这里只是为了练习GPIO的使用,没有加任何的译码设备,也没加任何的放大设备,直接用树莓派的16个gpio引脚,连接一个8*8LED点阵的16个引脚,考虑到树莓派所能提供的电流不能太大,所以统一在点阵的8个阳极各加了一个1kΩ的电阻
8*8电阻的16个引脚,8个阳极,8个阴极,我们可以第一为R1~R8、C1~C8(考虑到点阵是方形的,所以不去区分行列,只区分阴阳,上面的R/C和“阴/阳”的对应关系,请根据实际共阴还是共阳区分清楚)
下面几段核心的python代码
管脚对应关系,这里和gpio与8*8点阵的链接有关- rs = [21, 20, 16, 12, 25, 24, 23, 18] #R1:13 R2:3 R3:4 R4:10 R5:6 R6:11 R7:15 R8:16
- cs = [26, 19, 13, 6, 5, 22, 27, 17] #C1:5 C2:2 C3:7 C4:1 C5:12 C6:8 C7:14 C8:9
复制代码 字模,八行,N列- #Hello World
- vhws = [
- [0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],
- [0,0,0,0,0,0,0,0,1,0,0,0,1,0,0,0,1,1,0,0,0,0,1,0,0,0,0,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1,0,0,0,0,0,1,0,0,0,0,0,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1,0,0,0,0,0,0,0,1,0,0,0,0,0,0],
- [0,0,0,0,0,0,0,0,1,0,0,0,1,0,0,1,0,0,1,0,0,0,1,0,0,0,0,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1,0,0,0,0,0,1,0,0,0,0,0,1,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,1,0,0,0,0,0,0,0,1,0,0,0,0,0,0],
- [0,0,0,0,0,0,0,0,1,0,0,0,1,0,0,1,0,0,0,1,0,0,1,0,0,0,0,1,0,0,0,0,0,0,0,1,0,0,0,0,0,0,0,0,0,1,0,0,0,1,0,1,0,0,0,1,0,0,0,0,0,0,1,0,0,0,1,1,0,1,0,0,1,0,0,0,0,0,0,0,1,0,0,0,0,0,0],
- [0,0,0,0,0,0,0,0,1,1,1,1,1,0,1,1,1,1,1,1,0,0,1,0,0,0,0,1,0,0,0,0,0,0,1,0,1,0,0,0,0,0,0,0,0,1,0,0,0,1,0,1,0,0,0,1,0,0,0,0,0,1,0,1,0,0,0,1,1,0,0,0,1,0,0,0,0,0,1,1,1,0,0,0,0,0,0],
- [0,0,0,0,0,0,0,0,1,0,0,0,1,0,0,1,0,0,0,0,0,0,1,0,0,0,0,1,0,0,0,0,0,1,0,0,0,1,0,0,0,0,0,0,0,0,1,0,1,0,0,0,1,0,1,0,0,0,0,0,1,0,0,0,1,0,0,1,0,0,0,0,1,0,0,0,0,1,0,0,1,0,0,0,0,0,0],
- [0,0,0,0,0,0,0,0,1,0,0,0,1,0,0,0,1,0,0,1,0,0,1,0,1,0,0,1,0,1,0,0,0,0,1,0,1,0,0,0,0,0,0,0,0,0,1,0,1,0,0,0,1,0,1,0,0,0,0,0,0,1,0,1,0,0,0,1,0,0,0,0,1,0,1,0,0,1,0,0,1,0,0,0,0,0,0],
- [0,0,0,0,0,0,0,0,1,0,0,0,1,0,0,0,0,1,1,0,0,0,0,1,0,0,0,0,1,0,0,0,0,0,0,1,0,0,0,0,0,0,0,0,0,0,0,1,0,0,0,0,0,1,0,0,0,0,0,0,0,0,1,0,0,0,0,1,0,0,0,0,0,1,0,0,0,0,1,1,1,1,0,0,0,0,0],
复制代码 从字模里拿一个8*8数组- isRig = 1
- vhwi = 0
- def hwv():
- global isRig
- global vhwi
- l = len(vhws[0])
- if isRig > 0:
- vhwi += 1
- else:
- vhwi -= 1
- if vhwi >= (l - 8):
- isRig = 0
- if vhwi <= 0:
- isRig = 1
- r = []
- for i in range(0, len(vhws)):
- j = vhwi
详细的代码请看我的博客:http://www.jiangkunlun.com/2015/04/led_8/
