查看: 3666|回复: 0
BPI-M1+ openwrt wifi驱动问题
    发表于 2015-8-8 18:02:05 | 显示全部楼层 |阅读模式
    最近在解决BPI-M1+的openwrt wifi问题,搞了好久了,wifi还是启动不了,身心疲惫啊。所以上论坛来求助。。。
    下面是openwrt的启动内核日志,有不有看得懂的朋友,帮忙确定下wifi到底搞定没。
    这一行:
    1. [ 8.839605] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
    是不是代表通讯成功了?
    内核启动日志:
    1. [    0.000000] Booting Linux on physical CPU 0x0
    2. [    0.000000] Linux version 3.18.19 (charli@charli-pc) (gcc version 4.8.3 (OpenWrt/Linaro GCC 4.8-2014.04 r46549) ) #1 SMP PREEMPT Sat Aug 8 16:25:50 CST 2015
    3. [    0.000000] CPU: ARMv7 Processor [410fc074] revision 4 (ARMv7), cr=10c5387d
    4. [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
    5. [    0.000000] Machine model: BPI M1+
    6. [    0.000000] Memory policy: Data cache writealloc
    7. [    0.000000] On node 0 totalpages: 260096
    8. [    0.000000] free_area_init_node: node 0, pgdat c0509740, node_mem_map ef00a000
    9. [    0.000000]   Normal zone: 1520 pages used for memmap
    10. [    0.000000]   Normal zone: 0 pages reserved
    11. [    0.000000]   Normal zone: 194560 pages, LIFO batch:31
    12. [    0.000000]   HighMem zone: 512 pages used for memmap
    13. [    0.000000]   HighMem zone: 65536 pages, LIFO batch:15
    14. [    0.000000] psci: probing for conduit method from DT.
    15. [    0.000000] psci: Using PSCI v0.1 Function IDs from DT
    16. [    0.000000] PERCPU: Embedded 9 pages/cpu @eefe0000 s6272 r8192 d22400 u36864
    17. [    0.000000] pcpu-alloc: s6272 r8192 d22400 u36864 alloc=9*4096
    18. [    0.000000] pcpu-alloc: [0] 0 [0] 1
    19. [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 258576
    20. [    0.000000] Kernel command line: console=ttyS0,115200 earlyprintk rootwait root=/dev/mmcblk0p2
    21. [    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
    22. [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
    23. [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
    24. [    0.000000] Memory: 1025356K/1040384K available (3827K kernel code, 170K rwdata, 1072K rodata, 204K init, 606K bss, 15028K reserved, 262144K highmem)
    25. [    0.000000] Virtual kernel memory layout:
    26. [    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    27. [    0.000000]     fixmap  : 0xffc00000 - 0xffe00000   (2048 kB)
    28. [    0.000000]     vmalloc : 0xf0000000 - 0xff000000   ( 240 MB)
    29. [    0.000000]     lowmem  : 0xc0000000 - 0xef800000   ( 760 MB)
    30. [    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
    31. [    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
    32. [    0.000000]       .text : 0xc0008000 - 0xc04d0ef4   (4900 kB)
    33. [    0.000000]       .init : 0xc04d1000 - 0xc0504000   ( 204 kB)
    34. [    0.000000]       .data : 0xc0504000 - 0xc052e878   ( 171 kB)
    35. [    0.000000]        .bss : 0xc052e878 - 0xc05c6208   ( 607 kB)
    36. [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
    37. [    0.000000] Preemptible hierarchical RCU implementation.
    38. [    0.000000]         RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
    39. [    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
    40. [    0.000000] NR_IRQS:16 nr_irqs:16 16
    41. [    0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
    42. [    0.000008] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 2863311519744ns
    43. [    0.000022] Switching to timer-based delay loop, resolution 41ns
    44. [    0.000358] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956969942ns
    45. [    0.000517] sched_clock: 32 bits at 160MHz, resolution 6ns, wraps every 26843545593ns
    46. [    0.000682] Console: colour dummy device 80x30
    47. [    0.000711] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
    48. [    0.000727] pid_max: default: 32768 minimum: 301
    49. [    0.000833] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
    50. [    0.000844] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
    51. [    0.001461] CPU: Testing write buffer coherency: ok
    52. [    0.001763] /cpus/cpu@0 missing clock-frequency property
    53. [    0.001783] /cpus/cpu@1 missing clock-frequency property
    54. [    0.001797] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    55. [    0.001850] Setting up static identity map for 0x40011c20 - 0x40011c54
    56. [    0.060433] CPU1: Booted secondary processor
    57. [    0.060479] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
    58. [    0.060552] Brought up 2 CPUs
    59. [    0.060575] SMP: Total of 2 processors activated (96.00 BogoMIPS).
    60. [    0.060582] CPU: All CPU(s) started in HYP mode.
