TA的每日心情 | 开心 2014-2-20 10:23 |
签到天数: 45 天 连续签到: 1 天 [LV.5]常住居民I
参考的正点原子的代码
测试平台 stm32f429i-disco 配了一个gpio
时钟
gpio
代码- /* USER CODE BEGIN 0 */
- typedef uint8_t u8;
- typedef uint32_t u32;
- u8 fac_us;
- void delay_init(u8 SYSCLK)
- #if SYSTEM_SUPPORT_OS //?????? OS.
- u32 reload;
- #endif
- HAL_SYSTICK_CLKSourceConfig(SYSTICK_CLKSOURCE_HCLK);
- //SysTick ??? HCLK
- fac_us=SYSCLK; //?????? OS,fac_us ?????
- reload=SYSCLK; //???????? ??? K
- reload*=1000000/delay_ostickspersec; //?? delay_ostickspersec ??????
- //reload ? 24 ????,???:16777216,? 180M ?,?? 0.745s ??
- fac_ms=1000/delay_ostickspersec; //?? OS ?????????
- SysTick->CTRL|=SysTick_CTRL_TICKINT_Msk;//?? SYSTICK ??
- SysTick->LOAD=reload; //? 1/OS_TICKS_PER_SEC ?????
- SysTick->CTRL|=SysTick_CTRL_ENABLE_Msk; //?? SYSTICK
- #else
- #endif
- void delay_us(u32 nus)
- u32 ticks;
- u32 told,tnow,tcnt=0;
- u32 reload=SysTick->LOAD; //LOAD ??
- ticks=nus*fac_us; //??????
- told=SysTick->VAL; //?????????
- while(1)
- tnow=SysTick->VAL;
- if(tnow!=told)
- if(tnow<told)tcnt+=told-tnow;//???? SYSTICK ??????????.
- else tcnt+=reload-tnow+told;
- told=tnow;
- if(tcnt>=ticks)break; //????/????????,???.
- /* USER CODE END 0 */
复制代码- int main(void)
- /* USER CODE BEGIN 1 */
- /* USER CODE END 1 */
- /* MCU Configuration----------------------------------------------------------*/
- /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
- HAL_Init();
- /* Configure the system clock */
- SystemClock_Config();
- /* Initialize all configured peripherals */
- MX_GPIO_Init();
- /* USER CODE BEGIN 2 */
- delay_init(168);
- /* USER CODE END 2 */
- /* Infinite loop */
- /* USER CODE BEGIN WHILE */
- while (1)
- /* USER CODE END WHILE */
- HAL_GPIO_WritePin(GPIOF, GPIO_PIN_7, GPIO_PIN_SET);
- delay_us(50);
- HAL_GPIO_WritePin(GPIOF, GPIO_PIN_7, GPIO_PIN_RESET);
- delay_us(50);
- /* USER CODE BEGIN 3 */
- /* USER CODE END 3 */
复制代码 实际测试, 函数调用能带来几百ns的误差.
转自网络
