查看: 3605|回复: 4
[经验] GD32启动代码的分析
    无聊
    2019-8-28 20:17
  • 签到天数: 9 天
    发表于 2015-7-1 21:26:25 | 显示全部楼层 |阅读模式
    大家都晒过板子了,我也就不再晒了,在这里送上对GD32启动代码的分析。
    ;  * @file    startup_gd32f1x0.s
    ;  * @author  MCU SD
    ;  * @version V1.0.1
    ;  * @date    6-Sep-2014
    ;  * @brief   GD32F1x0 startup code.
    ;/* <<< Use Configuration Wizard in Context Menu >>>                                                        */
    ; Amount of memory (in bytes) allocated for Stack and Heap
    ; Tailor those values to your application needs
    ;// <h> Stack Configuration
    ;//   <o> Stack Size (in Bytes) <0-8192:8>
    ;// </h>
    Stack_Size          EQU     0x400                                ;¶¨ÒåÕ»¿Õ¼äµÄ´óС£¬0x400 = 1k byte
                        AREA    STACK, NOINIT, READWRITE, ALIGN = 3
    Stack_Mem           SPACE   Stack_Size                           ;¿ª±ÙÒ»¶Î´óСΪStack_SizeµÄÄÚ´æ¿Õ¼ä×÷Ϊջ
    __initial_sp                                                     ;±êºÅ__initial_sp£¬±íʾջ¶¥£¨ÏòÏÂÉú³¤µÄÂúջģÐÍ£©
    ;// <h> Heap Configuration
    ;//   <o>  Heap Size (in Bytes) <0-8192:8>
    ;// </h>
    Heap_Size           EQU     0x400                                ;¶¨Òå¶Ñ¿Õ¼äµÄ´óС£¬0x400 = 1k byte
                        AREA    HEAP, NOINIT, READWRITE, ALIGN = 3
    __heap_base                                                      ;±êºÅ__heap_base£¬±íʾ¶Ñ¿Õ¼äµÄÆðʼµØÖ·
    Heap_Mem            SPACE   Heap_Size                            ;¿ª±ÙÒ»¶Î´óСΪStack_SizeµÄÄÚ´æ¿Õ¼ä×÷Ϊ¶Ñ
    __heap_limit                                                     ;±êºÅ__heap_limit£¬±íʾ¶Ñ¿Õ¼äµÄ½áÊøµØÖ·
                        PRESERVE8                                    ;¸æËß±àÒëÆ÷ÒÔ8×Ö½Ú¶ÔÆë
                        THUMB                                        ;¸æËß±àÒëÆ÷ʹÓÃThumbÖ¸Áî
    ; Vector table entries with the exceptions ISR address
                        AREA    RESET, DATA, READONLY                ;¶¨ÒåÖ»¶ÁÊý¾Ý¶Î£¬Êµ¼ÊÊÇCODEÇø
                        EXPORT  __Vectors                            ;½«±êºÅ__VectorsÉùÃ÷Ϊȫ¾Ö±êºÅ£¬ÕâÑùÍⲿÎļþ¾Í¿ÉÒÔʹÓÃÕâ¸ö±êºÅ
                        EXPORT  __Vectors_End
                        EXPORT  __Vectors_Size
    ;±êºÅ__Vectors£¬±íʾÖжÏÏòÁ¿±íÈë¿ÚµØÖ·
    __Vectors           DCD     __initial_sp               ; Top of Stack
                        DCD     Reset_Handler              ; Reset Handler
                        DCD     NMI_Handler                ; NMI Handler
                        DCD     HardFault_Handler          ; Hard Fault Handler
                        DCD     MemManage_Handler          ; MPU Fault Handler
                        DCD     BusFault_Handler           ; Bus Fault Handler
                        DCD     UsageFault_Handler         ; Usage Fault Handler
                        DCD     0                          ; Reserved
                        DCD     0                          ; Reserved
                        DCD     0                          ; Reserved
                        DCD     0                          ; Reserved
                        DCD     SVC_Handler                ; SVCall Handler
                        DCD     DebugMon_Handler           ; Debug Monitor Handler
                        DCD     0                          ; Reserved
                        DCD     PendSV_Handler             ; PendSV Handler
                        DCD     SysTick_Handler            ; SysTick Handler
                        ; External Interrupts
                        DCD     WWDG_IRQHandler                ; Window Watchdog
                        DCD     LVD_IRQHandler                 ; LVD through EXTI Line detect
                        DCD     RTC_IRQHandler                 ; RTC through EXTI Line
                        DCD     FMC_IRQHandler                 ; FMC
                        DCD     RCC_IRQHandler                 ; RCC
                        DCD     EXTI0_1_IRQHandler             ; EXTI Line 0 and 1
                        DCD     EXTI2_3_IRQHandler             ; EXTI Line 2 and 3
                        DCD     EXTI4_15_IRQHandler            ; EXTI Line 4 to 15
                        DCD     TS_IRQHandler                  ; TS
