查看: 3392|回复: 5
Touch Sensor Module of Linker Kit on pcDuino
  • 签到天数: 1018 天
    发表于 2013-3-15 14:00:29 | 显示全部楼层 |阅读模式
    In this tutorial, we are going to use touch sensor module of Linker kit on pcDuino.
    First, we take a protoshield , and female to female jumpers.
    Now we can add Arduino shield.
    We use Linker kit in this tutorial:
    With the following code, when we touch the touch module, the LED will light up. It will go off when we remove from the touch module.
    http://player.youku.com/player.php/sid/XNTI3MTA5MjU2/v.swf
    Code:
    1. ubuntu@ubuntu:~/arduino/test$ more touch_sen.c
    2. /*
    3. * Touch Sensor module of Linker Kit for pcDuino
    4. * http://linksprite.com/wiki/index.php5?title=Touch_Sensor_Module
    5. */
    6. #include "core.h"
    7. int led_pin = 8; //Connect LED module to GPIO 8
    8. int btn_pin = 7; //Connect touch module to GPIO 7
    9. void setup()
    10. {
    11. pinMode(led_pin, OUTPUT);
    12. pinMode(btn_pin, INPUT);
    13. }
    14. void loop()
    15. {
    16. int value = digitalRead(btn_pin); // get button status
    17. if ( value == HIGH ) // button pressed
    18. {
    19. digitalWrite(led_pin, HIGH); // turn on LED
    20. }
    21. else // button released
    22. {
    23. digitalWrite(led_pin, LOW); // turn off LED
    24. }
    25. delay(100);
    26. }
    无聊
    2016-12-20 15:08
  • 签到天数: 510 天
    发表于 2013-3-15 22:18:42 | 显示全部楼层
    话说怎么感觉从视频里看不到灯亮呢
  • 签到天数: 1018 天
    发表于 2013-3-15 22:50:13 | 显示全部楼层
    ming1006 发表于 2013-3-15 22:18
    话说怎么感觉从视频里看不到灯亮呢
    视频中灯在下方,灯光不是太明显,与拍摄环境有关系!
  • 签到天数: 1018 天
    发表于 2013-3-15 22:50:23 | 显示全部楼层
    话说怎么感觉从视频里看不到灯亮呢
    无聊
    2016-12-20 15:08
  • 签到天数: 510 天
    发表于 2013-3-15 23:02:22 | 显示全部楼层
    又看了一遍,终于看到了
    发表于 2013-3-19 13:35:57 | 显示全部楼层
    少看电影多看教学视频。屌丝男华丽变成高富帅。。。。。
    GMT+8, 2024-11-19 14:30 , Processed in 0.157016 second(s), 25 queries , MemCache On.
