查看: 3260|回复: 5
基于GD32F190的非接触智能卡模块,之SPI接口函数设计
  • 签到天数: 56 天
    [LV.5]常住居民I
    发表于 2016-6-7 19:08:48 | 显示全部楼层 |阅读模式
    void SPI_RC522_Init(void)
        GPIO_InitPara  GPIO_InitStructure;
        SPI_InitPara  SPI_InitStructure;
        RCC_AHBPeriphClock_Enable(RCC_AHBPERIPH_GPIOB, ENABLE);
        RCC_APB2PeriphClock_Enable(RCC_APB2PERIPH_SPI1, ENABLE);
        /* GPIO AF configuration */
        GPIO_PinAFConfig(GPIOB, GPIO_PINSOURCE13, GPIO_AF_0);
        GPIO_PinAFConfig(GPIOB, GPIO_PINSOURCE14, GPIO_AF_0);
        GPIO_PinAFConfig(GPIOB, GPIO_PINSOURCE15, GPIO_AF_0);
        /* SPI1_CLK(PB13),  SPII_MISO(PB14) and SPII_MOSI(PB15) GPIO pin configuration */
        GPIO_InitStructure.GPIO_Pin = GPIO_PIN_13 | GPIO_PIN_14 | GPIO_PIN_15;
        GPIO_InitStructure.GPIO_Speed = GPIO_SPEED_50MHZ;
        GPIO_InitStructure.GPIO_Mode    = GPIO_MODE_AF;
        GPIO_InitStructure.GPIO_OType   = GPIO_OTYPE_PP;
        GPIO_InitStructure.GPIO_PuPd    = GPIO_PUPD_NOPULL;
        GPIO_Init(GPIOB, &GPIO_InitStructure);
        /* SPII_CS(PD2) GPIO pin configuration */
        GPIO_InitStructure.GPIO_Pin = GPIO_PIN_12;
        GPIO_InitStructure.GPIO_Mode    = GPIO_MODE_OUT;
        /* Chip select invalid*/
        GPIO_SetBits(GPIOB, GPIO_PIN_12);
        /* SPI1 configuration */
        SPI_InitStructure.SPI_TransType = SPI_TRANSTYPE_FULLDUPLEX;
        SPI_InitStructure.SPI_Mode = SPI_MODE_MASTER;
        SPI_InitStructure.SPI_FrameFormat = SPI_FRAMEFORMAT_8BIT;
        SPI_InitStructure.SPI_SCKPL = SPI_SCKPL_LOW;
        SPI_InitStructure.SPI_SCKPH = SPI_SCKPH_1EDGE;
        SPI_InitStructure.SPI_SWNSSEN = SPI_SWNSS_SOFT;
        SPI_InitStructure.SPI_PSC = SPI_PSC_8;
        SPI_InitStructure.SPI_FirstBit = SPI_FIRSTBIT_MSB;
        SPI_InitStructure.SPI_CRCPOL = 7;
        SPI_Init(SPI1, &SPI_InitStructure);
        SPI_Enable(SPI1, ENABLE);
    后面对RC522操作就简单了,直接使用固件库中SPI读写函数:
    写一字节:
    int32_t SPI_WriteByte(SPI_TypeDef* SPIx, uint16_t TxData)
            uint8_t retry=0;
            while (SPI_I2S_GetBitState(SPIx, SPI_FLAG_TBE) == RESET) //等待发送区空
                    retry++;
                    if(retry>200) return -1;
            SPI_I2S_SendData(SPIx,TxData);                                                   //发送一个byte
    读一字节:
    注意该函数是接收缓存区返回的数据,对SPI接口没有操作。需要先检测是否收到数据
    uint16_t SPI_ReadByte(SPI_TypeDef* SPIx)
            uint8_t retry=0;
            unit16_t result;
            while (SPI_I2S_GetBitState(SPIx, SPI_FLAG_RBNE) == RESET)                                //等待接收完一个byte
                    retry++;
                    if(retry>200)return -1;
            result=SPI_I2S_ReceiveData( SPIx );
            return result;                                          //返回收到的数据
  • 签到天数: 1354 天
    发表于 2016-6-7 22:45:15 | 显示全部楼层
    写的好,参考和学习
  • 签到天数: 827 天
    发表于 2016-6-8 00:17:49 | 显示全部楼层
             RC522?
  • 签到天数: 56 天
    [LV.5]常住居民I
     楼主| 发表于 2016-6-8 09:35:01 | 显示全部楼层
    suoma 发表于 2016-6-8 00:17
    RC522?
    这个程序暂时是用RC522模块调的
  • 签到天数: 827 天
    发表于 2016-6-8 20:11:55 | 显示全部楼层
    lgxeefouse 发表于 2016-6-8 09:35
    这个程序暂时是用RC522模块调的
    可以将整个工程分享一下吗?我也在用RC522
  • 签到天数: 56 天
    [LV.5]常住居民I
     楼主| 发表于 2016-6-9 13:06:15 | 显示全部楼层
    没有问题,本来就准备开源的
    GMT+8, 2025-2-6 00:13 , Processed in 0.152126 second(s), 25 queries , MemCache On.