                        DCD     DMA1_Channel1_IRQHandler       ; DMA1 Channel 1
                        DCD     DMA1_Channel2_3_IRQHandler     ; DMA1 Channel 2 and Channel 3
                        DCD     DMA1_Channel4_5_IRQHandler     ; DMA1 Channel 4 and Channel 5
                        DCD     ADC1_CMP_IRQHandler            ; ADC1, CMP1 and CMP2
                        DCD     TIM1_BRK_UP_TRG_COM_IRQHandler ; TIM1 Break, Update, Trigger and Commutation
                        DCD     TIM1_CC_IRQHandler             ; TIM1 Capture Compare
                        DCD     TIM2_IRQHandler                ; TIM2
                        DCD     TIM3_IRQHandler                ; TIM3
                        DCD     TIM6_DAC_IRQHandler            ; TIM6 and DAC
                        DCD     0                              ; Reserved
                        DCD     TIM14_IRQHandler               ; TIM14
                        DCD     TIM15_IRQHandler               ; TIM15
                        DCD     TIM16_IRQHandler               ; TIM16
                        DCD     TIM17_IRQHandler               ; TIM17
                        DCD     I2C1_EV_IRQHandler             ; I2C1 Event
                        DCD     I2C2_EV_IRQHandler             ; I2C2 Event
                        DCD     SPI1_IRQHandler                ; SPI1
                        DCD     SPI2_IRQHandler                ; SPI2
                        DCD     USART1_IRQHandler              ; USART1
                        DCD     USART2_IRQHandler              ; USART2
                        DCD     0                              ; Reserved
                        DCD     CEC_IRQHandler                 ; CEC
                        DCD     0                              ; Reserved
                        DCD     I2C1_ER_IRQHandler             ; I2C1 Error
                        DCD     0                              ; Reserved
                        DCD     I2C2_ER_IRQHandler             ; I2C2 Error
                        DCD     I2C3_EV_IRQHandler             ; I2C3 Event
                        DCD     I2C3_ER_IRQHandler             ; I2C3 Error
                        DCD     USB_LP_IRQHandler              ; USB Low  Priority
                        DCD     USB_HP_IRQHandler              ; USB High Priority
                        DCD     0                              ; Reserved
                        DCD     0                              ; Reserved
                        DCD     0                              ; Reserved
                        DCD     USBWakeUp_IRQHandler           ; USB Wakeup from suspend
                        DCD     0                              ; Reserved
                        DCD     0                              ; Reserved
                        DCD     0                              ; Reserved
                        DCD     0                              ; Reserved
                        DCD     0                              ; Reserved
                        DCD     DMA1_Channel6_7_IRQHandler     ; DMA1 Channel 6 and Channel 7
                        DCD     0                              ; Reserved
                        DCD     0                              ; Reserved
                        DCD     SPI3_IRQHandler                ; SPI3
                        SPACE   0x4A
    __Vectors_End
    __Vectors_Size      EQU  __Vectors_End - __Vectors
                        AREA    |.text|, CODE, READONLY
    ; Reset handler routine
    Reset_Handler       PROC                                   ;¸´Î»ÖжϷþÎñ³ÌÐò£¬PROC¡­¡­ENDP½á¹¹±íʾ³ÌÐòµÄ¿ªÊ¼ºÍ½áÊø
                        EXPORT  Reset_Handler                   [WEAK]
                        IMPORT  __main                         ;IMPORTÖ¸ÁָʾºóÐø·ûºÅÊÇÔÚÍⲿÎļþ¶¨Òå
                        IMPORT  System_Init
                        LDR     R0, =System_Init
                        BLX     R0
                        LDR     R0, =__main
                        BX      R0
                        ENDP
    ; Dummy Exception Handlers
    NMI_Handler         PROC
                        EXPORT  NMI_Handler                     [WEAK]
                        B       .
