一、gpio_init函数 void GPIO_Init(GPIO_TypeDef* GPIOx, GPIO_InitTypeDef* GPIO_InitStruct) 调用时的格式一般是例如 RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOB, ENABLE);//使能时钟 GPIO_InitTypeDef GPIO_InitStructure; GPIO_InitStructure.GPIO_Pin=GPIO_Pin_0; GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode=GPIO_Mode_Out_PP; GPIO_Init(GPIOD,&GPIO_InitStructure); 参数1是GPIO_TypeDef类型,如下,就是7个寄存器的地址。 typedef struct { __IO uint32_t CRL; __IO uint32_t CRH; __IO uint32_t IDR; __IO uint32_t ODR; __IO uint32_t BSRR; __IO uint32_t BRR; __IO uint32_t LCKR; } GPIO_TypeDef; 下面是宏定义 #define GPIOD ((GPIO_TypeDef *) GPIOD_BASE) #define GPIOD_BASE (APB2PERIPH_BASE + 0x1400) #define APB2PERIPH_BASE (PERIPH_BASE + 0x10000) #define PERIPH_BASE ((uint32_t)0x40000000) 可以看出0x40000000是外设的首地址,在STM32芯片的内部STM32有两个,一个叫APB1,一个叫APB2 参数2为GPIO_InitTypeDef* GPIO_InitStruct。就是一个指向GPIO _InitTypeDef的地址。 typedef struct { uint16_t GPIO_Pin; GPIOSpeed_TypeDef GPIO_Speed; GPIOMode_TypeDef GPIO_Mode; }GPIO_InitTypeDef;