    61. [    0.060587] CPU: Virtualization extensions available.
    62. [    0.064980] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 4
    63. [    0.065373] pinctrl core: initialized pinctrl subsystem
    64. [    0.065766] regulator-dummy: no parameters
    65. [    0.072012] NET: Registered protocol family 16
    66. [    0.072359] DMA: preallocated 256 KiB pool for atomic coherent allocations
    67. [    0.111482] reg-fixed-voltage usb1-vbus: could not find pctldev for node /soc@01c00000/pinctrl@01c20800/usb1_vbus_pin@0, deferring probe
    68. [    0.111517] platform usb1-vbus: Driver reg-fixed-voltage requests probe deferral
    69. [    0.111546] reg-fixed-voltage usb2-vbus: could not find pctldev for node /soc@01c00000/pinctrl@01c20800/usb2_vbus_pin@0, deferring probe
    70. [    0.111561] platform usb2-vbus: Driver reg-fixed-voltage requests probe deferral
    71. [    0.111761] vcc3v0: 3000 mV
    72. [    0.111976] vcc3v3: 3300 mV
    73. [    0.112218] vcc5v0: 5000 mV
    74. [    0.112302] reg-fixed-voltage gmac-3v3: could not find pctldev for node /soc@01c00000/pinctrl@01c20800/gmac_power_pin@0, deferring probe
    75. [    0.112320] platform gmac-3v3: Driver reg-fixed-voltage requests probe deferral
    76. [    0.112345] reg-fixed-voltage vmmc3: could not find pctldev for node /soc@01c00000/pinctrl@01c20800/vmmc3_pin@0, deferring probe
    77. [    0.112359] platform vmmc3: Driver reg-fixed-voltage requests probe deferral
    78. [    0.112812] SCSI subsystem initialized
    79. [    0.112893] libata version 3.00 loaded.
    80. [    0.113219] usbcore: registered new interface driver usbfs
    81. [    0.113302] usbcore: registered new interface driver hub
    82. [    0.113422] usbcore: registered new device driver usb
    83. [    0.113578] pps_core: LinuxPPS API ver. 1 registered
    84. [    0.113588] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    85. [    0.113617] PTP clock support registered
    86. [    0.114672] Switched to clocksource arch_sys_counter
    87. [    0.121745] NET: Registered protocol family 2
    88. [    0.122773] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
    89. [    0.122856] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
    90. [    0.122978] TCP: Hash tables configured (established 8192 bind 8192)
    91. [    0.123064] TCP: reno registered
    92. [    0.123083] UDP hash table entries: 512 (order: 2, 16384 bytes)
    93. [    0.123140] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
    94. [    0.123409] NET: Registered protocol family 1
    95. [    0.124904] futex hash table entries: 512 (order: 3, 32768 bytes)
    96. [    0.125064] audit: initializing netlink subsys (disabled)
    97. [    0.125146] audit: type=2000 audit(0.110:1): initialized
    98. [    0.133943] VFS: Disk quotas dquot_6.5.2
    99. [    0.134202] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
    100. [    0.135925] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    101. [    0.135945] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
    102. [    0.136670] msgmni has been set to 1490
    103. [    0.138796] bounce: pool size: 64 pages
    104. [    0.138823] io scheduler noop registered
    105. [    0.138837] io scheduler deadline registered
    106. [    0.138888] io scheduler cfq registered (default)
    107. [    0.139218] platform 1c13400.phy: Driver sun4i-usb-phy requests probe deferral
    108. [    0.141931] sun7i-a20-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
    109. [    0.184509] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
    110. [    0.187053] console [ttyS0] disabled
    111. [    0.207470] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 33, base_baud = 1500000) is a U6_16550A
    112. [    0.828391] console [ttyS0] enabled
    113. [    0.854981] 1c28800.serial: ttyS1 at MMIO 0x1c28800 (irq = 35, base_baud = 1500000) is a U6_16550A
    114. [    0.886924] 1c29c00.serial: ttyS2 at MMIO 0x1c29c00 (irq = 52, base_baud = 1500000) is a U6_16550A
    115. [    0.899486] platform 1c50000.ethernet: Driver stmmaceth requests probe deferral
    116. [    0.906966] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
    117. [    0.913493] ehci-platform: EHCI generic platform driver
    118. [    0.918900] platform 1c14000.usb: Driver ehci-platform requests probe deferral
    119. [    0.926226] platform 1c1c000.usb: Driver ehci-platform requests probe deferral
    120. [    0.933544] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
    121. [    0.939770] ohci-platform: OHCI generic platform driver
    122. [    0.945130] platform 1c14400.usb: Driver ohci-platform requests probe deferral
