查看: 4883|回复: 0
[求助] 关于bananapi启动卡logo
发表于 2015-10-26 22:54:56 | 显示全部楼层 |阅读模式
自己给bananapi编译了个安卓系统
但是启动卡在开机的LOGO了 大家帮看下怎么回事
下面是启动log
Starting kernel ...
[    0.737282] aw_pm_init: not support super standby.
[    1.393318] init: /init.rc: 389: ignored duplicate definition of service 'console'
[    1.578133] init: FB_OPEN failed!
[    1.578145] init: open display device failed!
[    1.628373] init: open display device failed!
[    1.633332] init: open display device failed!
[    1.638371] init: open display device failed!
[    1.643327] init: open display device failed!
[    1.648366] init: HDMI status = -1, try 1 times!TV status = 0
[    1.746062] init: start e2fsck listening...
[    1.865004] init: do_umount: /data
[    2.141403] init: do_umount: /cache
[    2.244364] init: dont need format /dev/block/UDISK
[    2.251882] init: dont need format /dev/block/private
[    2.265843] init: do_umount: /databk
[    2.721858] i2c i2c-1: Invalid 7-bit I2C address 0x00
[    2.750783] init: C_IN_START
[    2.754043] init: path = /dev/block/data
[    2.758478] init: C_IN_START
[    2.761777] init: path = /dev/block/cacheuvcvideo: disagrees about version of symbol module_layout
[    2.827647] init: untracked pid 1065 exited
[    2.842940] init: cannot find '/system/etc/install-recovery.sh', disabling 'flash_recovery'
[    2.866154] android_usb: already disabled
[    2.871154] init: using deprecated syntax for specifying property 'sys.usb.config', use ${name} instead
[    2.885184] init: using deprecated syntax for specifying property 'sys.usb.config', use ${name} instead
root@android:/ # [    4.042730] init: untracked pid 1144 exited
[    5.138958] init: untracked pid 1312 exited
[    7.361007] init: untracked pid 1413 exited
dmesg
<6>[    0.000000] Booting Linux on physical CPU 0
<6>[    0.000000] Initializing cgroup subsys cpuset
<5>[    0.000000] Linux version 3.4.39 (question@ubuntu) (gcc version 4.6.3 20120201 (prerelease) (crosstool-NG linaro-1.13.1-2012.02-20120222 - Linaro GCC 2012.02) ) #4 SMP PREEMPT Fri Oct 23 06:37:53 PDT 2015
<4>[    0.000000] CPU: ARMv7 Processor [410fc074] revision 4 (ARMv7), cr=10c5387d
<4>[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
<4>[    0.000000] Machine: sun7i
<4>[    0.000000] [sun7i_fixup]: From boot, get meminfo:
<4>[    0.000000]  Start: 0x40000000
<4>[    0.000000]  Size: 1024MB
<6>[    0.000000] memory reserved(in bytes):
<6>[    0.000000]  : 0x43000000, 0x00010000
<6>[    0.000000]  : 0x52000000, 0x00020000
<4>[    0.000000] Memory policy: ECC disabled, Data cache writealloc
<7>[    0.000000] On node 0 totalpages: 207872
<7>[    0.000000] free_area_init_node: node 0, pgdat c0897380, node_mem_map d1400000
<7>[    0.000000]   DMA zone: 576 pages used for memmap
<7>[    0.000000]   DMA zone: 0 pages reserved
<7>[    0.000000]   DMA zone: 64960 pages, LIFO batch:15
<7>[    0.000000]   Normal zone: 1134 pages used for memmap
<7>[    0.000000]   Normal zone: 73618 pages, LIFO batch:15
<7>[    0.000000]   HighMem zone: 594 pages used for memmap
<7>[    0.000000]   HighMem zone: 66990 pages, LIFO batch:15
<4>[    0.000000] [scu_get_core_count] cores=1800001
<6>[    0.000000] sun7i_init_early: enter
<6>[    0.000000] PERCPU: Embedded 8 pages/cpu @d1d08000 s10944 r8192 d13632 u32768
<7>[    0.000000] pcpu-alloc: s10944 r8192 d13632 u32768 alloc=8*4096
<7>[    0.000000] pcpu-alloc: [0] 0 [0] 1
<4>[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 205568
<5>[    0.000000] Kernel command line: console=ttyS0,115200 root=/dev/mmcblk0p7 init=/init loglevel=4 partitions=bootloader@mmcblk0p2:env@mmcblk0p5:boot@mmcblk0p6:system@mmcblk0p7:data@mmcblk0p8:misc@mmcblk0p9:recovery@mmcblk0p10:cache@mmcblk0p11:private@mmcblk0p12:databk@mmcblk0p13:UDISK@mmcblk0p1 mac_addr= specialstr= boot_type=1
<6>[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
<6>[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
<6>[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
<6>[    0.000000] Memory: 64MB 748MB = 812MB total
<5>[    0.000000] Memory: 808108k/808108k available, 240468k reserved, 270336K highmem
<5>[    0.000000] Virtual kernel memory layout:
<5>[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
<5>[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
<5>[    0.000000]     vmalloc : 0xf0000000 - 0xff000000   ( 240 MB)
<5>[    0.000000]     lowmem  : 0xc0000000 - 0xef800000   ( 760 MB)
<5>[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
<5>[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
<5>[    0.000000]       .text : 0xc0008000 - 0xc07f25c0   (8106 kB)
<5>[    0.000000]       .init : 0xc07f3000 - 0xc083dac0   ( 299 kB)
<5>[    0.000000]       .data : 0xc083e000 - 0xc0899d18   ( 368 kB)
<5>[    0.000000]        .bss : 0xc0899d3c - 0xc0a181b0   (1530 kB)
<6>[    0.000000] Preemptible hierarchical RCU implementation.
<6>[    0.000000] NR_IRQS:160
<6>[    0.000000] aw_clkevt_init: timer base 0xf000cc00
<4>[    0.000000] [aw_delay]: It is use use_time_delay function!
<6>[    0.000000] aw_clksrc_init(96)
<6>[    0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
<6>[    0.000000] aw_clksrc_init(120)
<6>[    0.000000] Architected local timer running at 24.00MHz.
<6>[    0.000000] Console: colour dummy device 80x30
<6>[    0.000552] Calibrating delay loop... 1816.98 BogoMIPS (lpj=9084928)
<6>[    0.059939] pid_max: default: 32768 minimum: 301
<6>[    0.060435] Mount-cache hash table entries: 512
<6>[    0.061527] Initializing cgroup subsys debug
<6>[    0.061552] Initializing cgroup subsys cpuacct
<6>[    0.061567] Initializing cgroup subsys freezer
<6>[    0.061637] CPU: Testing write buffer coherency: ok
<6>[    0.061707] ftrace: allocating 21231 entries in 63 pages
<6>[    0.104045] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
<6>[    0.104453] hw perfevents: enabled with ARMv7 Cortex-A7 PMU driver, 5 counters available
<6>[    0.104577] Setting up static identity map for 0x4058f978 - 0x4058f9d0
<4>[    0.217138] CPU1: Booted secondary processor
<6>[    0.274454] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
<6>[    0.274565] Brought up 2 CPUs
<6>[    0.274586] SMP: Total of 2 processors activated (3640.52 BogoMIPS).
<6>[    0.275639] devtmpfs: initialized
<4>[    0.281103] script_init enter!
<4>[    0.282095] script_init exit!
<4>[    0.282895] kworker/u:0 used greatest stack depth: 6344 bytes left
<6>[    0.284349] dummy:
<6>[    0.285042] NET: Registered protocol family 16
<7>[    0.285678] sunxi_dump_init success
<6>[    0.286088] script_sysfs_init success
<4>[    0.286277] kworker/u:0 used greatest stack depth: 6112 bytes left
<6>[    0.288348] sun7i_init: enter
<6>[    0.289148] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
<6>[    0.289168] hw-breakpoint: maximum watchpoint size is 8 bytes.
