查看: 2634|回复: 5
[求助] GD32 18b20求助
  • 签到天数: 971 天
    发表于 2015-8-3 23:04:12 | 显示全部楼层 |阅读模式
    18B20  1-wire总线的数据传输,遗憾的是在GD32中总是驱动不了,我知道以前用freecale KL25Z 与STM32F103 都很容易驱动成功,但是这GD32 花费了我一周多的时间还是不成功,求助于大家!~请大家指点指点一下
    1. class DigitalInOut {
    2. public:
    3.     /** Create a DigitalInOut connected to the specified pin
    4.      *
    5.      *  @param pin DigitalInOut pin to connect to
    6.      */
    7.     DigitalInOut(PinName pin){
    8.         GPIO_InitPara GPIO_InitStructure;
    9.                 GPIOx = (GPIO_TypeDef *)(AHB2PERIPH_BASE +(uint32_t)((pin&0xffff0000)>>16));
    10.                 GPIO_Pin = (uint16_t)(pin&0xffff);
    11.
    12.     }
    13.     /** Set the output, specified as 0 or 1 (int)
    14.      *
    15.      *  @param value An integer specifying the pin output value,
    16.      *      0 for logical 0, 1 (or any other non-zero value) for logical 1
    17.      */
    18.     void write(int value) {
    19.                 if(value)
    20.                         GPIO_WriteBit(GPIOx,GPIO_Pin,Bit_SET);
    21.                 else
    22.                         GPIO_WriteBit(GPIOx,GPIO_Pin,Bit_RESET);
    23.     }
    24.     /** Return the output setting, represented as 0 or 1 (int)
    25.      *
    26.      *  @returns
    27.      *    an integer representing the output setting of the pin if it is an output,
    28.      *    or read the input if set as an input
    29.      */
    30.     int read() {
    31.         if(GPIO_ReadInputBit(GPIOx,GPIO_Pin))
    32.                         return 1;
    33.                 else
    34.                         return 0;
    35.     }
    36.     /** Set as an output
    37.      */
    38.     void output() {
    39.         //gpio_dir(&gpio, PIN_OUTPUT);
    40.         GPIO_InitPara GPIO_InitStructure;
    41.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin;
    42.         GPIO_InitStructure.GPIO_Mode = GPIO_MODE_OUT;
    43.         GPIO_InitStructure.GPIO_Speed = GPIO_SPEED_50MHZ;
    44.         GPIO_InitStructure.GPIO_OType = GPIO_OTYPE_PP;
    45.         GPIO_InitStructure.GPIO_PuPd = GPIO_PUPD_NOPULL;
    46.         GPIO_Init(GPIOx,&GPIO_InitStructure);
    47.     }
    48.     /** Set as an input
    49.      */
    50.     void input() {
    51.         //gpio_dir(&gpio, PIN_INPUT);
    52.         GPIO_InitPara GPIO_InitStructure;
    53.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin;
    54.         GPIO_InitStructure.GPIO_Mode = GPIO_MODE_IN;
    55.     GPIO_InitStructure.GPIO_PuPd = GPIO_PUPD_NOPULL;
    56.         GPIO_Init(GPIOx,&GPIO_InitStructure);
    57.     }
    58.     /** Set the input pin mode
    59.      *
    60.      *  @param mode PullUp, PullDown, PullNone, OpenDrain
    61.      */
    62.      /*
    63.     void mode(PinMode pull) {
    64.         //gpio_mode(&gpio, pull);
    65.     }*/
    66. protected:
    67.     GPIO_TypeDef* GPIOx;
    68.         uint16_t GPIO_Pin;
    69. };
    评分
    参与人数 1与非币 +5 收起 理由
    loveeeboard + 5 三周年铜板双倍!
    查看全部评分
  • 签到天数: 1368 天
    发表于 2015-8-4 07:51:39 | 显示全部楼层
    如果没有外部上拉,需要把内部的打开。
  • 签到天数: 971 天
    发表于 2015-8-4 10:40:08 | 显示全部楼层
    tjcfeng 发表于 2015-8-4 07:51
    如果没有外部上拉,需要把内部的打开。
    外部有上拉
  • 签到天数: 385 天
    发表于 2015-8-9 10:56:52 | 显示全部楼层
    c++开发,楼主用的是什么软件?
  • 签到天数: 971 天
    发表于 2015-8-10 08:20:18 | 显示全部楼层
    党国特派员 发表于 2015-8-9 10:56
    c++开发,楼主用的是什么软件?
    MDK :, 可惜到现在还是不能通信,调回原来的程序发现也是这样,怀疑是硬件出问题了
  • 签到天数: 385 天
    发表于 2015-8-10 09:22:39 | 显示全部楼层
    dvd1478 发表于 2015-8-10 08:20
    MDK :, 可惜到现在还是不能通信,调回原来的程序发现也是这样,怀疑是硬件出问题了 ...
    MDK好不支持C++吧。如果要做成C++那种,只有用STRUCT代替。
    GMT+8, 2024-12-24 22:07 , Processed in 0.175832 second(s), 26 queries , MemCache On.
