今天跟大家分享一个利用树莓派和L298N模块制作手机遥控小车的程序。具体小车的硬件链接我将不再这里赘述,网上会搜索到很多教程。在这只和大家交流分享利用Python实现的程序代码。先上一张效果图。
1.程序思路:
(1)在树莓派上编写一个控制小车运行的文件index.py。
(2)在树莓派上利用Python的bottle库建立web应用服务,运行main.py。
(3)在手机浏览器访问树莓派上的遥控器网页index.html,实现与index.py程序交互,进而控制小车运行。
2.程序文件:
(1)控制小车运行的Python文件:index.py- #!/usr/bin/env python3
- from bottle import get,post,run,request,template
- import RPi.GPIO as GPIO
- import time
- IN1 = 11
- IN2 = 12
- IN3 = 13
- IN4 = 15
- def init():
- GPIO.setmode(GPIO.BOARD)
- GPIO.setup(IN1,GPIO.OUT)
- GPIO.setup(IN2,GPIO.OUT)
- GPIO.setup(IN3,GPIO.OUT)
- GPIO.setup(IN4,GPIO.OUT)
- # 前进
- def forward(tf):
- GPIO.output(IN1,GPIO.HIGH)
- GPIO.output(IN2,GPIO.LOW)
- GPIO.output(IN3,GPIO.HIGH)
- GPIO.output(IN4,GPIO.LOW)
- time.sleep(tf)
- GPIO.cleanup()
- # 后退
- def down(tf):
- GPIO.output(IN1,GPIO.LOW)
- GPIO.output(IN2,GPIO.HIGH)
- GPIO.output(IN3,GPIO.LOW)
- GPIO.output(IN4,GPIO.HIGH)
- time.sleep(tf)
- GPIO.cleanup()
- # 左转弯
- def left(tf):
- time.sleep(tf)
- GPIO.cleanup()
- # 右转弯
- def right(tf):
- time.sleep(tf)
- GPIO.cleanup()
- # 停止
- def stop():
- GPIO.output(IN1,False)
- GPIO.output(IN2,False)
- GPIO.output(IN3,False)
- GPIO.output(IN4,False)
- GPIO.cleanup()
- @get("/")
- def index():
- return template("index")
- @post("/cmd")
- def cmd():
- print("按下了按钮: "+request.body.read().decode())
- init()
- sleep_time = 1
- arg = request.body.read().decode()
- if(arg=='up'):
- forward(sleep_time)
- elif(arg=='down'):
- down(sleep_time)
- elif(arg=='left'):
- left(sleep_time)
- elif(arg=='right'):
- right(sleep_time)
- elif(arg=='stop'):
- stop()
- else:
- return False
- #return "OK"
- run(host="0.0.0.0",port="8080")
复制代码 (2)建立Web服务的Python文件:main.py- #!/usr/bin/env python3
- @get("/")
- def index():
- @post("/cmd")
- def cmd():
- #return "OK"
(3)控制小车的网页html文件:index.html- <html lang="en">
- <head>
- <meta charset="UTF-8">
- <meta name="viewport" content="width=device-width, initial-scale=1.0">
- <title>树莓派遥控小车</title>
- <link rel="stylesheet" media="screen">
- <script src="http://code.jquery.com/jquery.js"></script>
- <style type="text/css">
- #up {
- margin-left: 55px;
- margin-bottom: 3px;
- #down {
- margin-top: 3px;
- </style>
- <script>
- $(function(){
- $("button").click(function(){
- $.post("/cmd",this.id,function(data,status){});
- </script>
- </head>
- <body>
- <div id="container" class="container">
- <div>
- <button id="up" class="btn btn-lg btn-primary glyphicon glyphicon-circle-arrow-up"></button>
- </div>
- <div>
- <button id='left' class="btn btn-lg btn-primary glyphicon glyphicon-circle-arrow-left"></button>
- <button id='stop' class="btn btn-lg btn-primary glyphicon glyphicon-stop"></button>
- <button id='right' class="btn btn-lg btn-primary glyphicon glyphicon-circle-arrow-right"></button>
- </div>
- <div>
- <button id='down' class="btn btn-lg btn-primary glyphicon glyphicon-circle-arrow-down"></button>
- </div>
- </div>
- <script src="http://cdn.bootcss.com/bootstrap/3.3.5/js/bootstrap.min.js"></script>
- </body>
- </html>
3.程序原理及代码解析
(1)main.py 文件中通过使用Python最轻量级的web框架bottle在树莓派上建立web应用服务,并设置服务开放的端口号为8080,进而实现通过手机等客户端访问树莓派上的html网页文件。
(2)index.py 文件中通过引用Python的GPIO库,实现通过树莓派的11、12、13、14号GPIO接口链接控制L298N模块,进而控制小车的马达实现小车的运动。
(3)index.html通过使用js的click事件,检测网页中的button点击情况并反馈给index.py文件,从而实现通过点击按钮实现对小车的控制。
(4)以上三个文件需放置到同一文件路径下。