<6>[    0.289198] [ccu-inf] aw clock manager init
<6>[    0.289209] [ccu-inf] aw_ccu_init
<6>[    0.289447] [ccu-inf] script config pll3 to 297MHz
<6>[    0.289466] [ccu-inf] script config pll4 to 300MHz
<6>[    0.289482] [ccu-inf] script config pll6 to 600MHz
<6>[    0.289500] [ccu-inf] script config pll7 to 297MHz
<6>[    0.289515] [ccu-inf] script config pll8 to 336MHz
<4>[    0.290133] axp config [pmu_para] [pmu_used] : 1
<4>[    0.290151] axp config [pmu_para] [pmu_twi_id] : 0
<4>[    0.290164] axp config [pmu_para] [pmu_irq_id] : 32
<4>[    0.290177] axp config [pmu_para] [pmu_twi_addr] : 52
<4>[    0.290191] axp config [pmu_para] [pmu_battery_rdc] : 100
<4>[    0.290204] axp config [pmu_para] [pmu_battery_cap] : 3200
<4>[    0.290218] axp config [pmu_para] [pmu_init_chgcur] : 300
<4>[    0.290232] axp config [pmu_para] [pmu_suspend_chgcur] : 1000
<4>[    0.290246] axp config [pmu_para] [pmu_resume_chgcur] : 300
<4>[    0.290260] axp config [pmu_para] [pmu_shutdown_chgcur] : 1000
<4>[    0.290274] axp config [pmu_para] [pmu_init_chgvol] : 4200
<4>[    0.290289] axp config [pmu_para] [pmu_init_chgend_rate] : 15
<4>[    0.290302] axp config [pmu_para] [pmu_init_chg_enabled] : 1
<4>[    0.290316] axp config [pmu_para] [pmu_init_adc_freq] : 100
<4>[    0.290330] axp config [pmu_para] [pmu_init_adc_freqc] : 100
<4>[    0.290344] axp config [pmu_para] [pmu_init_chg_pretime] : 50
<4>[    0.290358] axp config [pmu_para] [pmu_init_chg_csttime] : 720
<4>[    0.290372] axp config [pmu_para] [pmu_bat_para1] : 0
<4>[    0.290385] axp config [pmu_para] [pmu_bat_para2] : 0
<4>[    0.290398] axp config [pmu_para] [pmu_bat_para3] : 0
<4>[    0.290412] axp config [pmu_para] [pmu_bat_para4] : 0
<4>[    0.290425] axp config [pmu_para] [pmu_bat_para5] : 5
<4>[    0.290438] axp config [pmu_para] [pmu_bat_para6] : 8
<4>[    0.290452] axp config [pmu_para] [pmu_bat_para7] : 11
<4>[    0.290465] axp config [pmu_para] [pmu_bat_para8] : 22
<4>[    0.290478] axp config [pmu_para] [pmu_bat_para9] : 33
<4>[    0.290492] axp config [pmu_para] [pmu_bat_para10] : 43
<4>[    0.290506] axp config [pmu_para] [pmu_bat_para11] : 50
<4>[    0.290519] axp config [pmu_para] [pmu_bat_para12] : 59
<4>[    0.290532] axp config [pmu_para] [pmu_bat_para13] : 71
<4>[    0.290546] axp config [pmu_para] [pmu_bat_para14] : 83
<4>[    0.290559] axp config [pmu_para] [pmu_bat_para15] : 92
<4>[    0.290573] axp config [pmu_para] [pmu_bat_para16] : 100
<4>[    0.290587] axp config [pmu_para] [pmu_usbvol_limit] : 1
<4>[    0.290600] axp config [pmu_para] [pmu_usbvol] : 4000
<4>[    0.290614] axp config [pmu_para] [pmu_usbcur_limit] : 0
<4>[    0.290628] axp config [pmu_para] [pmu_usbcur] : 0
<4>[    0.290641] axp config [pmu_para] [pmu_pwroff_vol] : 3300
<4>[    0.290655] axp config [pmu_para] [pmu_pwron_vol] : 2900
<4>[    0.290668] axp config [target] [dcdc2_vol] : 1400
<4>[    0.290683] axp config [target] [dcdc3_vol] : 1250
<4>[    0.290696] axp config [target] [ldo2_vol] : 3000
<4>[    0.290708] axp config [target] [ldo3_vol] : 2800
<4>[    0.290720] axp config [target] [ldo4_vol] : 2800
<4>[    0.290733] axp config [pmu_para] [pmu_pekoff_time] : 4000
<4>[    0.290747] axp config [pmu_para] [pmu_pekoff_en] : 1
<4>[    0.290761] axp config [pmu_para] [pmu_peklong_time] : 1500
<4>[    0.290775] axp config [pmu_para] [pmu_pwrok_time] : 64
<4>[    0.290788] axp config [pmu_para] [pmu_pwrnoe_time] : 2000
<4>[    0.290802] axp config [pmu_para] [pmu_intotp_en] : 1
<4>[    0.290815] axp config [pmu_para] [pmu_pekon_time] : 1000
<6>[    0.291600] [gpio-inf] aw gpio init start
<6>[    0.291634] [gpio-inf] gpio_clk_init: apb pio clk enable success
<6>[    0.291930] gpiochip_add: registered GPIOs 0 to 17 on device: GPA
<6>[    0.292201] gpiochip_add: registered GPIOs 24 to 47 on device: GPB
<6>[    0.292440] gpiochip_add: registered GPIOs 54 to 78 on device: GPC
<6>[    0.292656] gpiochip_add: registered GPIOs 85 to 112 on device: GPD
<6>[    0.292884] gpiochip_add: registered GPIOs 119 to 130 on device: GPE
<6>[    0.293153] gpiochip_add: registered GPIOs 137 to 142 on device: GPF
<6>[    0.293388] gpiochip_add: registered GPIOs 149 to 160 on device: GPG
<6>[    0.293687] gpiochip_add: registered GPIOs 167 to 194 on device: GPH
<6>[    0.293946] gpiochip_add: registered GPIOs 201 to 222 on device: GPI
<6>[    0.294456] [gpio-inf] aw gpio init done
<6>[    0.340528] bio: create slab <bio-0> at 0
<5>[    0.342920] SCSI subsystem initialized
<6>[    0.344034] usbcore: registered new interface driver usbfs
<6>[    0.344512] usbcore: registered new interface driver hub
<6>[    0.344964] usbcore: registered new device driver usb
<4>[    0.347719] -------------------------------------------
<4>[    0.347738] axp_mfd_probe:axp20_mfd pmu probed !
<4>[    0.347748] -------------------------------------------
<6>[    0.350129] axp_mfd 0-0034: AXP (CHIP ID: 0x41) detected
<4>[    0.350827] -------------------------------------------
<4>[    0.350841] axp_mfd_probe:axp20_mfd pmu request_irq ok !
<4>[    0.350851] -------------------------------------------
<6>[    0.353087] I2C: i2c-0: sun7i I2C adapter
<4>[    0.353103] **********start************
<4>[    0.353114] 0x40
<4>[    0.353122] 0xf8
<4>[    0.353130] 0x58
<4>[    0.353138] 0x0
<4>[    0.353146] 0x0
<4>[    0.353156] **********end************
<6>[    0.353569] I2C: i2c-1: sun7i I2C adapter
<4>[    0.353586] **********start************
<4>[    0.353596] 0x40
<4>[    0.353604] 0xf8
<4>[    0.353612] 0x58
<4>[    0.353620] 0x0
<4>[    0.353628] 0x0
<4>[    0.353635] **********end************
<6>[    0.354022] I2C: i2c-2: sun7i I2C adapter
<4>[    0.354037] **********start************
<4>[    0.354047] 0x40
<4>[    0.354055] 0xf8
<4>[    0.354065] 0x28
<4>[    0.354073] 0x0
<4>[    0.354081] 0x0
<4>[    0.354089] **********end************
<6>[    0.354497] I2C: i2c-3: sun7i I2C adapter
<4>[    0.354510] **********start************
<4>[    0.354521] 0x40
<4>[    0.354529] 0xf8
<4>[    0.354537] 0x58
<4>[    0.354544] 0x0
<4>[    0.354552] 0x0
<4>[    0.354560] **********end************
<6>[    0.356439] I2C: i2c-4: sun7i I2C adapter
<4>[    0.356460] **********start************
<4>[    0.356471] 0x40
<4>[    0.356479] 0xf8
<4>[    0.356487] 0x58
<4>[    0.356495] 0x0
<4>[    0.356503] 0x0
<4>[    0.356511] **********end************
<6>[    0.356764] Linux video capture interface: v2.00
<6>[    0.357521] axp20_ldo1: 1300 mV
<6>[    0.359357] axp20_ldo2: 1800 <--> 3300 mV at 3000 mV
<6>[    0.361118] axp20_ldo3: 700 <--> 3500 mV at 2800 mV
<6>[    0.362848] axp20_ldo4: 1250 <--> 3300 mV at 2800 mV
<6>[    0.364619] axp20_buck2: 700 <--> 2275 mV at 1400 mV
<6>[    0.366727] axp20_buck3: 700 <--> 3500 mV at 1250 mV
<6>[    0.367836] axp20_ldoio0: 1800 <--> 3300 mV at 2800 mV
<6>[    0.368720] gpiochip_add: registered GPIOs 229 to 233 on device: axp_pin
<6>[    0.370044] Advanced Linux Sound Architecture Driver Version 1.0.25.
<6>[    0.371420] Bluetooth: Core ver 2.16
<6>[    0.371683] NET: Registered protocol family 31
<6>[    0.371699] Bluetooth: HCI device and connection manager initialized
<6>[    0.371716] Bluetooth: HCI socket layer initialized
<6>[    0.371729] Bluetooth: L2CAP socket layer ini[   17.773708] init: untracked pid 1627 exited
tialized
<6>[    0.371764] Bluetooth: SCO socket layer initialized
<6>[    0.372620] cfg80211: Calling CRDA to update world regulatory domain
<6>[    0.373576] Switching to clocksource arch_sys_counter
<5>[    0.394822] FS-Cache: Loaded
<6>[    0.395500] CacheFiles: Loaded
<4>[    0.419432] line = 507,usb_manager[   17.806183] init: untracked pid 1633 exited
_init
<4>[    0.419448] [usb_manager]: CONFIG_USB_SW_SUN7I_USB0_OTG
<4>[    0.419488] WRN220(drivers/usb/sun7i_usb/manager/usb_manager.c):ERR: get usbc(0) det_vbus gpio failed
<4>[    0.419512] WRN252(drivers/usb/sun7i_usb/manager/usb_manager.c):ERR: get usbc(0) ac_enable failed
<4>[    0.420167] [sw_hcd0]: usb host driver initialize........
