查看: 5506|回复: 2
[求助] 换了sources后,update,报错了,求助啊
    擦汗
    2013-1-16 14:35
  • 签到天数: 2 天
    发表于 2013-1-12 01:07:11 | 显示全部楼层 |阅读模式
    pi@raspberrypi:~$ sudo apt-get update
    Hit http://downloads.raspberrypi.org wheezy InRelease
    Hit http://archive.raspberrypi.org wheezy InRelease
    Hit http://archive.raspberrypi.org wheezy/main armhf Packages
    Get:1 http://downloads.raspberrypi.org wheezy/main armhf Packages [7,402 kB]
    Get:2 http://downloads.raspberrypi.org wheezy/contrib armhf Packages [23.3 kB]
    Get:3 http://downloads.raspberrypi.org wheezy/non-free armhf Packages [47.7 kB]
    Ign http://archive.raspberrypi.org wheezy/main Translation-en_SG
    Hit http://downloads.raspberrypi.org wheezy/rpi armhf Packages
    Ign http://downloads.raspberrypi.org wheezy/contrib Translation-en_SG
    Ign http://downloads.raspberrypi.org wheezy/main Translation-en_SG
    Ign http://downloads.raspberrypi.org wheezy/non-free Translation-en_SG
    Ign http://downloads.raspberrypi.org wheezy/rpi Translation-en_SG
    Fetched 3 B in 43s (0 B/s)
    W: Failed to fetch bzip2:/var/lib/apt/lists/partial/downloads.raspberrypi.org_raspbian_raspbian_dists_wheezy_main_binary-armhf_Packages  Hash Sum mismatch
    W: Failed to fetch bzip2:/var/lib/apt/lists/partial/downloads.raspberrypi.org_raspbian_raspbian_dists_wheezy_contrib_binary-armhf_Packages  Hash Sum mismatch
    W: Failed to fetch bzip2:/var/lib/apt/lists/partial/downloads.raspberrypi.org_raspbian_raspbian_dists_wheezy_non-free_binary-armhf_Packages  Hash Sum mismatch
    E: Some index files failed to download. They have been ignored, or old ones used instead.
    pi@raspberrypi:~$
  • 签到天数: 15 天
    [LV.4]偶尔看看III
    发表于 2013-1-12 15:06:11 | 显示全部楼层
    powerdruy 发表于 2013-1-12 10:11
    你换的源地址是啥
    在国内应该就用新加坡的那个源,我的帖子里有讲过的
    周末还在网上呆着呀,呵呵
    擦汗
    2013-1-16 14:35
  • 签到天数: 2 天
    发表于 2013-1-12 20:23:18 | 显示全部楼层
    你换的源地址是啥
    deb http://mirror.nus.edu.sg/raspbian/raspbian/ wheezy main contrib non-free rpi
    deb-src http://mirror.nus.edu.sg/raspbian/raspbian/ wheezy main contrib non-free rpi
    deb http://archive.raspbian.org/raspbian/ wheezy main contrib non-free rpi
    deb-src http://archive.raspbian.org/raspbian/ wheezy main contrib non-free rpi
    我目前的文件内荣。
    找到原因了,是把后面的deb写到上面的一行末尾去了。
    GMT+8, 2024-11-19 04:39 , Processed in 0.160972 second(s), 18 queries , MemCache On.
