查看: 2368|回复: 0
Gokit2资料
  • 签到天数: 15 天
    [LV.4]偶尔看看III
    发表于 2015-9-29 11:46:39 | 显示全部楼层 |阅读模式
    在Gokit2所用的wifi模块驱动,电机驱动,红外检测传感器,温湿度检测器,RGB三色灯驱动,可以移植到项目中去,
    1,电机驱动程序及数据手册
    #ifndef _HAL_RGB_LED_H
    #define _HAL_RGB_LED_H
    #include "include.h"
    #define  R_MAX  255
    #define  G_MAX  255
    #define  B_MAX  255
    #define SCL_LOW         GPIO_ResetBits(GPIOB,GPIO_Pin_8)
    #define SCL_HIGH         GPIO_SetBits(GPIOB,GPIO_Pin_8)
    #define SDA_LOW                GPIO_ResetBits(GPIOB,GPIO_Pin_9)
    #define SDA_HIGH        GPIO_SetBits(GPIOB,GPIO_Pin_9)
    void RGB_LED_Init(void);
    void LED_R_Control(uint8_t R);
    void LED_G_Control(uint8_t G);
    void LED_B_Control(uint8_t B);
    void LED_RGB_Control(uint8_t R,uint8_t B,uint8_t G);
    #endif /*_HAL_RGB_LED_H*/
    void LED_delay(unsigned int  ms)
            volatile unsigned  int i=0;
         for(i=0;i<ms;i++);
    /************ generation clock *********************/
    void ClkProduce(void)
      SCL_LOW;    // SCL=0
            LED_delay(40);
      SCL_HIGH;     // SCL=1
      LED_delay(40);
    /**********  send 32 zero ********************/
    void Send32Zero(void)
      unsigned char i;
            SDA_LOW;   // SDA=0
            for (i=0; i<32; i++)
                    ClkProduce();
    /********* invert the grey value of the first two bits ***************/
    uint8_t TakeAntiCode(uint8_t dat)
        uint8_t tmp = 0;
            tmp=((~dat) & 0xC0)>>6;
            return tmp;
    /****** send gray data *********/
    void DatSend(uint32_t dx)
        uint8_t i;
                if ((dx & 0x80000000) != 0)
                    SDA_HIGH;     //  SDA=1;
                    else
                 SDA_LOW;    //  SDA=0;
                    dx <<= 1;
        ClkProduce();
    /******* data processing  ********************/
    void DataDealWithAndSend(uint8_t r, uint8_t g, uint8_t b)
        uint32_t dx = 0;
        dx |= (uint32_t)0x03 << 30;             // The front of the two bits 1 is flag bits
        dx |= (uint32_t)TakeAntiCode(g) << 28;
        dx |= (uint32_t)TakeAntiCode(b) << 26;
        dx |= (uint32_t)TakeAntiCode(r) << 24;
        dx |= (uint32_t)g << 16;
        dx |= (uint32_t)b << 8;
        dx |= r;
        DatSend(dx);
        RCC->APB2ENR|=1<<3;     //使能PORTB时钟
        GPIOB->CRH&=0X0FFFFF00;//PA13,15设置成输出
        GPIOB->CRH|=0X80800033;
        GPIOB->ODR|=1<<8;    //PB8上拉,PA0默认下拉
        GPIOB->ODR|=1<<9;    //PB9上拉
            Send32Zero();
            DataDealWithAndSend(0,0,0);          // display red
    void LED_RGB_Control(uint8_t R, uint8_t G, uint8_t B)
            Send32Zero();
            DataDealWithAndSend(R, G, B);          // display red
    //        printf("LED_R = %d LED_G = %d LED_B = %d",R,G,B);
    L9110.pdf
    144.81 KB, 下载次数: 0
    售价: 1 与非币  [记录]  [购买]
    电机驱动
    L9110.pdf
    144.81 KB, 下载次数: 0
    售价: 1 与非币  [记录]  [购买]
    电机驱动
    L9110.pdf
    144.81 KB, 下载次数: 0
    售价: 1 与非币  [记录]  [购买]
    电机驱动
    GMT+8, 2024-11-22 11:44 , Processed in 0.110771 second(s), 17 queries , MemCache On.