<4>[    0.420291] [sw_hcd0]: open_usb_clock
<4>[    0.440198] [sw_hcd0]: host_init_state = 0
<4>[    0.440213] [sw_hcd0]: platform is usb host
<4>[    0.440304] [sw_hcd0]: sw_hcd_init_controller: sw_hcd_host0: USB Host mode controller at f1c13000 using PIO, IRQ 70
<6>[    0.440339] sw_hcd_host0 sw_hcd_host0: sw_hcd host driver
<6>[    0.440360] sw_hcd_host0 sw_hcd_host0: new USB bus registered, assigned bus number 1
<6>[    0.441626] hub 1-0:1.0: USB hub found
<6>[    0.441667] hub 1-0:1.0: 1 port detected
<4>[    0.441701] wrn: hcd is not enable, need not start hcd
<4>[    0.442247] [sw_hcd0]: sw_usb_host0_disable start
<4>[    0.442270] -------sw_hcd0_soft_disconnect---------
<4>[    0.442288] [sw_hcd_host0]: Set USB Power OFF
<4>[    0.442303] wrn: hcd is not enable, need not stop hcd
<4>[    0.442343] [sw_hcd0]: close_usb_clock
<4>[    0.442363] [sw_hcd0]: sw_usb_host0_disable end
<4>[    0.442593] [sw_udc]: udc_init: version 20080411
<6>[    0.443552] NET: Registered protocol family 2
<6>[    0.444188] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
<6>[    0.446925] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
<6>[    0.450857] TCP bind hash table entries: 65536 (order: 7, 786432 bytes)
<6>[    0.451907] TCP: Hash tables configured (established 131072 bind 65536)
<6>[    0.451922] TCP: reno registered
<6>[    0.451980] UDP hash table entries: 512 (order: 2, 16384 bytes)
<6>[    0.452053] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
<6>[    0.452589] NET: Registered protocol family 1
<6>[    0.453394] RPC: Registered named UNIX socket transport module.
<6>[    0.453413] RPC: Registered udp transport module.
<6>[    0.453426] RPC: Registered tcp transport module.
<6>[    0.453437] RPC: Registered tcp NFSv4.1 backchannel transport module.
<6>[    0.453893] Unpacking initramfs...
<6>[    0.533799] hub 1-0:1.0: [hub_activate 872]
<6>[    0.734939] Freeing initrd memory: 2732K
<6>[    0.735782] sunxi_reg_init enter
<4>[    0.736993] [pm]aw_pm_init!
<6>[    0.737014] dram config [dram_para] [dram_baseaddr] : 0x40000000
<6>[    0.737028] dram config [dram_para] [dram_clk] : 0x1b0
<6>[    0.737041] dram config [dram_para] [dram_type] : 0x3
<6>[    0.737053] dram config [dram_para] [dram_rank_num] : 0x1
<6>[    0.737067] dram config [dram_para] [dram_chip_density] : 0x1000
<6>[    0.737080] dram config [dram_para] [dram_io_width] : 0x10
<6>[    0.737093] dram config [dram_para] [dram_bus_width] : 0x20
<6>[    0.737106] dram config [dram_para] [dram_cas] : 0x9
<6>[    0.737118] dram config [dram_para] [dram_zq] : 0x7f
<6>[    0.737131] dram config [dram_para] [dram_odt_en] : 0x0
<6>[    0.737144] dram config [dram_para] [dram_size] : 0x400
<6>[    0.737156] dram config [dram_para] [dram_tpr0] : 0x42d899b7
<6>[    0.737170] dram config [dram_para] [dram_tpr1] : 0xa090
<6>[    0.737182] dram config [dram_para] [dram_tpr2] : 0x22a00
<6>[    0.737195] dram config [dram_para] [dram_tpr3] : 0x0
<6>[    0.737207] dram config [dram_para] [dram_tpr4] : 0x1
<6>[    0.737220] dram config [dram_para] [dram_tpr5] : 0x0
<6>[    0.737232] dram config [dram_para] [dram_emr1] : 0x4
<6>[    0.737245] dram config [dram_para] [dram_emr2] : 0x10
<6>[    0.737257] dram config [dram_para] [dram_emr3] : 0x0
<6>[    0.737270] standby_mode = 0.
<3>[    0.737282] aw_pm_init: not support super standby.
<6>[    0.737294] cpu0_en = 0.
<6>[    0.737304] dram_selfresh_en = 1.
<6>[    0.737315] wakeup src cnt is : 0.
<4>[    0.737408] DRAM_STANDBY_PGD_ADDR:d201c000
<4>[    0.737440] [wifi]: select wifi: rtl8188eu !!
<4>[    0.737893] [rtl8188eu]: exec rtl8188eu_wifi_gpio_init
<4>[    0.737918] [rtl8188eu]: module power name
<4>[    0.737929] [rtl8188eu]: rtl8188eu module power set by axp.
<4>[    0.737948] [rtl8188eu]: get power regulator failed.
<4>[    0.737983] [wifi_pm]: wifi gpio init is OK !!
<6>[    0.738213] [powernow inf] module init
<6>[    0.738439] [powernow inf] create class sw_powernow done
<4>[    0.741592] highmem bounce pool size: 64 pages
<6>[    0.745329] NTFS driver 2.1.30 [Flags: R/W].
<6>[    0.745618] fuse init (API version 7.18)
<6>[    0.747025] msgmni has been set to 1055
<6>[    0.749257] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
<6>[    0.749285] io scheduler noop registered
<6>[    0.749297] io scheduler deadline registered (default)
<6>[    0.749457] io scheduler cfq registered
<4>[    0.759693] [uart]: driver initializied
<6>[    0.760520] sw_serial.0: ttyS0 at MMIO 0x1c28000 (irq = 33) is a SW
<4>[    0.760550] [uart]: console setup baud 115200 parity n bits 8, flow n
<4>[    0.760585] [uart]: uart0 LCR & BAUD changed, reset controller...
<6>[    0.766262] console [ttyS0] enabled
<6>[    0.766952] sw_serial.2: ttyS2 at MMIO 0x1c28800 (irq = 35) is a SW
<7>[    0.768644] G2D: drv_g2d_init
<6>[    0.768880] G2D: Module initialized.major:251
<4>[    0.769779] sunmm_probe, line 269
<6>[    0.777758] loop: module loaded
<6>[    0.778722] tun: Universal TUN/TAP device driver, 1.6
<6>[    0.778738] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
<6>[    0.779179] PPP generic driver version 2.4.2
<6>[    0.779730] PPP BSD Compression module registered
<6>[    0.779749] PPP Deflate Compression module registered
<6>[    0.780615] PPP MPPE Compression module registered
<6>[    0.780639] NET: Registered protocol family 24
<6>[    0.780695] PPTP driver version 0.8.5
<6>[    0.781542] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
<6>[    0.782037] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
<4>[    0.782336] [sw_hci_sun4i_init 1254]
<4>[    0.782364] WRN163(drivers/usb/host/sw_hci_sun7i.c):ERR: sw-ehci1(restrict_gpio) is invalid
<4>[    0.782429] WRN163(drivers/usb/host/sw_hci_sun7i.c):ERR: sw-ohci1(restrict_gpio) is invalid
<4>[    0.782511] WRN163(drivers/usb/host/sw_hci_sun7i.c):ERR: sw-ehci2(restrict_gpio) is invalid
<4>[    0.782560] WRN163(drivers/usb/host/sw_hci_sun7i.c):ERR: sw-ohci2(restrict_gpio) is invalid
<4>[    0.782955] [sw-ehci1]: probe, pdev->name: sw-ehci, pdev->id: 1, sw_ehci: 0xc090e444
<4>[    0.782979] [sw-ehci1]: open clock
<4>[    0.802924] [sw-ehci1]: open clock, 0x60(0xc162), 0xcc(0x102)
<4>[    0.802946] [sw-ehci1]: Set USB Power ON
<4>[    0.802960] __set_vbus
<6>[    0.802975] sw-ehci sw-ehci.1: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
<6>[    0.803030] sw-ehci sw-ehci.1: new USB bus registered, assigned bus number 2
<6>[    0.803210] sw-ehci sw-ehci.1: irq 71, io mem 0xf1c14000
<6>[    0.814290] sw-ehci sw-ehci.1: USB 0.0 started, EHCI 1.00
<6>[    0.815666] hub 2-0:1.0: USB hub found
<6>[    0.815705] hub 2-0:1.0: 1 port detected
<4>[    0.816537] [sw-ohci1]: probe, pdev->name: sw-ohci, pdev->id: 1, sw_ohci: 0xc090e558
<4>[    0.816564] [sw-ohci1]: open clock
<4>[    0.836442] [sw-ohci1]: open clock, 0x60(0xc166), 0xcc(0x162)
<4>[    0.836460] [sw_ohci_hcd_probe 361]:reg(0xf1c20060) = c166
<6>[    0.836477] sw-ohci sw-ohci.1: SW USB2.0 'Open' Host Controller (OHCI) Driver
<6>[    0.836519] sw-ohci sw-ohci.1: new USB bus registered, assigned bus number 3
<6>[    0.836581] sw-ohci sw-ohci.1: irq 96, io mem 0xf1c14400
<6>[    0.898821] hub 3-0:1.0: USB hub found
<6>[    0.898882] hub 3-0:1.0: 1 port detected
<4>[    0.899707] [sw-ehci2]: probe, pdev->name: sw-ehci, pdev->id: 2, sw_ehci: 0xc090e66c
<4>[    0.899730] [sw-ehci2]: open clock
<6>[    0.913666] hub 2-0:1.0: [hub_activate 872]
<4>[    0.919684] [sw-ehci2]: open clock, 0x60(0xc16e), 0xcc(0x166)
<4>[    0.919701] [sw-ehci2]: Set USB Power ON
<4>[    0.919714] __set_vbus
<6>[    0.919726] sw-ehci sw-ehci.2: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
<6>[    0.919769] sw-ehci sw-ehci.2: new USB bus registered, assigned bus number 4
<6>[    0.919938] sw-ehci sw-ehci.2: irq 72, io mem 0xf1c1c000
<6>[    0.933674] sw-ehci sw-ehci.2: USB 0.0 started, EHCI 1.00
<6>[    0.934782] hub 4-0:1.0: USB hub found
<6>[    0.934823] hub 4-0:1.0: 1 port detected
<4>[    0.935670] [sw-ohci2]: probe, pdev->name: sw-ohci, pdev->id: 2, sw_ohci: 0xc090e780
<4>[    0.935695] [sw-ohci2]: open clock
<4>[    0.955677] [sw-ohci2]: open clock, 0x60(0xc17e), 0xcc(0x1e6)
<4>[    0.955696] [sw_ohci_hcd_probe 361]:reg(0xf1c20060) = c17e
<6>[    0.955712] sw-ohci sw-ohci.2: SW USB2.0 'Open' Host Controller (OHCI) Driver
<6>[    0.955756] sw-ohci sw-ohci.2: new USB bus registered, assigned bus number 5
<6>[    0.955814] sw-ohci sw-ohci.2: irq 97, io mem 0xf1c1c400
<6>[    0.993674] hub 3-0:1.0: [hub_activate 872]
<6>[    1.018761] hub 5-0:1.0: USB hub found
<6>[    1.018802] hub 5-0:1.0: 1 port detected
<6>[    1.019691] usbcore: registered new interface driver cdc_acm
<6>[    1.019707] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
<6>[    1.019721] Initializing USB Mass Storage driver...
