查看: 2132|回复: 1
[原创] AM335x -GPMC使用总结
发表于 2018-3-13 11:12:44 | 显示全部楼层 |阅读模式
AM335X GPMC使用比较灵活,可以配置为
●    8-bit 同步或者异步并行总线 (非burst)
●     16-bit 同步或者异步并行中线
●     16-bit 非复用的NORFlash
●     16-bit 数据和地址总线复用的NORFlash
●     8-bit 和 16-bitNAND Flash
●     16-bit pSRAM.
下面以EVB335X扩展EXAR ST16C554为例,讲解如何配置GPMC。
1.      配置GPMC引脚
static structpinmux_config gpmc_pin_mux[] = {
       /********* 8-bit data bus **************/
       {"gpmc_ad0.gpmc_ad0",                    OMAP_MUX_MODE0 | AM33XX_PIN_INPUT_PULLUP},
       {"gpmc_ad1.gpmc_ad1",                    OMAP_MUX_MODE0 | AM33XX_PIN_INPUT_PULLUP},
       {"gpmc_ad2.gpmc_ad2",                    OMAP_MUX_MODE0 | AM33XX_PIN_INPUT_PULLUP},
       {"gpmc_ad3.gpmc_ad3",                    OMAP_MUX_MODE0 | AM33XX_PIN_INPUT_PULLUP},
       {"gpmc_ad4.gpmc_ad4",                    OMAP_MUX_MODE0 | AM33XX_PIN_INPUT_PULLUP},
       {"gpmc_ad5.gpmc_ad5",                    OMAP_MUX_MODE0 | AM33XX_PIN_INPUT_PULLUP},
       {"gpmc_ad6.gpmc_ad6",                    OMAP_MUX_MODE0 | AM33XX_PIN_INPUT_PULLUP},
       {"gpmc_ad7.gpmc_ad7",                    OMAP_MUX_MODE0 | AM33XX_PIN_INPUT_PULLUP},
       /**************** 8-bit address bus ****************/
       {"gpmc_a0.gpmc_a0",                 OMAP_MUX_MODE0| AM33XX_PIN_OUTPUT},
       {"gpmc_a1.gpmc_a1",                 OMAP_MUX_MODE0| AM33XX_PIN_OUTPUT},
       {"gpmc_a2.gpmc_a2",                 OMAP_MUX_MODE0| AM33XX_PIN_OUTPUT},
       {"gpmc_a3.gpmc_a3",                 OMAP_MUX_MODE0| AM33XX_PIN_OUTPUT},
       {"gpmc_a4.gpmc_a4",                 OMAP_MUX_MODE0| AM33XX_PIN_OUTPUT},
       {"gpmc_a5.gpmc_a5",                 OMAP_MUX_MODE0| AM33XX_PIN_OUTPUT},
       {"gpmc_a6.gpmc_a6",                 OMAP_MUX_MODE0| AM33XX_PIN_OUTPUT},
       {"gpmc_a7.gpmc_a7",                 OMAP_MUX_MODE0 |AM33XX_PIN_OUTPUT},
       {"gpmc_csn2.gpmc_csn2",                  OMAP_MUX_MODE0 | AM33XX_PULL_DISA},
       {"gpmc_oen_ren.gpmc_oen_ren",        OMAP_MUX_MODE0 | AM33XX_PULL_DISA},
       {"gpmc_wen.gpmc_wen",                   OMAP_MUX_MODE0 | AM33XX_PULL_DISA},
       {NULL, 0},
       setup_pin_mux(gpmc_pin_mux);
2.      申请GPMC内存
unsigned long serial_gpmc_mem_base_phys;
int cs = 2;               /*EVB335X评估板中ST16C554接在CS2上 */
gpmc_cs_request(cs, SZ_16M, &serial_gpmc_mem_base_phys)
此时serial_gpmc_mem_base_phys存放的是该CS上多对应的物理起始地址。
3.      设置GMPC类型
gpmc_cs_configure(cs, GPMC_CONFIG_DEV_TYPE, GPMC_DEVICETYPE_NOR);/*设置为并行总线*/
val = GPMC_CONFIG1_READTYPE_SYNC;     /* 设置为8-bit sync */
val |= GPMC_CONFIG1_WRITETYPE_SYNC;
gpmc_cs_write_reg(cs, GPMC_CS_CONFIG1, val);
4.      设置GPMC时序
因此时序设置为: (单位ns)
static structgpmc_timings ext_uart_timings = {
       /* Minimum clock period for synchronous mode (in picoseconds)*/
       .sync_clk = 0,
       /* CS signal timings corresponding to GPMC_CONFIG2 */
       .cs_on = 10,                         /*T6s */
       .cs_rd_off = 80,                   /*oe_off + T7h */
       .cs_wr_off = 60,                  /*Tcs for write: we_off + T13h */
       /* ADV signal timings corresponding to GPMC_CONFIG3 */
//     .adv_on = 0,                 /* Address setup Tas*/
//     .adv_rd_off = 110,        /* Read deassertion time Trd + Tdd*/
//     .adv_wr_off = 90,         /* Write deassertion time Twr + Tdh*/
       /* WE signals timings corresponding to GPMC_CONFIG4 */
       .we_on = 20,         /*WE assertion time: cs_on + T13d */
       .we_off = 60,         /*WE deassertion time: we_on + T13w */
       /* OE signals timings corresponding to GPMC_CONFIG4 */
       .oe_on = 20,          /*OE assertion time: cs_on + T7d */
       .oe_off = 70,         /*OE deassertion time: oe_on + T7w */
       /* Access time and cycle time timings corresponding toGPMC_CONFIG5 */
//     .page_burst_access = 2 * 10,  /* Multiple access word delay */
       .access = 60,          /*Start-cycle to first data valid delay: at leaset oe_on + T12d */
       .rd_cycle = 110,            /*Total read cycle time: cs_rd_off + (T9d - T7h) - oe_on */
       .wr_cycle = 90,             /*Total write cycle time: cs_wr_off + (T15d - T13h) - we_on */
       /* The following are only on OMAP3430 */
       .wr_access = 40,            /*WRACCESSTIME: max we_off - T16s  */
       .wr_data_mux_bus = 0,  /*WRDATAONADMUXBUS */
gpmc_cs_set_timings(cs,&ext_uart_timings)
 楼主| 发表于 2018-3-14 14:47:47 | 显示全部楼层
AM335x开发板相关资料:
doc: AM335x 开发资料打包.rar (6.2 MB, 下载次数: 9)
GMT+8, 2025-1-12 19:08 , Processed in 0.130914 second(s), 18 queries , MemCache On.
