查看: 6024|回复: 0
香蕉派 banana pi BPI-M2 Ultra 四核开源单板计算机,全志R40
发表于 2017-6-8 17:02:17 | 显示全部楼层 |阅读模式
香蕉派 BPI-M2 Ultra 四核单板计算机采用全志 R40芯片开发。支持板载Wifi与蓝牙,支持SATA接口,可以直接接硬盘。并且板载8G eMMC ,可以选择SD卡启动或从eMMC flash 启动。
Banana PI BPI-M2 Ultra 兼容性强大,可以跑Android系统,Debian Linux,Ubuntu linux, Raspberry Pi系统 和 全志Tina 系统.
Banana PI BPI-M2 Ultra硬件:全志R40 四核处理器,2GB LPDDR3内存,千兆以太网口,3USB 接口 流畅运行Android5.1。Banana PI BPI-M2 Ultra 体积如信用卡大小,与BPI-M3尺寸一样,GPIO兼容Raspberry PiB+并能运行其ROM Image。
主要规格指标
1,Quad Core ARM Cortex A7 CPU
2,Dual core Mali 400 MP2 GPU
3,2G DDR3 SDRAM
4,support SATA interface
5,MicroSD slot supports up to 256GB expansion
6,8G eMMC flash (option 16/32/64G)
7,CSI camera intface and DSI display interface support
8,10/100/1000 Mb Ethernet port
9,(3) USB 2.0 hosts and (1) USB otg port
10,1080P high-definition video playback
11,HDMI port and multi-channel audio output
12,WIFI&Bluetooth 4.0 with 802.11BGN onboard
13,3.5mm Stereo Output mini-jack with microphone support
14,Built-in 3.7V Lithium Battery Charging Circuit
15,Hardware security enables trustzone security system, Digital Rights Management (DRM), information encryption/decryption, secure boot, secure JTAG and secure efuse
硬件接口:
硬件规格:
GPIO下定义:
GMT+8, 2025-1-19 19:32 , Processed in 0.116035 second(s), 16 queries , MemCache On.