<6>[    1.020149] usbcore: registered new interface driver usb-storage
<6>[    1.020166] USB Mass Storage support registered.
<6>[    1.020661] usbcore: registered new interface driver usbserial
<6>[    1.020678] usbserial: USB Serial Driver core
<6>[    1.020915] usbcore: registered new interface driver option
<6>[    1.021128] USB Serial support registered for GSM modem (1-port)
<6>[    1.033672] hub 4-0:1.0: [hub_activate 872]
<6>[    1.113668] hub 5-0:1.0: [hub_activate 872]
<6>[    1.133679] usb 2-1: new high-speed USB device number 2 using sw-ehci
<4>[    1.298122] [sw_udc]: [sw_usb_udc]: binding gadget driver 'android_usb'
<4>[    1.298149] [sw_udc]: alloc request: ep(0xc0876298, ep0, 64), req(0xef27c440)
<4>[    1.298196] WRN2596(drivers/usb/sun7i_usb/udc/sw_udc.c):ERR: usb device is not active
<4>[    1.298219] [sw_udc]: sw_udc_pullup, is_on = 0
<4>[    1.298233] WRN2631(drivers/usb/sun7i_usb/udc/sw_udc.c):ERR: usb device is not active
<6>[    1.298527] file system registered
<6>[    1.302468] android_usb gadget: Mass Storage Function, version: 2009/09/11
<6>[    1.302492] android_usb gadget: Number of LUNs=3
<6>[    1.302507]  lun0: LUN: removable file: (no medium)
<6>[    1.302521]  lun1: LUN: removable file: (no medium)
<6>[    1.302534]  lun2: LUN: removable file: (no medium)
<4>[    1.303570] WRN2596(drivers/usb/sun7i_usb/udc/sw_udc.c):ERR: usb device is not active
<6>[    1.303608] android_usb gadget: android_usb ready
<4>[    1.304252]  uinput result 0 , vmouse_init
<6>[    1.304675] input: vmouse as /devices/virtual/input/input0
<6>[    1.305650] mousedev: PS/2 mouse device common for all mice
<6>[    1.306752] input: sw-keyboard as /devices/virtual/input/input1
<6>[    1.308014] sunxi_rtc_init: enter
<6>[    1.308356] rtc_hw_init(400): start
<6>[    1.308471] rtc_hw_init(432): end
<6>[    1.308548] sunxi_rtc_gettime, line 39
<6>[    1.308561] sunxi_rtc_gettime(59): rtc_tm->tm_year:0
<6>[    1.308573] sunxi_rtc_gettime(61): year < 70, so add 100, to check
<6>[    1.308588] sunxi_rtc_gettime(67): read time 2000-1-1 0:0:5
<6>[    1.308602] sunxi_rtc_getalarm(269): year < 70, so add 100, to check
<6>[    1.308618] sunxi_rtc_getalarm(281): get alarm time 2000-1-1 0:0:0
<6>[    1.308633] sunxi_rtc_gettime, line 39
<6>[    1.308644] sunxi_rtc_gettime(59): rtc_tm->tm_year:0
<6>[    1.308656] sunxi_rtc_gettime(61): year < 70, so add 100, to check
<6>[    1.308671] sunxi_rtc_gettime(67): read time 2000-1-1 0:0:5
<6>[    1.309329] using rtc device, rtc, for alarms
<6>[    1.309382] sunxi-rtc sunxi-rtc: rtc core: registered rtc as rtc0
<6>[    1.309625] i2c /dev entries driver
<6>[    1.311938] lirc_dev: IR Remote Control driver registered, major 248
<6>[    1.311960] IR NEC protocol handler initialized
<6>[    1.311971] IR RC5(x) protocol handler initialized
<6>[    1.311982] IR RC6 protocol handler initialized
<6>[    1.311992] IR JVC protocol handler initialized
<6>[    1.312003] IR Sony protocol handler initialized
<6>[    1.312013] IR RC5 (streamzap) protocol handler initialized
<6>[    1.312025] IR SANYO protocol handler initialized
<6>[    1.312036] IR MCE Keyboard/mouse protocol handler initialized
<6>[    1.312047] IR LIRC bridge handler initialized
<4>[    1.312271] [hx-cedar dev]: install start!!!
<4>[    1.313544] [cedar dev]: install end!!!
<6>[    1.314127] input: axp20-supplyer as /devices/platform/sun7i-i2c.0/i2c-0/0-0034/axp20-supplyer.28/input/input2
<4>[    1.324945] pmu_pekoff_time = 4000
<4>[    1.324963] pmu_pekoff_en = 1
<4>[    1.324972] pmu_peklong_time = 1500
<4>[    1.324982] pmu_pekon_time = 1000
<4>[    1.324991] pmu_pwrok_time = 64
<4>[    1.325001] pmu_pwrnoe_time = 2000
<4>[    1.325012] pmu_intotp_en = 1
<4>[    1.325646] [AXP]POWER20_OFF_CTL:2077-->0x42
<4>[    1.326267] POWER20_PEK_SET:2094-->0x9c
<4>[    1.326888] POWER20_PEK_SET:2105-->0x9c
<4>[    1.327507] POWER20_PEK_SET:2114-->0x9c
<4>[    1.328126] POWER20_PEK_SET:2125-->0x9c
<4>[    1.328744] POWER20_PEK_SET:2137-->0x9c
<4>[    1.329362] POWER20_HOTOVER_CTL:2146-->0xad
<4>[    1.334023] [AXP]last_rest_vol = 0, now_rest_vol = 100
<4>[    1.336096] [AXP]Cur_CoulombCounter = 0
<4>[    1.336110] [AXP]charger->rest_vol = 100
<4>[    1.338097] ==============backup=============
<4>[    1.340442] axp20_ldo2: Failed to create debugfs directory
<7>[    1.340462] regulator_virtual_consumer_probe:get regulator:axp20_analog/fm ok
<7>[    1.340817] regulator_virtual_consumer_probe:get regulator:axp20_pll ok
<7>[    1.341191] regulator_virtual_consumer_probe:get regulator:axp20_hdmi ok
<4>[    1.341519] axp20_buck2: Failed to create debugfs directory
<7>[    1.341537] regulator_virtual_consumer_probe:get regulator:axp20_core ok
<7>[    1.341875] regulator_virtual_consumer_probe:get regulator:axp20_ddr ok
<7>[    1.342267] regulator_virtual_consumer_probe:get regulator:axp20_mic ok
<6>[    1.343231] device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat.com
<6>[    1.344259] device-mapper: multipath: version 1.3.0 loaded
<6>[    1.344285] device-mapper: multipath round-robin: version 1.0.0 loaded
<6>[    1.344301] device-mapper: multipath queue-length: version 0.1.0 loaded
<6>[    1.344315] device-mapper: multipath service-time: version 0.2.0 loaded
<4>[    1.346597] [mmc-msg] sw_mci_init
<4>[    1.346657] [mmc-msg] MMC host used card: 0x9, boot card: 0x1, io_card 8
<4>[    1.348078] [mmc-msg] sdc0 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
<4>[    1.349167] [mmc-msg] sdc0 Probe: base:0xf003e000 irq:64 sg_cpu:ffdf7000(43c00000) ret 0.
