查看: 2789|回复: 2
linux内核如何开启USB支持?
  • 签到天数: 1618 天
    [LV.Master]伴坛终老
    发表于 2015-4-13 10:28:00 | 显示全部楼层 |阅读模式
    我用的是TI的AM335X,内核是3.17.2,试了网上几种配置,貌似都没用,U盘插上去无反应,girlkoo的博文里是这样配置的
    Device Drivers  --->
  • USB support  --->
  •      OTG support
            <*>     EHCI HCD (USB 2.0) support
  •        Improved Transaction Translator scheduling (NEW)
            <*>     EHCI support for OMAP3 and later chips (NEW)
            <*>     OHCI HCD (USB 1.1) support
            <*>       OHCI support for OMAP3 and later chips (NEW)
            <*>   Inventra Highspeed Dual Role Controller (TI, ADI, ...)
                MUSB Mode Selection (Dual Role mode)  --->
            <*>     Platform Glue Layer (TI DSPS platforms)  --->
                MUSB DMA mode (Disable DMA (always use PIO))  --->
    但这样配置后启动系统进入命令行过几秒钟串口就不停重复打印如下信息
    [   44.104567] CAUTION: musb: Babble Interrupt Occurred
    [   44.109805] musb_stage0_irq 789: unhandled DISCONNECT transition (a_wait_bcon)
    求助,有人遇到过相同的情况吗
  • 回复
    发表于 2015-5-4 17:37:28 | 显示全部楼层
    回帖奖励 +3 与非币
    解决了吗?
  • 签到天数: 1618 天
    [LV.Master]伴坛终老
     楼主| 发表于 2015-5-4 20:10:40 | 显示全部楼层
    晃悠一下 发表于 2015-5-4 17:37
    解决了吗?
    解决了,,,是我硬件的原因
    GMT+8, 2025-1-27 07:42 , Processed in 0.130338 second(s), 19 queries , MemCache On.
