查看: 4195|回复: 1
【望月追忆】带你入门STM32F0之三:按键----查询方式
  • 签到天数: 16 天
    [LV.4]偶尔看看III
    发表于 2012-12-7 15:17:18 | 显示全部楼层 |阅读模式
    按键查询方式,无非就是读按键对应引脚的电平,下面直接贴代码
    1.按键引脚初始化
    1. void KEY_Init(void)
    2. {
    3.         /* GPIOC Periph clock enable */
    4.         GPIO_InitTypeDef  GPIO_InitStructure;
    5.         RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOF, ENABLE);
    6.   /* Configure PF6 and PF7 in input pushpull mode */
    7.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7;
    8.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN;
    9.   GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
    10.         GPIO_InitStructure.GPIO_Speed =GPIO_Speed_Level_2;
    11.   GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
    12.   GPIO_Init(GPIOF, &GPIO_InitStructure);
    13. }
    2.读取按键引脚电平
    1. uint8_t ReadKeyValue(void)
    2. {
    3.         uint8_t key_value = 0xFF;
    4.         if(GPIO_ReadInputDataBit(GPIOF, GPIO_Pin_6) == Bit_RESET)
    5.         {
    6.                 SysTick_Delay_nms(10);
    7.                 if(GPIO_ReadInputDataBit(GPIOF, GPIO_Pin_6) == Bit_RESET)
    8.                 {
    9.                         key_value = KEY1;
    10.                 }
    11.         }
    12.
    13.         if(GPIO_ReadInputDataBit(GPIOF, GPIO_Pin_7) == Bit_RESET)
    14.         {
    15.                 SysTick_Delay_nms(10);
    16.                 if(GPIO_ReadInputDataBit(GPIOF, GPIO_Pin_7) == Bit_RESET)
    17.                 {
    18.                         key_value = KEY2;
    19.                 }
    20.         }
    21.
    22.         return key_value;
    23. }
    3.按键控制小灯
    1. LED_Init();
    2.         KEY_Init();
    3.   while (1)
    4.   {
    5.                 if(ReadKeyValue() == KEY1)
    6.                 {
    7.                         LED_Ctrl(LED1, LED_ON);
    8.                         LED_Ctrl(LED2, LED_OFF);
    9.                 }
    10.
    11.                 if(ReadKeyValue() == KEY2)
    12.                 {
    13.                         LED_Ctrl(LED1, LED_OFF);
    14.                         LED_Ctrl(LED2, LED_ON);
    15.                 }
    16.   }
  • 签到天数: 188 天
    [LV.7]常住居民III
    发表于 2012-12-11 14:04:15 | 显示全部楼层
    坐个沙发
    GMT+8, 2025-1-12 01:37 , Processed in 0.131462 second(s), 17 queries , MemCache On.
