查看: 2392|回复: 4
[原创] 【fireprime】Socket进程通信:CS走起
  • 签到天数: 19 天
    [LV.4]偶尔看看III
    发表于 2015-12-7 15:15:20 | 显示全部楼层 |阅读模式
    首先搭载一个server:
    1. #include <stdio.h>
    2. #include <sys/types.h>
    3. #include <sys/socket.h>
    4. #include <sys/un.h>
    5. #include <linux/kernel.h>
    6. #define UNIX_DOMAIN "/tmp/UNIX.domain"
    7. int main(void)
    8. {
    9.     socklen_t clt_addr_len;
    10.     int listen_fd;
    11.     int com_fd;
    12.     int ret;
    13.     int i;
    14.     static char recv_buf[1024];
    15.     int len;
    16.     struct sockaddr_un clt_addr;
    17.     struct sockaddr_un srv_addr;
    18.     listen_fd=socket(PF_UNIX,SOCK_STREAM,0);
    19.     if(listen_fd<0)
    20.     {
    21.         perror("cannot create communication socket");
    22.         return 1;
    23.     }
    24.
    25.     //set server addr_param
    26.     srv_addr.sun_family=AF_UNIX;
    27.     strncpy(srv_addr.sun_path,UNIX_DOMAIN,sizeof(srv_addr.sun_path)-1);
    28.     unlink(UNIX_DOMAIN);
    29.     //bind sockfd & addr
    30.     ret=bind(listen_fd,(struct sockaddr*)&srv_addr,sizeof(srv_addr));
    31.     if(ret==-1)
    32.     {
    33.         perror("cannot bind server socket");
    34.         close(listen_fd);
    35.         unlink(UNIX_DOMAIN);
    36.         return 1;
    37.     }
    38.     //listen sockfd
    39.     ret=listen(listen_fd,1);
    40.     if(ret==-1)
    41.     {
    42.         perror("cannot listen the client connect request");
    43.         close(listen_fd);
    44.         unlink(UNIX_DOMAIN);
    45.         return 1;
    46.     }
    47.     //have connect request use accept
    48.     len=sizeof(clt_addr);
    49.     com_fd=accept(listen_fd,(struct sockaddr*)&clt_addr,&len);
    50.
    51.     if(com_fd<0)
    52.     {
    53.         perror("cannot accept client connect request");
    54.         close(listen_fd);
    55.         unlink(UNIX_DOMAIN);
    56.         return 1;
    57.     }
    58.     //read and printf sent client info
    59.         printf("\n *******  print client info ****\n");
    60.     for(; ;)
    61.     {
    62.         memset(recv_buf,0,1024);
    63.         int num=read(com_fd,recv_buf,sizeof(recv_buf));
    64.         perror("Receive Message");
    65.                 printf("Message from client (%d) :%s \n",num,recv_buf);
    66.     }
    67.     //close(com_fd);
    68.    // close(listen_fd);
    69.    // unlink(UNIX_DOMAIN);
    70.     return 0;
    71. }
    然后在搞一个client:
    7. int main(void)
    8. {
    9.     int connect_fd;
    10.     int ret;
    11.     char snd_buf[1024];
    12.     int i;
    13.     static struct sockaddr_un srv_addr;
    14.
    15.    //creat unix socket
    16.     connect_fd=socket(PF_UNIX,SOCK_STREAM,0);
    17.     if(connect_fd<0)
    18.     {
    19.         perror("cannot create communication socket");
    20.         return 1;
    21.     }
    22.     srv_addr.sun_family=AF_UNIX;
    23.     strcpy(srv_addr.sun_path,UNIX_DOMAIN);
    24.
    25.    //connect server
    26.     ret=connect(connect_fd,(struct sockaddr*)&srv_addr,sizeof(srv_addr));
    27.     if(ret==-1)
    28.     {
    29.         perror("cannot connect to the server");
    30.         close(connect_fd);
    31.         return 1;
    32.     }
    33.     memset(snd_buf,0,1024);
    34.     strcpy(snd_buf,"Hello,I am client");
    35. //send info server
    36.     for(i =0;i <5; i++)
    37.         {
    38.                 perror("send message");
    39.         write(connect_fd,snd_buf,sizeof(snd_buf));
    40.                 sleep(2);
    41.      }
    42.     close(connect_fd);
    43.     return 0;
    44. }
    最后编译运行跑起来,哈哈,makefile走起!
    1. server:server.c
    2.         gcc -o  server server.c
    3. client:client.c
    4.         gcc -o client client.c
    5. .PHONY:clean
    6. clean:
    7.         -rm -rf server client
    8.
    运行:
  • 签到天数: 19 天
    [LV.4]偶尔看看III
     楼主| 发表于 2015-12-7 15:15:47 | 显示全部楼层
    6666,顶起来~·6666,顶起来~·
  • 签到天数: 115 天
    [LV.6]常住居民II
    发表于 2015-12-7 15:24:59 | 显示全部楼层
    火急火燎地赶来顶贴 ,哔了狗了   ……
  • 签到天数: 652 天
    发表于 2015-12-7 16:41:04 | 显示全部楼层
    路过。。。。。。。。。。。
  • 签到天数: 19 天
    [LV.4]偶尔看看III
     楼主| 发表于 2015-12-7 18:32:38 | 显示全部楼层
    wudianjun2001 发表于 2015-12-7 15:23
    路过看看。。。。。
    :victory求助指点
    GMT+8, 2025-1-12 07:42 , Processed in 0.147219 second(s), 23 queries , MemCache On.