<4>[    1.349182] [mmc-msg] sdc0 set ios: clk 0Hz bm PP pm UP vdd 3.3V width 1 timing LEGACY(SDR12) dt B
<4>[    1.349194] [mmc-msg] sdc0 power on
<4>[    1.349982] [mmc-msg] sdc3 set ios: clk 0Hz bm OD pm OFF vdd 3.3V width 1 timing LEGACY(SDR12) dt B
<4>[    1.351075] [mmc-msg] sdc3 Probe: base:0xf0094000 irq:67 sg_cpu:ffdf6000(43c01000) ret 0.
<6>[    1.354985] usbcore: registered new interface driver usbhid
<6>[    1.355006] usbhid: USB HID core driver
<6>[    1.356183] ashmem: initialized
<6>[    1.356477] logger: created 256K log 'log_main'
<6>[    1.356768] logger: created 256K log 'log_events'
<6>[    1.357053] logger: created 256K log 'log_radio'
<6>[    1.357333] logger: created 256K log 'log_system'
<6>[    1.359260] value is 1
<4>[    1.359606] enter sun7i Audio codec!!!
<6>[    1.361281] sun7i audio support initialized
<4>[    1.361523] sun7i Audio codec successfully loaded..
<4>[    1.363716] soc-audio soc-audio.0: ASoC machine sndhdmi should use snd_soc_register_card()
<4>[    1.363736] [mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
<6>[    1.364620] asoc: sndhdmi <-> sun7i-hdmiaudio.0 mapping ok
<4>[    1.366025] [I2S]sun7i-i2s cannot find any using configuration for controllers, return directly!
<4>[    1.366668] [hdcp]sndhdcp cannot find any using configuration for controllers, return directly!
<4>[    1.366691] [I2S]sun7i_sndi2s cannot find any using configuration for controllers, return directly!
<4>[    1.368729] soc-audio soc-audio.1: ASoC machine sndspdif should use snd_soc_register_card()
<6>[    1.369531] asoc: sndspdif <-> sun7i-spdif.0 mapping ok
<4>[    1.370780] [I2S] i2s_select type err!
<4>[    1.370796] [I2S]sun7i-i2s cannot find any using configuration for controllers, return directly!
<4>[    1.371428] [I2S]sndi2s cannot find any using configuration for controllers, return directly!
<4>[    1.371448] [I2S] i2s_master type err!
<4>[    1.371459] [I2S] audio_format type err!
<4>[    1.371469] [I2S] signal_inversion type err!
<4>[    1.371478] [I2S]sun7i_sndi2s cannot find any using configuration for controllers, return directly!
<4>[    1.371494] func:sun7i_pcm_init(line:953)sun7i-pcm.c
<4>[    1.371510] func:sun7i_pcm_init(line:964)sun7i-pcm.c,pcm_used:0
<4>[    1.371521] [PCM]sun7i-i2s cannot find any using configuration for controllers, return directly!
<4>[    1.371535] func:sun7i_soc_platform_i2s_init(line:803)sun7i-pcmdma.c
<4>[    1.372083] func:sndpcm_codec_init(line:181)sndpcm.c
<4>[    1.372103] func:sndpcm_codec_init(line:187)sndpcm.c,pcm_used:0
<4>[    1.372115] [PCM]sndi2s cannot find any using configuration for controllers, return directly!
<4>[    1.372135] func:sun7i_sndpcm_init(line:209)sun7i-sndpcm.c,pcm_used:0
<4>[    1.372146] [I2S]sun7i_sndi2s cannot find any using configuration for controllers, return directly!
<6>[    1.372387] Netfilter messages via NETLINK v0.30.
<6>[    1.372513] nf_conntrack version 0.5.0 (12669 buckets, 50676 max)
<6>[    1.373132] ctnetlink v0.93: registering with nfnetlink.
<6>[    1.373267] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
<6>[    1.373281] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
<6>[    1.374858] xt_time: kernel timezone is -0000
<6>[    1.375092] IPv4 over IPv4 tunneling driver
<6>[    1.376210] gre: GRE over IPv4 demultiplexor driver
<6>[    1.376228] ip_gre: GRE over IPv4 tunneling driver
<6>[    1.377700] ip_tables: (C) 2000-2006 Netfilter Core Team
<6>[    1.377943] arp_tables: (C) 2002 David S. Miller
<6>[    1.378021] TCP: cubic registered
<6>[    1.378033] Initializing XFRM netlink socket
<6>[    1.378537] NET: Registered protocol family 10
<6>[    1.379970] Mobile IPv6
<6>[    1.380030] ip6_tables: (C) 2000-2006 Netfilter Core Team
<6>[    1.380266] IPv6 over IPv4 tunneling driver
<6>[    1.382911] NET: Registered protocol family 17
<6>[    1.382980] NET: Registered protocol family 15
<6>[    1.383194] Bluetooth: RFCOMM TTY layer initialized
<6>[    1.383222] Bluetooth: RFCOMM socket layer initialized
<6>[    1.383234] Bluetooth: RFCOMM ver 1.11
<6>[    1.383247] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
<6>[    1.383258] Bluetooth: BNEP filters: protocol multicast
<6>[    1.383271] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
<6>[    1.383611] L2TP core driver, V2.0
<6>[    1.383908] PPPoL2TP kernel driver, V2.0
<6>[    1.383922] L2TP IP encapsulation support (L2TPv3)
<6>[    1.384174] L2TP netlink interface
<6>[    1.384239] L2TP ethernet pseudowire support (L2TPv3)
<6>[    1.384510] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 4
<6>[    1.384540] ThumbEE CPU extension supported.
<5>[    1.384572] Registering SWP/SWPB emulation handler
<4>[    1.384591] [rfkill]: init no bt used in configuration
<4>[    1.386538] axp20_buck3: incomplete constraints, leaving on
<4>[    1.386890] axp20_buck2: incomplete constraints, leaving on
<4>[    1.387236] axp20_ldo4: incomplete constraints, leaving on
<4>[    1.387582] axp20_ldo3: incomplete constraints, leaving on
<4>[    1.387927] axp20_ldo2: incomplete constraints, leaving on
<4>[    1.388272] axp20_ldo1: incomplete constraints, leaving on
<6>[    1.388534] sunxi_rtc_gettime, line 39
<6>[    1.388546] sunxi_rtc_gettime(59): rtc_tm->tm_year:0
<6>[    1.388558] sunxi_rtc_gettime(61): year < 70, so add 100, to check
<6>[    1.388572] sunxi_rtc_gettime(67): read time 2000-1-1 0:0:5
<6>[    1.388624] sunxi-rtc sunxi-rtc: setting system clock to 2000-01-01 00:00:05 UTC (946684805)
<6>[    1.388705] ALSA device list:
<6>[    1.388715]   #0: sun7i-CODEC  Audio Codec
<6>[    1.388725]   #1: sndhdmi
<6>[    1.388733]   #2: sndspdif
<6>[    1.389501] Freeing init memory: 296K
<3>[    1.393318] init: /init.rc: 389: ignored duplicate definition of service 'console'
<4>[    1.403214] init (1): /proc/1/oom_adj is deprecated, please use /proc/1/oom_score_adj instead.
<4>[    1.414834] kworker/u:3 used greatest stack depth: 6012 bytes left
<4>[    1.435895] [mmc-err] smc 0 err, cmd 52,  RTO
<4>[    1.436748] [mmc-err] smc 0 err, cmd 52,  RTO
<4>[    1.436792] [mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
<4>[    1.439230] [mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
<4>[    1.441439] [mmc-err] smc 0 err, cmd 5,  RTO
<4>[    1.442289] [mmc-err] smc 0 err, cmd 5,  RTO
<4>[    1.443139] [mmc-err] smc 0 err, cmd 5,  RTO
<4>[    1.443981] [mmc-err] smc 0 err, cmd 5,  RTO
<4>[    1.444688] [mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
<4>[    1.444757] [mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
<4>[    1.447193] [mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B
<4>[    1.520181] [mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing SD-HS(SDR25) dt B
<4>[    1.520251] [mmc-msg] sdc0 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 1 timing SD-HS(SDR25) dt B
<4>[    1.573881] [mmc-msg] sdc0 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 4 timing SD-HS(SDR25) dt B
<6>[    1.573978] mmc0: new high speed SDHC card at address aaaa
<6>[    1.575216] mmcblk0: mmc0:aaaa SS08G 7.40 GiB
<4>[    1.577271] [uart]: uart0 LCR & BAUD changed, reset controller...
<3>[    1.578133] init: FB_OPEN failed!
<3>[    1.578145] init: open display device failed!
<6>[    1.586882]  mmcblk0: p1 p2 p3 < p5 p6 p7 p8 p9 p10 p11 p12 p13 >
<6>[    1.587537] init: command 'loglevel' r=0
<6>[    1.587601] init: command 'export' r=0
<6>[    1.587623] init: command 'export' r=0
<6>[    1.587641] init: command 'export' r=0
<6>[    1.587659] init: command 'export' r=0
<6>[    1.587678] init: command 'export' r=0
<6>[    1.587695] init: command 'export' r=0
<6>[    1.587711] init: command 'export' r=0
<6>[    1.587728] init: command 'export' r=0
<6>[    1.587747] init: command 'export' r=0
<4>[    1.609524] [NAND][NAND]nand init start, nand_used_flag is 1
<4>[    1.609546] [NAND]nand_cache_level err! 0[NAND]nand init start
<4>[    1.609617] NandHwInit(): nand driver physical layer version: 0, 0, 20131015, 10:57
<4>[    1.609630] NandHwInit(): Start Nand Hardware initializing .....
