查看: 2722|回复: 1
STM32两个普通定时器,一个正常中断,一个不中断
发表于 2015-7-28 16:10:36 | 显示全部楼层 |阅读模式
用的STM32F103RB,设置了两个TIM定时器TIM2和TIM3,产生中断后计数,通过Jlink查看计数值,来判断中断执行情况。
现在其中一个定时器TIM3中断,可以正常进行(正常计数)。另一个TIM2中断,就没法产生中断(因为计数变量没有变化)。
这两个中断程序基本是一样的,求大神们帮忙看看为什么TIM2就不能中断呢?
void NVIC_Configuration(void)             //中断优先级
  NVIC_InitTypeDef NVIC_InitStructure;
  /* Configure the NVIC Preemption Priority Bits */
  NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
  /* Enable the USART1 Interrupt */
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 3;
  NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3;
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  NVIC_Init(&NVIC_InitStructure);
  /* Enable the USART2 Interrupt */
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
  NVIC_InitStructure.NVIC_IRQChannel = USART2_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
        /* Enable the TIM3 Interrupt */
        NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQn;
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 2;
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 2;
        /* Enable the Motor Interrupt */
        NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQn;
        NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
        NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
void TIM3_Config(void)
        TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
        TIM_DeInit(TIM3);
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3,ENABLE);
        TIM_TimeBaseStructure.TIM_Period = 2000 - 1;
        TIM_TimeBaseStructure.TIM_Prescaler = 8400 - 1;
        TIM_TimeBaseStructure.TIM_ClockDivision = 0x0;
        TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
        TIM_TimeBaseInit(TIM3,&TIM_TimeBaseStructure);
        TIM_ClearFlag(TIM3,TIM_FLAG_Update);
        TIM_ITConfig(TIM3,TIM_IT_Update,ENABLE);
        TIM_Cmd( TIM3, ENABLE);
void TIM2_Config(void)
        TIM_DeInit(TIM2);
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2,ENABLE);
        TIM_TimeBaseInit(TIM2,&TIM_TimeBaseStructure);
        //TIM_ARRPreloadCongig(TIM2,ENABLE);
        TIM_ClearFlag(TIM2,TIM_FLAG_Update);
        TIM_ITConfig(TIM2,TIM_IT_Update,ENABLE);
        TIM_Cmd( TIM2, ENABLE);
* Function Name  : TIM3_IRQHandler
* Description    : This function handles TIM3 global interrupt request. Count for 1min
* Input          : None
* Output         : None
* Return         : None
* Global                                 : Count1min
u8 Count1min=59;        //1s->1min
void TIM3_IRQHandler(void)
        if(TIM_GetITStatus(TIM3, TIM_IT_Update) != RESET)    //¼ì²âÊÇ·ñ·¢ÉúÒç³ö¸üÐÂʼþ
                TIM_ClearITPendingBit(TIM3 , TIM_FLAG_Update);//                Çå³ýÖжϴý´¦Àíλ
                if(Count1min == 0)                   //¼Æ60s
                                GPIOC->ODR ^= GPIO_Pin_6;
                                //Count1min=59;
                        else                            //for test
                                Count1min--;
* Function Name  : TIM2_IRQHandler
* Description    : This function handles TIM2 global interrupt request.
* Input          : None
* Output         : None
* Return         : None
* Global                                 : delay
        u8 Count1min4=59;        //1s->1min
void TIM2_IRQHandler(void)
        u8 outflag;
        if(TIM_GetITStatus(TIM2, TIM_IT_Update) != RESET)
                TIM_ClearITPendingBit(TIM2 , TIM_FLAG_Update);
                if(Count1min4 == 0)
                                GPIOC->ODR ^= GPIO_Pin_2;
                                Count1min4=59;
                        else                            //for test
                                Count1min4--;
评分
参与人数 1与非币 +5 收起 理由
loveeeboard + 5 三周年铜板双倍!
查看全部评分
    慵懒
    2018-3-28 17:24
  • 签到天数: 276 天
    发表于 2015-7-31 09:54:02 | 显示全部楼层
    你仿真调试下   看看  具体的寄存器工作没
    GMT+8, 2025-1-24 14:44 , Processed in 0.122862 second(s), 18 queries , MemCache On.
