查看: 2738|回复: 0
开箱试验GD32450VE
    发表于 2017-5-30 09:09:02 | 显示全部楼层 |阅读模式
    收到GD32F450有段时间了,偶尔有空看看,原来以为和ST的完全兼容,准备拿来公司做项目用的,后来发现差别还是挺大的,里面的定时器用STCubeMX生成后只有一个定时器可以正常,其他都不能使用,还需要花时间去学习习惯GD的驱动代码库
    自己花时间写了一个定时器的代码发现不能进入中断,pend不能置位
    void inittimer(void)
         timer_parameter_struct* timer_initpara ;
         timer_break_parameter_struct timer_breakpara;
        rcu_periph_clock_enable(RCU_TIMER1);
        rcu_timer_clock_prescaler_config(RCU_TIMER_PSC_MUL4);
        timer_deinit(TIMER1);
        timer_initpara->prescaler = 63;
        timer_initpara->alignedmode = TIMER_COUNTER_EDGE;
        timer_initpara->clockdivision = TIMER_CKDIV_DIV1;
        timer_initpara->counterdirection = TIMER_COUNTER_UP;
        timer_initpara->period = 2000-1;
        timer_initpara->repetitioncounter = 0;
        //timer_breakpara.breakpolarity
        timer_init(TIMER1,timer_initpara);
        timer_input_trigger_source_select(TIMER1,TIMER_SMCFG_TRGSEL_ITI0);
        //timer_primary_output_config(TIMER0,ENABLE);
        //timer_slave_mode_select(TIMER0,TIMER_SLAVE_MODE_EVENT);
        timer_interrupt_enable(TIMER1,TIMER_INT_UP);
        /* auto-reload preload enable */
        //timer_auto_reload_shadow_enable(TIMER0);
        //timer_interrupt_enable(TIMER0,TIMER_INT_TRG);
        timer_enable(TIMER1);
        \brief      configure the nested vectored interrupt controller
        \param[in]  none
        \param[out] none
        \retval     none
    void nvic_configuration(void)
        nvic_priority_group_set(NVIC_PRIGROUP_PRE1_SUB3);
        nvic_irq_enable(TIMER1_IRQn, 1, 3);//TIMER0_CC_IRQn
    GMT+8, 2024-12-24 07:43 , Processed in 0.123212 second(s), 16 queries , MemCache On.