<4>[    1.609641] [NAND]channel cnt is 1
<4>[    1.609654] [NAND] nand driver version(A20): 0x3, 0x1 0x20130613 1204
<4>[    1.609743] [NAND] nand clk request start
<4>[    1.609780] [NAND] nand clk request ok!
<4>[    1.609815] [NAND DMA] request dma success
<4>[    1.609828] [NAND DMA] set fulldone_cb success
<4>[    1.609837] NFC Randomizer start.
<4>[    1.609900] [PHY_DBG] CH 0 Nand flash chip id is:0x0 0x0 0x0 0x0 0x0 0x0
<4>[    1.609913] nand id of two channel is not the same, set to 1 channel mode
<4>[    1.609927] [SCAN_DBG] Nand flash chip id is:0x0 0x0 0x0 0x0 0x0 0x0
<4>[    1.609939] [SCAN_ERR] search nand physical architecture parameter failed!
<4>[    1.609951] [ERR]NandHwInit(): SCN_AnalyzeNandSystem() failed!
<4>[    1.609962] NandHwInit(): End Nand Hardware initializing ..... FAIL!
<4>[    1.609969]
<6>[    1.611601] init: command 'insmod' r=0
<6>[    1.611818] init: command 'symlink' r=0
<6>[    1.611889] init: command 'symlink' r=0
<4>[    1.617276] busybox used greatest stack depth: 5852 bytes left
<3>[    1.628373] init: open display device failed!
<3>[    1.633332] init: open display device failed!
<3>[    1.638371] init: open display device failed!
<3>[    1.643327] init: open display device failed!
<3>[    1.648366] init: HDMI status = -1, try 1 times!TV status = 0
<6>[    1.652837] init: command 'exec' r=0
<6>[    1.652957] init: command 'symlink' r=0
<6>[    1.652998] init: command 'mkdir' r=0
<6>[    1.693911] init: command 'mount' r=0
<6>[    1.694095] init: command 'mkdir' r=0
<6>[    1.694186] init: command 'mkdir' r=0
<6>[    1.694259] init: command 'mkdir' r=0
<6>[    1.694321] init: command 'mkdir' r=0
<6>[    1.694373] init: command 'mkdir' r=0
<6>[    1.694425] init: command 'mkdir' r=0
<6>[    1.694624] init: command 'mount' r=0
<6>[    1.694705] init: command 'mkdir' r=0
<6>[    1.694762] init: command 'mkdir' r=0
<6>[    1.694817] init: command 'mkdir' r=0
<6>[    1.694953] init: command 'mount' r=0
<6>[    1.695014] init: command 'mkdir' r=0
<6>[    1.695145] init: command 'mount' r=0
<6>[    1.695294] init: command 'write' r=0
<6>[    1.695349] init: command 'write' r=-2
<6>[    1.695445] init: command 'write' r=0
<6>[    1.695490] init: command 'write' r=-2
<6>[    1.695532] init: command 'write' r=-2
<6>[    1.695569] init: command 'write' r=-2
<6>[    1.695635] init: command 'write' r=0
<6>[    1.695704] init: command 'write' r=0
<6>[    1.695770] init: command 'write' r=0
<6>[    1.695850] init: command 'write' r=0
<6>[    1.695936] init: command 'write' r=0
<6>[    1.696013] init: command 'write' r=0
<6>[    1.696085] init: command 'write' r=0
<6>[    1.696128] init: command 'mkdir' r=0
<6>[    1.743832] init: command 'mount' r=0
<6>[    1.743920] init: command 'chown' r=0
<6>[    1.744074] init: command 'chown' r=0
<6>[    1.744147] init: command 'chmod' r=0
<6>[    1.744198] init: command 'write' r=-22
<6>[    1.744245] init: command 'write' r=0
<6>[    1.744289] init: command 'write' r=0
<6>[    1.744436] init: command 'mkdir' r=0
<6>[    1.744505] init: command 'chown' r=0
<6>[    1.744548] init: command 'chmod' r=0
<6>[    1.744588] init: command 'write' r=0
<6>[    1.744633] init: command 'write' r=0
<6>[    1.744674] init: command 'write' r=0
<6>[    1.744819] init: command 'mkdir' r=0
<6>[    1.744877] init: command 'chown' r=0
<6>[    1.744919] init: command 'chmod' r=0
<6>[    1.744963] init: command 'write' r=0
<6>[    1.745007] init: command 'write' r=0
<6>[    1.745049] init: command 'write' r=0
<6>[    1.745113] init: command 'chmod' r=0
<6>[    1.745154] init: processing action 0x34fe8 (early-fs)
<6>[    1.745633] init: command 'dispe2fsck' r=0
<3>[    1.746062] init: start e2fsck listening...
<6>[    1.760397] EXT4-fs (mmcblk0p7): barriers disabled
<6>[    1.778961] EXT4-fs (mmcblk0p7): recovery complete
<6>[    1.780321] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts: barrier=0
<6>[    1.780408] init: command 'mount' r=0
<6>[    1.780506] init: processing action 0x35070 (fs)
<6>[    1.780596] init: command 'wait' r=0
<6>[    1.863304] EXT4-fs (mmcblk0p8): recovery complete
<6>[    1.864663] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: barrier=1
<6>[    1.864751] init: command 'mount' r=0
<6>[    1.864980] init: command 'setupfs' r=0
<3>[    1.865004] init: do_umount: /data
<6>[    1.913731] init: command 'umount' r=0
<4>[    2.004156] e2fsck->main: e2fsck start...
<4>[    2.004211] e2fsck->pipe_write: pipe_write type=1
<4>[    2.016796] e2fsck used greatest stack depth: 5168 bytes left
<4>[    2.017486] logwrapper used greatest stack depth: 5160 bytes left
<6>[    2.017639] init: command 'exec' r=0
<6>[    2.112307] EXT4-fs (mmcblk0p8): mounted filesystem with ordered data mode. Opts: barrier=1,journal_checksum,noauto_da_alloc
<6>[    2.112793] init: command 'exec' r=0
<6>[    2.139709] EXT4-fs (mmcblk0p11): recovery complete
<6>[    2.141105] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: barrier=1
<6>[    2.141194] init: command 'mount' r=0
<6>[    2.141380] init: command 'setupfs' r=0
<3>[    2.141403] init: do_umount: /cache
<6>[    2.203712] init: command 'umount' r=0
<4>[    2.213991] e2fsck->main: e2fsck start...
<4>[    2.214049] e2fsck->pipe_write: pipe_write type=1
<6>[    2.226061] init: command 'exec' r=0
<6>[    2.241440] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: barrier=1,journal_checksum,noauto_da_alloc
<6>[    2.241958] init: command 'exec' r=0
<3>[    2.244364] init: dont need format /dev/block/UDISK
<6>[    2.249629] init: command 'format_userdata' r=1
<6>[    2.249928] init: command 'export' r=0
<3>[    2.251882] init: dont need format /dev/block/private
<6>[    2.257376] init: command 'format_userdata' r=1
<6>[    2.257756] init: command 'mkdir' r=0
<6>[    2.260167] init: command 'mount' r=0
<6>[    2.260266] init: command 'wait' r=0
<6>[    2.265556] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Opts: barrier=1
<6>[    2.265643] init: command 'mount' r=0
<6>[    2.265817] init: command 'setupfs' r=0
<3>[    2.265843] init: do_umount: /databk
<6>[    2.313720] init: command 'umount' r=0
<6>[    2.313821] init: command 'rmdir' r=0
<6>[    2.313865] init: processing action 0x2ebf8 (post-fs)
<6>[    2.313960] init: command 'mount' r=0
<6>[    2.313999] init: command 'mount' r=0
<6>[    2.314215] init: command 'chown' r=0
<6>[    2.314286] init: command 'chmod' r=0
<6>[    2.315345] init: command 'chown' r=-2
<6>[    2.315391] init: command 'chmod' r=-2
<6>[    2.315515] init: command 'chown' r=0
<6>[    2.315582] init: command 'chmod' r=0
<6>[    2.315645] init: command 'chown' r=0
<6>[    2.315701] init: command 'chmod' r=0
<6>[    2.315757] init: command 'chown' r=0
<6>[    2.315811] init: command 'chmod' r=0
<6>[    2.315969] init: command 'mkdir' r=0
<6>[    2.316039] init: processing action 0x2ee48 (post-fs-data)
<6>[    2.316128] init: command 'chown' r=0
<6>[    2.316181] init: command 'chmod' r=0
<6>[    2.327317] init: command 'mkdir' r=0
<6>[    2.327430] init: command 'copy' r=-1
<6>[    2.328168] init: command 'chown' r=-2
<6>[    2.328212] init: command 'chmod' r=-2
<6>[    2.328259] init: command 'copy' r=-1
<6>[    2.328319] init: command 'chown' r=-2
<6>[    2.328353] init: command 'chmod' r=-2
<6>[    2.328396] init: command 'write' r=-2
<6>[    2.337215] init: command 'mkdir' r=0
<6>[    2.338150] init: command 'mkdir' r=0
<6>[    2.338286] init: command 'mkdir' r=0
<6>[    2.338391] init: command 'mkdir' r=0
<6>[    2.338490] init: command 'mkdir' r=0
<6>[    2.338616] init: command 'mkdir' r=0
<6>[    2.338731] init: command 'mkdir' r=0
<6>[    2.338827] init: command 'mkdir' r=0
<6>[    2.339548] init: command 'chmod' r=-2
<6>[    2.339592] init: command 'chown' r=-2
<6>[    2.339734] init: command 'mkdir' r=0
<6>[    2.339843] init: command 'mkdir' r=0
<6>[    2.339890] init: command 'chown' r=0
<6>[    2.348836] init: command 'mkdir' r=0
<6>[    2.357613] init: command 'mkdir' r=0
<6>[    2.357818] init: command 'mkdir' r=0
<6>[    2.357951] init: command 'chmod' r=0
<6>[    2.359122] init: command 'chmod' r=0
<6>[    2.359234] init: command 'chmod' r=0
<6>[    2.359341] init: command 'chmod' r=0
<6>[    2.359402] init: command 'chown' r=0
<6>[    2.359450] init: command 'chown' r=0
<6>[    2.359498] init: command 'chown' r=0
<6>[    2.359549] init: command 'chown' r=0
<6>[    2.360299] init: command 'mkdir' r=0
<6>[    2.368971] init: command 'mkdir' r=0
<6>[    2.377955] init: command 'mkdir' r=0
<6>[    2.386762] init: command 'mkdir' r=0
<6>[    2.386965] init: command 'mkdir' r=0
<6>[    2.387126] init: command 'mkdir' r=0
<6>[    2.387240] init: command 'mkdir' r=0
<6>[    2.387345] init: command 'mkdir' r=0
<6>[    2.388229] init: command 'mkdir' r=0
<6>[    2.388359] init: command 'mkdir' r=0
<6>[    2.388463] init: command 'mkdir' r=0
<6>[    2.388513] init: command 'chown' r=0
<6>[    2.388558] init: command 'chmod' r=0
<6>[    2.388685] init: command 'mkdir' r=0
<6>[    2.388789] init: command 'mkdir' r=0
<6>[    2.388860] init: processing action 0x32f30 (post-fs-data)
<6>[    2.389076] init: command 'chown' r=0
<6>[    2.389200] init: command 'chmod' r=0
<6>[    2.389299] init: command 'chown' r=0
<6>[    2.389382] init: command 'chmod' r=0
<6>[    2.389401] init: processing action 0x35430 (post-fs-data)
<4>[    2.400694] keyname:ir_para  subname:ir_rate ,get error!
