查看: 6027|回复: 7
为你的pcDuino开发板安装一块LCD扩展模块
  • 签到天数: 1018 天
    发表于 2013-3-14 11:06:32 | 显示全部楼层 |阅读模式
    我们从LinkSprite买了一块16×2 LCD扩展板,并为pcDuino安装上 。你只需要花半个小时进行Arduino代码转码,转码完成后我们就可以在16×2 LCD屏幕上显示文本啦。
    代码如下:
    #include <core.h>
    #define RS 8
    #define EN 9
    #define backlight 10
    #define RS_L digitalWrite(RS,LOW)
    #define RS_H digitalWrite(RS,HIGH)
    #define EN_L digitalWrite(EN,LOW)
    #define EN_H digitalWrite(EN,HIGH)
    int DB[] = {7,6,5,4};
    void write_command(int command)
    int i,temp;
    RS_L;
    EN_L;
    temp=command & 0xf0;
    for (i=0; i < 4; i++)
    if(temp&0×80)
    digitalWrite(DB,HIGH);
    else digitalWrite(DB,LOW);
    temp <<= 1;
    EN_H;
    delayMicroseconds(1);
    EN_L;
    temp=(command & 0x0f)<<4;
    if(temp&0×80)
    temp <<= 1;
    EN_H;
    EN_L;
    void write_data(int dat)
    int i=0,temp;
    RS_H;
    EN_L;
    temp=dat & 0xf0;
    if(temp&0×80)
    temp <<= 1;
    EN_H;
    EN_L;
    temp=(dat & 0x0f)<<4;
    if(temp&0×80)
    temp <<= 1;
    EN_H;
    EN_L;
    void LCD_write_char( int x,int y,int dat)
    int address;
    if (x ==0) address = 0×80 + y;
    else address = 0xC0 + y;
    write_command(address);
    write_data(dat);
    delayMicroseconds(10);
    void lcd1602_init()
    int i = 0;
    pinMode(RS,OUTPUT);
    pinMode(EN,OUTPUT);
    pinMode(backlight,OUTPUT);
    digitalWrite(backlight,HIGH);
    pinMode(DB,OUTPUT);
    delay(100);
    write_command(0×28);
    delay(50);
    write_command(0×06);
    delay(50);
    write_command(0x0c);
    delay(50);
    write_command(0×80);
    delay(50);
    write_command(0×01);
    delay(100);
    void setup (void)
    lcd1602_init();
    void loop (void)
    write_command(0×02);
    delay(10);
    LCD_write_char(0,2,’W');
    LCD_write_char(0,3,’e');
    LCD_write_char(0,4,’l');
    LCD_write_char(0,5,’c');
    LCD_write_char(0,6,’o');
    LCD_write_char(0,7,’m');
    LCD_write_char(0,8,’e');
    LCD_write_char(0,10,’t');
    LCD_write_char(0,11,’o');
    LCD_write_char(1,4,’p');
    LCD_write_char(1,5,’c');
    LCD_write_char(1,6,’D');
    LCD_write_char(1,7,’u');
    LCD_write_char(1,8,’i');
    LCD_write_char(1,9,’n');
    LCD_write_char(1,10,’o');
    while(1);
    爱板商城购买链接:
    猛戳 https://www.cirmall.com/shop/?c=products&a=view&id=221
  • 签到天数: 11 天
    发表于 2013-3-14 11:36:18 | 显示全部楼层
    详细代码都有,太强了  LZ
  • 签到天数: 1341 天
    发表于 2013-3-15 19:22:11 | 显示全部楼层
    代码转换是什么意思呢
    发表于 2013-3-19 13:36:42 | 显示全部楼层
    碉堡了,这专业性真强
  • 签到天数: 359 天
    发表于 2013-6-7 09:41:04 | 显示全部楼层
    不知道您说的代码转换什么意思 可否详细解释一下呢
  • 签到天数: 1018 天
     楼主| 发表于 2013-6-7 10:14:02 | 显示全部楼层
    这个问题可以找版主@pcduino 进行咨询!
    发表于 2013-6-13 22:49:00 | 显示全部楼层
    我买了!GY-80 想放飞pcDuino 等芯片到了拜托版主也给我代码转换一下!
    郁闷
    2013-6-3 09:22
  • 签到天数: 29 天
    [LV.4]偶尔看看III
    发表于 2013-6-14 09:30:26 | 显示全部楼层
    我就是想说欣欣哪里搞的“代码转换”,这里不是一个功能,翻译有问题。。。这里就是移植嘛
    GMT+8, 2025-1-20 19:23 , Processed in 0.178529 second(s), 30 queries , MemCache On.
