查看: 2230|回复: 0
刚开始系统学习FPGA
    慵懒
    2017-2-27 03:33
    发表于 2017-2-27 03:33:35 | 显示全部楼层 |阅读模式
    刚开始系统学习FPGA,写了一个带按键消抖的按键数码管计数器,但是有一个问题,复位以后数码管显示的不是0,是1,有点不理解。
    贴代码:
    `timescale 1ns / 1ps
    module prj_keyseg
            //输入端口
            clk,rst_n,key,
            //输出端口
            SEG_DATA,SEG_EN
    //--        外部端口声明
    input                                        clk;                                //时钟的端口,开发板用的50MHz晶振
    input                                        rst_n;                                //复位的端口,低电平复位
    input                key;                                        //对应开发板上的key
    output           SEG_EN;                                //数码管使能端口
    output                  [6:0]SEG_DATA;                        //数码管数据端口(查看管脚分配文档或者原理图)
    //----按键消抖程序
    reg key_rst;
    always @(posedge clk  or negedge rst_n)
        if (!rst_n) key_rst <= 1'b1;
        else key_rst <= key;
    reg key_rst_r;
    always @ ( posedge clk  or negedge rst_n )
        if (!rst_n) key_rst_r <= 1'b1;
        else key_rst_r <= key_rst;
    //当寄存器key_rst由1变为0时,led_an的值变为高,维持一个时钟周期
    wire key_an = key_rst_r & ( ~key_rst);
    reg[19:0]  cnt;        //计数寄存器
    always @ (posedge clk  or negedge rst_n)
        if (!rst_n) cnt <= 20'd0;        //异步复位
            else if(key_an) cnt <=20'd0;
        else cnt <= cnt + 1'b1;
    reg low_sw;
        if (!rst_n) low_sw <= 1'b1;
        else if (cnt == 20'hfffff)         //满20ms,将按键值锁存到寄存器low_sw中         cnt == 20'hfffff
          low_sw <= key;
    reg   low_sw_r;
        if (!rst_n) low_sw_r <= 1'b1;
        else low_sw_r <= low_sw;
    //当寄存器low_sw由1变为0时,seg_ctrl的值变为高,维持一个时钟周期
    wire seg_ctrl = low_sw_r & ( ~low_sw);
    reg[3:0] num;        //显示数值
            if(!rst_n) num <= 4'h0;   //复位数字清零
            else if(seg_ctrl)
                            begin
                                    if(num<4'h9) num<=num+1'd1;    //按键按一次,数码管加一
                                    else num<=4'h0;
                            end
    /*        共阴极 :不带小数点
                  ;0,  1,  2,  3,  4, 5,  6,  7,
          db      3fh,06h,5bh,4fh,66h,6dh,7dh,07h
                  ;8,  9, a,  b,   c,  d,  e,  f , 灭
          db      7fh,6fh,77h,7ch,39h,5eh,79h,71h,00h*/
    parameter        seg0        = 7'h3f,
                            seg1        = 7'h06,
                            seg2        = 7'h5b,
                            seg3        = 7'h4f,
                            seg4        = 7'h66,
                            seg5        = 7'h6d,
                            seg6        = 7'h7d,
                            seg7        = 7'h07,
                            seg8        = 7'h7f,
                            seg9        = 7'h6f;
    reg[6:0] SEG_DATAR;                //7段数码管(不包括小数点)
    always @ (num)
                    case (num)        //NUM值显示在两个数码管上
                            4'h0: SEG_DATAR <= seg0;
                            4'h1: SEG_DATAR <= seg1;
                            4'h2: SEG_DATAR <= seg2;
                            4'h3: SEG_DATAR <= seg3;
                            4'h4: SEG_DATAR <= seg4;
                            4'h5: SEG_DATAR <= seg5;
                            4'h6: SEG_DATAR <= seg6;
                            4'h7: SEG_DATAR <= seg7;
                            4'h8: SEG_DATAR <= seg8;
                            4'h9: SEG_DATAR <= seg9;
                            default: ;
                            endcase
    assign SEG_DATA = SEG_DATAR;
    assign SEG_EN = 1'b0;                //数码管常开
    endmodule
    GMT+8, 2024-11-19 07:46 , Processed in 0.111248 second(s), 15 queries , MemCache On.