    123. [    0.952415] platform 1c1c400.usb: Driver ohci-platform requests probe deferral
    124. [    0.959814] usbcore: registered new interface driver usb-storage
    125. [    0.966107] mousedev: PS/2 mouse device common for all mice
    126. [    0.976406] axp20x-regulator axp20x-regulator: regulators node not found
    127. [    0.983233] LDO1: 1300 mV
    128. [    0.986389] LDO2: at 3000 mV
    129. [    0.989772] LDO3: at 2275 mV
    130. [    0.992902] LDO4: at 2800 mV
    131. [    0.996307] LDO5: at 2800 mV
    132. [    0.999711] DCDC2: at 1400 mV
    133. [    1.003163] DCDC3: at 1250 mV
    134. [    1.006325] axp20x 0-0034: AXP20X driver loaded
    135. [    1.011868] sunxi-wdt 1c20c90.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
    136. [    1.020412] sunxi-mmc 1c0f000.mmc: No vqmmc regulator found
    137. [    1.026377] sunxi-mmc 1c0f000.mmc: Got CD GPIO
    138. [    1.064943] sunxi-mmc 1c0f000.mmc: base:0xf00f6000 irq:64
    139. [    1.070823] platform 1c12000.mmc: Driver sunxi-mmc requests probe deferral
    140. [    1.080139] sunxi-ss 1c15000.crypto-engine: Die ID 0
    141. [    1.087203] TCP: cubic registered
    142. [    1.090535] Initializing XFRM netlink socket
    143. [    1.094912] NET: Registered protocol family 17
    144. [    1.099471] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
    145. [    1.112092] 8021q: 802.1Q VLAN Support v1.8
    146. [    1.116417] Registering SWP/SWPB emulation handler
    147. [    1.121734] registered taskstats version 1
    148. [    1.122893] mmc0: host does not support reading read-only switch, assuming write-enable
    149. [    1.125826] mmc0: new high speed SDHC card at address 0001
    150. [    1.126299] mmcblk0: mmc0:0001 00000 7.44 GiB
    151. [    1.127496]  mmcblk0: p1 p2
    152. [    1.147328] usb1-vbus: 5000 mV
    153. [    1.150855] usb2-vbus: 5000 mV
    154. [    1.154338] gmac-3v3: 3300 mV
    155. [    1.157813] vmmc3: 3300 mV
    156. [    1.264752] stmmaceth 1c50000.ethernet: no reset control found
    157. [    1.270591]  Ring mode enabled
    158. [    1.273642]  No HW DMA feature register supported
    159. [    1.278189]  Normal descriptors
    160. [    1.281510]  TX Checksum insertion supported
    161. [    1.290061] libphy: stmmac: probed
    162. [    1.293474] eth0: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active
    163. [    1.299841] eth0: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01)
    164. [    1.305947] ehci-platform 1c14000.usb: EHCI Host Controller
    165. [    1.311549] ehci-platform 1c14000.usb: new USB bus registered, assigned bus number 1
    166. [    1.319433] ehci-platform 1c14000.usb: irq 71, io mem 0x01c14000
    167. [    1.344691] ehci-platform 1c14000.usb: USB 2.0 started, EHCI 1.00
    168. [    1.350985] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
    169. [    1.357787] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    170. [    1.365012] usb usb1: Product: EHCI Host Controller
    171. [    1.369886] usb usb1: Manufacturer: Linux 3.18.19 ehci_hcd
    172. [    1.375376] usb usb1: SerialNumber: 1c14000.usb
    173. [    1.380485] hub 1-0:1.0: USB hub found
    174. [    1.384273] hub 1-0:1.0: 1 port detected
    175. [    1.388893] ehci-platform 1c1c000.usb: EHCI Host Controller
    176. [    1.394496] ehci-platform 1c1c000.usb: new USB bus registered, assigned bus number 2
    177. [    1.402379] ehci-platform 1c1c000.usb: irq 72, io mem 0x01c1c000
    178. [    1.424698] ehci-platform 1c1c000.usb: USB 2.0 started, EHCI 1.00
    179. [    1.430992] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
    180. [    1.437800] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    181. [    1.445029] usb usb2: Product: EHCI Host Controller
    182. [    1.449902] usb usb2: Manufacturer: Linux 3.18.19 ehci_hcd
    183. [    1.455395] usb usb2: SerialNumber: 1c1c000.usb
    184. [    1.460468] hub 2-0:1.0: USB hub found
    185. [    1.464251] hub 2-0:1.0: 1 port detected
    186. [    1.468834] ohci-platform 1c14400.usb: Generic Platform OHCI controller
    187. [    1.475511] ohci-platform 1c14400.usb: new USB bus registered, assigned bus number 3
    188. [    1.483366] ohci-platform 1c14400.usb: irq 96, io mem 0x01c14400
    189. [    1.548867] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
    190. [    1.555680] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    191. [    1.562896] usb usb3: Product: Generic Platform OHCI controller
    192. [    1.568829] usb usb3: Manufacturer: Linux 3.18.19 ohci_hcd
    193. [    1.574311] usb usb3: SerialNumber: 1c14400.usb