<6>[    2.401386] input: sun7i-ir as /devices/virtual/input/input3
<6>[    2.401957] init: command 'insmod' r=0
<4>[    2.407552] gpio_sunxi: disagrees about version of symbol module_layout
<6>[    2.407709] init: command 'insmod' r=-1
<6>[    2.444315] init: command 'insmod' r=-1
<4>[    2.472154] UMP: UMP device driver 0000 loaded
<6>[    2.472722] init: command 'insmod' r=0
<4>[    2.569778] mali: Unknown symbol sun7i_get_fb_addr_para (err 0)
<6>[    2.573616] init: command 'insmod' r=-1
<6>[    2.586069] init: command 'insmod' r=0
<6>[    2.595266] init: command 'insmod' r=0
<4>[    2.617186] axp20_ldo3: Failed to create debugfs directory
<4>[    2.678489] [i2c1] incomplete xfer (status: 0x20, dev addr: 0x3c)
<6>[    2.678965] init: command 'insmod' r=0
<6>[    2.695957] init: command 'insmod' r=0
<6>[    2.720448] [CSI]Welcome to CSI driver
<6>[    2.720467] [CSI]csi_init
<3>[    2.721858] i2c i2c-1: Invalid 7-bit I2C address 0x00
<6>[    2.727549] [CSI_ERR]Error registering v4l2 subdevice,input_num = 0
<6>[    2.727593] [CSI_ERR]failed to install
<6>[    2.728136] init: command 'insmod' r=0
<3>[    2.750783] init: C_IN_START
<3>[    2.754043] init: path = /dev/block/data
<3>[    2.758478] init: C_IN_START
<3>[    2.761777] init: path = /dev/block/cacheuvcvideo: disagrees about version of symbol module_layout
<6>[    2.796945] init: command 'insmod' r=-1
<4>[    2.808471] get_device_para_value:get subname:stk831x error! val.val:0
<4>[    2.808492] get_detect_list: script_get_item err.support_number = 4.
<6>[    2.808535] init: command 'insmod' r=0
<6>[    2.824066] usbcore: registered new interface driver rtl8150
<6>[    2.824151] init: command 'insmod' r=0
<6>[    2.824187] init: processing action 0x37128 (property_service_init)
<6>[    2.827409] init: Created socket '/dev/socket/property_service' with mode '666', user '0', group '0'
<6>[    2.827452] init: command 'property_service_init' r=0
<6>[    2.827486] init: processing action 0x37170 (signal_init)
<6>[    2.827625] init: waitpid returned pid 1065, status = 00000000
<3>[    2.827647] init: untracked pid 1065 exited
<6>[    2.832316] init: command 'signal_init' r=0
<6>[    2.832389] init: processing action 0x371b8 (check_startup)
<6>[    2.832457] init: command 'check_startup' r=0
<6>[    2.832479] init: processing action 0x2f6f8 (boot)
<6>[    2.833981] init: command 'ifup' r=0
<6>[    2.834137] init: command 'hostname' r=0
<6>[    2.834211] init: command 'domainname' r=0
<6>[    2.834241] init: command 'setrlimit' r=0
<6>[    2.834334] init: command 'write' r=0
<6>[    2.834414] init: command 'write' r=0
<6>[    2.834541] init: command 'chown' r=0
<6>[    2.834600] init: command 'chmod' r=0
<6>[    2.834683] init: command 'chown' r=0
<6>[    2.834740] init: command 'chmod' r=0
<6>[    2.834818] init: command 'write' r=0
<6>[    2.834890] init: command 'write' r=0
<6>[    2.834959] init: command 'chown' r=0
<6>[    2.835016] init: command 'chown' r=0
<6>[    2.835083] init: command 'chown' r=0
<6>[    2.835137] init: command 'chown' r=0
<6>[    2.835183] init: command 'chmod' r=0
<6>[    2.835231] init: command 'chmod' r=0
<6>[    2.835275] init: command 'chmod' r=0
<6>[    2.835348] init: command 'chown' r=0
<6>[    2.835405] init: command 'chmod' r=0
<6>[    2.835467] init: command 'chown' r=0
<6>[    2.835522] init: command 'chmod' r=0
<6>[    2.835582] init: command 'chown' r=0
<6>[    2.835631] init: command 'chmod' r=0
<6>[    2.835721] init: command 'chown' r=0
<6>[    2.835780] init: command 'chown' r=0
<6>[    2.835837] init: command 'chown' r=0
<6>[    2.835893] init: command 'chown' r=0
<6>[    2.835949] init: command 'chown' r=0
<6>[    2.836003] init: command 'chown' r=0
<6>[    2.836112] init: command 'chown' r=0
<6>[    2.836206] init: command 'setprop' r=0
<6>[    2.836269] init: command 'setprop' r=0
<6>[    2.836328] init: command 'setprop' r=0
<6>[    2.836387] init: command 'setprop' r=0
<6>[    2.836448] init: command 'setprop' r=0
<6>[    2.836507] init: command 'setprop' r=0
<6>[    2.836565] init: command 'setprop' r=0
<6>[    2.836599] init: command 'setprop' r=0
<5>[    2.836770] init: starting 'servicemanager'
<5>[    2.837370] init: starting 'vold'
<6>[    2.837882] init: command 'class_start' r=0
<5>[    2.838032] init: starting 'netd'
<5>[    2.838667] init: starting 'debuggerd'
<6>[    2.839035] init: Created socket '/dev/socket/mdns' with mode '660', user '0', group '1000'
<6>[    2.839203] init: Created socket '/dev/socket/dnsproxyd' with mode '660', user '0', group '3003'
<5>[    2.839241] init: starting 'ril-daemon'
<6>[    2.839317] init: Created socket '/dev/socket/netd' with mode '660', user '0', group '1000'
<5>[    2.839851] init: starting 'surfaceflinger'
<5>[    2.840480] init: starting 'zygote'
<5>[    2.841067] init: starting 'drm'
<5>[    2.841690] init: starting 'media'
<5>[    2.842324] init: starting 'installd'
<6>[    2.842343] init: Created socket '/dev/socket/vold' with mode '660', user '0', group '1009'
<3>[    2.842940] init: cannot find '/system/etc/install-recovery.sh', disabling 'flash_recovery'
<6>[    2.847383] init: Created socket '/dev/socket/zygote' with mode '660', user '0', group '1000'
<6>[    2.853784] init: Created socket '/dev/socket/rild-debug' with mode '660', user '1001', group '1000'
<6>[    2.853983] init: Created socket '/dev/socket/rild' with mode '660', user '0', group '1001'
<5>[    2.855377] init: starting 'keystore'
<5>[    2.856054] init: starting 'u3gmonitor'
<5>[    2.856747] init: starting 'securefile'
<5>[    2.857396] init: starting 'isomountmanager'
<5>[    2.858014] init: starting 'gpio'
<5>[    2.858747] init: starting 'property'
<6>[    2.859313] init: command 'class_start' r=0
<6>[    2.859374] init: processing action 0x37200 (queue_property_triggers)
<6>[    2.859542] init: command 'queue_property_triggers' r=0
<6>[    2.859575] init: processing action 0x301c0 (property:ro.debuggable=1)
<5>[    2.859703] init: starting 'console'
<6>[    2.860295] init: command 'start' r=0
<6>[    2.860352] init: processing action 0x33928 (property:persist.sys.usb.config=*)
<6>[    2.860458] init: command 'setprop' r=0
<6>[    2.860488] init: processing action 0x36680 (property:sys.usb.config=mass_storage,adb)
<6>[    2.861017] init: Created socket '/dev/socket/installd' with mode '600', user '1000', group '1000'
<3>[    2.866154] android_usb: already disabled
<6>[    2.870726] init: command 'write' r=0
<6>[    2.870974] init: command 'write' r=0
<6>[    2.871121] init: command 'write' r=0
<3>[    2.871154] init: using deprecated syntax for specifying property 'sys.usb.config', use ${name} instead
<6>[    2.883344] init: Created socket '/dev/socket/keystore' with mode '666', user '0', group '0'
<6>[    2.884353] init: command 'write' r=0
<6>[    2.884530] init: command 'write' r=0
<5>[    2.884577] init: starting 'adbd'
<4>[    2.885094] [uart]: uart0 LCR & BAUD changed, reset controller...
