查看: 3903|回复: 1
I2C颜色识别传感器+STM32 F091 nucleo
    7 天前
  • 签到天数: 792 天
    发表于 2018-1-16 23:36:45 | 显示全部楼层 |阅读模式
    正好前几天收到了stm32F091 nucleo开发板,试试这款Dfrobot的颜色传感器。
    1. 硬件准备
    开发板
    tcs34725 color sensor
    导线 4根
    2连接方式(兼容ardunio的pin)
    传感器===》Nucleo
    SDA==>SDA/D14
    SCL==》SCL/D15
    注意不是A4,A5
    2. 软件开发环境 mbed 在线编译
    修改一下频率为(100000)原来是200000会报错
    附上代码,非常简单
    1. // Example program connecting to the TCS34725 Color Sensor to the K64F using I2C
    2. #include "mbed.h"
    3. I2C i2c(I2C_SDA, I2C_SCL); //pins for I2C communication (SDA, SCL)
    4. Serial pc(USBTX, USBRX);
    5. int sensor_addr = 41 << 1;
    6. DigitalOut green(LED1);
    7. int main() {
    8.     pc.baud(9600);
    9.     green = 1; // off
    10.
    11.     // Connect to the Color sensor and verify whether we connected to the correct sensor.
    12.
    13.     i2c.frequency(100000);//修改为100000,否则报错
    14.
    15.     char id_regval[1] = {146};
    16.     char data[1] = {0};
    17.     i2c.write(sensor_addr,id_regval,1, true);
    18.     i2c.read(sensor_addr,data,1,false);
    19.
    20.     if (data[0]==68) {
    21.         green = 0;
    22.         wait (2);
    23.         green = 1;
    24.         } else {
    25.         green = 1;
    26.     }
    27.
    28.     // Initialize color sensor
    29.
    30.     char timing_register[2] = {129,0};
    31.     i2c.write(sensor_addr,timing_register,2,false);
    32.
    33.     char control_register[2] = {143,0};
    34.     i2c.write(sensor_addr,control_register,2,false);
    35.
    36.     char enable_register[2] = {128,3};
    37.     i2c.write(sensor_addr,enable_register,2,false);
    38.
    39.     // Read data from color sensor (Clear/Red/Green/Blue)
    40.
    41.     while (true) {
    42.         char clear_reg[1] = {148};
    43.         char clear_data[2] = {0,0};
    44.         i2c.write(sensor_addr,clear_reg,1, true);
    45.         i2c.read(sensor_addr,clear_data,2, false);
    46.
    47.         int clear_value = ((int)clear_data[1] << 8) | clear_data[0];
    48.
    49.         char red_reg[1] = {150};
    50.         char red_data[2] = {0,0};
    51.         i2c.write(sensor_addr,red_reg,1, true);
    52.         i2c.read(sensor_addr,red_data,2, false);
    53.
    54.         int red_value = ((int)red_data[1] << 8) | red_data[0];
    55.
    56.         char green_reg[1] = {152};
    57.         char green_data[2] = {0,0};
    58.         i2c.write(sensor_addr,green_reg,1, true);
    59.         i2c.read(sensor_addr,green_data,2, false);
    60.
    61.         int green_value = ((int)green_data[1] << 8) | green_data[0];
    62.
    63.         char blue_reg[1] = {154};
    64.         char blue_data[2] = {0,0};
    65.         i2c.write(sensor_addr,blue_reg,1, true);
    66.         i2c.read(sensor_addr,blue_data,2, false);
    67.
    68.         int blue_value = ((int)blue_data[1] << 8) | blue_data[0];
    69.
    70.         // print sensor readings
    71.
    72.         pc.printf("Clear (%d), Red (%d), Green (%d), Blue (%d)\r\n", clear_value, red_value, green_value, blue_value);
    73.         wait(0.5);
    74.     }
    75.
    76. }
    下载编译结果,打开串口助手之类的,使用三种颜色来实验,结果如下(传感器不能离的太近,否则数值飙升)
    使用红色的时候,红色值偏大,使用蓝色,蓝色值偏大,另外两个值基本固定在100多不到200.
    最后来张合影
    发表于 2018-2-22 18:40:02 | 显示全部楼层
    学习学习最近在学习当中
    GMT+8, 2025-1-12 01:42 , Processed in 0.133827 second(s), 19 queries , MemCache On.