                        ENDP
    HardFault_Handler   PROC
                        EXPORT  HardFault_Handler               [WEAK]
                        B       .
                        ENDP
    MemManage_Handler   PROC
                        EXPORT  MemManage_Handler               [WEAK]
                        B       .
                        ENDP
    BusFault_Handler    PROC
                        EXPORT  BusFault_Handler                [WEAK]
                        B       .
                        ENDP
    UsageFault_Handler  PROC
                        EXPORT  UsageFault_Handler              [WEAK]
                        B       .
                        ENDP
    SVC_Handler         PROC
                        EXPORT  SVC_Handler                     [WEAK]
                        B       .
                        ENDP
    DebugMon_Handler    PROC
                        EXPORT  DebugMon_Handler                [WEAK]
                        B       .
                        ENDP
    PendSV_Handler      PROC
                        EXPORT  PendSV_Handler                  [WEAK]
                        B       .
                        ENDP
    SysTick_Handler     PROC
                        EXPORT  SysTick_Handler                 [WEAK]
                        B       .
                        ENDP
    Default_Handler     PROC
                        EXPORT  WWDG_IRQHandler                 [WEAK]
                        EXPORT  LVD_IRQHandler                  [WEAK]
                        EXPORT  RTC_IRQHandler                  [WEAK]
                        EXPORT  FMC_IRQHandler                  [WEAK]
                        EXPORT  RCC_IRQHandler                  [WEAK]
                        EXPORT  EXTI0_1_IRQHandler              [WEAK]
                        EXPORT  EXTI2_3_IRQHandler              [WEAK]
                        EXPORT  EXTI4_15_IRQHandler             [WEAK]
                        EXPORT  TS_IRQHandler                   [WEAK]
                        EXPORT  DMA1_Channel1_IRQHandler        [WEAK]
                        EXPORT  DMA1_Channel2_3_IRQHandler      [WEAK]
                        EXPORT  DMA1_Channel4_5_IRQHandler      [WEAK]
                        EXPORT  DMA1_Channel6_7_IRQHandler      [WEAK]
                        EXPORT  ADC1_CMP_IRQHandler             [WEAK]
                        EXPORT  TIM1_BRK_UP_TRG_COM_IRQHandler  [WEAK]
                        EXPORT  TIM1_CC_IRQHandler              [WEAK]
                        EXPORT  TIM2_IRQHandler                 [WEAK]
                        EXPORT  TIM3_IRQHandler                 [WEAK]
                        EXPORT  TIM6_DAC_IRQHandler             [WEAK]
                        EXPORT  TIM14_IRQHandler                [WEAK]
                        EXPORT  TIM15_IRQHandler                [WEAK]
                        EXPORT  TIM16_IRQHandler                [WEAK]
                        EXPORT  TIM17_IRQHandler                [WEAK]
                        EXPORT  I2C1_EV_IRQHandler              [WEAK]
