12
返回列表 发新帖
楼主: lxc115
[12月26日更新]关于Keil 创建LM4F120 新工程的问题
    发表于 2013-1-15 13:45:52 | 显示全部楼层
    cn_x 发表于 2013-1-14 12:45
    ROM_SysCtlClockSet(SYSCTL_SYSDIV_4|SYSCTL_USE_PLL|SYSCTL_XTAL_16MHZ|
                        SYSCTL_OSC_ ...
    找到什么原因了么,我看着也不知道哪里出错
    无聊
    2018-3-6 09:47
  • 签到天数: 51 天
    [LV.5]常住居民I
    发表于 2013-1-15 14:24:11 | 显示全部楼层
    我找到答案了
    I think you may be running into the max flash read speed.  The flash can only read at 40 Mhz.  We have a pre-fetch buffer mechanism to fetch 2 words instead of one when running faster than 40 mhz.  In a tight loop like the SysCtlDelay you may find that the the pre-fetch cannot do it's job well due to the jumping in the loop.
    Some things to try that might verify this is true.
    Change SYSCTL_SYSDIV_2_5 to SYSCTL_SYSDIV_5.  See if the delay is exactly twice as long or if you are hitting the read time limit then the delay will be the same.
    A second test would be to try using ROM_SysCtlDelay() with the rest of your software the same as shown.  The ROM can run at the full 80Mhz and will not be slowed down.
    Dexter
    链接
    http://e2e.ti.com/support/microc ... f/471/t/143842.aspx
    发表于 2013-1-16 19:44:05 | 显示全部楼层
    cn_x 发表于 2013-1-15 14:24
    我找到答案了
    I think you may be running into the max flash read speed.  The flash can only read at 4 ...
    原来是flash和rom的读取速度的限制啊?
    发表于 2013-1-17 10:06:28 | 显示全部楼层
    我找到答案了
    已验证。
    ROM_SysCtlClockSet(SYSCTL_SYSDIV_4|SYSCTL_USE_PLL|SYSCTL_XTAL_16MHZ|SYSCTL_OSC_MAIN;
    ROM_SysCtlDelay(SysCtlClockGet()/3);
    延时1s,说明没有达到ROM的读取速度限制。
    SysCtlClockSet(SYSCTL_SYSDIV_4|SYSCTL_USE_PLL|SYSCTL_XTAL_16MHZ| SYSCTL_OSC_MAIN);
    延时2s,超过Flash读取速度上限,如果改为:
    SysCtlClockSet(SYSCTL_SYSDIV_5|SYSCTL_USE_PLL|SYSCTL_XTAL_16MHZ| SYSCTL_OSC_MAIN);
    是系统运行在40MHz,延时仍然是1s。
    GMT+8, 2024-12-20 13:23 , Processed in 0.149009 second(s), 19 queries , MemCache On.
