在常规的Arduino UNO驱动库中,对于LCD5110的驱动程序一般是缺少中文支持的,恰逢圣诞来临之际,就以“圣诞快乐”的界面制作来介绍一下实现中文显示的方法。 1. 以3310液晶显示屏绘制提取程序来提取汉字字模,其操作如图1所示。
图1 提取中文字模
2. 建立一个名为chinese.h的头文件,将字模存入该文件。 - const unsigned char chinese_character[][24]=
- //圣
- {0x40,0x42,0x26,0x2A,0x12,0xD2,0x12,0x2A,0x26,0x42,0x40,0x00,0x08,0x08,0x09,0x09,0x09,0x0F,0x09,0x09,0x09,0x08,0x08,0x00},
- //诞
- {0x11,0xF2,0x00,0x72,0xCE,0x00,0xF2,0x02,0xFE,0x11,0x11,0x00,0x00,0x07,0x0A,0x04,0x0B,0x08,0x09,0x09,0x09,0x09,0x09,0x00},
- //快
- {0x78,0x00,0xFF,0x48,0x44,0x44,0xFF,0x44,0x44,0x7C,0x40,0x00,0x00,0x00,0x0F,0x08,0x04,0x03,0x00,0x03,0x04,0x08,0x08,0x00},
- //乐
- {0x00,0x3E,0xA2,0x22,0x22,0xFA,0x21,0x21,0xA1,0x20,0x00,0x00,0x04,0x02,0x01,0x08,0x08,0x0F,0x00,0x00,0x00,0x01,0x06,0x00},
复制代码 3. 将Arduino UNO与LCD5110连接起来,其连接关系如下: VCC -- 3.3V GND -- GND LCD_CS -- 4 LCD_DIN -- 5 LCD_CLK -- 6 LCD_RST -- 7 LCD_DC -- 8 VO -- 3.3V 4. 在LCD5110驱动库中添加语句 #include "chinese.h",以引入自行构建的小字库。然后再添加如下的汉字显示函数。 - void LCD_write_hanzi(uint8_t X,uint8_t Y,uint8_t s)
- do
- char line;
- NOKIA5110_set_XY(X,Y);
- for (line=0; line<12; line++)
- NOKIA5110_write_byte(chinese_character[s][line], NOKIA5110_DATA);
- NOKIA5110_set_XY(X,Y+1);//LCD_set_XY(X,Y+1);
- for (line=12; line<24; line++)
- }while(0);
复制代码 此外,再添加如下的主处理函数。 - void Main_Deal ()
- NOKIA5110_init();
- NOKIA5110_clear_screen();
- LCD_write_hanzi(0,0,0);
- LCD_write_hanzi(12,0,1);
- LCD_write_hanzi(24,0,2);
- LCD_write_hanzi(36,0,4);
- NOKIA5110_display_8x6_text (0, 2, "merry christmas");
- NOKIA5110_display_8x6_text (0, 4, " 2016.12.24");
- while (1);
复制代码5. 经编译与下载,其显示效果如图2所示。
图2 中文显示效果