                        EXPORT  I2C2_EV_IRQHandler              [WEAK]
                        EXPORT  SPI1_IRQHandler                 [WEAK]
                        EXPORT  SPI2_IRQHandler                 [WEAK]
                        EXPORT  USART1_IRQHandler               [WEAK]
                        EXPORT  USART2_IRQHandler               [WEAK]
                        EXPORT  CEC_IRQHandler                  [WEAK]
                        EXPORT  I2C1_ER_IRQHandler              [WEAK]
                        EXPORT  I2C2_ER_IRQHandler              [WEAK]
                        EXPORT  I2C3_EV_IRQHandler              [WEAK]
                        EXPORT  I2C3_ER_IRQHandler              [WEAK]
                        EXPORT  SPI3_IRQHandler                 [WEAK]
                        EXPORT  USBWakeUp_IRQHandler            [WEAK]
                        EXPORT  USB_HP_IRQHandler               [WEAK]
                        EXPORT  USB_LP_IRQHandler               [WEAK]
    WWDG_IRQHandler
    LVD_IRQHandler
    RTC_IRQHandler
    FMC_IRQHandler
    RCC_IRQHandler
    EXTI0_1_IRQHandler
    EXTI2_3_IRQHandler
    EXTI4_15_IRQHandler
    TS_IRQHandler
    ADC1_CMP_IRQHandler
    TIM1_CC_IRQHandler
    TIM2_IRQHandler
    TIM3_IRQHandler
    TIM6_DAC_IRQHandler
    TIM14_IRQHandler
    TIM15_IRQHandler
    TIM16_IRQHandler
    TIM17_IRQHandler
    I2C1_EV_IRQHandler
    I2C2_EV_IRQHandler
    SPI1_IRQHandler
    SPI2_IRQHandler
    USART1_IRQHandler
    USART2_IRQHandler
    CEC_IRQHandler
    I2C1_ER_IRQHandler
    I2C2_ER_IRQHandler
    I2C3_EV_IRQHandler
    I2C3_ER_IRQHandler
    SPI3_IRQHandler
    USB_HP_IRQHandler
    USB_LP_IRQHandler
                    B       .
                    ENDP
                    ALIGN
    ; User Stack and Heap initialization
                     IF      EF:__MICROLIB
                     EXPORT  __initial_sp
                     EXPORT  __heap_base
                     EXPORT  __heap_limit
                     ELSE
                     IMPORT  __use_two_region_memory
                     EXPORT  __user_initial_stackheap
                     LDR     R0, =  Heap_Mem
                     LDR     R1, =(Stack_Mem + Stack_Size)
                     LDR     R2, = (Heap_Mem +  Heap_Size)
                     LDR     R3, = Stack_Mem
                     BX      LR
                     ALIGN
                     ENDIF
                     END
    ;/******************* (C) COPYRIGHT 2014 GIGADEVICE *****END OF FILE****/
    无聊
    2019-8-28 20:17
  • 签到天数: 9 天
    发表于 2015-7-1 21:28:49 | 显示全部楼层
    额,乱码,我的错。keil直接辅助过来有乱码。下面我传个文件吧
    无聊
    2019-8-28 20:17
  • 签到天数: 9 天
    发表于 2015-7-1 21:30:10 | 显示全部楼层
    下面附件就是了,内容不多,但是看了之后对启动还是有帮助的。
    startup_gd32f1x0.zip
    2.57 KB, 下载次数: 13
  • 签到天数: 4 天
    发表于 2015-7-1 21:54:31 | 显示全部楼层
    乱码有点而烦人呢
  • 签到天数: 222 天
    [LV.7]常住居民III
    发表于 2015-7-2 09:15:46 | 显示全部楼层
    多谢楼主分享
    GMT+8, 2025-1-11 23:40 , Processed in 0.150789 second(s), 24 queries , MemCache On.
