查看: 5347|回复: 0
[项目] 树莓派使用4G模块上网
    慵懒
    2014-11-28 09:29
  • 签到天数: 3 天
    发表于 2017-7-24 14:21:34 | 显示全部楼层 |阅读模式
    一、4G Luci配置
    1、 新建一个wwan接口;
    2、 上网方式为dhcp自动获取;
    3、 物理设置选择wwan0;
    4、 防火墙选择wan
    二、重连脚本redial4g
    1. LogFile=/root/4g_Log.log
    2. mdate=`date +%R-%d-%m-%Y`
    3. if [ -e /var/run/udhcpc-wwan0.pid ]; then
    4.     echo 4G pid is ok!
    5.     #echo $mdate 4G pid is ok! >> $LogFile
    6.     #exit 0
    7. else
    8.     echo 4G pid is failed!
    9.     echo $mdate 4G pid is failed! >> $LogFile
    10.     #/etc/myLte/dial4g
    11.     #reboot
    12.     #exit 0
    13. fi
    14. if ping -c3 www.baidu.com > /dev/null 2>&1
    15. then
    16.     echo ping baidu is ok!
    17.     #echo $mdate  ping baidu is ok! >> $LogFile
    18.     echo 0 > /tmp/4g_tmp.txt
    19.     exit 0
    20. else
    21.     echo ping baidu is failed!
    22.     echo $mdate ping baidu is failed! >> $LogFile
    23.     /etc/myLte/dial4g  #must place here
    24.     #read pvar < /tmp/4g_temp.txt
    25.     #if [ -z "$pvar" ] ; then
    26.     #    pvar=0
    27.     #fi
    28.     if [ ! -f "/tmp/4g_tmp.txt" ] ; then
    29.         pvar=0
    30.         echo file not exist
    31.     else
    32.         read pvar < /tmp/4g_tmp.txt
    33.         echo file exist
    34.     fi
    35.     pvar=`expr $pvar + 1`
    36.     echo $pvar > /tmp/4g_tmp.txt
    37.     if [ $pvar -ge 5 ] ; then
    38.         echo failed 5 times!
    39.         echo $mdate failed 5 times! >> $LogFile
    40.         reboot
    41.     fi
    42.
    43. fi
    44. exit 0
    三、crontab
    */2 * * * * /etc/myLte/redial4g
    重连时间不要设太短,太短可能还没拨号结束就又进行重播,会重复了。
    四、拨号脚本dial4g
    1. PORT=/dev/ttyUSB0
    2. MODE="AT+CFUN=1" gcom -d $PORT -s /etc/gcom/setmode.gcom
    3. sleep 3
    4. MODE="AT+COPS=0" gcom -d $PORT -s /etc/gcom/setmode.gcom
    5. sleep 3
    6. MODE="AT+CEREG=1" gcom -d $PORT -s /etc/gcom/setmode.gcom
    7. sleep 3
    8. MODE="AT+CGDCONT=1,'IP'" gcom -d $PORT -s /etc/gcom/setmode.gcom
    9. sleep 3
    10. MODE="AT+CGACT=1,1" gcom -d $PORT -s /etc/gcom/setmode.gcom
    11. sleep 3
    12. MODE="AT+ZGACT=1,1" gcom -d $PORT -s /etc/gcom/setmode.gcom
    13. sleep 3
    14. ifup wwan &
    15. exit 0
    五、开机启动
    1. # Put your custom commands here that should be executed once
    2. # the system init finished. By default this file does nothing.
    4. exit 0
    转自互联网,作者念愧聚
    GMT+8, 2025-1-15 21:05 , Processed in 0.129349 second(s), 17 queries , MemCache On.