    194. [    1.579406] hub 3-0:1.0: USB hub found
    195. [    1.583190] hub 3-0:1.0: 1 port detected
    196. [    1.587753] ohci-platform 1c1c400.usb: Generic Platform OHCI controller
    197. [    1.594391] ohci-platform 1c1c400.usb: new USB bus registered, assigned bus number 4
    198. [    1.602294] ohci-platform 1c1c400.usb: irq 97, io mem 0x01c1c400
    199. [    1.668872] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
    200. [    1.675676] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    201. [    1.682892] usb usb4: Product: Generic Platform OHCI controller
    202. [    1.688826] usb usb4: Manufacturer: Linux 3.18.19 ohci_hcd
    203. [    1.694308] usb usb4: SerialNumber: 1c1c400.usb
    204. [    1.699372] hub 4-0:1.0: USB hub found
    205. [    1.703164] hub 4-0:1.0: 1 port detected
    206. [    1.708020] sunxi-mmc 1c12000.mmc: No vqmmc regulator found
    207. [    1.974668] sunxi-mmc 1c12000.mmc: fatal err update clk timeout
    208. [    1.994692] sunxi-mmc 1c12000.mmc: base:0xf0140000 irq:67
    209. [    2.000142] drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
    210. [    2.011029] vcc5v0: disabling
    211. [    2.014016] vcc3v0: disabling
    212. [    2.019809] EXT4-fs (mmcblk0p2): couldn't mount as ext3 due to feature incompatibilities
    213. [    2.029313] EXT4-fs (mmcblk0p2): couldn't mount as ext2 due to feature incompatibilities
    214. [    2.045735] EXT4-fs (mmcblk0p2): mounted filesystem without journal. Opts: (null)
    215. [    2.053263] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    216. [    2.060395] Freeing unused kernel memory: 204K (c04d1000 - c0504000)
    217. [    2.176702] init: Console is alive
    218. [    2.180385] init: - watchdog -
    219. [    2.244693] sunxi-mmc 1c12000.mmc: fatal err update clk timeout
    220. [    2.494676] sunxi-mmc 1c12000.mmc: fatal err update clk timeout
    221. [    2.744661] sunxi-mmc 1c12000.mmc: fatal err update clk timeout
    222. [    3.184272] init: - preinit -
    223. [    3.257002] random: mktemp urandom read with 5 bits of entropy available
    224. [    6.319899] mount_root: mounting /dev/root
    225. [    6.330347] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    226. [    6.341254] procd: - early -
    227. [    6.344267] procd: - watchdog -
    228. [    7.087126] procd: - ubus -
    229. [    8.091561] procd: - init -
    230. [    8.577709] NET: Registered protocol family 10
    231. [    8.588762] ip6_tables: (C) 2000-2006 Netfilter Core Team
    232. [    8.605358] sunxi-rtc 1c20d00.rtc: rtc core: registered rtc-sunxi as rtc0
    233. [    8.612181] sunxi-rtc 1c20d00.rtc: RTC enabled
    234. [    8.635875] Loading modules backported from Linux version master-2015-03-09-0-g141f155
    235. [    8.643796] Backport generated by backports.git backports-20150129-0-gdd4a670
    236. [    8.652636] ip_tables: (C) 2000-2006 Netfilter Core Team
    237. [    8.663109] nf_conntrack version 0.5.0 (16024 buckets, 64096 max)
    238. [    8.765806] xt_time: kernel timezone is -0000
    239. [    8.780029] cfg80211: Calling CRDA to update world regulatory domain
    240. [    8.786642] cfg80211: World regulatory domain updated:
    241. [    8.791800] cfg80211:  DFS Master region: unset
    242. [    8.797322] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
    243. [    8.807247] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
    244. [    8.815328] cfg80211:   (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
    245. [    8.823368] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
    246. [    8.831497] cfg80211:   (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
    247. [    8.839605] cfg80211:   (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
    248. [    8.849181] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
    249. [    8.857352] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
    250. [    8.865405] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
    251. [    8.879149] PPP generic driver version 2.4.2
    252. [    8.884560] NET: Registered protocol family 24
    253. [    8.894576] usbcore: registered new interface driver brcmfmac
    254. [   11.824589]  RX IPC Checksum Offload disabled
    255. [   11.847320]  No MAC Management Counters available
    256. [   16.805015] stmmaceth 1c50000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
    257. [  198.727765] random: nonblocking pool is initialized
    评分
    参与人数 1与非币 +5 收起 理由
    loveeeboard + 5 三周年铜板双倍!
    查看全部评分
    GMT+8, 2025-1-19 22:14 , Processed in 0.120463 second(s), 16 queries , MemCache On.
