查看: 2354|回复: 0
BPI zigbee 模块与Zigbee开发板。物联网应用必备工具
发表于 2015-5-23 22:04:29 | 显示全部楼层 |阅读模式
zigbee module 4.JPG zigbee board 4.jpg zigbee board 1.jpg zigbee board 3.jpg zigbee board with d1.jpg zigbee board with debugger.jpg zigbee board with M1.jpg zigbee board with M2.jpg zigbee board with r1.jpg
Parameter Description•Chip: TI CC2530
•Excellent performance and low power 8051 microcontroller core with code prefetch feature
•256K system programmable flash memory
•8KB RAM, with a power supply in a variety of data retention
•Hardware debugging support
•The powerful 5-channel DMA
•Integrated high-performance operational amplifiers and ultra low-power comparator•IEEE 802.15.4 MAC timer, general-purpose timers (one 16 bit, two 8 bit)
•IR generating circuit
•32-kHz sleep timer capture
•CSMA / CA hardware support
•Accurate digital RSSI / LQI support
•6 channels can be configured 12-bit ADC resolution
•AES security coprocessor
•2 Powerful USART interface to support multiple serial protocol
•1 common SPI interface
•8 general purpose I / O pins (6×4 mA, 2×20 mA)
•Watchdog Timer
•Wireless Performance
    Adapt 2.4GHz IEEE802.15.4 RF transceiver
    High receiver sensitivity and robustness
    Programmable output power up to 4.5dBm
•Low power consumption
    Active mode RX (CPU idle): 29mA
    TX Active mode in 1dBm (CPU idle): 29mA
    Power mode 1 (4us wake): 0.2mA
    Power Mode 2 (Sleep timer runs): 0.2mA
    Power Mode 3 (external interrupts): 0.4uA
    Wide supply voltage range (2V-3.6V)
    Wide range of operating temperature:-40℃to70℃
GMT+8, 2024-12-19 19:03 , Processed in 0.118321 second(s), 17 queries , MemCache On.
