TA的每日心情 | 奋斗 2022-6-20 16:11 |
签到天数: 19 天 连续签到: 1 天 [LV.4]偶尔看看III
老早就收到开发板,无奈最近一直很忙,终于抽出时间发帖,分享一下我移植emwin的过程。
①:调屏,要emwin首先要把TFT液晶屏调通,我用的是spi接口的显示器,分辨率320*240.屏幕调试很简单,商家给的驱屏程序移植过来改一下接口就能用。- 底层驱动:
- void LCD_WR_DATA8( char da ) /* 发送数据-8位参数 */
- while ( RESET == spi_i2s_flag_get( SPI0, SPI_FLAG_TBE ) );
- LCD_DC_H;
- SPI_DATA( SPI0 ) = (uint32_t) da;
- void LCD_WR_DATA( int da )
- LCD_DC_H;
- SPI_DATA( SPI0 ) = (uint32_t) (da >> 8);
- void LCD_WR_REG( char da )
- LCD_DC_L;
- void LCD_WR_REG_DATA( int reg, int da )
- LCD_WR_REG( reg );
- LCD_WR_DATA( da );
[color=rgb(51, 102, 153) !important]复制代码
屏幕测试:显示"Hello World",附加垂直滚动效果
视频:
代码很简单:- while(1)
- LCD_ShowString(0,i++,"Hello World!");
- delay_ms(10);
屏幕正常点亮之后就要进行第二步,添加emwin到工程。添加的文件不多,如下图所示:
添加库文件之后,要配置emwin与屏幕驱动的接口。代码如下:- static void _SetPixelIndex(GUI_DEVICE * pDevice, int x, int y, int PixelIndex) {
- // Convert logical into physical coordinates (Dep. on LCDConf.h)
- #if (LCD_MIRROR_X == 1) || (LCD_MIRROR_Y == 1) || (LCD_SWAP_XY == 1)
- int xPhys, yPhys;
- xPhys = LOG2PHYS_X(x, y);
- yPhys = LOG2PHYS_Y(x, y);
- #else
- #define xPhys x
- #define yPhys y
- #endif
- GUI_USE_PARA(pDevice);
- GUI_USE_PARA(x);
- GUI_USE_PARA(y);
- GUI_USE_PARA(PixelIndex);
- POINT_COLOR = PixelIndex;
- LCD_DrawPoint(x,y);
- #if (LCD_MIRROR_X == 0) && (LCD_MIRROR_Y == 0) && (LCD_SWAP_XY == 0)
- #undef xPhys
- #undef yPhys
- #endif
添加读点和写点函数emwin就能正常工作,但是我这个屏幕商家没提供读点函数,自己也不想捣鼓了,添加写点函数就能满足emwin大部分操作,我就只添加了LCD_DrawPoint(x,y);。
下一步还得进行emwin的相关配置,比如屏幕分辨率,色彩,显存大小等。- #define XSIZE_PHYS 240 // To be adapted to x-screen size
- #define YSIZE_PHYS 320 // To be adapted to y-screen size
- void LCD_X_Config(void) {
- GUI_DEVICE * pDevice;
- // CONFIG_FLEXCOLOR Config = {0};
- // GUI_PORT_API PortAPI = {0};
- // Set display driver and color conversion
- pDevice = GUI_DEVICE_CreateAndLink(&GUIDRV_Template_API, GUICC_M565, 0, 0);
- // Display driver configuration, required for Lin-driver
- LCD_SetSizeEx (0, XSIZE_PHYS , YSIZE_PHYS);
- LCD_SetVSizeEx(0, VXSIZE_PHYS, VYSIZE_PHYS);
- // Orientation
我给了64KB的内存空间供emwin使用。- #define GUI_NUMBYTES 64*1024
- #define GUI_BLOCKSIZE 0X80 //块大小
现在可以执行emwin初始化以及它自带的Demo了。跑起来看看效果:- int main()
- Lcd_Init();
- delay_ms(10);
- GUI_Init();
- GUI_Clear();
- GUIDEMO_Main();
这个当时没有拍视频,demo的样子大家都知道。
好了,到此为止GD32F450移植emwin就完成了,欢迎大家拍砖。
分享我的预期成果:基于GD32F450以及ESP8266的网络信息发布屏
