TA的每日心情 | 奋斗 2014-7-16 09:10 |
签到天数: 361 天 连续签到: 1 天 [LV.8]以坛为家I
The SAMA5D35-EK is a full-featured evaluation platform for the Atmel SAMA5D35
embedded microprocessor. The kit consists of a main board and a computer module equipped with a SAMA5D35 processor. It is supported by the SAMA5D3 Softpack, a free set of bare metal C examples, and is delivered with on-board demos for Linux and Qt-based GUI. The SAMA5D35-EK allows users to extensively evaluate, prototype and create applications that require audio, mass storage, networking, connectivity and more.
Source files and binaries for the on-board demo are available on Linux4SAM, the entry point to open source solutions for Atmel ARM® core-based embedded microprocessors.
关键特征:- Atmel SAMA5D35 embedded MPU running at 536MHz in a BGA324 package
- 4Gb DDR2, 2Gb NAND Flash, 128Mb NOR , 32Mb SPI Serial DataFlash, 512Kb EEPROM
- JLink and CDC on-board, optional JTAG test access port
- MII/RMII Ethernet 10/100 w/PHY
- RGMII Ethernet 1Gb w/PHY
- Four-wire RS232
- Two USB 2.0 Hosts, one USB 2.0 Host/Device
- Conexant CX20548 SmartDAA for soft modem implementation
- MicroSD card slot
- MMC/MMC+/SD/SDIO/CE-ATA
- Headphone output, line in and microphone
- One ISI interface for connection to a CMOS sensor
- One HDMI interface
- One 10-pin connector for Atmel RZ600 ZigBee® module
- Two CAN connectors
