查看: 2340|回复: 0
GD32方案分享②:串口打印
  • 签到天数: 7 天
    发表于 2017-5-25 21:36:53 | 显示全部楼层 |阅读模式
    1. #include "uart.h"
    2. void UART_Init(uint32_t usart,uint64_t baud)
    3. {
    4.          /* enable GPIO clock */
    5.     rcu_periph_clock_enable(RCU_USART0);
    6.
    7.     /* enable USART clock */
    8.     rcu_periph_clock_enable(RCU_GPIOA);
    9.     /* connect port to USARTx_Tx */
    10.     gpio_af_set(GPIOA, GPIO_AF_7, GPIO_PIN_9);
    11.     /* connect port to USARTx_Rx */
    12.     gpio_af_set(GPIOA, GPIO_AF_7, GPIO_PIN_10);
    13.     /* configure USART Tx as alternate function push-pull */
    14.     gpio_mode_set(GPIOA, GPIO_MODE_AF, GPIO_PUPD_PULLUP,GPIO_PIN_9);
    15.     gpio_output_options_set(GPIOA, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ,GPIO_PIN_10);
    16.     /* configure USART Rx as alternate function push-pull */
    17.     gpio_mode_set(GPIOA, GPIO_MODE_AF, GPIO_PUPD_PULLUP,GPIO_PIN_9);
    18.     gpio_output_options_set(GPIOA, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ,GPIO_PIN_10);
    19.     /* USART configure */
    20.     usart_deinit(usart);
    21.     usart_baudrate_set(usart,baud);
    22.     usart_receive_config(usart, USART_RECEIVE_ENABLE);
    23.     usart_transmit_config(usart, USART_TRANSMIT_ENABLE);
    24.     usart_enable(usart);
    25. }
    26. int fputc(int ch, FILE *f)
    27. {
    28.         while(usart_flag_get(Debug_UART,USART_FLAG_TBE)==0);
    29.         usart_data_transmit(Debug_UART,ch);
    30.         return ch;
    31. }
    注意添加这个fputc 和调用stdio.h 就可以打印了
    1. #include "include.h"
    2. int main(void)
    3. {
    4.     systick_config();
    5.
    6.         UART_Init(USART0,115200);
    7.
    8.           while(1)
    9.          {
    10.                     delay_1ms(200);
    11.                     printf("uart test is OK\r\n");
    12.
    13.     }
    14. }
    GMT+8, 2025-1-29 08:25 , Processed in 0.104815 second(s), 15 queries , MemCache On.
