查看: 2874|回复: 1
【LinkSprite试用】HRM检测问题
  • 签到天数: 827 天
    发表于 2016-4-17 21:41:39 | 显示全部楼层 |阅读模式
    接上一个帖子https://www.cirmall.com/bbs/thread-47276-1-1.html
    在手机端安装NORDIC官方的NRF TOOLBOX应用,这是NORDIC官方的工具箱,内置丰富的测试功能。
    在mbed界面选择import,程序库里搜索BLE_HeartRate程序并将它导入到MBED中。
    编译完看见程序和爱板网https://www.cirmall.com/evaluation/mbed-ble-sensors-tag/5/中main程序不一样
    评测文章
    1. int main(void)
    2. {
    3.     led1 = 1;
    4.     led2 = 0;
    5.     Ticker ticker;
    6.     ticker.attach(periodicCallback, 1); // blink LED every second
    7.     BLE& ble = BLE::Instance(BLE::DEFAULT_INSTANCE);
    8.     ble.init(bleInitComplete);
    9.     /* SpinWait for initialization to complete. This is necessary because the
    10.      * BLE object is used in the main loop below. */
    11.     while (ble.hasInitialized()  == false) { /* spin loop */ }
    12.     // infinite loop
    13.     while (1) {
    14.         // check for trigger from periodicCallback()
    15.         if (!key_p)
    16.          {
    17.              wait_ms(10);
    18.              if (!key_p)
    19.               hrmCounter++;
    20.              while (!key_d);
    21.              }
    22.         if (!key_d)
    23.          {
    24.              wait_ms(10);
    25.              if (!key_d)
    26.               hrmCounter--;
    27.               while (!key_d);
    28.         }
    29.         hrService->updateHeartRate(hrmCounter);
    30.             ble.waitForEvent(); // low power wait for event
    31.
    32.     }
    33. }
    mbed库文件如下
    1. int main(void)
    2. {
    3.     led1 = 1;
    4.     Ticker ticker;
    5.     ticker.attach(periodicCallback, 1); // blink LED every second
    6.     BLE& ble = BLE::Instance(BLE::DEFAULT_INSTANCE);
    7.     ble.init(bleInitComplete);
    8.     /* SpinWait for initialization to complete. This is necessary because the
    9.      * BLE object is used in the main loop below. */
    10.     while (ble.hasInitialized()  == false) { /* spin loop */ }
    11.     // infinite loop
    12.     while (1) {
    13.         // check for trigger from periodicCallback()
    14.         if (triggerSensorPolling && ble.getGapState().connected) {
    15.             triggerSensorPolling = false;
    16.             // Do blocking calls or whatever is necessary for sensor polling.
    17.             // In our case, we simply update the HRM measurement.
    18.             hrmCounter++;
    19.             if (hrmCounter == 175) { //  100 <= HRM bps <=175
    20.                 hrmCounter = 100;
    21.             }
    22.             hrService->updateHeartRate(hrmCounter);
    23.         } else {
    24.             ble.waitForEvent(); // low power wait for event
    25.         }
    26.     }
    27. }
    我把两个文件都编译下载进开发板,手机选择“linksprite”连接后显示如下问题“the devices don't require services”,后就自动退出连接,HRM心跳检测没能显示
    其中评测文章程序开发板显示如下
  • 签到天数: 827 天
     楼主| 发表于 2016-4-17 21:43:11 | 显示全部楼层
    之前LED是粉色,现在是红色,也算是一个发现
    GMT+8, 2025-1-20 16:53 , Processed in 0.117927 second(s), 18 queries , MemCache On.
