查看: 14387|回复: 22
[教程] 树莓派驱动rgb点阵显示屏
  • 签到天数: 78 天
    [LV.6]常住居民II
    发表于 2016-3-27 21:55:01 | 显示全部楼层 |阅读模式
    一星期前,淘到块32*64 RGB点阵显示屏,回来,马上接stm32试了下,没有坏点。全部点亮,是1/16扫描,也就是说是标准接口
    接口特写:
    0x02:驱动
    得益于强大的树莓派社区,发现个rgb点阵项目。直接拿来用不错:https://github.com/hzeller/rpi-rgb-led-matrix
    项目是支持RPI B / B+ / 2B 的,所以提供了3种接线方法。实际我接线是采用 “[1]” 的接线方法只用到前26个gpio 为嘛不采用2 或3的接线方法呢,是因为我没有40pin的PI ,只有个B 。
    0x03:运行
    1. wget https://github.com/hzeller/rpi-rgb-led-matrix/archive/master.zip
    解压缩:
    1. unzip master.zipcd rpi-rgb-led-matrix-master/
    进入目录:
    1. cd rpi-rgb-led-matrix-master/
    编译:
    1. make
    运行:
    1. ./led-matrix
    会弹出如下提示:
    1. usage: ./led-matrix <options> -D <demo-nr> [optional parameter]Options:
    2. -r <rows> : Display rows. 16 for 16x32, 32 for 32x32. Default: 32
    3. -c <chained> : Daisy-chained boards. Default: 1.
    4. -L : 'Large' display, composed out of 4 times 32x32
    5. -p <pwm-bits> : Bits used for PWM. Something between 1..7
    6. -g : Do gamma correction (experimental)
    7. -D <demo-nr> : Always needs to be set
    8. -d : run as daemon. Use this when starting in
    9.       /etc/init.d, but also when running without
    10.       terminal (e.g. cron).
    11. -t <seconds> : Run for these number of seconds, then exit.
    12.          (if neither -d nor -t are supplied, waits for <RETURN>)
    13. Demos, choosen with -D
    14. 0 - some rotating square
    15. 1 - forward scrolling an image (-m <scroll-ms>)
    16. 2 - backward scrolling an image (-m <scroll-ms>)
    17. 3 - test image: a square
    18. 4 - Pulsing color
    19. Example:
    20. ./led-matrix -t 10 -D 1 runtext.ppm
    21. Scrolls the runtext for 10 seconds
    运行测试demo:
    1. sudo ./led-matrix -d -r 32 -c 2 -t 20 -D 1 runtext.ppm #-d 会后台运行,-t 运行时间  -r 32 -c 2 指定是32*64点阵显示
    1. (while :; do date +%T ; sleep 0.5 ; done) | sudo ./text-example -f fonts/8x13B.bdf -y8 -c2 -C 255,255,255
    之后嘿嘿就可以看到rgb 点阵屏上显示信息:(滚动显示ppm图片内容,懒得弄gif 了假装图片会动)
    显示字符demo:
    1. (while :; do date +%T ; sleep 0.5 ; done) | sudo ./text-example -f fonts/8x13B.bdf -y8 -c2 -C 255,255,255<p style="line-height: 28px;"></p>
    实际上更有意思的是显示图片玩
    1. sudo aptitude install libgraphicsmagick++-dev libwebp-dev
    效果嘛如下:
    参考文献:
  • 签到天数: 78 天
    [LV.6]常住居民II
     楼主| 发表于 2016-3-27 22:12:58 | 显示全部楼层
    沙发自己坐
  • 签到天数: 1018 天
    发表于 2016-3-28 10:30:36 | 显示全部楼层
    假装图片会动,我也是醉了
    昨天 11:18
  • 签到天数: 2873 天
    [LV.Master]伴坛终老
    发表于 2016-4-6 15:08:42 | 显示全部楼层
    手机现在拍GIF也很方便,和拍照片一样
  • 签到天数: 216 天
    [LV.7]常住居民III
    发表于 2016-8-10 16:28:53 | 显示全部楼层
    这个好!抱走了~话说没有爆闪的现象吧?
    3 天前
  • 签到天数: 1472 天
    发表于 2016-8-16 01:08:36 来自手机 | 显示全部楼层
    好玩,也找块试试。
  • 签到天数: 78 天
    [LV.6]常住居民II
     楼主| 发表于 2016-8-19 22:44:25 | 显示全部楼层
    PokeBox 发表于 2016-8-10 16:28
    这个好!抱走了~话说没有爆闪的现象吧?
    刷新率蛮高。手机拍完全拍不出闪烁。肉眼看也不会闪烁
  • 签到天数: 78 天
    [LV.6]常住居民II
     楼主| 发表于 2016-8-19 22:46:47 | 显示全部楼层
    行色匆匆 发表于 2016-8-16 01:08
    好玩,也找块试试。
    多谢支持。单块分辨率低。还是要搞64*64以上分辨率才震撼。没试过太大。不知道速度能跟上不
  • 签到天数: 216 天
    [LV.7]常住居民III
    发表于 2016-9-6 19:16:00 | 显示全部楼层
    geek1024 发表于 2016-8-19 22:46
    多谢支持。单块分辨率低。还是要搞64*64以上分辨率才震撼。没试过太大。不知道速度能跟上不 ...
    有试过32x64的屏么?我买了块32x64的感觉好像玩不起来……而且现在项目也更新了。
  • 签到天数: 78 天
    [LV.6]常住居民II
     楼主| 发表于 2016-9-7 17:47:57 | 显示全部楼层
    PokeBox 发表于 2016-9-6 19:16
    有试过32x64的屏么?我买了块32x64的感觉好像玩不起来……而且现在项目也更新了。 ...
    32*64完全没问题,我这块不就是32*64的分辨率。实际还可以更高,源项目是用dma传的。
    GMT+8, 2025-1-30 11:04 , Processed in 0.190170 second(s), 33 queries , MemCache On.