<6>[    2.885138] init: command 'start' r=0
<3>[    2.885184] init: using deprecated syntax for specifying property 'sys.usb.config', use ${name} instead
<6>[    2.886162] init: Created socket '/dev/socket/adbd' with mode '660', user '1000', group '1000'
<6>[    2.898959] init: command 'setprop' r=0
<6>[    2.900316] adb_open
<4>[    2.900365] ep_matches, wrn: endpoint already claimed, ep(0xc08762e4, 0xef2827c0, ep1-bulk)
<6>[    2.900381] adb_bind_config
<4>[    2.900394] ep_matches, wrn: endpoint already claimed, ep(0xc08762e4, 0xef2827c0, ep1-bulk)
<4>[    2.900409] ep_matches, wrn: endpoint already claimed, ep(0xc0876330, 0xef2827c0, ep2-bulk)
<4>[    2.900424] ep_matches, wrn: endpoint already claimed, ep(0xc08762e4, 0xef2827c0, ep1-bulk)
<4>[    2.900439] ep_matches, wrn: endpoint already claimed, ep(0xc0876330, 0xef2827c0, ep2-bulk)
<4>[    2.900453] ep_matches, wrn: endpoint already claimed, ep(0xc087637c, 0xef138ec0, ep3-bulk)
<4>[    2.900469] [sw_udc]: alloc request: ep(0xc08763c8, ep4-bulk, 512), req(0xef26c1c0)
<4>[    2.900491] [sw_udc]: alloc request: ep(0xc087637c, ep3-bulk, 512), req(0xef26c240)
<4>[    2.900526] [sw_udc]: alloc request: ep(0xc087637c, ep3-bulk, 512), req(0xef26c640)
<4>[    2.900557] [sw_udc]: alloc request: ep(0xc087637c, ep3-bulk, 512), req(0xef26c740)
<4>[    2.900584] [sw_udc]: alloc request: ep(0xc087637c, ep3-bulk, 512), req(0xeea84ec0)
<4>[    2.900614] [sw_udc]: sw_udc_pullup, is_on = 1
<4>[    2.900629] WRN2631(drivers/usb/sun7i_usb/udc/sw_udc.c):ERR: usb device is not active
<4>[    2.913764] get_device_para_value:get subname:ilitek_ts error! val.val:0
<4>[    2.913787] get_detect_list: script_get_item err.support_number = 7.
<4>[    2.913801] get_device_para_value:get subname:aw5306_ts error! val.val:0
<4>[    2.913812] get_detect_list: script_get_item err.support_number = 6.
<4>[    2.913825] get_device_para_value:get subname:zet622x error! val.val:0
<4>[    2.913837] get_detect_list: script_get_item err.support_number = 5.
<4>[    2.931364] [i2c3] incomplete xfer (status: 0x20, dev addr: 0x38)
<4>[    2.944076] [i2c3] incomplete xfer (status: 0x20, dev addr: 0x38)
<4>[    2.963982] [i2c3] incomplete xfer (status: 0x20, dev addr: 0x38)
<4>[    2.984061] [i2c3] incomplete xfer (status: 0x20, dev addr: 0x38)
<4>[    3.004109] [i2c3] incomplete xfer (status: 0x20, dev addr: 0x38)
<4>[    3.024317] [i2c3] incomplete xfer (status: 0x20, dev addr: 0x76)
<4>[    3.044317] [i2c3] incomplete xfer (status: 0x20, dev addr: 0x76)
<4>[    3.067858] [i2c3] incomplete xfer (status: 0x20, dev addr: 0x76)
<4>[    3.083988] [i2c3] incomplete xfer (status: 0x20, dev addr: 0x76)
<4>[    3.098567] id used greatest stack depth: 5124 bytes left
<4>[    3.104723] [i2c3] incomplete xfer (status: 0x20, dev addr: 0x76)
<4>[    3.124078] [i2c3] incomplete xfer (status: 0x20, dev addr: 0x39)
<4>[    3.144082] [i2c3] incomplete xfer (status: 0x20, dev addr: 0x39)
<4>[    3.164043] [i2c3] incomplete xfer (status: 0x20, dev addr: 0x39)
<4>[    3.183927] [i2c3] incomplete xfer (status: 0x20, dev addr: 0x39)
<4>[    3.203956] [i2c3] incomplete xfer (status: 0x20, dev addr: 0x39)
<4>[    3.225288] [i2c3] incomplete xfer (status: 0x20, dev addr: 0x41)
<4>[    3.225648] ip6tables used greatest stack depth: 4836 bytes left
<4>[    3.243985] [i2c3] incomplete xfer (status: 0x20, dev addr: 0x41)
<4>[    3.263947] [i2c3] incomplete xfer (status: 0x20, dev addr: 0x41)
<4>[    3.284544] [i2c3] incomplete xfer (status: 0x20, dev addr: 0x41)
<4>[    3.305128] [i2c3] incomplete xfer (status: 0x20, dev addr: 0x41)
<6>[    4.038240] init: waitpid returned pid 1143, status = 0000000b
<5>[    4.038278] init: process 'surfaceflinger', pid 1143 exited
<5>[    4.038305] init: process 'surfaceflinger' killing any children in process group
<5>[    4.038341] init: service 'zygote' is being killed
<5>[    4.038539] init: starting 'zygote'
<6>[    4.041027] init: Created socket '/dev/socket/zygote' with mode '660', user '0', group '1000'
<4>[    4.042307] zygote used greatest stack depth: 4668 bytes left
<6>[    4.042701] init: waitpid returned pid 1144, status = 00000009
<3>[    4.042730] init: untracked pid 1144 exited
<6>[    5.138924] init: waitpid returned pid 1312, status = 00000000
<3>[    5.138958] init: untracked pid 1312 exited
<5>[    7.145834] init: starting 'surfaceflinger'
<6>[    7.343338] init: waitpid returned pid 1586, status = 0000000b
<5>[    7.343373] init: process 'surfaceflinger', pid 1586 exited
<5>[    7.343396] init: process 'surfaceflinger' killing any children in process group
<5>[    7.343431] init: service 'zygote' is being killed
<5>[    7.343733] init: starting 'zygote'
<6>[    7.345210] init: Created socket '/dev/socket/zygote' with mode '660', user '0', group '1000'
<6>[    7.360975] init: waitpid returned pid 1413, status = 00000009
<3>[    7.361007] init: untracked pid 1413 exited
<6>[   10.183345] warning: `zygote' uses 32-bit capabilities (legacy support in use)
<6>[   10.343248] init: processing action 0x303f8 (property:sys.sensors=1)
<5>[   10.343309] init: starting 'sensors'
<6>[   10.343937] init: command 'start' r=0
<6>[   10.368987] init: waitpid returned pid 1610, status = 00000a00
<5>[   10.369018] init: process 'sensors', pid 1610 exited
<5>[   12.371381] init: starting 'surfaceflinger'
<6>[   12.550926] init: waitpid returned pid 1622, status = 0000000b
<5>[   12.550956] init: process 'surfaceflinger', pid 1622 exited
<5>[   12.550978] init: process 'surfaceflinger' killing any children in process group
<5>[   12.551006] init: service 'zygote' is being killed
<5>[   12.551347] init: starting 'zygote'
<6>[   12.552628] init: Created socket '/dev/socket/zygote' with mode '660', user '0', group '1000'
<6>[   12.574417] init: waitpid returned pid 1591, status = 00000009
<3>[   12.574449] init: untracked pid 1591 exited
<6>[   12.594665] init: waitpid returned pid 1597, status = 00000009
<3>[   12.594695] init: untracked pid 1597 exited
<6>[   14.558028] init: processing action 0x303f8 (property:sys.sensors=1)
<5>[   14.558087] init: starting 'sensors'
<6>[   14.558668] init: command 'start' r=0
<6>[   14.577754] init: waitpid returned pid 1646, status = 00000a00
<5>[   14.577784] init: process 'sensors', pid 1646 exited
root@android:/ # [   23.001907] init: untracked pid 1661 exited
[   23.032931] init: untracked pid 1667 exited
GMT+8, 2025-1-16 01:57 , Processed in 0.119755 second(s), 15 queries , MemCache On.
