查看: 3163|回复: 1
香蕉派 BPI-M2 Ultra利用opencv实现人脸检测
  • 签到天数: 216 天
    [LV.7]常住居民III
    发表于 2017-2-8 12:52:59 | 显示全部楼层 |阅读模式
        前面给出了相关的环境搭建和具体步骤,这里只是给出具体的代码和实验效果,结合相关的步骤进行说明,实验如下:
    步骤一:搭建opencv开发环境
    参考前面步骤
    步骤二:安装SimpleCV库函数
    1. sudo apt-get install ipython python-opencv python-scipy python-numpy python-setuptools
    2. python-pip
    3. sudo pip install https://github.com/ingenuitas/SimpleCV/zipball/master
    4. sudo apt-get install python-pygame
    5. sudo apt-get install python-imaging
    步骤三:开发插入UVC摄像头并测试
    步骤四:Python实现人脸识别程序
    1. #!/usr/bin/env python
    2. from SimpleCV import *
    3. from time import sleep
    4. myCamera = Camera(prop_set={'width':320, 'height': 240})
    5. myDisplay = Display(resolution=(320, 240))
    6. while not myDisplay.isDone():
    7.    frame = myCamera.getImage()
    8.    faces = frame.findHaarFeatures('face')
    9.    if faces:
    10.      for face in faces:
    11.         print "Face at: " + str(face.coordinates())
    12.         facelayer = DrawingLayer((frame.width,frame.height))
    13.         w=face.width()
    14.         h=face.height()
    15.         print "x:"+str(w)+" y:"+str(h)
    16.         facebox_dim = (w,h)
    17.         facebox = facelayer.centeredRectangle(face.coordinates(),facebox_dim)
    18.         frame.addDrawingLayer(facelayer)
    19.         frame.applyLayers()
    20.                 print "faces has detected."
    21.    else:
    22.         print "No faces detected."
    23.    frame.save(myDisplay)
    24.    sleep(.1)
    说明:
    myCamera =Camera(prop_set={'width':320, 'height': 240})
    #指定摄像头影像尺寸
    myDisplay =Display(resolution=(320, 240))
    #显示窗口大小
    frame =myCamera.getImage()
    #获取视频流摄像头影像
    faces =frame.findHaarFeatures('face')
    #寻找人脸
    facebox =facelayer.centeredRectangle(face.coordinates(),facebox_dim)
    #框出识别到的人脸并把图层放到画面上
    print "Nofaces detected."
    #如果未检测到人脸打印信息
    效果
  • 签到天数: 736 天
    发表于 2017-2-8 16:31:49 | 显示全部楼层
    赞一个,可以进一步区别不同的人脸吗?
    GMT+8, 2025-1-19 19:37 , Processed in 0.130325 second(s), 20 queries , MemCache On.
