'arduino'...
    7. remote: Counting objects: 123, done.
    8. remote: Compressing objects: 100% (100/100), done.
    9. remote: Total 123 (delta 17), reused 119 (delta 13)
    10. Receiving objects: 100% (123/123), 109.03 KiB, done.
    11. Resolving deltas: 100% (17/17), done.
    12. ubuntu@ubuntu:~/myworkdirectory$ ls
    13. arduino
    Next we show how to compile:
    1. ubuntu@ubuntu:~/myworkdirectory$ cd arduino/
    2. ubuntu@ubuntu:~/myworkdirectory/arduino$ ls
    3. Makefile hardware libraries output sample
    4. ubuntu@ubuntu:~/myworkdirectory/arduino$ make
    To run the executable, please refer to:
    1. buntu@ubuntu:~/myworkdirectory/arduino$ cd output
    2. ubuntu@ubuntu:~/myworkdirectory/arduino/output$ ls
    3. test
    4. ubuntu@ubuntu:~/myworkdirectory/arduino/output$ cd test
    5. ubuntu@ubuntu:~/myworkdirectory/arduino/output/test$ ls
    6. Motor_shield io_test pwm_test smg xbee_shield
    7. adc_test liquidcrystal_i2c relay_shield spi_test
    8. adxl345_test liquidcrystal_spi serial_test test
    9. drawCircle paint sim900 xbee_relay
    10. ubuntu@ubuntu:~/myworkdirectory/arduino/output/test$
  • 签到天数: 361 天
    发表于 2013-3-22 14:07:34 | 显示全部楼层
    我来坐你的沙发。。。。。
    发表于 2013-3-22 15:22:42 | 显示全部楼层
    牛。。板凳
    发表于 2013-5-30 15:05:12 | 显示全部楼层
    下载地址貌似不行了。。。
    郁闷
    2013-6-3 09:22
  • 签到天数: 29 天
    [LV.4]偶尔看看III
     楼主| 发表于 2013-5-31 09:44:33 | 显示全部楼层
    xujiaweidick 发表于 2013-5-30 15:05
    下载地址貌似不行了。。。
    地址是改了,这个翻墙可以进https://github.com/pcduino/
    GMT+8, 2025-1-20 19:13 , Processed in 0.136446 second(s), 22 queries , MemCache On.
