TA的每日心情 | 开心 2017-2-20 09:01 |
签到天数: 35 天 连续签到: 1 天 [LV.5]常住居民I
发表于 2013-1-8 11:11:07
显示全部楼层
血染盔甲 发表于 2013-1-8 10:52
有源usbhub应该不是必要的,硬盘线不是还有一根补充电源的吗,把它插上一个手机的充电器就差不多了,你不 ...
pi@raspberrypi /dev $ sudo mount -t ntfs-3g /dev/sda1 /media/USBHDD
Error opening '/dev/sda1': No such device or address
Failed to mount '/dev/sda1': No such device or address
Either the device is missing or it's powered down, or you have
SoftRAID hardware and must use an activated, different device under
/dev/mapper/, (e.g. /dev/mapper/nvidia_eahaabcc1) to mount NTFS.
Please see the 'dmraid' documentation for help.
通过dmesg 信息如下:
[ 178.792010] sd 0:0:0:0: [sda] 976773164 512-byte logical blocks: (500 GB/465 GiB)
[ 178.793010] sd 0:0:0:0: [sda] Write Protect is off
[ 178.793041] sd 0:0:0:0: [sda] Mode Sense: 03 00 00 00
[ 178.794123] sd 0:0:0:0: [sda] No Caching mode page present
[ 178.794149] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 178.799244] sd 0:0:0:0: [sda] No Caching mode page present
[ 178.799272] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 178.846745] sda: sda1 < sda5 sda6 sda7 >
[ 178.851399] sd 0:0:0:0: [sda] No Caching mode page present
[ 178.851430] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 178.851450] sd 0:0:0:0: [sda] Attached SCSI disk
[ 179.265864] usb 1-1.2: USB disconnect, device number 4
[ 179.275726] scsi 0:0:0:0: rejecting I/O to offline device
[ 179.275763] scsi 0:0:0:0: [sda] killing request
[ 179.275844] scsi 0:0:0:0: [sda] Unhandled error code
[ 179.275861] scsi 0:0:0:0: [sda] Result: hostbyte=0x01 driverbyte=0x00
[ 179.275883] scsi 0:0:0:0: [sda] CDB: cdb[0]=0x28: 28 00 3a 38 4c 2c 00 00 08 00
[ 179.275924] end_request: I/O error, dev sda, sector 976768044
[ 179.275947] Buffer I/O error on device sda7, logical block 362362056
[ 179.275970] Buffer I/O error on device sda7, logical block 362362057
[ 179.275987] Buffer I/O error on device sda7, logical block 362362058
[ 179.276004] Buffer I/O error on device sda7, logical block 362362059
[ 179.276020] Buffer I/O error on device sda7, logical block 362362060
[ 179.276036] Buffer I/O error on device sda7, logical block 362362061
[ 179.276052] Buffer I/O error on device sda7, logical block 362362062
[ 179.276068] Buffer I/O error on device sda7, logical block 362362063
[ 179.276132] scsi 0:0:0:0: rejecting I/O to offline device
[ 179.276151] scsi 0:0:0:0: [sda] killing request
[ 179.276246] scsi 0:0:0:0: [sda] Unhandled error code
[ 179.276263] scsi 0:0:0:0: [sda] Result: hostbyte=0x01 driverbyte=0x00
[ 179.276282] scsi 0:0:0:0: [sda] CDB: cdb[0]=0x28: 28 00 24 9f 17 14 00 00 08 00
[ 179.276319] end_request: I/O error, dev sda, sector 614405908
[ 179.276338] Buffer I/O error on device sda6, logical block 409593160
[ 179.276356] Buffer I/O error on device sda6, logical block 409593161
[ 306.926558] fuse init (API version 7.17)
[ 6898.230022] usb 1-1.2: new high-speed USB device number 5 using dwc_otg
[ 6898.332301] usb 1-1.2: New USB device found, idVendor=05e3, idProduct=0718
[ 6898.332333] usb 1-1.2: New USB device strings: Mfr=0, Product=1, SerialNumber=2
[ 6898.332349] usb 1-1.2: Product: USB Storage
[ 6898.332361] usb 1-1.2: SerialNumber: 000000000033
[ 6898.349983] scsi1 : usb-storage 1-1.2:1.0
[ 6899.352941] scsi 1:0:0:0: Direct-Access WDC WD50 00AAKS-00V1A0 0009 PQ: 0 ANSI: 0
