查看: 2182|回复: 0
Marvell ESPRESSObin评测-安装深度学习工具#3芯片介绍
发表于 2017-5-2 15:36:45 | 显示全部楼层 |阅读模式
1、芯片介绍Armada 3700
Marvell® ARMADA® 3700 是双核 Cortex-A53 ARMv8高性能SoC, 包括以下功能:
2 x Gigabit Ethernet 1Gbps / 2.5Gbps
SGMII / HS-SGMII / RGMII
Compatible with Marvell NBASE-T Transceivers
USB 3.0 Host/Device compatible with xHCI v1.0
USB 2.0 Host
PCI Express (PCIe) 2.0 (RC or EP)
SATA 3.0
DMA, 2 x high-bandwidth DMA/XOR/CRC engines
Flash and Peripheral I/Os, including 2 x SDIO 3/0. SPI, UART, GPIOs
Integrated power switches for dynamic shut-down of
Dual core ARMv8 Cortex-A53 CPU
CPU core operating speed of up to 1.2 GHz
FIPS-140 certified
32 KB-Instruction / Data (4-way) set associative L1 cache with Parity/ECC protection
芯片的原理结构图如下,
2、开发板
原理图如下,充分把端口都引出并连接出来。
GMT+8, 2024-11-20 11:26 , Processed in 0.114752 second(s), 16 queries , MemCache On.
